View Full Version : Evo Engine / Turbo / Drivetrain
  1. Exhaust weight....
  2. OEM ECU Knock Sensor Logic
  3. MR Short Shift
  4. Launching with Spec staqe 3 clutch
  5. Dyno'd again... finally happy
  6. What would YOU do?
  7. Ordering parts need opinions!!!!
  8. BR 37r, EMS and VSR pics!!!!
  9. AEM Intake UICP question
  10. Mega DP- UR HFC fitment question
  11. Full Race Vertical Flow Intercooler Review
  12. jdm and usdm
  13. hks valve springs
  14. pic: det, blow-by, or both?
  15. What coolant do you use?
  16. help with code i have p00069
  17. Question about tranny gunk.
  18. Two transfer cases dead within 450 miles!!!
  19. Replacing the Gasket between J-Pipe and Turbo
  20. please help diagnose my engine problem
  21. please help diagnose my engine problem
  22. Basic performance mod questions
  23. Low Boost, Boost Leaks and No Resolve
  24. Transfer case removal
  25. Trans Problem Help
  26. Best Triple Plate Clutch
  27. 20 g bolt ons?
  28. Oil light question
  29. Steps in which I should complete?
  30. dp and 02 housing
  31. Question about twin in-tank setup
  32. Would this be beneficial for Meth Injection? Vid.
  33. How to identify an EVO 9 turbo?
  34. Breather filter on T-case/tranny overflowing?
  35. Eclipse 2G stroker kit will fit EVO ?
  36. Fuel pump options
  37. Forge UNOS Help!
  38. Which spring comes in a Forge Unos MBC?
  39. Extreme Turbo Systems - Intake System + IC Piping Installed Pictures
  40. New Keys.
  41. Bent Some Valves!
  42. turbo clipping?
  43. Intake Air Temps - Ambient underhood, pre and post intercooler
  44. Strange Sound Need Answers!!!!
  45. problems... :-(
  46. Loose throttle cable, pedal goes all the way to the floor but cable is still attached
  47. Boost gauge needle shaking?
  48. greddy 36mm water temp adapter: what size is sensor hole??
  49. I have a gt35r kit on my car untuned is it ok to run wot under wastegate pressure?
  50. can anybody share some knowledge?pls...
  51. Whistle at certain throttle %
  52. ???? about FP Green
  53. intake manifold
  54. What all companies or businesses make/sell solid MM's?
  55. help!! clutch keeps locking me out!
  56. Differences in cam
  57. meth injection and reflashed ecu?
  58. Cam Help
  59. Wastegate?
  60. Broken intake valve guide question????
  61. Helix V1 DP fit ACD?
  62. CRAZY irregular idle after Cosworth IX Cam install! Why? Does it even make sense?
  63. Dumb, Fuel Pump Question
  64. HKS Evo IX Mivec Cams, who has them?
  65. Parts Advice
  66. Greddy oil filter block adapter safe for engine?
  67. question about valves,and springs and retainers
  68. Transmission Cooler
  69. More Flywheel chatter than before??
  70. The most advanced water/methanol injection kit
  71. where to route cable for wideband?
  72. DP,TP,CELfix
  73. Soliciting engine rebuild advice
  74. Thanks to Sean Ivey
  75. turbo kit???atp/sbr/buschur/greddy??
  76. Adjusting Forge RS BOV
  77. MBC problems
  78. Please help! The pursuit of better boost control for a 16G.
  79. HKS type S or type R?
  80. Ar 63 Or Ar 82
  81. Brian Crower 280 cams require springs?
  82. Who makes quality v-band clamps?
  83. ?'s for guys with 475-500awhp Daily Drivers
  84. Clutch Question
  85. IX Evogreen - Camshaft?
  86. Licp to short??
  87. To Get Valve Spring and Retainers or Not to get?
  88. **ALL EVO IX's BUILT HEADS COME HERE **
  89. Cat Flange leaks water but no air.
  90. Full Race Turbokit.... What exhaust???
  91. my buschur turbo kit bolts keep on backing out!!!!!!
  92. Dyno Flash Evo goes 9.50 in the 1/4 mile
  93. 20g-9LT (green) vs IX turbo
  94. Did I put the right grade oil in my 9? I have valve ticking at idle after the change.
  95. Head flow numbers
  96. Evo 4 RS transfer case
  97. ETS Manifold Vs full Race
  98. (gauges) BSPT to NPT fittings? get em locally?
  99. Dyno sheets of Cosworth cams and -4 and -2 cam gear settings/dyno videos
  100. catless Helix HFC
  101. Need help selecting a turbo
  102. Stock gearset limitations?
  103. Info on build help
  104. service engine soon
  105. Would buying a greddy turbo be worth it.
  106. My AMS Lightweight Front cross member review
  107. A Good Flywheel choice?
  108. My buschur racing pump gas evo..Part deux
  109. Extreme Turbo Systems GT42R Kit is better than sex
  110. Flywheel Removal Tricks?
  111. Help with my new Engine!(clank noise)
  112. Dyno#s with Cosworth cams and camgear settings!!
  113. Evo Crank
  114. clutch vendors
  115. Ultimate racing HFC???
  116. Evo Ix Mr Cams ? Every Opinion Counts.
  117. mivec camshafts
  118. Which MBC?
  119. utec on my bolt on evo and only laying down 264???
  120. Yet Another ~12psi boost limit
  121. 5th gear grind - advice needed
  122. Clutch retention spring: anyone seen or had this happen to them?
  123. a/c noise
  124. Low RPM troubles dip/stall
  125. Engine Size Comparison
  126. 955 Dyno Jet WHP at ICS Dyno Jet - Dyno Flash Evo 8
  127. Question about Boost
  128. 1.1 Bar > 1.3 Bar [Untuned] ????
  129. E3 Spark Plugs
  130. AeM Wideband
  131. 35R Buschur dyno'ed today!
  132. My Tilton Clutch blew.
  133. help me decide
  134. shifting problem "help"
  135. how do i get this o2 housing gasket off?
  136. Clutch Pedal Adjustment Question
  137. hks gd max rebuild clutch kit
  138. need help before buying parts!
  139. new setup coming soon
  140. 280 Cams.. help
  141. Exhaust Question
  142. Exhaust tooo loud.. need advise.
  143. What makes this Turbo Whistling Sound? [VID]
  144. Trying to find the cause! Blown Engine!
  145. what causes a turbo to back spool in high rpm's
  146. devisl own kit
  147. All Evos whine a little right?
  148. 10 psi again?????????????
  149. catch can and breather help
  150. New front 02 sensor shows 0.00 volts??? HELP
  151. Misfire and boost problem
  152. fresh install of Injen intake & IC pipes BOV noise
  153. Intake manifold question
  154. Compressor Wheel is Screwed!!! Please Help
  155. Please Help my compressor Wheel is screwed!!!
  156. Pls help, car wont start after cleaning fuel filter.
  157. Clutches
  158. vacuum hose diagram?
  159. Need help choosing Downpipe and intake.
  160. anyone running megan's new TBE
  161. Wideband O2 Shootout Test & Results
  162. Piston sizes info need.
  163. Anyone have experience with Precision Turbo & Engine either with your G or other car?
  164. ACT prolite flywheel or ACT streetlite flywheel
  165. Fidanza cam gear problems
  166. Evolution III swap
  167. ive noticed my bov
  168. What size tbolt clamps?
  169. synapse synchronic bov???
  170. Losing my mind here...
  171. Custom Turbo Project Turbo Selection?
  172. sick of forge bov flutter??
  173. little help? IX fuel pump
  174. MEGAN o2 housing review.. internal pictures.. not so impressed,,
  175. Stock Clutch
  176. my transfer case makes some noises
  177. The Turbo Landscape in Detail
  178. Can close gap cause Over Heating?
  179. My EVO hated me today
  180. Guide: Remove TC w/out removing ACD line
  181. Exhaust Issue
  182. Lower ic piping worth the buck
  183. AEM Wideband gague issue...
  184. Radiator
  185. Tranny noise
  186. Cosworth Mivec Cams
  187. identify cam
  188. installed LICP, now front bumper wont go on...pics.
  189. Underbody exhaust heat shield - Can i remove?
  190. Velocity stack (maf and adapters)
  191. Curiosity question for those who have...
  192. Which Stroker kit....
  193. O2 housing questions
  194. Evo Viii And Ix Uicp?
  195. Missing part of my LC-1!
  196. Mod advise
  197. intercooler upgrade
  198. TurboXS FMIC question
  199. Help!! Broke something!!
  200. gsc s1's evo ix turbo dyno graphs!
  201. HELP! Car sounds like a diesel!
  202. 2005 transfer case removal
  203. Question about switching from 93 to 91 octane
  204. Injector Size
  205. Went back to OEM exhaust...left the rest of performance parts untouched
  206. Fuel guage - fuel pump/fuel level...
  207. Lots of unhappy sounds from somewhere
  208. exhaust mani. gaskets
  209. Saikou Mitchi can quick question
  210. manifold torque spec
  211. Tansfer Case Leaking Fluid Leak Letf Lipseal Axe
  212. Best Piston and rod combo
  213. Wideband(help)
  214. Mini-Battery Research
  215. Turbo xs rfl bov. . .
  216. Is this whine the walbro fuel pump?
  217. Major accident threw p0335 and p0340 codes
  218. WTB:evo9 stock waist gate actuator turbo heat shield
  219. throttle position sensor install
  220. Need help with sending unit for gauges
  221. downpipe,test pipe
  222. Dyno'd my IX today..
  223. problem fitting 35r kit
  224. Stock Evo 8, 8 grand to spend
  225. GT35R over GT37R
  226. P0403 Exhaust Gas Recirculation Circuit Malfunction
  227. Transfer case oil
  228. Injector question!!
  229. Not understanding the power loss!
  230. 2006 Evo TSB's
  231. Stroker Timing Question
  232. 8-9 Battery Sizes?
  233. Turbo Outlet.
  234. Free HKS SSQV... should I do it?
  235. Need help......weird loss of power after parts install
  236. Boost fluctuation - any ideas welcome
  237. Battle of the Turbos - 50 Trim vs. GT35 - dyno comparision
  238. TBE and drop in filter with no tune...
  239. Evo 8, Smoke, Oil smell comin out of the exhaust when I let off the Gas.
  240. System Too Rich (PO172)
  241. clutch install, now steering problems
  242. My rebuilt engine (in process)
  243. car battery
  244. Extreme Turbo Systems - 5" Intercooler (PICS) Do you dare?
  245. Extreme Turbo Systems - More SEXY PIPES - Stock Battery UICP!
  246. Boost Leak
  247. Where to weld O2 bung on Fujitsubo catback exhaust?
  248. my first evo. need some input.
  249. TB boost leak
  250. 60K and timing belt
