- 10.5 vs Evo9 Turbo vs 20G vs EvoGreen
- Cusco/Exedy Twin help finding a part
- Magnaflow Exhaust on my Evo8
- Buschur Guys
- HELP>>> My Idle went up then go down and it almost stall......
- MR owners question!
- bad sound from motor
- Need Help from anyone with a 35R
- Hearing a noise at idle...
- Uk GSC S2's on Stock Turbo Result
- 579 HP Stock Motor Daily Driver
- Car is running weird
- What should I buy to run 11s by the next 2 weeks?
- Tranny whine in 1st gear only
- Gt35r???
- Running rich as hell 10.0????
- Ignition is out... Any ideas?
- Rattling & Vibration from TC
- MAF adapter question. Need answers quick
- Looking for people I've tuned for some information.............
- boost lost top of 3rd gear need help
- boost problems..HELP!!
- Dynoed brog warner 362
- ACD fluid level
- bad engine codes
- VSS (Vehicle Speed Sensor)
- Stock rods??
- I might have a few issues
- motor build questions
- Fidanza 3.2 Clutch / Flywheel
- Am I crazy?
- Stay AWAY from Greddy turbo kits.
- Gauging Interest - GTSPEC 3" HF Cat
- Turbo removal
- Video of last night ProccoEvo
- fullrace 30r advise on intake
- problem when flooring the gas pedal.
- look what i got so far!!!
- How much more whp using meth?
- Do I need a Fuel Pump
- megan o2 with pics
- Balance Shaft removal = PO300???
- test pipe flanges
- What did you guys pay...
- White Smoke!!! What are you!?
- Bearing wear?
- Downpipe problems
- Mis-Fire
- Do You Guys/Gals no What this might be??
- Clutch Stop
- A tenth in the sixty foot worth two tenths in the quarter?
- A different video of the BR "BAD BISH" 9.6 @ 151mph w/ Time Slip *COME CHECK IT OUT*
- need help with boost leak
- Vendors! Does anyone have a 156mm rod in stock?
- Odd thing happened while driving
- High oil pressure
- What Intercooler??
- What Cams For Faster Spool??
- mobil 1 for transmission oil?
- ok so im buying a gt35...what am i gonna need?
- Drivetrain fluid change intervals when tracking car
- How good is the Megan Racing EVO Turbo Back Exhaust System
- **Help Me Pinpoint My Idle Surge Problem**
- what are restrictor pills?
- Exhaust studs
- confused about fluidampr
- 893 awhp & 646 awtq Titan Procco Evo 8 !!!
- Going for 900whp this Week!!! Pics Inside!!!
- ATP Turbo Kit
- Question About Taking Apart Br Tubular Header!!!
- Reflash, Green, 2 liters and 507 ft lbs/443 whp..
- HELP! Major Acceleration issues!
- Drive train question
- Different Styles of Lower Intercooler Pipe, which is best?
- Miss firing in multiple cyclinders
- Exhaust Manifold install sequence (tightening nuts)
- few questions
- Stock O2 sensor replacement alternatives?
- solid cams?
- turbo swap complete something is really wronge with car i need your help
- Best oil for Transfer case and Tranny
- Car problems... bucks and flutters?
- flywheel????
- More Power and Torque for OKIX's 20G-LT..
- uicp issues..
- Top mount turbo with MAF sensor?
- My TC whine video
- please help
- Shockproof + Amsoil cocktail in 6-speed gearbox
- Redline Oil Vs. OEM
- Stock oil cooler?
- Will An OEM Evo 8 Timing Belt Fit An Evo 9?
- Read Differential of Tansfer Case?? Whining!
- Service Engine Light On
- David Buschur's BADBISH 9.6@151mph *VIDEO*
- help hks ti carbon ex.
- Is this ATS twin carbon any good?
- can sombody help me
- Timing Belt Replacement Price?
- Invidia Turbo Outlet
- fluttering at part throttle sometimes
- DB gauge Innovate not accurate????
- LICP and FMIC compatibility
- My goal has been achieved......one very BADBISH
- I just reinstalled my intake and now my clutch is bad..
- EGR removal w/ aftermarket intake manifold
- ets intercooler fitment problems??
- What spring are you running on your Tial External Waste gate? Tial BOV?
- Serpentine belt replacement...how??
- poping sputter sounds (please read)
- Build!!! What else am I forgetting?
- T67 vs GT35R vs ETS turbo kit
- P0401
- ats or exedy
- Fidanza Cam Gears - Which direction +-
- HKS SSQV Ver. 3
- Weird noise, need HELP ASAP!!!
- transfer case when doing clutch
- i need help i cant get exhaust mani off to do turbo swap
- Serious Help w/ Timing Belt
- Clutch Problem
- Tranny Noises on my MR -- is it death whine?
- Who runs Open Dump Tube off of your external wastegate? Experiences?
- question about turbo
- Under hood shifter buashing help for MR ?
- Do HKS 280/272 cams require upgraded valvetrain?
- Erratic idle that will reset with ignition off/on, then go bad again
- Anyone ever use an ACT PP with stock disc?
- evomotos guide clutch swap need help!!!
- What's Next After You Outrun Your Walbro Drop-In??
- Car Feels incredibly slow - Can't hear Turbo Spool
- ecu cutting boost?
- Newbie ? - How to adjust Cam gear timing?
- Grinding noise when turn and slowing down
- best downpipe and turbo outlet?
- ets,ams,blitz
- TBE with test pipe only mod with no tune?
- Agency Power DP
- Drop-in replacement turbo options
- is it a 20G wheel? or a Green wheel?
- So un-decided on what I want next....
- Tranny sound at 75mph
- tranny code???
- Cams, Knocking, RPM, Oh my..
- buschur intake pipe and filter
- Grinding 2nd, some 3rd, and 5th gear.... at 13k miles
- Please help!!!Race Car)
- GT35R Spoolup Answers (part 2)
- loud noise car dies??
- ratchet shifter
- which on line shop for the 20g titanium turbo evo 9 bolt on?
- Your thoughts on this.
- greddy timing belts?
- clutch swap...
- problems
- jus frustrated about this clutch n need to vent
- gear oil spewing from some hole in tranny in left wheel well
- Anyone Running Vishnu Stage Subzero?
- 20G turbo not boosting more the 18 psi help???
- starting problem
- A discussion about fuel systems and limitations
- Over Boosting
- need new clutch soon
- trans remove
- VEI gauges?!? Anyone used these??
- EVO Green vs GT3071R
- Evo IX and BOV
- Engine break in article:
- I had a nice weekend. Here are some pics!
- HTA35R-700whp/646ft lbs......Buschur RS
- Question about acd
- anti-lag
- Threw a new code today: P0113 - Intake Air Temperature Circuit High Input
- Exedy stg1 and gruppe s flywheel review?
- just installed megan turboback
- GSC S1 cams dyno
- HKS VS. Sun Ignition modules.
- Fluids changed, now shuddering on left turns?
- Engine Startup Grind???
- down pipe on evo 9
- around What WHP am i at?
- Evo/GT35R/Stock engine?
- any experience with HBX intercoolers...
- base idle set screw (BISS)
- HTA35R drivablity
- forcefed catback exhaust?
- Are there any good electronic boost controllers?
- Okada Project Coil packs
- What are the best cam gears?
- Helix Parts
- Inconsistent shifting quality in 5-speed?
- Weird engine noise (chug-chug-chug)
- Misfire codes at idle - narrowing it down
- 20g evo9 turbo
- Apexi induction box modify
- Prostreet Cam gears - STAY AWAY -
- Buschur TBE off a VIII fit a IX????
- Anyone running a t3 stageV wheel?
- Cam Suggestions gt-35r stock 2.0
- Castrol Syntorque 75/85
- Is this clutch shot?
- Cams and Turbo question
- 6 spd. Tranny Tech...Gurus Look
- ??boost??
- Problem Clocking Turbo
- valentine 1
- blinder laser
- tilton vs exedy vs cusco
- how long does your Clutch Masters clutch last
- Tranny Fluid Question
- Leaking Head Gasket
- Changing stock 9 turbo to 9.8 hotside
- 350whp with good driveability (Parts list inside)
- I know this has been discussed but I"M FED UP W/ MY ACT CLUTCH!
- Worst Experience Ever... Advice???
- cobb EVO access port
- 500 + HP daily driver
- Hp/Tq Capability with these mods?
- JMF Sheet Metal Intake Manifold
- 2.4 & HTA 35R - track time + boost graph
- new head gasket
- Gear Lockout?
- Need some turbo help
- Need help with clutch
- need help on cam install
- Does anyone regret having stroker?
- Evos acting wierd an i need help :( battery problems
- 4G64 block questions
- Fuel Cell???
- New Polished rail fuel...
- Ported, Coated exhaust manifold - Beads of melted Metal??
- car idling at 10.0????
- Brad Penn Oil
- Anyone have the FP Green In Stock?
- Buschur Mustache Bar installed!!!!
- what's Evo's stock boost pressure....
- Car wont start after motor went back in
- What Injectors For A 50 Trim
- Which 30r?
- Clicking noise from the engine?
- Clutch
- TBE, MBC, stock airbox on 91 dyno
- Domestic guy needs your help
- Exedy Twin question
- cam gears on stock cams?
- hks type r
- Evo 1 rear differential
- ATP turbo kit on an IX- impressions please
- HTA & Twin-Scroll
- Whining Noise w/ Video Clip
