- evo8 vs. evo9 w/g actuator differences?
- Stock fuel pressure?
- Wierd noise after cam install........
- Stock Coil Pack Pictures any one??? I REALLY need this ASAP
- Single Puck/Dual Puck Turbo???
- Happy Turbo Day Everyone!!!
- Boost
- Boost right?
- Does anyone user Borg Warner?
- stock airbox vs aftermarket intake
- Loud Popping noise in my exhaust (Backfire?) NEED HELP!! I just installed parts
- Exedy Stage 2 Cerametallic Clutch Kit
- 20G O2 Housing
- Buschur vs AMS bushings
- Turbo XS type H34 recirc valve issues
- FP's W/G actuator setting link for fp-grn?
- Buschur's new tires/wheels, going for a new best ET/MPH
- gt35r motor internal build suggestions
- Motec ACD Controller = AWESOME
- The Phenomenon of Lifting the Head
- need your opinion on this
- FP Green vs FQ400
- Engine problem... Please read
- buschur fp3065
- Edge racing resonated Test pipe
- My idea for the "Red" turbo
- Weight of Cams
- Working with Extreme Turbo Systems and English Racing on my goals of 8s and 1100whp.
- GSC S1's or Cosworth 272?
- meth kit installed under hood?
- ACT Street Disc
- ACT Street Disc
- Install Pics of 04' VIII RS w/ Buschur Parts
- turbo
- wheres the best place to get a BARE evo 9 block?
- ix turbo or fp green
- Misfire problem
- HELP:Swaping turbo will give me gains?(video inside 12.2 in 1/4mile)
- e-01... tbe... idc! im TURNING IT UP!
- Upgrade Thoughts
- Best stock turbo replacement?
- suitable inner cv joint boot replacement
- need fast answer on tranny fluid
- what kinda leak might this be?
- JVTR Intercooler?
- Once Again......avoid Valero Gas Stations......they Are Robbing Us.
- Agency Power 50-trim
- What next?
- 264/272 HKS cam timing for best emissions results
- How to store and use E85/Ethanol
- how to get E85 near you!
- Flow comparison
- Bosch 044 Noise
- Weird Misfire
- How much boost am i able to run?
- I installed cams and ARP head studs and now I have a big oil leak.. HELP PLEASE!!!
- Please help oil leak!!!!
- Engine and turbo build need opinions
- Titanium catback heatwrap
- okay car shut off
- Propeller Shaft noise under Decelaretion??
- Well, I'm pretty sure my Tilton is slipping.
- How to turn crank to TDC?
- EGR Valve
- Getting ready to add nitrous. Have a Q
- 6,7,8, & 9 transmission?
- something's not right...
- Unknown Aftermarket Gasket
- cams and smog
- Over Dimensions on Half Size Radiator anyone help me out.
- question on the 42r
- When is it time to get intercooler?
- How do you know the ECU was reflashed?
- Help with emissions test in Denver
- New record for pump gas, set with the HTA35r
- anyone ever use?
- Fuel Trim Bank 1 Error Code
- Power question...please help
- Milti cylinder missfire error code?
- titanium downpipes
- E85 + 100% meth???
- how can you tell if a turbo is bad?
- Tilton or Exedy
- gt35 kit, need input
- Forge RS Adjustable...Car acts weird on 5th gear...
- Going for the EVO Green
- K&N Testing Site
- Are Boost Leaks Fixable?
- custom gt35r...whats your opinion?
- new to evolution scene
- custom downpipe for garrett turbo
- 459whp/394wtq with EvoGreen on E85! (Dyno Sheet inside)
- throttle plate sticking on high boost > 2 bar
- who runs eagle rods?
- Transfer Case Help
- EVO IX MR 6-speed Oil Additives?
- Driveshaft help/advice
- Boost Leak from Throttle Body?
- Direct Exhaust Injection
- Want to replace recirc valve, which one would perform better?
- Thinking of a cam change... opinions?
- Cam Cards?
- 3rd gear grind?
- Front Axles
- general question on the evo8 dv
- Any one make their own cam install tensioner tool? PLEASE HELP
- will ams manifold work with BR FPHTA35R
- 600hp Peakboost GT37R
- Shifter issue. IX MR
- new piston idea
- Rev limiter as shift indicator?
- My EvoIX goes into limp mode...
- Clutch/Flywheel weight combos...compared to
- *clunk* after vibrating clutch pedal
- spoolup comparison, 35r, 30r 3076, 50trim, green, evo9, evo8
- Best Cams for a 2.3 stroked GT35R car
- HKS Reloaded vs. HKS RS Filter Replacement
- DNP Stock turbo Manifold
- downpipe question
- 10psi 1st/2nd gear....30++++psi 3/4/5th gear. HELP!
- After I stopped I heard a unique wierd noise, Please help.
- Does this accessory belt look normal to you?
- where 2 get + ternimal fuse
- what size cam to get?
- turbo rpm
- Evo stutters. More info inside. Help
- where goes engine oil travel in order?
- Air temp & MAP sensor questions
- When does the factory un-ported head cause a restriction?
- ?'s about O-ringing head/block
- Problem With A Mod
- So whats the trick? Oil pump sproket bolt w/race balance shaft.
- engine sputtering at high rpms (in boost)
- 6 years of being an evo owner..AND..still confused...CLUTCH HELP please?
- cam break in period?
- best shortshifter???
- fuel pressure regulator?s
- 20G-LT in the 10s w/ meth
- The end all thread of clutch rebuilds!
- motor heads only
- Wideband Users: what AFRs are you seeing during h/w cruising?
- solution to exedy single clutch chatter?!?
- Save 300$ Read this!.
- Green's in the 10's
- new clutch fixed my random misfire codes
- Do i need to upgrade the clutch?
- Another ACT clutch problem.
- WOW!!! I recieved my Green within 10 days of ordering!!!!
- intake manifold removal
- how much did you guys pay ?
- Swapped 6 speed to 5 speed and having problems (PICS)
- Front A/C fan removal?
- Getting Tranny Rebuild What's The Best Gearing?
- Cuts out, need help please.
- Blow By System (GM MAF) Questions and who is running it??? PLEASE ANSWER!!!
- Evo IX spark plugs
- Stroker or Stroked short block?
- 0300 misfire code
- Need Help Immediately!
- Gauge Dilemma, dont know what to buy....
- arp headstuds
- List of MR Owners who has switched to 5 Speed
- PeakBoost HVS topmount 37R on E85 only!
- gas octane questions
- Camshaft effects on cylinder pressure and ignition timing
- 2.0 or 2.3 better?
- ETS, TURBO XS, Weapon R Intercooler Pipes !
- ets or ams fmic...
- My new parts list
- P0125
- It started with tapping for egt...
- cold weather boost!!!
- possible failing water pump
- synchro fluid
- buschur log manifold gasket matched?
- injen intake filter size?
- fluid change
- need help!!!!!
- Tranny Swap--> Am I missing Something
- What's wrong with my tranny/clutch?
- new build...opinions?
- Muse Motorsports Manifold
- Idle Fix
- Walbro 255 Fuel pump
- Has anyone swapped from an ACD TC to a NON ACD?
- Evo 8 won't pass Emissions/smog test.
- Stroker & turbo question
- Future Mods? But what?
- weird issue with my wife's Evo IX
- Coil Packs Won't Fully Reseat on New Denso Spark Plugs
- How is your 2 step launch limiter set-up?
- need help with my 2.3 build
- My Vacuum line Saga/Project
- toluene
- Shift Linkage? Lemon?
- Injector Fitment
- Fujitsubo Exhuast
- Valvetrain Spring Compressor
- coils?
- suggestions on Forged and Forced Performance heavy duty wastegate actuators
- My Zeitronix 2.3 logs!
- 27psi race gas tune on stock headbolts question.
- ACT Clutch Pricing going up December 1st 2007
- Cheap belts
- oem piston hp capability?
- I can hear whining somehwere in my engine....could it be TC?
- EVO MR 6-speed short shifter???
- Need answer PLEASE!
- clutch related?
- torque specs?
- aftermarket exhaust
- 400hp? Advice on how to get there...
- Upgrading Turbo .. CAM ideas please?
- Shift Linkage??
- brake / batt light? flicker?
- Evo ix backfiring??
- ugrading injectors
- When car gets toward full boost i lose power abruptly...
- Look what came out of my differential
- Anyone know What manifold This Is?
- CEL Fix Installed and Still SES Light on...
- Do dyno #'s lie?
- Why stock head bolts are not good for 30+ psi
- Help!!!! No Boost?
- New mods? Will they help? Please?
- Anyone tried the Clutchmaster twin plate clutch?
- 10.8 @WOT sigh
- IX Turbo ?
- Oil Additives
- Evo VIII vs. Evo IX Exhaust
- Need clutch opinion....
- !!ETS 61mm Tuned!!
- Valve Springs?
- Q about cam sizes
- Clutch
- Cosworth cams
- 650whp goal?!
- eibach valve springs?
- PVC Cap For Boost Leak Tester
- Cam Install Tips?
- BC 2.4L Evos...
- Flywheel inspection cover
- car wont start
- Evo 9 SE upgrades
- Evo 8 24k miles and I blew my stock motor?
- To cam or not to cam?
- VTA BOV with HKS EIDS...who has this set up?any problems?
- A/F @ Idle to high?
- Possiably getting MIVEC cams for Evo 9
