- clutch went out tonight
- ACT clutch disengagment problems HELP what 2 adjust
- Question Guys
- AEM Intake vs Apexi
- 680 Inj On 3065
- Quartermaster or exedy twin disc clutch?
- Nisei street IC + ETS UICP
- does anybody have a blown mivec head?
- arp head studs torque?
- Headgames ported my HTA35R you must see it!
- banjo bolt from feedline on head
- Look at this guys!
- AMS 2.3RR + Full Race 3076 TS Kit = faster than stock spool?
- Quest for more power 3" exhaust vs 3.5" exhaust
- Brian Crower Cams - How do they compare to cams twice the price???
- engine stalling when shifting to neutral problem need help
- Some help with supporting mods
- Buschur's New Duel Stage Boost Controller is better than.............
- ACT 6 puck clutch
- evo iv turbo upgrade?
- Need help in choosing valve springs
- t-case change out
- cam for gt42 1000hp RWD?
- what size E-clip on 6spd underhood shift linkage?
- I ordered a TBE,drop-in filter,MBC..Have questions..
- Just ordered BR HTA 35R...Help with supporting mods??
- suspension
- Should I port out my Buschur 65mm T-body and intake manifold some more??
- My new Buschur Racing engine and car build up for 8's !
- TiAL Recirculating BOV
- someone please
- what intake for 30R ?
- rwd adapter plates
- Gt30r Setup...???
- think the car pulled timing on me
- Mynes vs Vivid
- GT3071 comp housing
- proper injectors
- helpp cant decide
- fpgreen or 30r which one
- question on oily spark plugs...repost
- ignition gurus, will these work?
- driveline fluids
- Going BB worth extra 500$
- BMC Airfilters
- governer?
- parts
- power
- Full-Race manifold/downpipe question
- 3065 / 3071
- grounding kit points
- How many cmf's does a 3076r pump out
- evo 8 transmission question
- AMS twin rail manifold or 1200cc injectors?
- Test Pipe On Stock car?
- Clutch slipping only in first gear...?
- 4G64 block w/ 4G63 MIVEC head
- gsc s1 or hks?
- hotside and turbo
- Buschur vs AMS racing battery?
- HKS Twin GD Pro Installed - Noise when clutch pedal is pressed
- MAF Implosion!!!
- Throttle sticking/won't start...
- Cam Install - Tune Necessary?
- Need Sugestions For Clutch!!!
- Compressor leak test... help...
- recomendation for exhaust?
- is this an evo 8 t case??? PICS!!
- a little help with exhaust choice
- More boost in the LOWER gears???
- arc super induction box
- wich cam's to go with
- cobb and helix test pipes
- Brian Crower Cams for Evo IX - run untuned?
- stupid question
- Question about stutter.
- Finally a welding and fabbing forum..
- Need new engine.
- adding a muffler instead of a test pipe
- HTA35R + E85 + Stock 2.0 + Topspeed=:)
- IX fuel pump or Walbro limits
- its finally blew up....!
- 5 bolt o2 housing???
- CBRD and ETS build..
- Will a IX mivec map work on a VIII
- Help please
- P0506 code, what do i do now?
- valve train question
- nitrous question
- head rebuild sorta...
- nitpick this setup
- cv joint boot
- Check This Out
- Xvt Stainless/nitrided Valves?
- help with trouble code
- Exedy Twin Dist Hd Ceramatallic
- NEW LOGO for Koyo aluminum radiator?
- hard pedal?
- AMS Tests: The New EVO AccessPort
- new Amsoil study on GL-5 gear lubes
- cams...for a green or 30 I dunno...
- Tranny Help is here!!
- Boost Leak Test past the Throtle Body
- Tranny Problem with my 9 MR
- 5th Gear Lockout
- Trans case I think
- TTP prototype turbo kits under development
- Where to buy turbo?
- Dyno tuned finally!!! 572whp 385wtq 24#'s for now....
- Dynotuning VS. Street/track tuning.
- 4g64 build, rev question
- boost creep problems, help
- Tranny / clutch problem ?
- Records are meant to be broken....HTA35r again.
- Buschur FP3065 !
- slight hicup at idle
- AMS header hotness...back purging 101
- good bov/dv source????
- EVO head noises after really cold start.
- 2.4l 4g63
- timimg case
- leaky pcv valve
- so im pullin the head!
- motor mounts
- TB diamter/TB hose ID?
- parts on the way
- 2.4L 67mm - Ignition troubles galore!!
- Groden Aluminum Rods a must for serious power
- Need some help on our new setup. Octane limited???
- Coolant leak
- exhaust coatings??
- transfer case problems
- 2.3l
- $200 Turbo
- Vacuum Hose Length w/ EBC Boost Solenoid?
- The AMS HP shop is up and running!
- Replacing Stock Manifold without removing turbo. Possible?
- Gruppe-S 2.3
- tranny...
- drop in pistons and rods?
- tranny
- rear diff
- post what clutch you have
- post your green numbers w/mods!
- looking for VCU
- ACT street clutch problem
- ichiba,topspeed,jic on my IX
- Can't get transfercase off help
- Drivetrain acting WEIRD!!!
- fitment problem
- 2.3, ported head & sheet metal :)
- What would cause this??
- Mod with only a 3" TBE and Intake
- Which Internals!!!!
- Valve cover coil bolts...a ground?
- Carbonetic Twin related to CEL???
- What clutch should i get
- Something broke during launch today :(
- Boost leak test
- Help.. Evo threw P0455 Code
- hks 272 mivec cams installed and dyno'd!
- larger than stock turbos + high flow cats
- whistles/ hiss
- evo green spool
- FULL RACE TWIN SCROLL 30R results and data
- 2.4L block - Cams + crank
- greddy t67 turbo??
- newbie and 700 awhp turbo
- Throttle mayhem...
- meth & nos
- quick question
- dipstick coming out
- Anyone considering a Magnus manifold, check this out!!!
- Exhaust manifold nuts
- Unreal Dyno Results...
- Who's manifold is this T3/t4
- Compressor surge
- FMIC - If you don't need the xtra cooling
- Head flow #s?
- Exhaust Manifold...anyone running this?
- FPgreen VS 57trim
- less boost more whp?
- new clutch - grinding when turning
- PeakBoost HVS for TiAL vband turbine
- TiAL vband PeakBoost manifold
- fuel question!
- PPG on an EVO
- SC3431vsPT61
- quick turbo/boost question
- Engine Dyno
- Turbonetics question
- 4th Grind on 6 Speed - Parts Needed?
- Help me pick a path.
- 3G 4G64 w/IX Mivec head?
- gains from adjustable cam gears
- too much oil in motor
- Turbo timer
- Present for a buddy
- might wanna check out this particular test pipe
- 600AWHP with a 35r!?
- what head gasket for 40+ psi??
- My 2.3 cam comparison...with dyno sheet!
- need help
- Transfer case removal?
- which turbo...on my built engine?
- Interesting Carbonetics Triple Failure
- 3" exahst flanges?
- **** Car revvs by itself HELP *****
- Huge Problem With Bov!!! Help
- Innovate wideband blinking non-stop
- Cold weather idle issue
- Looking at buying aftermaket clutch/flywheel.
- Engine Torque Damper
- gt35 on stock block?
- Question About Motor Rebuilt On Ix!!!
- Weird Bursts?
- HTA35R vs 37R
- oil consuption and dark oil
- GT3076R turbo questions!
- new car's #'s
- Complete Peakboost GT kit, opinions?
- ets or turbo xs
- Buschur tuned HTA35R evo fly by
- evo iv mods?
- evo 8 transfer case .
- cobb accessport vs. vishnu XFlash
- Drop in air fitler
- Boost issues after installation
- help!! i have questions about my 2.3 build
- CV boot torn, need help
- New Clutch Install now ACD PROBLEMS
- no boost?
- front axles
- gsc s1 cam with fp3065
- Engine/Tranny Removal???
- works throttle body shaft seals
- Need a new oil pan gasket?
- 06 lsd in a 2003 evo??? possible
- When choosing your parts how do you decide?
- FP 20g-9-5 rebuild?
- Exedy clutch uers, see this.
- bent valve?
- Perrin High Flow Cat
- Ralliart Clutch
- Check Engine Light
- my goals..
- Project FQ-400
- Fitment issues with LICP
- Who has ported their ebay 02 housing to cure boost creep?
- Need to Change the Clutch?
