- Help with codes P0456 and P0401
- Oil squirters
- Largest cam on a stock ECU?
- Which turbo should I choose?
- HKS SSQV+ Condom...
- IX plugs?
- Anyone ever tried Brian Crower 272 cams?
- clutch replacement
- COBB Exhaust and Dyno Plot Video is here
- which dealer
- best turbo
- HKS ti-Carbon inner or outer diameter question
- Engine trouble
- misfire new spark plugs
- New E9 - Oil in Coolant (not Redline WW...)
- 50trim + 2.3L Dyno Numbers
- Fuel Injectors?
- Installed My Engine Damper
- Cylinder 3 over loaded with fuel - coming out exhaust unburned
- are these logs correct? It's gonna blow!
- What's the shelf life of Diaqueen gear oil?
- flange
- Clutch question
- header
- Post dyno charts on GT40R or GT42R.
- Stock Evo Oil filters...
- cant boost found the problem,type-s diaphragm torn
- lower i c pipe
- Clutch problem help!
- p0335 and p0340 help
- Tranny reinstall help: cant get up into bay
- Turbo Decision...3071r
- I think a valve is ticking.
- Transfercase Oil
- Cam question
- Can u use a Autometer A/R gauge for a Innovative Wide Band LC-1 ?
- New clutch installed now weird noise! HELP
- Please help with engine noise...
- Apexi Plug Wires
- Custom 35R? why not...
- OS Giken Twin Plate clutch
- 6 speed Issue
- Clutch line
- What exactly is a short block?
- What would white smoke mean pertaining to Air Fuel Ratio ?
- Aeromotive FPR
- What did I do wrong?
- boost taper..
- tire size & dyno numbers
- Evo 9 turbo install kit for Evo 8
- Next up, turbo upgrade. Need help choosing between GT30/GT35R.
- is my clutch slipping?
- Car falls on its face during boost
- E85 + tuned for 93 octane = boom?
- RNR Turbo Kit made POWER with a DynoFlash tune!!
- Challenge: Who has a solution to my stall problem??
- Clutch issue
- turbo question!!!
- Ticking?
- ACPT CF driveshaft ??
- 37r question
- transfer case
- Quick question on the 3065
- New Set Up What Will I Make Whp??????
- cry about puck clutches.....
- my power curve...** :) **
- Anyone have experience w/ VP "Q16"
- Need advice on a problem.
- FPgreen or Full Race 30R twinscroll or other?
- Whine in 1st gear
- Rotational noise and vibration
- 2nd gear prob's!!!
- 480's-500+ whp?
- Could front drive axle be going bad?
- Wondering what the differences in the a/r and the hot side a/r (Ibelieve) are ?
- Hollow out HFC?
- Where to buy GM MAF blow through kit ?
- So i went over to Extreme Turbo Systems today( Wife not knowing)
- Jdm Oem Map Sensor
- Pure Tuning Evo IX Cosworth Cams Dyno Test
- Smoke on left turns only?
- Huge boost leak!
- Which Boost Controller is BEST?
- Looking to go with Speed Density Set up anyone know where to find ?
- Help please.......ABS/Speed Sensor help
- To all GT35r turbo owners
- sitting for 3 months, bad gas?
- Fuel Pump Noise...
- test pipe vs stock cat??
- Question for those running aftermarket intake manifolds.
- SWITZER TUNED EvoGreen, E85, 439HP/454TQ
- need some info on clutch upgrade
- Brian Crower IX cams, anyone?
- HEEEEEllllllllppppppppppp the mechanic is working on the car right now... HEEEEEELLPP
- exedy twin disc...i hate it
- Exedy twin HD Installed
- Rod bolts to instal or not to instal?
- emissions question???
- Q. for anyone w/ buschur moustache bar
- HFC....Any quieter?
- HELP code p0355 and p0340
- help on engine build
- SES light "E" - code (shift solenoid)
- AMS recommended Redline, i'm a bit worried....
- Best Buschur mod...new bullet muffler with a Magnaflow
- Air/Fuel Ratio
- 20GLT (fpgreen) dyno sheet from this weekend at Buschur Racing
- Which 35R Kit is Best? !!Make Money No Issue!!
- Oil cooler lines
- Looking for Tuner in RI anyone know of anyone ?
- Y-Block Location for Parallel Fuel Systems??
- code P0505
- new studs and gasket
- 810awhp on Superflow Dyno
- need help choosign a exhaust
- blown turbo......looking to upgrade
- Help out a Soon to be evo owner!!
- BOV/DV question..
- need advice on what to do next
- Power Steering Fluid??
- Royal purple to cause damage to T-Case?
- HELP! Stroker with a Lifter tap
- Exhaust Choices
- Can sum1 Explain ETS H Cover Turbo Kit ?
- ISP Racing 35R Kit anyone have any Input ??
- hks hipower and helix dp
- *It's Installed...ETS 50-Trim*
- Damaged front diff autocrossing?
- What can a 2.4 engine really be reved up to without failing.
- white smoke
- Can't hold boost!!!
- Void Warrenty?
- HKS EVC V Help
- Buschur 35r lag video........
- turbo, evacuate! evacuate!
- HELP!!! Evo is not boosting.
- Upper Intercooler pipe.
- Works Short Throw, anyone using it?
- 35R at 26psi on stock block
- P0171, bank 1 lean
- EVO IX redyno 364whp new run 12.1@113
- Cold start idle issue
- 5th gear grinding????
- Blitz SBC on stock evo?
- safe a/f
- valve cover ? v. powdercoat
- questions after manifold and 02 install
- Car sputtering and breaking up in between shifts
- Buschur Magnaflow?
- Car idle problem *HELP*
- Oil light / knocking question. looking for opinions
- Should I stop shifting 5th gear???HELP
- aftermarket trottle body with stock ecu
- lost all boost is drivng safe until fixed?
- Help EVO ticking like crazy!! PLS Help
- FP Green install questions
- Hesitation
- How to drain all the Transfer Case Fluid out?
- White smoke after WOT lift off
- jun 272 or tomei 270
- Find turbo peak efficiency?
- aftermarket lifters?
- another pump not priming
- Which option to retain power?
- EVO IX - Ivey Re-Tuned for HKS Cams
- DC Sports exhaust manifold cracked
- SSAutochrome's internal wastegate o2 housing dump.
- another turbo down?
- Boost problems after reflash
- Average downtime from BR for mail-in flash..
- Christmas in october..
- I want to run a antilag setup on my evo 9, what do I need?
- Water Overlow
- Boost problems
- What is the safest way to start a new engine?
- Forged High Compression Pistons in 4g63T do able ? and worth while ?
- 4g63 Block; 4g64 Crank; High Comp. Pistons ?
- Intake questions for '03 Evo
- Is there a specific FP turbo that out performs a diff. FP turbo
- 4g64 Crank and Stock 4g63T Block good combo ?
- Hondata Heat Shield
- same clutch on 5 and 6 speed?
- best "street" set-up?
- 2nd gear lockout
- Oil Change? Octane Boost?
- 1014.53WHP! & Learned the limits on Twin Scroll Exhaust Housing
- Couple of stock block FULL FUNCTION EVO's and a 2G DSM
- DC Sports Cat-Back
- Hard starting and I smell gas!
- Tilton Clutch causing wheel hop?
- High Oil Pressure, Help!!!!
- Modding opinions before purchase?
- HELP!! oil light came on
- I opened my cam gear cover and i saw....
- APEXi AVC-R questions
- Installed new clutch now I have ?s
- Springs and Retainers?
- intake dilemma
- AMS mini radiator weight w/ fan?
- Buschur Exhaust?
- 690AWHP@30psi
- Greddy Type-S Leak
- HELP fuel injectors not sealing at fuel rail
- Low octane, stock consequences
- Built motor time---> pics inside (56k no way)
- Any one look into the Forced Performance GT3082R Ballistic Concepts Turbo
- Evo V rack & pinion
- AMS has changed the Drag car yet again
- turbo needs
- is it common?
- Is this Worth it? Intake question
- wtb ac or pass seat
- New parts install.
- IGR7A-G vs BPR7EIX
- Can someone explain clipping a turbo?
- Dyno Tales: EVO8 351hp/354hp on pump (stock cams)!
- injecters help
- FP Green Turbo versus FP Red Turbo
- cam inatall IX how knows how
- Which stainless clutch line did you go with?
- vacuum loss at idle after LICP/UICP install
- Anyone ever look into water to air intercooling ?
- Im finally 100% satisfied with my evo...
- Hks rail off Ebay i think its not for Evo
- Need help! overboosting!
- turbo swap VIII to a IX
- Highest trap speed from FP Green on stock longblock and ECU???
- Front O2 sensor - Did it change from 8 to 9?
- lots of noob questions. intake bov ect.
- Evo 8 Head and ECU swap with Evo 9
- Buschur Racing's black EVO with new dyno record just in time for shootout.
- ethanol and high compression
- A reasonable clutch for a daily driven evo 8.
- For those with Exedy twin disc HD
- Release of Oliver's new, stronger rods.....
- Greddy Profec A/ Question?
- Best Shifter Lube
- Beware Of Garbage Gasoline
- Which UICP works with ARC induction box?
- Coolant leak? Advice appreciated
- QTP Downpipe, short review
- ralliart clutch??
- Balance shaft removal how to?
- evo ix boost ?
- My setup
- Vendors Who Sells Magnus Inatke Manifolds CHEAP
- Which exhaust combo?
- cam combination
