- Spark plug part number!
- "Overspeed" turbo failure?
- 8 to ix turbo
- Engine Internals
- How Is My BOV Holding On?
- comp or act
- boost leak question for advanced people only
- Boost stutter?
- Drivetrain?
- More broken parts for the Bad Bish
- 500whp on ACT 6 puck
- Need help with next purchase. Input appreciated, Thanks.
- Acceleration problem - AUGH
- big power stock MAF people inside here
- Injectors/ Head Question
- Boost / Fuel Cut 15psi
- Stumped, Insight ?
- 100mm crank
- Exedy twin part #s ?
- Transmission identification
- Transfer Case question
- DC Sports vs. Buscher Ported Ex Manifold
- 5th and Reverse issue Please help
- Electrical Madness
- How do I?...Hook up two fans to the radiator? pic of radiator incl.
- Autolite Iridium XP Plugs installed- Problem
- clunk noise from transmission driver side/
- Wont go into 5th gear?
- Tranny makes a whiney noise... please help
- Loud Whining Noise
- Ivey Trans 6sp Rebuild
- Need Help!!!
- Balance Shaft Delete question
- a couple simple questions!?!?!plz help
- timing belt question
- Replacement cbe for Greddy Ti-C
- AYC Reservior Bleed and Fluid Change
- Ap Racing Brake Pads
- Transmisison whine 3k-5k rpms and little throttle
- Brian Crower Stage 4 Cams 288/288
- Evo viii maf vs evo ix
- speed density !!!!!Need help
- busted oil cooler
- car broke again, wont start!
- Mandrel Bend vs Press Bend?
- Need STOCK UICP FLexpipe coupler to IC
- Bolt from exhaust manifold to turbo fell off....
- Opinions welcome
- Tomei Poncams or Cosworth for IX MR
- evo ix 272/272 cams
- Strange grinding sound with new clutch
- Mivec Compression test numbers. Aftermarket cams.
- My new ride
- Stock ECU, 1000CC injectors, Minibattery...
- Valve cover ?
- catalytic converter heat shields
- need help
- Evo 8 Clutch or master/slave cylinder help.
- 80MM Red Stock Appearing?
- Please help me out on this!!!!!!
- Having some issues
- e85 tune help
- engine problems
- Quieter Exhaust...
- Tough time starting engine..help
- Jm Fabrication "Drag" version smim rubbing.
- Dual Rail wiring
- Full Race Evo 9 Turbo manifold owners: What intake pipe?
- Turbo Info...
- Which will perform better?
- Turbo rebuild
- Low boost and dropping
- red issue on blade direction
- Power Steering..
- HELP!!! no start
- Setting the TPS
- engine light and water sucking
- Car shuts off with AC on.......
- Injector size vs power potential
- Drivetrain grinding and noise......
- FP Black?
- Few questions about 30k checkup
- Best exhaust manifold?
- RED LINE 75W-140: Can I use this in my transfer case?
- 2.2 engine and FP Red - what boost should I run ?
- Am i running too lean?
- Weird, Weird, Weird Issue!
- Warranty Question
- Idle Control Error
- throttle body gasket replacement question
- Timing Belt Slipped
- turbo timer install?!
- black smoke when decelerating
- Synapse synchronic bov
- n2o... Why don't we see much of it?
- Older 4g63 parts compatability
- Headlight broken bracket
- Battery Help
- replacement valves
- Official Boomba 75mm Big Bore Throttle Body Review and Dynotesting by TTP!
- about ACT cluches?
- Bad clutch or Bad wastegate?
- Ceramic Coating question
- Tilton twin disk
- Problems.....
- Has anyone tried the Kamak HP WGAs
- The best forged piston money can buy!!!
- SFP turbo kits?anyone?
- FP Red vs. CBRD Version 2 BBK
- post cam install problems??
- noticed some sort of leak on driveshaft
- FP Green
- Location for Greddy Oval Catch Can?
- Turbo Upgrade!?
- [ETS vs Full-Race] Twinscroll HTA3582... Opinions Needed!!!
- QM clutch rebuild cost?
- Sumping stock fuel tank
- 37R or P67 Billet turbo question
- help me get more power out of this car, what next?
- Precision Injector o-ring size?
- Turbo oil/water lines and drain tubes? what to use?
- Tighten' up MR 6-speed?
- Magnus vs Driven Innovation intake test
- Can't get my downpipe to seal to my manifold/ o2 help!!!
- 3.8" Garrett IC vs. 4" ETS IC
- Coolant Leak Around Back of Motor. ( With Pics )
- Hallman MBC install questions
- Help me Identify this turbo.
- Strange problem trying to install new spark plugs
- removing power steering without ams kit
- Any advantage to running Mitsubishi turbo kits like Buschurs over twin scroll?
- Fp hta green
- headgasket?
- IX owners with upgraded cams
- Thoughts on AMS vs. ETS IC cores
- question about t-case
- Another stock vs aftermarket intercooler thread
- Weird noise under acceleration...
- people with big turbos please HELP!!
- Anyone else got a leaking Mocal oil cooler
- need help have qustion on turbo 9.8 to 10.5
- JMF race and drag manifold your thoughts
- What torque for manifold bolts/nuts - fsm conflics PICS inside!!
- will tears make this okay?
- Which is better: HTA35 or twin scroll HTA35 on 2.0 motor?
- Question about Porting Exhuast manifold
- Iac valve
- Fuel shuts off when turbo goes into boost.
- Deatschwerks Injectors and E85 = New motor
- Greddy full auto turbo timer
- How long did you wait for your red?
- Greddy T67 25G problem HELP!!!
- Help With Delphi Injectors part number
- Timingbelt Service Question
- ATTEN: AEM Short Ram Intake users
- Wastegate size
- Aem Intake Filter diameter size?
- Clutch runout numbers
- What cams to use with CBRD BBK FULL Turbo
- 35R with Meth Injection
- Which spools faster: FP HTA GT3582, FP HTA GT 3586 or PTE 6262?
- Problem with the CCI Twin disk
- HELP Bolt Fell Out While Driving!!!!
- Finally, she is coming together! (Stroker Build)
- 2.3l + 20g
- MR Trans 4 gear stiffness
- problem. lines cut.
- opnions 4' ets intercooler
- Oil on spark plug
- Flashing SES light, did do a search....
- where does this line go??!!
- WaistGate and Boost Solenoid HELP!! Plzz!!
- 2 piece oil pan?
- Oil Filter
- ETS super value/gt35r/pt61 questions.
- Coverting GT3582 to the new HTA3586
- Question regarding Evo w/ACD
- BG Syncro Shift II Vs. Amsoil MGT
- Boost fell off 6psi..
- need help: greddy profec B spec-2
- aem meth kit nozzle size
- Stuck Transfer case oil fill bolt?
- Question about EDM/JDM 7/8RS ACD w/o AYC pump and placement
- Transfer Case Install
- timing issues?
- HTA gt35r vs PT6262
- Clamps Size?
- is there something wrong with my clutch?
- act break in
- FP Red Supporting Mod. bottlenecks...
- Evolution 6 Setup - need to know FWD tranny
- Cam question for new build
- Upgrade path...
- 3'' vs 3.5'' FMIC
- Strange WBo2 readings -- Bad MAS?
- Oil filter housing leak
- Trans swap questions
- misfire
- pulling engine
- Noisy ACD pump?
- AMS Turbo Back Exhaust with HFC and Resonated Test Pipe
- Amazing injectors 2200cc, no double pumper needed
- Variable Turbine Geometry for Evo?
- 1/4 mile times with HTA Green?
- Tomei Arms 7960 Turbo
- Open Dump sound??How??
- Help! Boost only w/ full throttle and above 4,500
- $12-13K! How would you create 500WHP+ Monster?!?!
- Oil pressure sensor relocation / Summit woes
- Help Tapping for Oil Lines(Turbo) and Oil Gauge Senders
- Head work.. Am I over looking something here?
- Mest method to remove seized rear diff drain plug.
- 60k Service in San Jose area
- Knock on start up
- p0172 and stalling issue
- Tubular Manifold Help
- Intercooler Pipeing Help
- Engine Compatibility
- Starter Screech?
- Tranny, Rear Diff and T-case Fluids
- what is this?
- Bled My ACD thoroughly and still have all 3 Lights lit up, any ideas???
- In the Process of Adjusting Clutch Pedal Please help!!
- Any of you have any experience with these CEL/Error Codes P0462/P0183
- I have a bad squeal now and it seems to be the altenator pulley
- possible C.V. boot or axel damage ?
- Simple questions I guess :)
- Headgasket questions
- got a CEL and Overboosting!!
- What to expect with a buscher head on stock block?
- Big Cams Cruise Tune for the Evo 8
- Boost cut on Evo 6 TME &
- act vs comp
- Little Noobie help
- Improved BBK
- How many REDs on stock block?
- When does the Slim Fan on an aftermarket turbo kit turn on??
- Blew 4th gear again Evo 2... Cryo?
- Looking for 170 degree thermostat
- Magnus help!
- I think I need a new sump/oil pan - help
- Stock boost gauge
- FP RED 80 or regular ???
- Injectors leaking boost
- Stock motor w/ HTA 35R?
- Buschur is what is needed for a reliable 9sec DD!
- Fp red not sure how to tell a 80mm!
- Bought a used turbo and found this...
- Amsoil Manual Tranny MTG vs Amsoil Severe Gear SVG
