View Full Version : Evo Engine / Turbo / Drivetrain
  1. Picture of Megan header under WOT
  2. Best Method to Reach Turbo/Waste Gate
  3. Actuator arm preload f/ EvoGreen
  4. Question about Boost Leak via Diverter Valve
  5. Muffler Size
  6. TB Coolant Bypass Mod - WARNING
  7. My ported exhaust manifold and O2 housing
  8. 9 sec. What gear box is this?
  9. AGP FMIC & Nisei LICP Pics, Testing, & Review
  10. Odd shifter problem
  11. 9 in 8
  12. What boost to run after tune?
  13. Installed Walbro, injectors, 02 housing...lumpy idle??
  14. Who here has done a mail in flash for a gt35r and supporting mods? Thanks.
  15. Gt35r???
  16. Tilotn rebuild PN???
  17. how to change the rod bolts?
  18. waste gaste q's
  19. 880cc vs 1000cc injectors for e85?
  20. Extreme Turbo Systems and English Racing hit 9.7 and 145mph
  21. How good are rebuilt engines?
  22. Manifold swap..
  23. Is anyone using XTD clutch
  24. And you say you don't need a Catch Can?
  25. Boost Numbers???
  26. ebay Coil on Plug ignition setup?
  27. Can't boost past 12psi. I give up!
  28. where to buy a transmission
  29. Redline trans fluid
  30. Aout to install my new Buschur 35r today!!
  31. O2 sensor ??
  32. HELP!!!!! With my IX
  33. Help with Injector Duty Cycle
  34. Weird sputter... am I "blowing out spark" Need Advice
  35. Ordered some WORKS goodies :)
  36. Approx. HP with IC setup?
  37. ebay/xs power cooler
  38. Should I step up to bigger cams?
  39. Need Manual Boost Controler Help!
  40. AMS GT30R (3076) or 50 Trim for a pump gas street EVO?
  41. 44mm Tial Wastegate not working
  42. Ported intake manifold
  43. cosworth cams valve tick?
  44. boost problem
  45. ACT HDSS/Stock Flywheel
  46. Going rate for a clutch job....
  47. Turbo
  48. Evo Green Dyno Sheet on 05 Evo with minimal mods
  49. Stage II Evo IX - Buschur Parts - dyno sheet
  50. bent LICP outlet....worth fixing????
  51. AMS FMIC Fitment?
  52. Is it ok to extend o2 sensor wires?
  53. ETS 35R kit makes 545hp 480tq pump/meth MD dyno
  54. Stock Evo IX BOV
  55. Whats the difference between GSR (w & w/o ACD) and RS transferee cases?
  56. AMS HFC VS Resonator pipe ??
  57. as it stands now... smoother boost curve
  58. Injen Intake/Flutter
  59. Very strange noise?
  60. CEL after cosworth cam install???Help
  61. AMS Performance or Buschur Racing?
  62. EGT Gauge install in AMS (or other header-based) turbo-kit
  63. LC-1 Power On Help
  64. Aftermarket FMIC help even with alchy?
  65. P0456 code.
  66. Wrong Tune!!
  67. Good IC Setup?
  68. MBC vs EBC...
  69. 6 puck carbon clutch is there anyone that makes one
  70. Burshur DP Question
  71. FPgreen on stock internals safe?
  72. Backfire question
  73. injector tick or somthing else?
  74. exhaust size?
  75. MAF Sensor delete
  76. Gt35R 2.3L Evo 8 with AEM - dyno sheet
  77. gsc s2 cams in a ix
  78. Injen intake vs. stock box vs. ic pipes
  79. New Evo green set-up
  80. going fast with a none acd car...
  81. stock exhaust mani. VS. megan
  82. New Turbo
  83. what's the + & - of the 6 speed MR trans?
  84. Cant find German Castrol oil anymore?!
  85. Anyone using Helix cams?
  86. Help with a 2.4 block
  87. How much boost
  88. Spun Rod Bearing Question
  89. Magnaflow TBE vs. Buschur TBE with Magnaflow Muffler
  90. New Tbe> How Loud???
  91. Serpentine belt lenght Help!
  92. Starter replacement
  93. How important is bleeding lifters when cam installing
  94. Rebuild on T/C average price?
  95. Help please. Oil plug thread.
  96. from full-race kit to stock... pictures
  97. Odd Engine Noise at 5500rpm, any ideas?
  98. Need Help on my 03 evo 8
  99. Just ordered my 42r need some input!
  100. Fuel hose cracked and leaking ?
  101. Recognize This Header??
  102. Smoke from center console
  103. faint smell of gas at WOT???
  104. I think I broke my front Diff???
  105. Need Clutch ASAP.
  106. Where can I buy an anti surge compressor housing for a gt35r?
  107. Boosting Issues, Help!!
  108. timing belt tensioner tool
  109. stock head studs with 35r and meth??
  110. no start ?
  111. Me and My Tilton love hate relationship
  112. Spearco W.A.V.E. Intercooler?
  113. Need Help – tcase or tranny issue?
  114. Blown Engine, Change the Oil Cooler?
  115. MBC Problem
  116. injen intake w/ upper and lower ic piping
  117. best stroker kit and cheapest
  118. questions on qtp downpipe
  119. 280's stock pistons? Does it work?
  120. dynograph and knock
  121. vacuum problem!
  122. Ideal camgear settings for HKS 280's/AMS 50 Trim???
  123. Where to get porting done in stamford connecticutt.
  124. i hope this is the right section...
  125. Turbo rebuild kit
  126. ebay exhaust
  127. Gear shifting problem...Please help me diagnose
  128. 880 cc injector question
  129. upgrading EVO 8 valvesprings and retainers w/o removing head?
  130. stock block power?
  131. Greddy Upper IC pipe Question
  132. Interesting weekend of IX dyno results - cosworth cams vs. no cams
  133. what hp do you think ill put down????
  134. Full race not port matched?????
  135. Will the hks racing suction intake work with a atp gt35r kit.
  136. Quick Time Performance Downpipe w/ E-Cutout
  137. Listening for Det
  138. Hallman Boost Controller Q&A...
  139. Bad lifter, Rod Knock, or Bent Valve (Video)
  140. GSC Camshafts, Mail in Flash ??
  141. quick question about wastegate install!
  142. Boost problem (been searching for answer for days now)
  143. Looking for strongest rods
  144. Heet
  145. New turbo kit.
  146. question for anyone that has done ix cams...
  147. Cams, Fuel Pump, Afr???
  148. Whining Sound, Not sure if it's the Transfer Case
  149. t.r.e tranny grinds with 2k miles????
  150. My Dynojet sheet
  151. Hks Blow off
  152. wastegate damage @17psi
  153. Timing belt problem
  154. Problems with idle and cutting out
  155. Thrown a rod out the block!!!
  156. Turbo upgrade and AIR/FUELS??
  157. Questions regarding greddy T67/25G
  158. blitz i color boost controler v.s. zeitronix wideband.
  159. Lower Degree Thermostat
  160. Intakes that work with Apex'i intake box?
  161. new numbers
  162. 13 psi:(
  163. over heating. HELP!!!
  164. Running 264/272 cams without tuning
  165. Stock Intake Manifold Question..
  166. WTB? Tired of ACT
  167. super rich
  168. Greddy Ti-R and UR testpipe =OMG LOUD
  169. JunB.L w/ Perrin 3" DP Vs. Buschur 3" TBE
  170. Question about alky over cams
  171. What Downpipe Should I Get With JunB.L?
  172. 20glt but what else
  173. Is their a ebc that reads a/f, boost, and other vitals. like a wideband?
  174. Zeitronix user opinions
  175. Need Help Installing Injen Licp On Evo Ix
  176. cusco/exedy?
  177. Honestly heads studs or not
  178. What is the max boost I could run safely with my gt35r kit, with 93.
  179. Noise while in gear at idle
  180. Life of a built 2.0L Block
  181. EXHAUST FOR MILD TUNING,,tubular or standard ?
  182. Prosport EGT guage....slow responding???
  183. 4G63 Oil life
  184. Friggin Silencer stuck in Muffler!
  185. Leakage help please
  186. Injectors for Evo Green & 550bhp
  187. Tob Hell!!!!!!!!help!!!!!!!!!!
  188. Gear Shift
  189. 5-speed vs. 6-speed
  190. Catless or High Flow Cat?
  191. 10sec Recipe?
  192. Chime in if you ever had your tranny filled with diaqueen.
  193. What is a good performing intercooler?
  194. Ideas welcome... P0300, P0139
  195. Experance with Brad Penn Motor Oil
  196. Evo ix gain downpipe only?
  197. 20G-LT / FPGreen boost and IDC data
  198. Help !!! New Turbo Mods for My Evo III
  199. Help!!!
  200. Clutch Pedal Adjustment Questions....please advise
  201. BOV sound??
  202. JDM evo 9 LSD, will it work?
  203. New Clutch for MR
  204. Possible causes...
  205. acd fault codes
  206. Oil pressure/EGT guage install HELP!!
  207. Car overheating Slightly!
  208. Downpipe Fitment Problems
  209. Clicking noise in the front end
  210. ses light ??? please help (NOT A NEWB??)
  211. RPS carbon clutch
  212. 2nd gear lock out.
  213. FP3065 On A Budget??
  214. Some Give Back From the Big Tuners Please.
  215. wanting to put on my new FMIC.. BUT....
  216. weird clutch/tranny problems?
  217. AFI are the hardest guys in the world to get up with.
  218. Oil Filter part # ?
  219. Hot Side Question
  220. new help on greddy boost controller
  221. Kelford IX Cams
  222. Is this a photo of an FP "Green" Turbo?
  223. 5th Gear Grinding
  224. 348WHP EVO vs. 380WHP STI...
  225. Does anyone know the part #s for evo 8 3rd and 4th gear?
  226. 4g64 block
  227. exedy hyper single help! how much power?
  228. June 23/24 2007–Buschur Racing 3rd Annual Mitsubishi VS Subaru Showdown
  229. Fuel Rail fittings...
  230. Exedy twin disc clutch failure
  231. Evo Ix Mr Need More Power ?!?!
  232. need evo 9 S1 cams!!!!!!!!
  233. removed undertray = weird idle?
  234. acd pump hardline
  235. Cam Opening/Closing on Standard JDM 8MR cams
  236. LSD or Coil-over's? please help me decide
  237. Evo IX with BPU Stage I on 93 - "real world" boost level
  238. Odyssey mini- battery vs: Braille?
  239. OBD2 "readiness" status questions for 05 EVO
  240. Fuel line adapter for fuel pressure gauge or fuel side of nitrous
  241. Evo owners with/without a catalytic convertor
  242. espiler dp fitment?
  243. IC piping pops off @ 17-18 psi?
  244. tiny drops of oil in coolant overflow tank?
  245. No check engine light after test pipe install
  246. cylinder head specs and repair...got questions
  247. 2 Problems in less than 5 min!!
  248. Best place to get DEFI 60mm gauges?
  249. need help with TurboXS intercooler install
  250. ??? Downpipe Work With Greddy Ti-c & Ultimate Racing Tp??? Help!!!
