- My setup
- Vendors Who Sells Magnus Inatke Manifolds CHEAP
- Which exhaust combo?
- cam combination
- Tried searching with no luck..Need part #...
- IC Piping Diameter.. how it relates to power?
- GT3540R, pump gas, and stock cams...
- Which side does this gasket go on?
- The Ultimate Evo 8/9 Transmission Failure Survey
- RACE FUEL and BOOST
- green and 20 g LT the same?
- Good 02 housing?
- Cam question
- Problem with idling on a hill??
- Needed: Photo of coolant overflow bottle bracket
- flywheel comparison?
- Wheel speed sensor?
- How to remove throw out bearing from pressure plate?
- how much extra power can i put down with clutch and uicp?
- timing and cam R&R for 4b11
- Thanks FULL FUNCTION for 527 AWHP on Mustang Dyno
- IC Piping?
- Rear Diff/Mustache Bushing
- just a bit more power,....
- ATS triple carbon squeaking sound in startup
- How much power with my mods and what next??? please help!
- boost problem..Please read????????
- Evo IX MR diverter valve?
- Exedy twin...kinda problem..
- FP green turbo worth the price?
- HELP! Big oil leak and car doesn't want to start...
- Is a 20g worth it???
- Car was driven with the park brake on for a mile or so...
- lost 3rd gear.....
- Where to get the clear things on the end of the injectors?
- o2 sensor wire ripped!
- How to install Greddy type S bov on evo
- 384 Hp / 396 Tq 100 octane!
- Triple carbon clutch woes
- I just re-made 400 WHP on 93 oct @ 22 psi w/FP Green
- Is it ok to dyno in FWD mode?
- 362whp/363.77wtq pump gas Evo IX!
- Which way does the 4g63 engine spin?
- dc3 oil catch can the best out there?
- Recirculate or Atmospheric Dump?
- trans or tcase problems?????
- All You stroker guys..What is the best way to get 2.3 liters
- HKS bov bad for evo engine?
- IX turbo, boost dropping, then returning?
- HTA GT35R Dyno results right here!
- HTA3582r who has it....
- Question about Greddy BOV
- Any chance of an FP3065 HTA soon?
- Cosworth Evo 8 cams???
- Loud VibrationNoise
- 2.3l?????
- Slipping clutch Q
- over radiator intercooler piping ? !
- Random misfire occurs @ 6000 rpms, need help.
- WTB:Front Axle RIGHT SIDE
- Problems with clutch pedal to high?
- EVO9 JDM rear diffusers finished and ready
- Intake Manifold Flange
- 4.11 gear question
- Q45 throttle body?
- Noise after clutch install....what did I mess up?
- transfer case
- do i need injectors?
- exedy twin release bearing popout!
- Royal Purple Syncromax...
- question about revolver cams
- Help pls:3rd to 4th shift not working...
- Evo IX Performance Upgrades
- 1100whp or Bust! this Monday
- Not an evo but...
- Just had Exedy Twin installed, questions about pedal adjustment.
- Exhaust manifold....:(
- Is this the stock clutch kit? Or do I need to buy everything seperate?
- How to find out CC's of unknown injectors?
- A/F Ring Options?
- evo torque capabilities on stock block?
- PLEASE HELP: Serp. Belt Tensioner Broke
- Full-Race vertical FMIC with FP Green or stock turbo?
- Questions about Cusco clutch.
- Apexi GT Spec
- Longer Stroke + No Balance Shafts = ??? re: Vibration
- Next step
- EXTREEME NOON QUESTIONS!!!! (intake)
- ets fmic and uicp
- Fuel pressure??!!
- P0300 help!!! TUNERS READ!!
- Dumb ? on exhaust
- Intercooler spray!!!
- Which Clutch?
- Fmic
- tranny problems
- 6 hour turbo back install... need some advice
- My Exedy Twin Disk HD Review (From a Exedy Stage 1 to Stage 4)
- Need Tranny help!
- Started car with MAF disconnected
- any good??
- BR 3065 cast mani kit to Tubular mani conversion?
- Boston area shops for clutch install?
- can anyone help me get this part.
- Why we love mitsu motors... ouchie!
- 5 speed conversion kit?
- I gave it some power and...
- Compression numbers help
- Another satisfied customer with TT turbo kit
- Oil Pressure acting funky
- checking a turbo..
- quickest way to 20g?
- Head Problem Please Help!!!!!!!
- Head Studs...
- Couple drivetrain issues
- Turbo kit next in power after green?
- Tune with upper and lower IC pipes?
- Forge RS blowoff valve opinions/help
- Stock ECU swap
- blown trans or x-fer case?!?
- Confused about fuel lines...help!
- Buzzing noise
- Who is using an ETS turbo kit?
- GT35R & JDM MR recirculation valve
- ARC Super Titanium twin tail muffler/ exhaust
- Cosworth 272 IX Owners In Here Please
- GT35R perfect for a high 10 second street car?
- ECUScan Logs - Knock Question?
- What meth kit?
- Boost leak test need help??
- Grandmaster of Bling
- What Do I Need For A Clutch Install?
- CBRD Radiator Install...
- transfer case, diferential oils????
- TiAL 44MM Wastegate Question.
- Brian Crower 272 setup
- Driveshaft for the evo
- Weird ticking sound, Need Help!!!!
- need info on evo9 turbo
- WB in stock o2 location?
- Need Help car not boosting!!!
- Idle Issues With Intake
- Which Cams for Bigger Turbo?
- Garret turbo question
- anyone replaced timing belt?
- Turbo XS Type H Hybrid BOV
- high rpm problem??
- Oil Temp vrs Oil Press - do i need both? how do i interpret them?
- Tranny fluid.
- Fluctuating Boost?
- Magnetic fuel savers...
- AEM uego reads......
- Did I Damage Anything?
- Looking to get green turbo
- no power to front wheels? drivetrain issue?
- LEAN AFR - Possible Injector issues?
- How MucH boost on a GT35R w/ Meth & 93oct?
- Effective duration of Buschur Racing BF272 Cams?
- Transfer Case?
- Vibration in the car!!!(how to adjust the balance shaft?)
- Damn licp! Help
- Oil Pressure gauge??!!
- Which Spark Plugs?
- why do my plugs look like this????
- AMS Turbo
- speeed crazy
- Ticking noise after letting off throttle?
- MR Transmission Problems HELP!!
- Greddy bov flutter?
- AMS 6 Speed shifter bushing HELP!!!
- shifting problem
- twin scroll hype?
- BR3065R or AMS3076R
- 30 PSI with meth is TOO MUCH?
- The Great Dyno Equalizer
- Installed Buschur o2 housing/licp thoughts and feedback.
- Tilton or Exedy Twin disc?
- Weapon R Intake Manifold
- EVO9 Dyno Results - Pump vs Race
- how much boost
- My JAM 2.3 50-trim dyno at CBRD
- First ride in my HTA35R car
- Fujita Intake and UICP
- Good Clutch?
- Um yeah 2step not working
- Would dealer notice a reflash? Warranty claim?
- Big problems on my drive home, blown motor?
- Intake Manifold Upgrade
- When changing tranny, t-case, and diff fluids
- exedy question!
- HELP missfire problem
- HTA GT35R on an AMS kit!
- OMG!!! Just opened the air box...
- dp
- Dead battery....
- first time to drag strip tomorrow
- ets gt35 kit - needs vs wants
- end all 2.3 2.4 2.1 stroker big block thread
- My cam compare data
- Greddy Oil Cooler Kit
- Highest whp 2.0L EVO on 91?
- performance problems
- For those who have ported FP Green hotsides
- OKADA Plasma Direct Coils under review by TTP-Engineering!
- Got tuned today...340.6 hp!
- 16g to green PLEASE READ
- 2.3 gt37 what cam?
- Need help, car won't start after breaking Exhaust O2 sensor
- Hallman mbc boost problem....
- Best test pipe
- EvoGreen w/ 9.8 housing
- Engine clearances/tolerances
- Exhaust "ding" bell sound?
- Evo 8 service manual
- Couple of DP/Test Pipe/Sensor Install Questions
- How much power on stock injectors?
- Blowthrough Users
- Megan Racing Exhaust
- Help with clutch smell
- Strange clutch slip. Video
- has anyone swtich from a Non-DBB to DBB turbo?
- Cause of black spark plug electores
- Buschur Racing Intercooler ?
- arp head studs (yup im gonna pull the head)
- Evo 8 Mr Vs Evo 9 Turbo?????
- Exhaust Manifold ?
- Max Boost Level & Rpm
- RPS 6 Puck
- Safe Boost Level
- Max RPM rev limit??!!
- horse power numbers
- 600+ftlbs cars, please help choose a clutch
- RPM when cranking engine
- oil presure light
- 501whp 37r Ems Stock Block Ix!!!!
- what clutch and flywheel are you 6spd guys using
- 3rd to 4th problems????
- Finally found out what happened to the motor
- which clutch would be better for me
- EVO 9 HKS cam=hollow??
- Diagnose my in-cabin oil smell?
- transmission problems
- Ball Bearing Or Twin Scroll
- Read this about ALS, anything on the market for EVOs?
- Cam Position Sensor Harness Help
- diferences gsc 280 vs S1
- What CAM for a 2.3L with a 50Trim? Experts weigh in
- Replace stock "spring bolts"?
- Clutch gone?
- FIC 750 injector questions
