View Full Version : Evo Engine / Turbo / Drivetrain
  1. MIVEC oil feed line leak?
  2. Best price on Tilton rebuild?
  3. Boost leak?
  4. n00b evo question... heatsoak?
  5. Check engine light codes that shut off engine
  6. tb spacer
  7. Hallman Pro vs. Stock BCS - My results
  8. normal boost?
  9. spark plug question
  10. Exedy Heavy Duty Twin Disc Cluth Noise Question
  11. horrible partial throttle any ideas?
  12. Wtb: Evo Motor
  13. Help with strange problem.
  14. Violent misfires, freeze plug...
  15. Just finished my o2 housing install.......
  16. Help two questions 35r and v-band
  17. 57 Trim on an evo
  18. Getting a race gas tune, which fuel should I use?
  19. need help with codes
  20. Boost leak or crappy install?
  21. 4g63 evo IV to IX
  22. Anyone ever had a transfer case go out?
  23. Can't boost over 19psi
  24. got dynoed today! 4WS FTMFW!!
  25. need to know a torque spec for turbo.
  26. First gear whine?
  27. How you you tell if the Buschur DP was made for the old non ACD or ACD transfer case
  28. JDM MR BOV on a 57 trim?
  29. XS Engineering Ignition Amp V2 WHAT PEOPLE THOUGHTS?
  30. Solid Motor mounts - knock?
  31. Oil adapter ring
  32. bov recirc pipe for uicp? where to buy?
  33. Is ACD worth it?
  34. downpipe / o2 housing headache
  35. ??? if i build my head...what rpm
  36. Cams w/ no tune runs lean?
  37. next mod decision?
  38. looking for Greddy BOV type RS 8 port outlet
  39. TCase or Clutch noise - horrible noise
  40. tc and diff
  41. need help with this code!!
  42. Can not pass 11 psi. Help!
  43. Checking what cams are in my car?
  44. Extreme Turbo Systems - Turbo Manifold Sexiness Galore!
  45. Anyone using MAF translator with good success?
  46. Mach V powder coated intake pipe kit?
  47. Failled exedy twin HD + synchro warranty woes
  48. i want to upgrade my hks 272's what cams to go with???
  49. Lessons learned along the way
  50. tranny help
  51. Garrett 60-1 Turbo how much lag?
  52. cam install
  53. Tranmission Help
  54. Buschur Race FMIC vs Deluxe FMIC (pics)
  55. **Dyno Results**
  56. best turbo for my setup
  57. Boost controller install? Wrong or right
  58. MAF sensor ?
  59. Evo IX with Aquamist HFS-5 kit and 25 psi pump gas
  60. 28 PSI peak boost vs 24 PSI peak boost on Stock Turbo Evo IX and pump with alcky
  61. Full Fluid Change. Fluid Suggestions.
  62. Considering PPI porting...
  63. My New Setup :)
  64. external wastegate
  65. loud exhaust sounds from exh manifold area?
  66. Yes... another SES post :)
  67. Clutch/tranny making odd sound!
  68. HKS Evo IX cams and tune results
  69. code p0401 (EGR)
  70. GSC 272 S1 Cams
  71. My buschur racing race gas evo
  72. An orgasmic combination of parts.......
  73. Show me pics or explain this to me!
  74. think I have a bad fuel pump need help!!
  75. cosworth cams question??
  76. Forgot to bolt up CAS durring my timing belt R/R
  77. Boost down, but LoadCalc up???
  78. Buschur turbo kit modifications needed to run Stock ECU & Stock location intercooler
  79. What to expect?
  80. Extreme Turbo Systems - ANOTHER Sick EVO Turbo Kit!
  81. **SickSilverNLow's ETS 57 Trim Dyno**
  82. godspeed intercoolers?
  83. Please help,Turbo!!!
  84. Evo IX 20 G from turbochargers.com on a Stage IV
  85. Clutch is almost gone.. Need help finding a new one!!! PLEASEE!!
  86. Retune after 10.5 & P/C manifold?...and some other questions
  87. warming up
  88. 457 TQ 430 WHP - Maxing out the stock injectors with 93 octane and alcky !
  89. Greddy M-Spec Intercooler Kit Mitsubishi EVO IX 06
  90. what is the problem !? help!
  91. Front LSD
  92. 968 AWD WHP ! Dyno Flash Evo with Buschur Power - (Video)
  93. VIII and IX Intercoolers - are they they identical?
  94. cause of cam gears wearing down/symptoms
  95. Shifter Bushings AMS OR BUSCHUR (6 Speed)
  96. Building Engine - Looking to Paint - Enamel Effects?
  97. HTA GT35r, any movment on this?
  98. Need help with ex manifold stud m8x1.25
  99. Very strange boost leak
  100. Car throwing 335 & 340 codes all of sudden
  101. Oil leak from underneath the intake manifold, but I can't see where exactly...
  102. Who is running aftermarket fan with GT35r
  103. Where does AEM UEGO O2 sensor go?? front or rear?
  104. Intercoolers??
  105. Clunking/Popping Noise Coming From Front Driverside Tire
  106. brian crowers 272 cams?
  107. looking for ported 65mm throttle body and intake gains
  108. ETS Tom - Joining the turbo kit fun!
  109. just got my aquamist HFS-1...... people with meth chime in
  110. RPM based Boost Controllers
  111. Attention: Racers At WRX vs EVO Shootout ! (Etown Aug 25)
  112. BOV to Intake coupler size???
  113. stock evo pistons...
  114. installed evo 9 turbo, mr02, and ams tb
  115. change my clutch
  116. Turbo upgrade and supporting mods
  117. my engine blew....any thoughts and help?
  118. cam break in?
  119. factory boost solenoid
  120. **HELP**Timing Mark of by 4-Teeth!
  121. Major Boost leak
  122. Help me figure out my turbo situation!!!
  123. clutch lock ring will not stay together
  124. Does A 50 Trim Need A "built" Motor?!
  125. Does A 50 Trim Need A "built" Motor?!
  126. Does A 50 Trim Need A "built" Motor?!
  127. Does A 50 Trim Need A "built" Motor?!
  128. Driveshaft question
  129. New mods New tune New thread
  130. 15th DSM Shootout Dyno Day - Video - Dyno Flash Evo makes 835 (Mustang Dyno) whp !
  131. greddy boost gauge help
  132. Clutch options....need recommendations
  133. For those removing A/C
  134. what should be the next upgrade for me? need help and good advice
  135. Hey guys noise in head need HeLP
  136. SHOP CT:Evo Green numbers are in...
  137. Any one have a clutchmaster clutch?
  138. Walbro 255
  139. Walbro fuel pump question
  140. intake ...which one??
  141. Max boost on stock motor ???
  142. high boost guys...some plug questions?
  143. why ?Evo IX transfer case leak
  144. blew up!!!!
  145. VTA, MAFT BOV issues
  146. We did some testing on GSC S2 cams and 1.02 to a 1.28 Divided housing on ETS42r
  147. update on my "noise"
  148. Need suggestions of possible problems! HELP!
  149. K U Eng. intake manifold?
  150. Did The Dealership Cause My Transfer Case Failure? (Expert/Mitsu Tech Help Please?!)
  151. Help identify turbo - pics on evo VIII with cast mani
  152. fp 3065 / ets 58trim
  153. ACT 2900 Street Disc........
  154. My Jam 2.3 Stroker Kit With Buschur Racing GT67 P Trim
  155. check engine light
  156. Boost problem
  157. how necessary is it to......
  158. Cosworth cam install questions
  159. Pros and Cons
  160. SBR's 20G updates?
  161. removing resonator...
  162. How are my stock plugs doing? 36,000 miles
  163. CBRD Product Development- updates...
  164. CBRD Product Development- updates...
  165. Bent Valve or Bad Cam Shaft?
  166. Found some FP EVOgreens
  167. evo 9 USDM gearbox
  168. Project: 2.3L stroker on stock turbo
  169. question
  170. The family...
  171. $#%&ing sound!!
  172. **VID**Help Me Identify This Whistling/Cricket Sound
  173. Magnaflow Questions
  174. Opinion on when to o-ring the head/block?
  175. Help!!!!!!!!!!!
  176. Stock block with Cosworth 272 Cams
  177. Oil Temp Question
  178. Tune problem with mods?
  179. Rear diff locked up --- where can I send it to be rebuilt???
  180. Help me diagnose this whistling/chirping sound **VID**
  181. o ring question
  182. Are you using an aftermarket wga??
  183. Build my Block Or Buy Built Shortblock?
  184. fuel pump and injectors
  185. driving without a snorkel?
  186. Buschur's advise(need help here)
  187. 5 bolt o2 housing for gt series (piecing together turbo kit)
  188. Nisei or ETS Intercooler...?
  189. O2 Housing
  190. where can i get a turbo rebuild kit? (gt30r)
  191. bov atmosphere with flash???
  192. evo ?s
  193. Has your TurboSmart BOV quit working?
  194. 2nd official post ......how bout some pics of some new goodies
  195. AMS or buschur FMIC...?
  196. stock ix fuel pump vs. walbro 255?
  197. Quickest spooling stock turbo
  198. Tune required for intake filter?
  199. aps bov needs adjustment
  200. Evo IX walbro inline pump install ???
  201. evo mod ?
  202. over heating issues seeking help!
  203. help!!! questions about AMS VSR
  204. internal wastegate
  205. New Pulstar Plugs replacing spark plugs
  206. upgrades help
  207. What to do if any before tune?
  208. Boost leak advice please
  209. shooting for low 10s, what should I do next?
  210. ABS delete kit??
  211. Why video tape a car on the dyno?
  212. Video of 612 awhp Evo 8 from NM
  213. i have a head noise need some outsiede opinions
  214. HKS 272 Cams - Timing Figures
  215. Offset 272 and 280
  216. **VID**HKS MIVEC Cams
  217. HKS intake pipe w/ Apexi' Filter problems
  218. go fast bits bov
  219. 2.3 or 2.4 stroker + Big Turbos (Explain Driving Experience)
  220. Possible Stripped Thread
  221. need some good advice for real!!
  222. Car idle like it got cam, but not sure.
  223. fluids for...
  224. New Record??? Thanks Buschur.....
  225. Did I loose Second Gear?
  226. Does your BOV hold Boost?? What are you using?
  227. EVO 8 Turbo 10.5 Single Upgrade Turbocharger
  228. Help Me Spend my Money!! ~4k
  229. Collapsed Lifters
  230. Trans noise
  231. Why are Evo8's quiet and 9's loud with walbros?
  232. *HKS MIVEC Cams Installed: Dyno Inside*
  233. timing belt tensioner
  234. Best way to get 400-450hp.
  235. MIVEC Cam Gear Plug Cap broke
  236. For all you guys with the Blitz exhaust
  237. Need some input on bigger cams for our 42r setup
  238. GT30R questions
  239. rear diff leak?
  240. Full Race Turbo kits
  241. Mods to go with big turbo?
  242. Case Study - Evo IX w/ BR Stage II - 350 / 350 93 octane
  243. Friend's Evo, Tcase cracked in half.
  244. Injen Intake w/ Stock BOV ICP Popped Off.
  245. Clutch Problems
  246. p0300(random misfire) code when trying to start the EVO
  247. rattle noise
  248. Problem....Boost/Clutch/flywheel??? pls help
  249. which gauges + boost control: for more power
  250. shift lingage problem
