View Full Version : Evo Engine / Turbo / Drivetrain
  1. tiny drops of oil in coolant overflow tank?
  2. No check engine light after test pipe install
  3. cylinder head specs and repair...got questions
  4. 2 Problems in less than 5 min!!
  5. Best place to get DEFI 60mm gauges?
  6. need help with TurboXS intercooler install
  7. ??? Downpipe Work With Greddy Ti-c & Ultimate Racing Tp??? Help!!!
  8. Which FMIC for Evo Green 20G-9LT ?
  9. Issues with Greddy Ti fitment...advice welcome
  10. Help me diagnose..
  11. Turbochargers.com Evo 20g upgrade
  12. 76mm/3 in o2 housing?
  13. Installing TBE and larger O2 housing...Do I NEED a tune!?
  14. spark plugs?
  15. Does anyone know how to install monster sport intercooler pipe set
  16. Just picked up 06 MR, Looking for Suggestions
  17. Shepard Trans plain and simple FTW.
  18. Whining noise?
  19. Cant boost past 10 psi Need Help
  20. Bad Ass GT35 R Stage IV Evo with Reflash on Dyno - Video
  21. Any 4094R cars in the works?
  22. dp touching oil pan
  23. best launch = cracked tranfer case
  24. Help Installing Exedy
  25. It Broke!
  26. witch wideband?
  27. how to remove starter
  28. evo 9 turbo in an s2000?
  29. looking for more power ...Sugestions?
  30. Will a IX downpipe fit a XIII?
  31. What spring for Forge Evo15 dv at 23psi?
  32. clutch problems guys
  33. Found out what the sound coming from my tranny...
  34. is any one running this AMS turbo KIT??
  35. Bypassing ACD any pointers?
  36. Breaking in an engine.....
  37. Single or duel vavle springs
  38. Tranny Problem!
  39. Spark plugs for Evogreen?
  40. IX spark plugs
  41. HELP PLEASE: Strange rubbing grinding noise coming from engine bay.
  42. Get Walbro Fuel Pump in addition?
  43. Check Engine Light On ( Engine Over Boost)
  44. who has perrin cat back ??
  45. Installed TestPipe Now less Boost
  46. Here is my new turbo kit for my Evo 9
  47. Car Won't Idle When Cold Keeps Stalling
  48. Clutch longevity
  49. SS Autochrome Manifold & O2 Housing
  50. Wideband with audible warning?
  51. To coat or not to coat, that is the ?
  52. Throttle Position Sensor
  53. Post Your Hp And Mods
  54. what goes bang first????
  55. having problems with the TTP Engineering DP. Please Help!!!
  56. Which Injectors
  57. Boost Tapering Help
  58. MR Super Diaqueen is awesome in the 5-speed GSR tranny!!!
  59. 20glt supporting mods
  60. Exhaust question
  61. Jun 272 or Cosworth 272 for Evo IX
  62. Staight 112 octane plug?
  63. keep GSC 280/280 mivec cams or return and wait for the S2 series
  64. went to mitsu dealership for tranfer case
  65. What is the best manifold I could use with a atp gt35r kit?
  66. 272/264 who has them
  67. injector question
  68. Help, I cant get the tranny out of the car
  69. WTF cant boost past 25 psi HELP
  70. Another BR 9 second EVO, this one is impressive.....
  71. cat length
  72. GT30R Turbo Kit for an 2005 Evo Mr
  73. Strange Gear Problem
  74. I think I got ripped off! Help please!
  75. Works air filter - Fitment on IX
  76. Is my clutch gone?
  77. Whats the easiest way to change rear motor mount??
  78. are all 4g63 head bolts and cam gears interchangeable?
  79. Getting Loose in 3rd and 4th gear !
  80. How do i remove 02 sensor from 02 housing?
  81. fuel pump
  82. question on twin disc hd exedy
  83. Evo Stock wheel hp???
  84. grinding in reverse
  85. Market for Twin Scroll/Integral gate GT30/35 Turbine housings ?
  86. so i put my buschur deluxe fmic on...CrOoKeD!!
  87. Need help. Broke something near radiator =gas and hissing noise
  88. CBRD and AMS Step 1: it arrives
  89. So i just got my Mivec S2 cams... or did i.....
  90. Hard shifting into 1st/2nd when my Evo is cold.
  91. Built 2.0
  92. Oil Pump
  93. 0 oil pressure @ idle in high altitude area
  94. Power Loss
  95. question about walbro 255 pumps
  96. Forced Performance Turbo
  97. new setup question
  98. Alky horror stories???
  99. WHY I Will Make 400awp on the EVO GREEN on PUMP!!!!!!!
  100. greddy type s with greddy type rs can it be done?
  101. thoughts on weapon R intake manifold?
  102. Opinions on Plastic BOV
  103. Check out how Nisei 1018 LICP is made in the USA
  104. exedy twin plate
  105. Target Goal 450 hp
  106. 4th gear gone
  107. oil chane up what grade?
  108. Tuning advice?
  109. Can I put the MR Super Diaqueen tranny oil in my IX GSR 5spd tranny???
  110. How to get the transfer case out.
  111. Trouble starting....help please.
  112. Downpipe Information Please ?!?!?!
  113. Max Boost IX intercooler?
  114. Is my Clutch Blown??
  115. Turbine Housing Porting?
  116. EVO Drivetrain Warranty Issues
  117. Atp kit with a dnp t3/t4 manifold?
  118. how to get 400whp with 20g?
  119. hp fuel pump vs. lp
  120. How's my 02 housing lookin'?
  121. meth before cams?
  122. which clutch between 2 (look!)
  123. how to clean maf??????????
  124. Gt35r blown turbo?
  125. AEM EMS or electric Boost control?
  126. 10.5 on evo 8
  127. Making a leak tester
  128. Evo VIII mods..
  129. Anyone using the new "piston-type" FORGE WGA on a IX???
  130. Megan racing EVO IX downpipe and turbo outlet question.
  131. Best turbo on PUMP GAS ?
  132. Help me with my Profec B Spec II!
  133. Ebay $300 TBE
  134. synchros $$$$$
  135. Lost clutch after 1 drag run! Need a new one!
  136. 2.1 stroker
  137. HKS 280's to GSC S1's for Evogreen
  138. Evo 7+ cams for Evo 6?
  139. transmission problem
  140. How to ID a FP Green
  141. REM ISF for transfercase?
  142. Cat O2 Bung Location and Where to Buy?
  143. Can't boost past 12 lbs! help!
  144. Buscher Modified Walbro Pump
  145. Boost issues from hell! IX still not boosting right
  146. My First Tune @ DSG
  147. what did you pay for your tcase upgrade?
  148. Possible to throw a code P0172 with just a Walboro FP?
  149. 10" slim fan
  150. Is a catch can really necessary for the EVO?
  151. Problem with using continuosly an high flow pump ? (A1000)
  152. Problems installing Precision Injectors
  153. Are my 35R numbers right were they should be?
  154. 03 same transfer case problems as 05?
  155. ix mr idle.. noise?
  156. evo 9 intake manifold and tb same as evo 8?
  157. Just purchased new Evo, black exhaust fumes?
  158. cosworth cams not making power anymore?
  159. Check Out What We Got On The Dyno Today!!! Evo V +42r=nuts!!!!
  160. head gasket replacement costs please...
  161. Evo Tranny Question? Opponions please
  162. Where should the clutch bite?
  163. Specs of our stock clutch
  164. My new Turbo with the PPI treatment!
  165. bov for over 26psi
  166. 13.0 Afr
  167. Ebay O2 Boost Creep Fix!
  168. EvoIX w/ 03 xfercase???
  169. Weird feeling on my car
  170. Trubo XS FMIC
  171. ACT HDSS installed part II MORE PROBLEMS!!!
  172. Finally.. MPFab 35R Pump/Meth #s!
  173. Road Race setup???
  174. EGR Solenoid
  175. Looking for mod advice...
  176. green turbo upgrade
  177. hks gt037 turbo with which intercooler?
  178. Is there an easy way to tell if you have a fuel pump?
  179. Alright i need some help
  180. Clutch with soft pedal feel
  181. ETS behind the scenes - Our intercooler quality control process
  182. 2.3 liter IX running a Stock IX 16G Turbo Questions
  183. Need some help. What is this?
  184. How many of you keep your stock air box?
  185. 305awhp Evo shatters RS diff :(
  186. No Boost!!
  187. DP question?
  188. exhaust ???'s
  189. Problem with 2nd gear
  190. Put on Greddy Ti w/ stock bumper = melted
  191. reving to 8k safely
  192. im just gonna have to get a ride.....
  193. how long will a exedy twin last
  194. 4th gear issue
  195. Saturated Timing Belt
  196. vibration problem!need help!
  197. anyone running over 500whp with the Greddy Rspl?
  198. Need some serious help please....
  199. Oil on Plug need help!!
  200. Which Cams for my Setup???
  201. Any tricks for getting B-pipe nuts off at the stock cat??
  202. trouble getting into 3rd gear
  203. calling all destroked cars
  204. Can I run open downpipe?
  205. 4 bolt to 5 bolt turbo hotside difference's?
  206. exhaust manifold question
  207. intercooler sprayers
  208. How long did you ACT last?
  209. What Clutch Should I Get?
  210. How far will meth take me on stock injectors?
  211. Best forge pistons for IX with stock ECU?
  212. New lightweight parts and safety items on their way...
  213. FP Green - Which Cam Combo is best suited for this turbo.
  214. crank walk?
  215. oil line from valve cover to intake arm.
  216. Anyone dyno the TITEK o2 housing
  217. Car sputters when cold?
  218. Hydraulic vs solid lifters
  219. Evo 5 CP9A/// What parts are compatible???
  220. gsc 272/272 vs gsc s1
  221. Where can I buy those factory style hose insulations?
  222. Perrin shifter help........
  223. Grinding issues
  224. Issue with above 20PSI
  225. Real quick, 780cc or 880cc for 50 trim/100% meth on stock ECU?
  226. No boost! help!!!
  227. Act just isntalled BIG PROBLEM...!!!
  228. where to get a green from
  229. something weird..can anyone help?
  230. Throwing codes after putting stock ECU back in...
  231. cant figure this out
  232. Pressure Test
  233. What Next??
  234. Green Numbers from today.....Thanks CFT!!
  235. Syncros
  236. quick fidanza cam gear question
  237. looking for cheap fmic and cams 03 evo 8
  238. Help! Cant get tranny in!
  239. Advice!!! clutch issue with Exedy twin
  240. Real Quality......
  241. 400 whp possible?
  242. no O2... less turbo? Need help please
  243. New MEGAN downpipe version just released!
  244. Cluth pedal vibration at 2500 RPMs
  245. Hallman MBC or Forge MBC
  246. Best Clutch.... For about 600 whp.
  247. ally rods, anyone using them???
  248. Any news on new Turbos?
  249. Any1 having issues with Exedy clutch?
  250. Aps Twin Vent?
