View Full Version : Evo Engine / Turbo / Drivetrain
  1. Whats wrong with my clutch?!
  2. CHeck Engine Light.
  3. The Greddy T67-25g Turbo?
  4. shifting woes
  5. Has anyone here used the Hondata intake mani gasket on their EVO???
  6. Any real difference between a PTE 50 trim to a Garrett?
  7. Which Turbo to Buy GT35, GT37R, or GT40R Twinscroll, Singlescroll
  8. Guess this part
  9. peeps running the bushcur 35r on the stock ecu, look in here
  10. Does anyone here have a 4.11 final drive with stock turbo????
  11. TME Compressor Wheel
  12. What psi to tune at
  13. safe rev limit? built head with stock bottom end
  14. length of nisei uicp?
  15. Cracking/Popping Sound
  16. TOB / Wedge Collar
  17. cam gear install wows......and pain
  18. high boosting problem???
  19. Need Help!!
  20. Perrin setup
  21. car is not pushing! HELP!
  22. injector leak
  23. Full Race Twinscroll GT37 on 2.0L
  24. BR35r impressions.
  25. removed broken tcase and this is what the shft looks like
  26. looking for sponsors?
  27. stock crank? whp
  28. evo clutch website
  29. Best route to take on transmission and clutch?? Shep VS TRE??? HELP PLEASE!!!!
  30. Agency Bov??
  31. So I went thru a Turbo and FP told me it was the motor...
  32. Car Dies at Idle
  33. Need Advice - Car bucks/ shutters from a stop
  34. transfer case trouble shooting
  35. turbochargers.com TME Evo9 20G
  36. PCV and crankcase breather vent
  37. Buying a Exedy Twin Disk, does any clutch alignment tool work?
  38. GSC 280s + Supertech Sptings/Retainers =Boner
  39. Help with Full Race turbo kit.
  40. help with weird compression numbers
  41. Car shakes upon ignition turning off
  42. Anybody with an educated guess?
  43. Help me understand typical DynoJey numbers...
  44. Stock Cams Size...
  45. Making a fast all around Evo
  46. Clutch/Flywheel/Drivetrain Service near Atco, NJ?
  47. 50 trim installed Vacume line mess
  48. losing boost?
  49. 550+whp...What headgasket are you using?
  50. boost leak around injectors
  51. supertech single valve springs
  52. Question for those with BR turbo kits.
  53. Forge EVO15 springs?
  54. Max boost on 100 octane?
  55. Max boost on 100 octane?
  56. 2.2L Stroker Kit
  57. Looking for 8 ports discharge for Greddy Type RS BOV
  58. Twin scroll style T4 GT35R
  59. Tranny Sealant??
  60. Alternator goes at 104k
  61. Boost Issue, need some direction
  62. God%@*& p0300 - need vehicle specific advice
  63. Best turbo without Meth/Alky?
  64. reflash reset??
  65. Who is FASTER? Shep or Trans
  66. stock evo bad idle problems
  67. 2.3 L with 35R and meth...WHAT CLUTCH TO CHOOSE???
  68. engine code
  69. Alky injection + checkvalve = BAD
  70. Where to look on an Exedy twin to determine if it is the HD or SD?
  71. Mirage EVO AWD Conversion
  72. another 02 housing question
  73. Best Ported stock exhaust manifold?
  74. 3065 and 3076 kits owners,please post your dyno sheets!
  75. TurboXS DTEC-BC
  76. EVO Green Dyno #’s w/ Meth and C-16
  77. help! 2nd gear gone
  78. Brian Crower IX cams?
  79. what is the easiest way to drain fuel tank?
  80. Flow Charts
  81. ETS Short route UICP stock air box?
  82. think to buy FULL-RACE 3076 0.82 twinscroll turbo kit!? comments?
  83. Bad Knock Sensor?
  84. Evo IX, stock turbo, Aquamist HFS-5, 30 psi. Dyno Results.
  85. Some stock EvoIII & EvoVIII Questions
  86. 35r, few questions/want some advice
  87. CBRD new dyno record...
  88. ATP a load of crap?
  89. trans
  90. turbo timer issue... HELP!!!
  91. Blocking off E.G.R.
  92. Spark plug problem...
  93. JUN High Lift Camshafts for 4G63 Mivec
  94. XTD stage 3 clutch
  95. Best product to switch maps with?
  96. Is Buschur exhaust mani worth headache?
  97. Which oil to use?
  98. Question for those spraying NOS
  99. Ets 35r
  100. Throttle Stop for Aftermarket TB's
  101. dumb question about installing a LICP
  102. AGP bov
  103. Competition Clutch??
  104. kb50ans...what is this transmission?
  105. New exhaust parts...Tomei o2 and DP combo
  106. Oil Path of our Engines
  107. turbo setup ?
  108. RS Clutch
  109. intercooler ques
  110. HKS Kansai airbox+apexi kit?
  111. Factory Mitsubishi Hyper Grounding Kit question.
  112. To re-use or not re-use?
  113. What can cause a lumpy idle???
  114. buschur fp3065 installed
  115. transmission problem..... i think?
  116. megan 02 gasket ix and vii
  117. E85 Ethanol vs Methanol/Water injection - The search for higher octane
  118. Catch can?
  119. 272 vs 280
  120. Borg Warner Turbo and DNP manifold
  121. My 2.3L Stroker wonders is stock cams will bring in more low-mid range?
  122. cam gear question
  123. boost question
  124. stock evo 9,boost controller question??
  125. Boost leak test Issues
  126. What evo owners are running 600 whp with the atp gt35r kit?
  127. gsc s2 or cossworth 272
  128. gsc s2 or cossworth 272
  129. questions about my transmittion
  130. Lightest clutch pedal feel?
  131. Playing with Racegas on the Dyno
  132. Need new clutch soon...suggestions??
  133. What's different between this 2 turbo kits?
  134. Help! will not idle
  135. gain for gsc s1 cams
  136. OBX short shifter
  137. Annoying idle problem with AEM EMS
  138. Kind of like a jump feeling when i slow down help
  139. Tial BOV opening under vacuum
  140. spark plug question
  141. Evo Green Results w/ meth
  142. IX owners and antiflouler CEL fix?
  143. Money to spend, need some guidence.
  144. How to Open BOV RS
  145. Aftermarket flywheel
  146. evo 8 cams or other parts
  147. BUSCHUR 37r INSTALLED!!!
  148. Buschur metal shifter bushing help!?
  149. spring pressure wastegate?
  150. What is the rpm diff between full boost with a atp gt35r kit v.s. other 35r kits?
  151. How would I go about attaching a nipple to my 35r compressor for an mbc connection?
  152. HALLMAN MBC question
  153. Transmission Problem - 5th and Reverse are VERY muddy... PLS Read
  154. Exhaust Gaskets
  155. FP Green Upgraded Actuator = Poo Poo...
  156. Ebay High Flow Cat
  157. took my evo to Harmanmotive for sum power pulls!!
  158. JUN MIVEC Cams are out
  159. looking for post of evo turbo in srt-4
  160. Valve Spring removal......help
  161. 02 housing for 4 bolt exhaust housing who makes one!!
  162. Getting rid of lifter tick
  163. What could be wrong with the car?
  164. Rear Radiator Fan Question
  165. Wanna see my new rebuilt engine?pics insde!
  166. Cant figure out the wastegate vacumn lines need help
  167. where to get upgraded front diff bolts?
  168. Somone told me Cold air intakes mess up turbos
  169. ETS 57 trim Dyno Graph
  170. CBRD 2.3 shop project car progress..
  171. Ets & English Racing Hit 1000whp And 645 Tq!!!
  172. EXEDY TWIN HD barks at me!!!
  173. what happend
  174. Buschur COP question
  175. short throw for a IX MR
  176. Cracked block?
  177. Question on XS Engineering products...
  178. Reverse Issue
  179. Things to consider when buying a new cluch - help me
  180. Arias Piston Question
  181. max boost?
  182. Help with supporting mods for an HKS gt2835r
  183. Exhaust Manifold
  184. Evolution 1 (yes. ONE!) drivetrain question.
  185. motor oil...
  186. Engine Swap 8 for a 9
  187. Intake questions
  188. Safe boost with a EBC w/o tune?
  189. BoV Question
  190. Have you seen my 4th gear?
  191. EVO Green, 93 octane, 30 psi of boost and a dyno chart
  192. What head bolts to run?
  193. 3076 Manifold Help
  194. The Final, What is a walbro install kit question, Answered
  195. 136.41 mph on 93 octane, new record.
  196. Forced performance stamp
  197. IX tranny problem and diff oil decision.HELP!
  198. Gt35r and Cali Smog!!!
  199. Exedy Clutch Questions....Need help Please
  200. Redline lightweight shockproof in Rear diff
  201. Precision GT3076R ball bearing turbo
  202. What turbo setup is this?
  203. Huge Problem Please Help !!!!
  204. do race high flow cats still smell?
  205. Anyone put a 3.8L 6G75 engine in your evo b4?
  206. Need some help Stock Evo 8 plastic Bov Surging -_-
  207. HELP)!!! Compression Numbers
  208. test pipe questions?
  209. evo 9 turbo
  210. trunk full of goodies
  211. Age old Question 3076R Vs 20G LT Green
  212. Where to buy Cusco LSD's
  213. Who to go to for porting?
  214. Mivec cam install questions!
  215. Buschur Racing Mustache Bar, Center Member & Rear Diff Bushings *Updated Pics & Info*
  216. What other turbo can i bolt on?
  217. Some Intercooler-Questions
  218. GReddy Racing Ti-C Exhaust
  219. where can i buy 4G64 block, OR a customised 2.6L engine?
  220. Anybody put a Turbonetics GTK on Evo?
  221. diagnose my drivetrain problem
  222. Hard to "Port", full rutter!!!
  223. what kind of spark plugs?
  224. Witch way should I go?
  225. o2 housing install questions
  226. Clutch Pedal Is Sticking
  227. need help .. evo ix 20g vs FP Freen ??
  228. Which Vendor has best deal on Forge RS and SBC ID3
  229. Wet 50 Shot Question
  230. .70 a/r vs. .82 What's the better 35r?
  231. Post HKS exhaust install - STRANGE NOISE
  232. anyone with a 4g64 + 4g63 evo head?
  233. How much is unused evo8 shortblock worth?
  234. Bench Race: Stock Turbo vs. GT35R (both 1.5 bar)
  235. CEL LIGHT- Help!
  236. a little help with mods
  237. Gaskets?
  238. My trans blew up
  239. knocking noise
  240. Fluid changes w/Clutch install
  241. Turbo making weird noise
  242. Needed: Stock BCS Pill (ASAP)
  243. Car won't start - Think it's the starter?
  244. About to adjust clutch pedal. Question
  245. MIVEC oil feed line leak?
  246. Best price on Tilton rebuild?
  247. Boost leak?
  248. n00b evo question... heatsoak?
  249. Check engine light codes that shut off engine
  250. tb spacer
