View Full Version : Evo Engine / Turbo / Drivetrain
  1. PTE vs GT
  2. Backfire at 5k
  3. Ever seen this JDM 02 housing??PIC
  4. Serious 4 cylinder power
  5. HKS DownPipe Question for the Experienced
  6. Attn: FullBlown twin pump users......
  7. Oil inside intake pipe
  8. CEL came on.
  9. Ebay 57trim?
  10. What turbo do I want? EVO9 or GREEN.
  11. help on dyno numbers
  12. Finishing up install on AMS 35R and I need help
  13. BOV vacuum line
  14. Buschur Racing 8.88 @ 169mph *Video*
  15. how is this possible...?
  16. Raced, in the cold..oil light randomly comming on..car not boosting/running like shi
  17. Help! Drivetrain/engine issues!
  18. Port and polishing turbo housing for 9?
  19. need help choosing cams
  20. where does this thing go?
  21. oil line feed sensor
  22. plateau of 16035.95 afr hz when logging?
  23. EVO IX Oil Leak
  24. need help car making bumping noise and vibrations
  25. New Dyno #'s
  26. oil pressure?
  27. ZEX Spark Plugs???????? HELP!!!
  28. Quaife front LSD vs ACD
  29. tach drive
  30. Perrin Evo Intake hose (hard silicon pipe) question.
  31. DP with WB o2 ??
  32. Buying Timing belt
  33. Forge or TIAL.?
  34. Finally.......8.88 at 169.4 mph, Buschur Racing
  35. Speedometer broken?
  36. Starter Issues
  37. Need mod advice … please !!!
  38. Brand new clutch, cam upgrade, and fmic upgrade Q's??? Please help!!!
  39. Exhaust leaking near o2/mani
  40. clutch paddel frozed !?
  41. How much oil will you loose if remove oil return line?
  42. think to put RS diff. help please!
  43. Stock two step questions
  44. wired problem..... help me out here
  45. It has begun...
  46. What sealer to use on Turbo out to intercooler pipe?
  47. Upgraded injectors and no tune?
  48. JVT Racing Radiator??
  49. My AMS 3076R Install
  50. BR3065+pumpgas+25psi??
  51. AMSuicp
  52. Help! Car suddenly went lean under WOT.
  53. EVO 8 and EVO 9 gearing....
  54. Project 2.3 + 50trim Finished!
  55. buschur 3065 install on Evo IX
  56. Weird Noise coming from car...
  57. boosting problem HELP
  58. Injectors for FPgreen?
  59. Exedy Twin HD vs stock MR tranny info??
  60. JUN 272 V's Cosworth M2?
  61. Need advice on cam upgrade (from hks264)
  62. Trans or something else?
  63. only one cam???
  64. uicp
  65. evo 8 4th gear...why??
  66. Axel possibly going out?
  67. BC 2.6 stroker
  68. 2.3+HTA35R+FR twinscroll?
  69. Need help from all arizona members!!!
  70. Balance shaft removal kit?
  71. HKS down pipe from a '03, will it fit a '05
  72. Buschur Racing 3' SS downpipe Install
  73. Best turbo for running 91 octane and meth/E85...
  74. Water/Meth Injection, FINALLY installed
  75. Brokern transfer case?
  76. Help Needed With Injector + Injector Harness Install!
  77. 2200cc injectors
  78. Piecing together my own 50 trim
  79. Does unplugging the rear o2 sensor throw the car in limp mode?
  80. Where to order new rear o2 sensor from?
  81. 2.75" vs 3" downpipe?
  82. Plug and Play Wideband???????
  83. Help!! Water Leak! Help!!
  84. firewall plugs issue
  85. Need Help Quick!
  86. which met h kit to get????
  87. Fullrace Twinscroll Kit or 2.3L Stroker?
  88. Hoe many GT35R owners experiencing spark blow-out
  89. EVO XI Axles and EVO 8 Axles w/o ACD
  90. Help! Syncro Break-in?
  91. Which transfer case is stronger one with acd or not
  92. Building my drivetrain... Help me out please
  93. I wanna go Slimfan
  94. Which DV/BOV?
  95. Porting??
  96. Is the Intake Manifold support neccesary
  97. TurboXS downpipe & aftermarket o2 housing
  98. Drive shaft rattle?
  99. Is this the good eBay o2 housing?
  100. Is there any demand for a spring t bolt kit?
  101. t4 flange pt67 or gt37r
  102. Questions about Carbonetic Twin Clutch
  103. stroker build - how many hours?
  104. Check Engine Light Came on...?
  105. trans went out? or just linkage?
  106. Megan headers have confused me.
  107. new intercooler piping question
  108. I guess ACT Clutchs are known for lock outs. Can someone tell me why?
  109. compression and boost
  110. ETS Short Route vs. Stock Battery UICP
  111. Drivetrain related problem ? Help
  112. FS Exedy twin disc
  113. I just made 455 WHP on 93 oct w/ the FP Green
  114. what can I do with $11,000 ??
  115. Fuel Injectors?
  116. How to tell aftermarket cams??
  117. intercooler
  118. Modification sugestions
  119. Some Questions about my upgrades
  120. Oil Pres. drop on curves
  121. need a lil insight
  122. Po300 Finally Fixed For Me!!!
  123. Porting inside hole of O2 housing - good idea?
  124. Clutch bolts over torqued...what issues??
  125. need help with transmission fluid choice
  126. Redline MT90
  127. Ecedy Twin vs ACT Street - Clutch Life ??
  128. Has anyone changed out the rear diff bushings?
  129. Works Stealthback + no resonator on factory plumbing
  130. est track time?
  131. could this effect boost?
  132. IX 6speed tranny goes bad...! need help
  133. Help wanted!
  134. Just made a big purchase from AMS
  135. SRT-4 owner crossover to the dark side Q's??
  136. IX owners running megan test pipes?
  137. HELP Negative effects of Kevlar timing belt?
  138. Some Pictures of my Open Dump 02 Housing
  139. Shifter bushing kit questions
  140. Cams...stock? Normal wear?
  141. 2.4L stroker turbo AR and trim question.
  142. oil pressure for our cars????
  143. 20G with 10.5 Hotside
  144. Buschur cone filter?
  145. am i crazy jdm 9rs turbo (magnesium)
  146. Who else has a HTA 35r comming?
  147. Help!!! Buschur fr3065 or fullrace?
  148. afr question
  149. T.s. 3065?
  150. blew the motor...
  151. read my plugs
  152. My PCV valve keeps popping out of valve cover..Why?
  153. Most miles running 25+psi?
  154. Is this a sign of my clutch going out?
  155. intercooler
  156. Can't Decide
  157. Boost not holding
  158. Are there any negative affects on No Lift Shifting?
  159. Tranny shifting weird, is it my clutch?
  160. Tale of two 500 plus whp Evo 8's on the ICS AWD Dyno !
  161. Injen 3" Downpipe Question
  162. Bought a 2.3L Evo..incomplete list of mods, what should I check?/What next?
  163. HKS mivec cams installed tuned
  164. Custom intake manifold work "sneak peak"
  165. part throttle/acceleration problem
  166. pic request: stock shifter
  167. Any one ever test out a SS chrome WG?
  168. RRE "No Name" clutch experiences?
  169. Rear-Differential Needs Replacement
  170. Mixing Trannsmission Fluids OK? (MR Diaqueen w/others) Experts Help Please!
  171. Weird Noise
  172. Tranny Question
  173. Has anyone had this problem or know what it is?
  174. BIG problem Need Help!!!!
  175. Buschur Race Intercooler FMIC on Evo ix 9
  176. Direct port N2O kit (Pics inside)
  177. Greddy Ti-C Silencer Removal
  178. First problem ever with my EVO!!
  179. Advice on my setup I am getting PLEASE!!!
  180. any documented ported cyl head dyno compares / power gains?
  181. Boost Problem.....
  182. Cbrd + Jam =
  183. Anitilag (Exhaust Flame Shooter)
  184. Best place to purchase one step colder plugs for the IX
  185. Car won't boost at all...help
  186. FP Evo Green Track Results- after the 487 whp results
  187. Invidia o2 Housing and Lower Heatshield
  188. Good Intake? Cause i just broke the stock airbox
  189. Another Engine noise diagnosis thread.
  190. Time to start adding HP
  191. mbc installation
  192. Leaking gear oil between trans & TC
  193. $1000 for power mods?
  194. Transmission Help Please
  195. Installed Ebay intercooler today
  196. qtp downpipe
  197. Car DIED on way home lost all Spark..NEED HELP!
  198. how to get it more streetable
  199. attn. all intercooler engineers (Blitz vs. stock)
  200. Tightening spark plugs by hand...
  201. Looking for Intake Manifold Pics: stock and ported stock
  202. Evo IX fuelpump question
  203. Stock Differentals.
  204. Road Race Engineering Exhaust
  205. Should I go with Meth or cams?
  206. 16g turbo problems
  207. Oil lines?
  208. Lowest db, free-flowing exhaust? Vendors please chime in.
  209. Clutch Sticking and LOCKOUT!!! Whats the cause and how to FIX????
  210. 35R Buschur track results, and spark blow out
  211. Power with standard Exhaust?
  212. Need a little help hope u guys can help
  213. took off rear section BR ex- 20psi 2 step holy!
  214. Reasonable rate for a cam swap job?
  215. bleeding the clutch, no pedal pressure!
  216. Ted B's Dynosheet
  217. boost issue
  218. Hks cams Dyno by Import tuner
  219. ebay o2 housing??
  220. Clutch noise
  221. Soooo?? whatever happened to Buschur racings 50 trim???
  222. gains from fp green
  223. Spark plugs are too white!
  224. AMS 35 or 37?
  225. MT90 or 6speed tranny fluid????
  226. 5w 30 or 10w 50?
  227. Numbers/Times to Expect
  228. Would you trust this MBC?
  229. Need help on turbo option!
  230. What Gains for these mods?
  231. what is next for me????
  232. Exhaust Wrap? or no?
  233. HELP!!! problem w/ UNOS MBC!!!
  234. low rpm dip/stall #2 - help please
  235. clutch question maybe dumb one
  236. anyone whos done the 6 to 5 speed conversion...
  237. High Compression
  238. Turbo differences?
  239. Mitsu bolts
  240. Anyone else's '03 turbo whine?
  241. Ku Engineering intake manifold?
  242. engine boggin @ full boost???
  243. To those running high horsepower and stock MAF.
  244. Some of my Carnage this Year!
  245. WHat is the best turbo for 100 octane
  246. Whats wrong with my clutch?!
  247. CHeck Engine Light.
  248. The Greddy T67-25g Turbo?
  249. shifting woes
  250. Has anyone here used the Hondata intake mani gasket on their EVO???
