- Apexi Boost Controller Help
- 2 step ?
- WORKS Short Shifter, I love it!
- Carbing air suction kit
- Any Help would be appreciated
- which valves to get and cams
- What spark plugs should I run in a 2.3 Liter?
- a friend blew his engine what do you think of this....??
- Do not buy from "Late Apex"
- dont know which pistons to go with
- Rear end shot?? Help plz :confused:
- Clutch Help
- My Broken Evo...
- mods without a tune???
- best way to hook up MBC
- Boost
- For those who want Evo 9 'TME' turbo
- what to lube BOV with?
- which flywheel
- Engine blown !!!!
- What is the flow rate of an IX fuel pump
- Megan DP intall question.
- Is Mitsubishi selling me wrong Transmission Fluid?
- Ideal specs for radiator fan?
- Symptoms for Transmission Fluid Change?
- Location of Tranny Bolts??
- Southbend OFE Clutch Install Pics
- Why is my car boosting on my gt35r when I have my forge mbc to the lowest setting.
- RPMs rise when clutch pushed in?
- Boost controllers and a new one coming from BR
- Bonzai - Dyno Flash Evo WR vs. EVO Shootout !
- what can i expect?
- Forge Rs Dv Owners Help
- What oil is everyone using in their built motors???
- My FORGE MBC sucks!
- How long is the waiting list for the "Green" Turbos?
- timing belt slack
- rnr 50 trim?
- evo 9 cams
- ShortBlock evo3... Head evo 8?
- Boost Creep Fix? Hitting 21psi on wastegate?
- How many times have you adjusted your Exedy twin?
- ACT clutch differences
- '03-04 Evo VIII: Factory front LSD the ticket in Auto-X?
- is a I/C sprayer wor it,
- Evo VII GT-A Help!
- AEM A/F Ratio Wideband
- Modification Sequence help = Benefit EVOM Members
- Jdm Mr Bov
- Upping Boost = Roaring Engine?
- Turbo Timer
- Please help.....
- The official hyundai 2.4L G4JS (4G64) thread
- tre or shep trans....
- can solid mounts cause false knock
- oil light blinking?
- Supercharged Evo anyone???
- AMS KIT vs BUSCHUR KIT
- NEW Product Release: AMS Drag Rear Differential Setup
- NEW Product Release: AMS Lightweight Front cross member
- NEW Product Release: AMS Brake master cylinder brace
- How to install ATP gt35r?
- How's this Dyno sheet look to you guys?
- Grass Fun
- tomei forged rods ???
- QTP electric cut out
- Best intake system for Road racing?
- Nisei LCp?
- question
- Port and polished exhaust manifold?
- Evo IX transfer case issues
- lifter tap and loss power!
- Problems with Exedy Twin HD
- Pump Gas record???
- Turbine stops to blow at 5-6K rpm
- Drop in IAT by disconnecting hot water feed to the throttle body?
- Perrin short shift drama's
- transfer case questions...
- clutch pedal squeak,ACT hd clutch,help
- Can a helical front diff from a acd transfer nox be fitted to a non acd transfer box.
- EGT fitting Brass ~1400F
- Fuel pump holding me back?
- Car just quit, please help
- Spark Plugs?
- clutch problems help!
- Forge mbc. Each click represent's how many psi?
- boost controller with stock everything?
- Tranny popping out of fifth gear (grumblerrrggg)
- bf cams
- What would you change your HKS 272's for?
- transfer case life expectancy?
- new gt35r setup with stock ecu
- Evo Intake-- whats Stealthy, but works
- Clutch suggestions
- Green related question.
- 50 trim Spark Plugs???
- Toga Oil Filter
- boost fluctuation question/help
- Help...gears locked out
- best turbo?
- new IC set up and mani...new tune?
- Forge diverter valve flutter
- Need help with buschur exhaust!!!
- Temperture
- Helix Rods.. is anyone using them?
- Oil Light?
- Tranny Grind ?
- Texas Tunner?
- Boost Leak Test Question???
- Vendors - who has a black Forge UNOS in stock and can ship ASAP?
- Can someone help diagnose this oil leak (photos)
- ARC induction + Greddy UICP
- Question about Waste Gate?
- i need advice
- HKS R-Type FMIC
- fully built evo VIII mr questions
- To convert your car to run E85, you need to...what?
- What's involved with installing rod bolts?
- Buschur pure power package?
- How many teeth on 4.111 and 3.73 gears?
- Ams Vsr + Green + Dyno!
- APS 3.5 turbo back and other mods?
- Whats the best Crank Pulley Damper ?
- Solution to leaky OEM Throttle Body Seals running higher boost.
- adaptive ECU how true is it on a EVO IX
- 280's with 272's cams
- Quietest high-flowing turboback?
- I have a WORKS BOV and a Bailey Motorsports BOV. Which to keep???
- 1000cc injectors on stock ecu doable??
- GSC S2s or 272s with 4G64 Strocker
- Clutch Install Help Evo VIII
- Which intake has the most power gains?
- best way to pull the head
- Boost leak test with a external wastegate??
- [b]need Help With Boost Problem[/b]
- Best way to pull motor?
- cosworth exhaust cam to big???
- Help with Buschur intake pipe install
- Vibrating pedal
- where does this tube go?
- Transmission syncros for evo 7
- DC3 catch can installed... & a CEL???
- How to correct P0069
- Help with exedy part!!!
- Fitting a test pipe
- Evo 8 ACT Clutch Noise
- Is this how to connect Turbo/Wastegate/Boost Control Silenoid?
- Getting used engine HELP
- Pictures of my clutch install
- Evo9 ECU compatablity
- cam senser
- AEM and 2step soft cut/hard cut configuration...
- fpgreen video's?
- Tuning Question
- manifold change
- 05 t/c into an 03
- Evo 9 owners: Please post ur dyno sheets(preferably Mustang dyno) and list parts Plse
- 3" O2 housing w/ external dump?
- Downpipes that clear on IX?
- Thoughts on going straight methanol? Fuel requirements? Ignition?Engine build?
- Need Advice on Boost, Mods, !Power!
- stoker kit
- How to tell if you have cams?
- Exhaust Sounds
- MR diaqueen p/n??
- Someone please help. Boost problem. .
- Bango bolt
- Is that Fuel Cut off
- 2.4L build
- How to Open Hallman Boost Controller?
- What milage should i change Sparkplugs at?
- adding oil squiters with 2.4L swap
- Repercussions of big cams and stock IX turbo?
- AC issue.
- boost not changing please help
- anyone flow match their injectors?
- BR STage I IX pump gas - perfectly shaped dyno sheet
- Testing Effect of High Flow cat vs test pipe on Stage IV Evo IX
- acd transfer case in non-acd car
- bearings with 2.4L swap
- Re-circulate BOV with stock air box: quite
- driveshaft
- recommended clutch
- UICP that will work with AMS fmic
- porting an evo 8 cylinder head
- timing belt
- hard to start
- running a DP+cutout on a stock exhaust?
- EGR CEL code
- Is the evo 8 rear end limited slip
- Stage 2 Has Started!!!!!!
- dnp t-4 manifold installed
- Question about "pull" type clutches...
- Apexi power intake drop-in?
- Ring and Pinion from Shep Trans Available Soon!!
- How do I run a boost leak test?
- Stock UICP no go.
- AEM Tru Boost fixed
- AC question?
- Boost too low
- Exedy Twin
- Exedy Organic single plate clutch and flywheel
- Anybody know injector lag timing or dead timing of AMS 680cc injectors?
- 2.3L vs 2.0L
- Learning to Weld
- clutch install ?'s
- P0401 Code and it's not a hose that came off..
- wat plugs and radiator cap for EVo9
- Anybody have the ATP 35R Setup?
- Break in lube for cam install?
- bosch o2 sensor
- hesitation pop
- Anyone have pictures of ported exhaust manifold uncoated?
- Intake manifold question
- invidia vs helix
- 4" Exhaust!?
- What psi should the stock diverter valve hold?
- Full Race mani and Pruven Tune
- 2.3 l vs 2.0 l
- Evo IX thorwout bearing noise...normal?
- Just got in E98 Going to try it with my ETS T-4 67 Turbo
- loss power after cam install
- Hose too close to Turbo Manifold?
- Clutch Question
- safe rev limit on upgraded valvetrain
- how much
- !!!help!!! car won't go into gear
- Prosportgauges.com?
- Damn You Turbo Compressor Nipple Hose!!!
- recommend me some cams
- Reviews on Blitz Catback? N looking for Used?
- transmision transfer case and rear diff fluid?
- Help me choose GSC S2 or Cosi Mivec cams?
- How much blow much be there in a built 2.0L
- outrageously priced parts....vent yourself to the atm in this thread!
- Built Motor Questions
- gain w/ injectors?
- Down Pipe
- O2 housing question
- Downpipe rattle
- Is my stock 8 BOV leaking??? Please help!!!
- Confusion with Boost Leak = Turbo working harder?[I think I answered my own question]
- Tomei EvoIX Cams??
- GSC S1 CAMS stock?
- 115 oct w/ 93oct map
- EGT probe thread size
- Twin scroll turbo kit.
- need help: will the intercooler + piping
- Anybody have pictures of a ported megan manifold.
- Picture of Megan header under WOT
