- VTA BOV with HKS EIDS...who has this set up?any problems?
- A/F @ Idle to high?
- Possiably getting MIVEC cams for Evo 9
- Green or 35R
- E85 tuning
- FP green question
- Quick HKS cam question.
- HKS mivec cams
- Flywheel bolts
- which throttle body to go with
- 3rd Gear Lockout
- Engine Tapping
- Question about Forge WG Actuator
- oil sensor problem
- Fuel Pressure....
- Turbo XS Hard Pipe Kit question
- drivetrain problem.. help...
- Question about altitude and octane
- Wintertime Tranny Fluid mixes.
- guys who installed LC-1
- looking into buying a evo
- Launch - Wheel Hop - Whining Noise - Gear Oil Leak
- Is this Exedy clutch any good?
- banging gears
- Two quick questions
- Cost of clutch replacement?
- yeah change my spark plugs and the code changes
- Gears Grind and Adjusting the Clutch Pedal Does Nothing??
- Stock Turbo Efficiency by Redline
- Exedy Twin Plate Adjustment help!
- Exhaust HP gains-
- Taller 5th gear
- which turbo, help me decide
- Quick Cam install & Tune Question
- Some information I need confirmation on...? (boost/drivetrain)
- fuel pump
- A/F Question
- Oil Temp (normal driving)
- clutch problem
- How to check if LSD is installed
- Strange noise coming from belts.
- Header
- Normal Blowby ????????
- Ok Ive done it this time
- Bov???
- HTA 35r, new power gains and the quest for 150 mph trap speeds.
- When to use a Fuel press or water temp gauge?
- aftermarket turbo-back exhaust w/ converter???
- F-450 Turbo slapped on a turbo?!!
- Stock Intercooler Coupler Size?
- Weird shifting from 1st->2nd->3rd...
- tranny issue
- Help me understand this boostcreep problem
- Used quaife lsd?? Anyone have experience?
- EVO Green Options/Questions
- Boost issue after installing Injen intake/UICP/LICP
- Quickest way to 400hp
- check engine
- what is max boost?
- Installed Hallman Pro RX MBC
- help with install urgent!!!!!!!!!
- So I thought my engine blew - another lesson learned
- Opinion on the T3/T67 H.O BB
- OCTANE horsepower translation thread
- clutch install problem??
- logging on to evoscan makes my car run crapy!
- Forced Performance Turbo Install Kit
- surging? boost problem?
- clutch about to go out?
- Uicp
- Clutch???????
- Having your cake and eating it too...quiet, but performance exhaust.
- Clutch
- What LICP???
- Simple answer? Oil Loss 1 qt/ 500 miles. BAD BLOWBY?
- Has Forcedperformance been returning peoples calls?
- Time for cams!
- Expected HP for Turbo Setup /w my mods?
- FP Green Turbine Housing pictures?
- clutch
- looking to buy stock evo 9 turbo
- Few questions Im a noobie
- Witch one should I get?
- my idle is weird
- Cheapest Exedy twin-disk install EVER!
- My Zex Nitrous setup
- Turbo Smart E-Boost 2 Help
- injector size for e85? and how to do a double pump setup?
- Dual Walbro 800hp Fuel System Question for a GT40r
- FP Evo Green HP 18psi Preload
- Sticking clutch pedal..
- I think this would be a sweet intake setup......
- exedy lockout help, already searched...
- Need QuicK answer...
- slipping clutch
- FP Turbo Install kit
- Transmission issue?
- Reverse popping out of gear.
- Fastest Spooling Turbo??
- New Turbo Help
- Exedy Tech Support?
- smoke out of the exhaust?
- Ding Dong the clutch is dead!!
- new turbo
- Please help!! TBE install as we speak!!
- Vibration in Gas Pedal, Rough Clutch
- E-bay intercooler kit! what do you think about that?
- Estimated Power?
- What exactly is P0401
- Ok. I'm stumped. Ignition help needed please
- FP White Rabbit or EVO IX Turbo
- were do I get replacment parts for a exedy twin disc
- to those using exedy twin disc HD
- Anybody do ARP rod bolt "Upgrade" stage 5 Buschur
- AEM Tru-Boost Install Instructions
- evo 8 10.5 vs evo 9 turbo
- Turbo XS Downpipe with aftermarket O2 housing
- Max power on GT4294R?
- How much boost??
- detonation hitting the rev limiter?
- ebay intercooler
- 5th/6th Gear Syncro or Clutch Adjustment?
- Quietest Evo Exhaust ????? WithOut Loosin Power
- Oil leak from dead center of car.
- blwon turbo....removing oil from intercooler?
- Front O2 sensor
- 30R dyno results
- Clutch is slipping, got a couple questions about the replacement.
- Question.
- low boost help
- need service manual ASAP!
- Buschur Lightweight Center Member Installed!!!
- Turbo Upgrade Questions
- Anybody have info on the evored?
- Car runs bad after cams
- Issues
- Missfire, please help
- Expertise help need please
- HKS BOV & ETS UICP flange match-up
- backfire while spooling
- Clutch "whispering"
- FP HTA 67 - aka HTA 37R - anyone know anything
- Better then 272 cams? need help
- MAFT pro OR AEM ems to run METH
- Which Turbo will spool faster ...
- Looking For A Specific Thread...help Please
- ss Braided line setups (need info)
- Help deciding on an intake/filter combo
- Ebay o2 housing
- How much boost
- Wastegate adjustment?
- Power Steering Fluid???
- stock turbo seems laggy
- 14 psi stock?
- turbo oil system
- Aluminum VS Carbonfiber Driveshaft
- quick ?
- what flange
- Zeitronix will not log anything!
- Ebay Radiators anyone used one ??????
- Cold Side Intercooler Piping idea to shorten it up a lot !!
- pistons and rods
- Scatter Shield
- Boost Creep or not?
- how much boost on stock headgaskets and bolts?
- US Evo9 turbo vs UK evo9,(EVO400)turbo and there green????????????/
- removing trans ?'s
- Balance Shaft Delete
- Possible Major Problem Insight Welcome
- 8.5:1 vs 9.0:1 Pistons differences
- Misfire under load
- no boost! help!
- FP Green and Me....the 1,000,001 thread...
- Any difference between 05 and 06 rear differential?
- HKS3037S vs FPGT35R ???
- Fuel Pump Resistor?
- Forge Adjustable Wastegate Actuator
- Performance ?'s advice/suggestions please
- Improving knock resistance?
- ECU memory retention question
- Video of COBB AccessPORT EVO 8/9 install
- ARP bolts on Eagle rods
- What to do next???
- Extreme Turbo Systems
- timing belt???
- Need FMIC selection advice
- 6 spd best place to mount a temp probe
- Stealthy Place to Mount an EVC Stepper Motor
- Ignition system problem. NO SPARK=NO START
- fuel filter? Where is it.
- Rear drive shaft removal
- Evo 9 head bolts and head gasket on evo 8
- new car hole in my intake manifold help!!!
- FP White Rabbit turbo
- Biggest Turbo to Purchase?
- Water temp ques.
- Poor gas mileage
- Engine wiring harness. 2005 VIII RS.
- Boosting to High?
- buschur twin walbros pump
- Car surging @ 4K RPMS Bad MAF????
- Mynes Performance Top Mount TS 35R/40R Kit
- HELP! running spacer/different offset can break diff!!???
- Evo Viii Pistons On A 2g 4g63, will it fit?
- couple P0134 code questions
- Fuel pump questions...
- turbo xs
- Evo 8 Turbos
- How much does the 3-Speed Scarrter shield weigh?
- Limiting factor in setting boost?
- Strange noises in rain? and gas mileage after Walbro 255
- HKS GD Max Clutch
- inj sizes for fp green
- Upgraded OEM Turbo
- some one direct me to evo performance..
- Clutch for 35R setup
- Anyone running a T3 37R (T3 67mm)?
- Boost Pill or Boost Controller?
- Mad boost leak and it's still stock
- EVO9 Turbo or Cams next?
- Is this a evo green turbo?
- Is there anything else???
- Exedy Twin Rebuild where?
- Another FPgreen Tuned by The Shop
- need help
- just switched from hfc to testpipe
- Drivetrain fluids
- Basic 8 and 9 question.
- 426whp/445wtq on stock IX turbo
- Full Race Manifold on Evogreen IX - Yes or No?
- Problem with Timing belt
- MR Tranny Help
- Looking for a: FP Green
- COBB turbo back sound clip and dyno plot
- Apexi AVC-R vs. any MBC
- hollowed out catalytic converter
- More Power On My Evo 9 MR w/ Stock Turbo and 91 Octane
- Quick Camshaft Install Questions
- Hypothetically, if i slipped a tooth on my crank pulley...
- death whine? or tranny gone bad? help.
- Quick power question.
- Stock Evo 9 throttle size??
- Tilton Twin Disk Question...
- ix turbo install w/ out tune
- ETS Turbo Kit never look so SEXY!
- Engine cooling for track use
- cam crank codes
- MAF cleaning
- Fitment of the ARC Ti IC Piping?
- Why wont Comp. read Innovative Wideband ?
