- Avid Motor Mounts
- I need a Quaife LSD ASAP:)
- Shifter linkage issues, need help ASAP
- Just received my Evo Green!
- New Clutch Recommedation
- Quick MBC Install Questions
- Thoughts on the XS Engineering 272 Cams
- recommended spark plug gap
- Has anyone tried this t3 manifold/downpipe off eBay?
- Quest for no lag Turbo IX
- clutch question, probably pretty stupid one too...
- evo 5 engine?
- aftermarket radiator worth it?
- where do it?
- tranny going?
- Shep Trans just came in
- BR2.0L or BR2.3L??
- Silky Smooth & Solid
- Speedo problem
- Code 300 evoix
- rnr down pipe
- What to do next? full bolt on Evo 9 SE
- How much lag on this turbo??
- big problems
- Installed Oil Cooler Fan: Pics Inside. Cost:$94 Benefit:10-15 degree drop
- Inside of a Buschur Racing engine with lots of abuse
- what could be causing my P0234
- Transmission Oil
- Misfire at 20PSI on 04 8
- "System Too Lean" Error (P0171)
- My catch can results...
- 5th gear grind
- Tranny noise under deceleration
- Cutout anti creep/spool proof?
- Full-Race Hypertune Intake Manifold Dyno Chart!?!
- which would you choose....
- Evo IX- Mivec cam swap for HTA35R
- IX ecu versions
- Need 35R turbo exhaust housing-- recommendations / support
- ok so i ordered cams and cam gears
- question, possibly boost leak?
- How much did it cost you to have your head gasket replaced?
- Boost Control with tune
- shifting blocks
- nisei hard pipe kit
- maf wiring?
- HKS DLI fixed misfire but P0300 still appears sometimes....
- o2 housing question
- built blocks AMS, B/R, JAM.. Who to go with and why
- Cam Gears? What brand do you use?
- PWR Intercooler ?
- very loud noises/vibrations coming from engine bay after service work
- Tuning Gains?
- Issue with my new turbo kit (driveability/stuttering, bov??): PLEASE HELP!!!! )
- Oil Temp Question
- Exhaust Brands
- Exhaust Volumes
- Getting Tuned by Turbo Trix this week
- Look what I can Do!
- who makes a UICP that uses the stock diverter valve??
- Which Turbo Is this...
- Buschur intake pipe users, what way is your pipe installed?
- Buschur HO Fuel Pumps
- What t4 turbo will spool good and make great power??
- Is it possible to Standardize Dyno Tests? Such as Starting RPM, AVG whp/wtq
- evo stock turbo and power?
- 280 & 272 cams what is the dif ?
- Alky kit w/o solenoid valve - bad idea...
- Why Buschur and AMS don't do twin-scroll T3 kits?
- Mitsu tech Motor assy guide?
- Royal Purple
- how many miles have you guys put on your built 2.0 motors or built stroker motors?
- JM Fabrications Intake Manifold
- K&N drop in filter or AMS Cone Style K&N Filter and Adapter
- Please help me identify this turbo.
- Big difference between 2.75 and 3" dp?
- KW variant 3 + Dynoflash Custom tune = Smiles!
- replaced spark plugs annndddd what the crap...
- ignition blade voltage regulator
- Almost lost my motor today
- Mr. Buschur: HTA 35R with .63 hotside instead of .82?
- Spark Plug issue.
- stock intercooler upperpipe problem...
- wastegate adjustment
- Turbo Problems (I think)
- 1st and 2nd gear gone?
- Anyone out there w/ a bone stock 8 dyno graph?
- Ported Cyl. Head Pics
- Need Help FAST!!!
- Meth injection (how much to you use a month?)
- wastegate actuator problems maybe?
- Trouble with new turbosmart dual port
- HKS 280, E85, Buschur TBE idle video
- ACL Main Bearing Part#?
- My Compression Pressure Test! Comments?
- meth or aem ems?
- quick tcase flush question
- just bought a used BR MBC..What size vacuum hose do i need to install??
- Anyone come across this engine noise?
- Need Pic of vacuum lines to Intake Manifold
- BC 272/272 Idle video
- AMS2.3RR vs BR2.3L vs BR2.0L
- Air Intake Help
- christmas came a lil late (t3 twin scroll gt35r)
- 750cc Injectors Large Enough for 30R Big Turbo?
- Exedy Twin Disc
- 02 housing bolt size
- Exedy Triple Oh my
- T-Case whine, what does it mean?
- Question.. regarding making of the Greddy Type-S BOV
- Noise in 3rd 4th and 5th under gas
- Might have a resolution to my issue.
- Help! Probs with shifter?What is it?!?
- what about this turbo?
- BOV advice needed
- power steering fluid
- Mahley pistons
- Noise from cone filter
- 264/272 vs 272/272
- Typhoon intake??read before you flame..I did search..
- What does stock muffler internals look like vs. Magnaflow? Magnaflow Model Questions
- IX compression numbers
- AMS 2.3L Stroker and Twin Scroll 35R with HTA Upgrade
- Turbo Experts, HELP
- Wastegate Problems
- MAF clamp size.
- Evo IX with Stage IV - BR Gt3065 Cast manifold 501 whp on pump with alchy
- downpipe question...
- Radiator Questions - Evo 5/6 radiator into an 05 VIII?
- question (help)
- Drool Factor 10 Engine parts from Japan
- How stuff works: TURBOS AND WASTEGATES EXPLAINED...
- Spacer for O2 sensor...where to buy?
- How stuff works: BLOW OFF VALVES EXPLAINED...
- Too Much Lag
- FP-GRN w/oem int vs. Weapon-R on 91 oct.
- boost spike in higher gears
- turbo install
- RPM Acceleration data on 91 oct.
- is O2 housing needed???
- Can Fidanza Flywheels be resurfaced???
- Are these S1 Cams?
- going 30R wat clutch...??
- Downpipe Donut Gasket
- Cam Cap Problem
- Clicking noise in high gear high boost?
- Experience with ball-type injectors vs Densos
- WHAT'S THIS?! HTA35r is off the car??
- Bigger fuel pump needed?
- Valvesprings and Cosworth Mivec Cams
- 2005 VIII and 2006 IX stock turbo hotside is the same, right?
- Service Engine Soon
- Major WOT sputtering problems AND rpm spike problem when shifting.
- Best Exhaust Manifold
- ramhorn exhaust manifold, vendors get in on this
- Intercooler piping question
- turbo choice reliability?
- rpm band help
- manual boost cont. how much boost??
- Perrin FMIC users please help!!!
- Please Explain To Me How This Works
- Highest whp on pump gas 91 ONLY
- Looking for Feedback
- ebay downpipes?
- 2003 Mitsubishi Lancer OZ Rally question.
- NEED HELP! Is my ACD broken?
- Searching for correct MAF Translator
- Cosworth M2 Cams STD Turbo
- Whiteline diff bushing install?
- sc61 anyone?
- need help please
- Shearer Fab. New 42R Setup
- my plans... for now.
- Support Modifications for HKS GT3240 Turbo
- Turbo XS Donut Gasket Needed
- Is this a sign of a new cluth ?
- Upper & Down Intercooler Pipes!
- Random misfire ses light! Opinions please
- Best Clutch????
- flywheel resurfacing?
- what the freakin heck is goin' on!
- fidanza 3.2 or act hdss
- Choosing turbos TME vrs Evo 9
- Magnus motorsports dogbox
- knock? blown engine? plz help!!!
- high knocks running on toulene
- bad wideband???
- clutch or syncro? Hard to shift..........
- installing evo 9 bov
- MY poor car is all tore apart
- Help please problem with A/C lines
- 10.5 housing
- Oil leak between the T-case and Trany( H E L P ! ! ! ! !)
- ?Question for you twin pump guys?
- fuel pressure reg. solenoid?
- What mods can I do while replacing intake manifold gasket?
- short shift?
- *** Decision: Non-BB .50 Trim OR 20G-LT ***
- Greddy PRofec B Spec 2 problems
- best cams with 35r kit
- how much hp is the walbro fuel pump good for
- GM MAF + intake size
- engine damper
- mishimoto carbon intake?
- why is the clutch pedal feel harder in 03-04 models?
- Just finished the build... getting tuned tomorrow
- Help with removing fuel injector connectors
- No Boost in lower gears
- 3 transfer cases in 3 months... help me!
- 822 bhp + 633 ft/lbs on Pump (97 RON = 93 PON)
- Weird Issue
- where is ur fuel filter?
- Ported VS non-ported shroud comp cover
- Balance shaft remove or not ??
- USP Motorsports Evo Makes 904whp on Gt42r!!!!
- BOV that can hold >27lbs boost
- Does anyone get backfires from 2 step and exhaust?
- boosting 12psi help!!!!
- clutch pedal has no pressure
- Intake manifold weld problems
- HELP #2and#3 arent fireing
- R.Purple Oil Mileage intervals?
- factory freak? is this possible?
- Starting problem (intermittent)
- 69-6543tr K&n
- 35r and what i need
- boosting 12psi HELP!!!!
- can we replace the pistons.....
- Do I have a warped flywheel?
- Rpm Problem
- Do I NEED to tune first?
- what gaskets and seals do i need for a clutch and lsd install
- Sputtering after catback install...
- Slave cyl pushrod stuck aka piston in slave
- alan wrench in timing belt
- Hks 272 cam instructions for EVO 8 MR JDM
- Need help with clutch
- SouthBend clutch? Anyone use this?
- q? for cali evo owners with cams. SMOG
- Primary 02 Sensor failure
- my dyno sheet
- Works Clutch Kit 2 Reviews?
- Anyone running ETS FMIC / piping with other turbo kits?
- 4th gear blowing up?
- 2006 IX Engine Tick Whine Rattle HELP!!!
- clutch went out tonight
- ACT clutch disengagment problems HELP what 2 adjust
- Question Guys
- AEM Intake vs Apexi
