View Full Version : Evo Engine / Turbo / Drivetrain
  1. what system is better?
  2. Help with short in wiring
  3. uicp question
  4. Injector scaling question
  5. Duel Welbro Fuel Pump - FullBlown
  6. Aquamist Large Pump Meth Kit - review and tuning notes
  7. Camshafts On E9
  8. Stock BOV too Loud after Injen Intake Install??
  9. help.. How do you do this..
  10. Need Help!!! Boost leak? Smoking?
  11. Cosworth Head studs VS AMS/TMS studs?
  12. 2.4 Blocks and measurements
  13. Another ACD question...
  14. Forge RS Valve fluttering @ partial throttle
  15. What oil filter??
  16. Fidanza Aluminium Flywheel?
  17. what would you replace 269 cams with?
  18. new motor break in, and break in oil?
  19. Which Turbo?
  20. what's the best aftermarket radiator fan
  21. Helix v2 cam lob centerlines
  22. My turbo died..need help
  23. 42R questions
  24. gsc vs cosworth vs hks
  25. MR transmissions suck
  26. 264/272 cam gear setting comparison
  27. how can you tell if its an MR transmission or a regular one?
  28. 6spd MR stiff gear mounts....??
  29. What should oil pressure be at idle?
  30. got my green after 3 months, pics inside.
  31. After installing hks 272 mivec cams cant make sure if they are installed help please
  32. Big Drivetrain Problems!!!!
  33. little advice.... on clutch
  34. any one with the Bushur ported jet coated mani
  35. 35R Compressor Cover: 4" vs. 3" power difference?
  36. Smoking problem...
  37. Colder plug for evo 9
  38. Coolant problem
  39. My IX tuned vs. my old VIII w/ cams and TME tuned (dyno comparison)
  40. HKS GT3037S Installation problem, Plz help!!!
  41. Talk about a disappointment
  42. Exhaust advice
  43. EVO 9 MR, advice on my next few mods, and a few questions..
  44. P0304 CEL Light on 06 MR...Help!!!
  45. Evo8 GT turbo. need info.
  46. Knock sensor readings on a 2.3
  47. No 2nd Gear - All other gears fine
  48. buschur cast manifold vs. tubular manifold eg. full race, ams...
  49. What Turbo Kit?
  50. Trouble shifting @ high rpms
  51. I need help guys, My car wont go into any gears.
  52. SARD R2D2 Blow Off Valve
  53. How do I make sure I have the new version of the megan catback?
  54. MBC longevity and or maintenance
  55. cam diff.?
  56. Car won't start after being shipped across country
  57. Cannot go in gear after launch
  58. Spark plugs BPR7ES .026
  59. 20g stage 1 @lancershop
  60. Cams... Hks-comp-helix
  61. wastegate
  62. Tranny question
  63. Horrible clacking noise help if you know
  64. New Evo Owner - Mod Questions
  65. Another high flow cat question
  66. cam decision
  67. So I was removing my turbo and then suddenly...SPARK AND A LITTLE FLAME! What now?
  68. Boost leak test - leak from the dipstick ??
  69. Turbo Orgy
  70. 06 evo 9 timing belt
  71. boost problems
  72. If you cant afford an exedy twin disk....what to buy?
  73. CAMS or ALKY INJECTION???
  74. clutch advice
  75. Which front differential?
  76. Just got some go fast parts
  77. ACD + Dynopack = Bad News...?
  78. Max WHP/WTQ with 1000cc injectors on stock ecu
  79. here is a good one, lets see if anyone can help me figure this out
  80. Acceptable Drive Shaft Play?
  81. humming sound after cams, cam gears and belts installed
  82. question about intercooler
  83. fitting forged rods with standard pistons?
  84. Worthy gains in ported/coated stock manifolds?
  85. Pros and cons going from 50 trim to 35r?
  86. Tial BOV
  87. Evo green owners....got a question!
  88. Cusco Tarmac 35/65 Centre Diff
  89. competent shop for clutch install
  90. Drop in Boost Pressure
  91. Check engine code p0441
  92. Rode in a IX with Cosi cams untuned!!
  93. correct way to install DV/BOV pics inside
  94. Where does this harness go to???
  95. Forge Waste Gate
  96. built 2.0 and reworked head+green?
  97. Exedy Organic Clutch
  98. Weigth of my jdm evo8 rs.
  99. Exedy twin disk HD
  100. help with new set up
  101. boost and turbo question
  102. stroker kit
  103. greddy 67r 25g turbo kit
  104. Ok my little reveiw of the S1 for a IX
  105. walbro without a tune??
  106. esplier catback with dc downpipe!!
  107. Transmission Problem?
  108. Breaking in(do's & don't)
  109. 03 VIII stock 16g
  110. P0300 code on IX...anyone else have it?
  111. Clutch delay valve
  112. Want more pump gas numbers-->check this thread out.
  113. more hp!
  114. anyone has pics directly comparing a 50 trim to a 16g or even a 20g?
  115. Starter install...
  116. new Pulstar spark plugs
  117. jackson auto machine(jam) vs cosworth
  118. Performance Package????
  119. Hooked up boost gauge today...and im only getting 17 PSI?
  120. bov on inake??
  121. Quaife????
  122. Intercooler lines blowing off!
  123. Turbosmart BOV Dual
  124. UICP&LICP question
  125. Was seeing lots of knock during tune
  126. Substitute for Mitsubishi's DiaQueen Gear Oil
  127. What years have a 10.5 hot side??
  128. Dependable injectors?
  129. Anyone else with new Cosworth cam results for Evo IX?
  130. cllutch problem?
  131. ACD controls...
  132. clutch install problem
  133. motors acting wierd
  134. timing belt question
  135. Cleaned MAF + BPR8ES plugs + race gas = lean (white plugs/exhaust tip)???
  136. has anybody in here dyno'd a 20glt without cams and fmic?
  137. Tanabe Touring or Borla XR-1 for IX MR?
  138. Downpipe cooking oil?
  139. Buschur 3582R installed!!!!!!!!!
  140. forge mbc problem
  141. HFC safe w/o tune?
  142. mivec head evo8cams hmm
  143. HELP Figure out noise......
  144. Full Race Turbo Kit Updates
  145. What supporting mods are needed to run a 20G-9LT turbo with 93 oct & meth @ ?? psi ?
  146. Help! Missfire, bov flutter, or something else?
  147. 93oct vs 93+100%METH VS 100oct+100%meth VS C16 racegas ??
  148. GSC S1 Cam Gear settings?
  149. noob who gots a clutch problum
  150. Where to Buy 5 mm Black Vacuum Hose?
  151. Where to Buy 5 mm Black Vacuum Hose?
  152. Walboro 255 LPH fuel pump burning a lot of gas at idle???
  153. squeaky belt?
  154. Anyone Using Aftermarket Radiator w/Buschur Turbo Kit?
  155. What is the LARGEST BOLT-ON turbo available for an Evo VIII / IX?
  156. Full-race's new toys
  157. best streetable clutch setup?
  158. please help me choosing an o2 outlet
  159. noise ?? have sound clip!! all ideas welcome
  160. just tuned a 20glt FP from bushur racing wow iam impressed!
  161. help me out please
  162. My new lightweight seats!
  163. 978 whp ! Dyno Flash Evo 8
  164. My buschur racing pump gas evo
  165. going to the track
  166. Other types of clutches...?
  167. Special Thanks to CBRD!!!!
  168. anyone have any BOV sounds?
  169. Dyno Results... evo ix gsc cams
  170. new turbo for noob
  171. Question about Air Flow
  172. Any trimming for BR deluxe ic?
  173. HELP!!! clutch installed & starter makes noise!
  174. BR Race Intercooler vs. Stock Intercooler
  175. Weird (Buschur) 20G9lt Issue
  176. Time to mod, but...
  177. Brian Crower? Are they good?
  178. Greddy M-Spec Intercooler
  179. Oil Pressure/temp
  180. Which gt35r outlet size is better?
  181. Case Study # 404 - You can not ever boost leak test too much !
  182. [B][/B] Weird Sound Coming From My Evo MR
  183. need help new clutch making noise
  184. 20Lt Green vs. GT3071..
  185. waste gate/turbo outlet...
  186. Case Study #403 - EWG on STock Turbo IX
  187. WORKS High Pressure Shaft Seals
  188. Dyno Forum
  189. cam select
  190. advice for the Evo's 1st trip to the strip?
  191. Next Mod?
  192. Ported head a must w/ bigger turbo?
  193. Evo Ralliart Head Bolts / Studs
  194. ETS T4 61mm Turbo Kit Glamour Shots - 600+whp anyone?
  195. ebay 02 housing vs ported stock
  196. Dropped a socket into engine!
  197. MBC, Check Engine Light
  198. Another whine thread???
  199. EVO IX 5th gear problem - Not grinding!!!
  200. Weird Sound
  201. Do I Need a Lightweight Flywheel?
  202. Odyssey Battery Nightmare!!!!!!!!!
  203. Pics of Buschur ported/coated exhaust manifold + testpipe
  204. stock mbc
  205. How far could I drive?
  206. Fuel Pressure Adapter???
  207. WOT porting?
  208. TBE Installed
  209. What turbo for most low-end torque possible???
  210. peak boost gt35r anyone runnin it
  211. header options for T3/T4 turbo
  212. Boost issue around 5k
  213. tranny swap - new flash?
  214. is this a good deal.....
  215. ETS 3" FMIC Dyno Results
  216. something wrong with my evo!!! need help..
  217. My FPGREEN is going in soon look at the goodies PICs
  218. Coolant leak...
  219. Noise coming from clutch? Chatter? Throw out bearing?
  220. Clutch Install?
  221. ACT HDSS installed, 5th gear grind
  222. CBRD- got evo?!
  223. Turbo 8 vs turbo 9??
  224. Driving 200 miles on 880 inj. no tune a good idea?
  225. Spark plugs turned Orange?
  226. Trasfer case for EVO 4
  227. ETS Intercooler - Polished - BLING anyone?
  228. I took off my 50trim and went back to stock, is my A/F supposed to be leaner?
  229. Another mechanical CEL Fix, but better
  230. IC Pipping Help PLEASSE
  231. perrin tbe
  232. Car losing power in upper rpms
  233. radiator hose for 8 and 9 same?
  234. HKS Easy Writer = Awesome
  235. Ported & Polished Head
  236. 6.5tme vs a stock 05 turbo
  237. mitsu is covering my 5th gear syncro /but clutch question
  238. So i took my car down to Extreme Turbo Systems
  239. how can I know if it is the clutch or the synchro?
  240. bushing kit
  241. Buschur Million Dollar Fuel System
  242. Best deal on built engine?
  243. Transfer Case (ring And Pinion)
  244. TURBO help 3040R VS GT35R Q's... I have search please read.
  245. cam install help
  246. 1/4 mile....fp green or 50trim
  247. How many thousandths?
  248. Measurements for Evo 9 turbo flange:
  249. car won't start
  250. Forced Performance intake arm
