- C L U T C H
- put uicp on , now tranny is jerking
- will an O5 Exhaust manifold fit my IX
- ams test pipe
- Controlling Boost
- gsc s1 evo8 cams
- Boost controller
- Blew My First Clamps!!!
- JohnEB and JustDSM at it again, New Build!!!
- t3/t4 or evo green
- Anybody have magnacore plug wires?
- Clevite part # for main & thrust bearing?
- Cosworth 272 Cam Idle Rise and Fall
- Wtb Hks 272 !
- Cleaning HKS filter???
- Stock exhaust VS Megan Racing
- AMS VSR INTAKE or MAGNUS INTAKE
- XTD Clutch
- Will "Jun" come out w/mivec cams for the 9 or not?
- Clutch Help
- HKS EVC V problem holding boost
- Best cams for the $!!?!
- HELP! Injen Intake w/ IC Piping and HKS BOV Ver. 2 w/ IC Piping
- Trying To Get Rid Of Your Stock Turbo
- 400-450 to wheels theirs a catch tho
- Wideband reading question
- Fuel cut?
- possible to reuse heat wrap? what if i soak it before removing?
- My new setup
- HKS Clutch
- Transmission question.
- Can I use this in my ACD?
- Extreme Turbo Systems & Racing make 924whp! Cheap Dsm coils to boot & $250 BC cams:)
- Greddy Mivec Cams?
- New record set on Buschur's dyno today
- Rerouted EVO throttle cable...Is it bad for the car???
- Input on ACT price
- Calling Tanabe Ultra Med Owners
- ACT Clutch Problem?
- APS Intercooler (pics)
- Royal Purple = lifter tick?
- ACT or EXEDY
- 2003 EVO: Code P0300 how worried should I be?
- Evo 9 Turbo Question
- Has anyone done 2mm valve seats on their 1mm oversized valves?
- Buddy Club Camshaft Failure
- Creaking noise
- Differene btw Exedy SD and HD?
- Dialing in cams with degree wheel and dial guage
- proper way to install a tial 44 mm?
- Question about HKS RS Intake
- 50 vs 57 trim...
- What boost?
- HKS DLi-2 install question?
- p0300 misfire
- Exhaust configuration
- Extreme Turbo Systems - T3 50 trim, 57 trim, 58mm, 60mm, 35R, 67mm Turbo Kit Release!
- What fan to go with??
- about header !
- thread pitch and diameter of bell housing to engine block bolt?
- leaking oil filter
- Trans Prob
- Boost Leak Around Fuel Injectors
- to build or not to build...
- Grounding out ecu fuse
- Forge EVO 9 Actuator
- Meth injection question
- 2nd Exedy triple carbon=crapola
- Iridium spark gapping
- AMS GT35R Turbo housing sizes???
- 1000whp fuel setup for Paul Nelsons car
- need a new bov what should i get that dosnt leak?
- Substitute C16 on car tuned for 93 + Meth
- Shep Stage 2 t-case
- In need of some help, please. NOISE
- Plugs for a lightly modded IX
- Anybody have a reciept to buying their Aem intake I can barrow?
- 4-Stroke Basics
- help with spark plugs
- Best Cams for an VIII stock turbo-gt35r
- Best Cams for stock turbo-gt35r
- Mobile 1 Transmission Fluid
- Electronic or Manual Boost controller
- Manf. R&R
- Clutch slip at 4500 rpr and up in 4th gear?
- ugh ohh boost creep
- EvoVIII & IX Lower Blocks
- Att all you guys with widebands
- Stock boost settings
- stock cams in an 05 diff from an 03?
- Any pics of the ebay turboback exhaust??
- What type of fan is the Evo 8 fan? Push or pull type?
- Problems, Please Help Asap
- HX-35 Turbo on Evo?
- ????'S About fourth gear??
- Boost Controller
- Hks Ssqv
- HELP! Evo 8 to Evo 9 Turbo install?
- Boost leak test materials for evo IX
- whats my next steps...
- Exedy Twin Rebuild Kit?!?!
- Evo 9 Upgrades without hurting low end???
- hks knockoff intake?
- Impression post test pipe!
- Exhaust Manifolds??
- Evo upgrades
- turbo
- Popping noise at sharp turns
- Recommend Cams for Evo9???
- Resonator for 35r
- Defi Gauge Sensor Question
- Turbo help?
- 20g-lt + e85= fun
- Will the Samco Turbo Hose kit for an EVO 8 fit and EVO 9?
- Quick WB installation question
- waht benifits and gains from porting just the stock head
- Lost first and second gear?????
- tuning the AEM Tru Boost....
- Help with identifying a blown head gasket
- code po171
- what oil fitting for gt3076?
- Question: weird sound after intercooler installation
- engine swap?!
- Boost leak on throttle body - how to fix?
- Thought I had enough break in miles? maybe not.
- *NEW* ETS 57 trim turbo kit
- new cams, do i wait to tune?
- Exedy Triple Plate Chatter Question
- AEM Tru Boost.. Vac line routing??? help my confusion please!!
- PERFORMANCE SHOP (this is a must see, so check it out)!!!!
- dd
- Bolt on 400whp, pump gas only, is it possible
- Code P0300
- Where are people breaking??
- Help with finding TDC
- What's the cause of CEL p0011?
- ACD fluid
- TurboXS Downpipe Leaking Help
- Exedy twin retainer clip. need advice!
- Intercooler woes: Plz help me to decide...
- Downpipe
- Is this the right trany fluid # for the MR?
- expirience with NX Nitrous Express???
- New fuel setup
- AMS Power stearing delete kit
- MBC problem, not a leak, but sucks just as much
- Clutch won't fully disengage; can't put car into gear once started.... Help.
- QTP Dp/WBo2 question
- Buschur intall mini battery and upper ic pipes
- EvoIXMR Stroker kit
- Looking for feedback on HKS cat back
- br cast mani or tub with 3065
- built head and stock block?
- track time est?
- Blown Tranny at 30,000miles
- Question Reguarding Cusco LSD
- fpgreen twinscroll?
- best mods start on 03 evo?
- Looking for 300+hp on a budget with my 05
- Recommended boost level for a IX with basic mods.
- Manifold
- ACD lights when hot only
- stock battery install?
- WHAT MPH is 8900 RPM in 5th gear in an evo 9???
- GT37R turbo explanation
- Whinning sound? which could it be?! HELP!
- need help now please!
- Next Mods?
- Walbro 255 Replacement
- Jun actuator on an evo ix stock turbo
- Trans Help Asap Stuck With A Car!!
- anybody run this fmic
- help on exhaust manifold
- Help me understand Exhaust
- Klunk sound out of car
- TRE or Shep for quick turn around
- ????Need some help?????
- Buschur Coil on plug system
- Garret 60-1 Turbo
- Tuners in Nebraska?
- need a banjo bolt
- Tomei DP Kit for IX MR
- soo hard to decide
- Porting ebay 02 Housing ??
- Found the problem, what now?
- What aftermarket intercooler kit will fit with Atp gt35r kit?
- HKS EVC not regulating boost?
- Best way to test front differential operation?
- question on cams
- a lil help please
- Anyone have experience with the BR Evolution Pure Power Package?
- BOV flutter
- stock clutch specs?
- Engine: Evo Blew on first day (Help!)
- Boost leak? Fuel economy?
- 25psi feels like 10
- help... ticking noise??
- Ebay Intercooler Pics
- Turbo timer, countdown??
- Boost needle under idle HELP
- re torque cam bolts?
- Installed my Cosworth Cams!
- need help hooking up the stock boost selonoid
- RWD Conversion Questions?
- Exhaust Fitment Q: JDM vs USDM IX
- Makinng Driveline stronger
- how to build a proper high boost-safe engine
- OEM factory muffler.. NY
- Exhaust ?
- fuel pump and catback exhaust??
- o2 housing delete
- best clutch for around 500 bucks....or cheaper
- fuel tank, pump, injector cleaner?
- Transmission know it all's.....
- best cams for me
- Full-Race Twinscroll 35R
- Evo reverse question?
- Any useful info on this....
- lost 1st nd 2nd gear
- front wheels only spinning
- evo radiator
- Megan Racing Evo 9 black cat back
- Syncos? From 3rd to 5th
- EGT Temps...at idle and cruise?
- Oil Pressure on E9MR
- 10.5 hotside noise?
- Attention Vendors I Need A Turbo
- Aem Wideband (where to run the wire from the O2 sensor)
- thoughts on Buschur Racing stage 1?
- hks280+etc..WHP?
- Spline Shafts
- 10 psi problem fixed!!! FINALLY!!
- GT30 and GT35 Guys
- Clutch and Fly wheel question?
- 3,000 rpm problem
- looking for evo 7 or 8 rear diff
- greddy 20g turbo kit
- hks turbo kit
- Need advice on adjusting the Forge Wastegate
- Bent valves need to replace. Which?
- greddy t67 turbo
- exhaust?
- need info on how to achieve 350-375 whp
- EVO GREEN & 2.3 STROKER 352awhp & 358tq
- Downpipe Fitment
- Exhaust weight....
- OEM ECU Knock Sensor Logic
- MR Short Shift
- Launching with Spec staqe 3 clutch
- Dyno'd again... finally happy
