View Full Version : Evo Engine / Turbo / Drivetrain
  1. What is this?
  2. what boost controler are you using
  3. Loudest Recirculated BOV
  4. Car Killing Batteries?
  5. Gt2876r
  6. ACT you bastard
  7. clunking when i shift
  8. best way to make an evo stock appearing mid 11's on pump and stock catback?
  9. Idle Problem?help
  10. HKS Valve Springs and Retainers
  11. Whine but not TC question
  12. boost leak problem
  13. buschur double pumper
  14. i need internal/upgrade help
  15. help evo 9 idel rough and code p0300
  16. Kelford 280/272 is actually 280/276???
  17. When 4.0" Is Not Big Enough!! We have 5.0" and 6.0" Intercoolers!!
  18. crank replacement
  19. Does stock fuel pump whine ? way to identify walbrol
  20. Possible overboost? not sure need help..
  21. Apm Sponsors DG Motor's Drag Evo 8!!!
  22. TB shaft seals
  23. Buschur Intercooler help
  24. Copper Spray on Headgasket - Yay or Nay
  25. Walbro Problem EVO VIII
  26. JDM Evo with twin boost solenoid setup
  27. Grinding and Popping
  28. Ebay/Custom made Straight pipe.
  29. Exedy stage 2 clutch noise
  30. Which battery?
  31. big problem after filling up with gas
  32. Is acd pump considered a "drivetrain" part?
  33. Evo won't take gas
  34. Electrical Problems
  35. Boost leak help
  36. Anyone using FIC Bluemax 1650cc inectors?
  37. 35r 2step boost???
  38. Boost gauge question
  39. Cusco front power brace with ARC intercooler?
  40. In need of assistance...
  41. New Exedy Twin, rattling when disengaging clutch
  42. high idol lean wideband
  43. Will a 3" intercooler be enough?
  44. Exedy Hyper Single
  45. brian crower 288/288 cams?? mivec delete? injectors?? throttle body??
  46. Plz check out this engine bay!need help to locate engine parts
  47. ETS 42R Turbo Kit w/ Full Size Radiator? AC? and Power Steering!
  48. ETS Mitsubishi Evolution 8/9 Custom Vertical Flow Intercooler
  49. ETS Front Facing Billet 6765 Turbo Kit w/ V-Band Housing!!!!
  50. Recirc BOV's above 28PSI, info request
  51. What is this noise????
  52. What shifter bushings to get?
  53. Issues With 2nd Gear
  54. Anyone have a back door intercooler setup?
  55. ATF in the engine??? ; (
  56. What is E85 & How does it increase HP ?
  57. Cel codes p0133
  58. 60K service aftermath....
  59. gsc s1 cams on my evo 9 with red
  60. Maintenance
  61. p0441 and p0011 after clutch install
  62. motor help
  63. Evo v conversion.....
  64. noticed t case HOLE during clutch install
  65. Fitment question
  66. Need opinions on warranty..not voided????
  67. transfer case death whine
  68. Smoke After Boost Leak Test ??
  69. 50trim turbo question?!
  70. Quick Question, Evo wanting to stall
  71. Choking at high boost
  72. Balance Shaft Delete
  73. honey comb @ 28 psi
  74. Finally building 2.0L
  75. blown turbo
  76. Exhaust stud size?
  77. HOW TO eliminate BOV boost flutter?
  78. Injectors for HTA Green? plus other mods?
  79. help
  80. Emissions issue....
  81. Whining..?!?
  82. Closed Loop Boost Control
  83. Red turbo
  84. throwing p0500[speed sensor]...
  85. injen IC Piping
  86. Big Turbo, Right Mods, Mellon Tuned, LOW POWER?? HELP!!!
  87. is 28-29 psi on a fp red with supporting mods and built longblock safe on 93 pump gas
  88. FP White vs FP Green - same day - same dyno comparision
  89. Forced Performance Evo 8 intake Pipe
  90. Help! Not boosting past 15 psi
  91. Half radiators?
  92. hit a curb what did i break?
  93. help me release this stupid TOB UGH!!
  94. exhaust port dimensions
  95. axle question please
  96. Tuning issue?....or?
  97. White smoke
  98. Various Spec Clutch Questions
  99. TB leak, again
  100. How many people have blown out the TitekO2 housing gasket?
  101. O2 housing question
  102. Wilson V2 + Throttle Body
  103. hard to go into gear?!
  104. removing acd
  105. Big Tranny Problem
  106. sparktech igntion problem
  107. Help- Stuttering and lag
  108. Exhaust Gasket help
  109. Problem...Crackd header...
  110. FP Red Owners
  111. cooling system pressure
  112. 6 speed swap
  113. Who is still on stock tranny and transfer case?
  114. Airflow for Evo IX Turbo, FP Green & BBK
  115. Need installation instructions for Hallman Pro Rx MBC!!!
  116. opinions on exedy twin disk
  117. Anybody using the Hks Twin disc??
  118. Stock EVO VI turbo
  119. Help with engine problems
  120. What intake with Buschur UICP????
  121. Lowering turbo inlet temps
  122. Stuck!
  123. Synapse BOV + HKS EVC Problem???
  124. MBC Location pics
  125. Intro & Mod questions
  126. FacePalm Day
  127. Difference in Timing belts 8 vs 9
  128. Evo 9 Waistegate - Help
  129. AEM Tru Boost Big Turbo Guys Using the 5 Bar External Sensor, Questions Please???
  130. crankshat sproket removal
  131. New fuel pump car wont start
  132. Can the Megan exhaust manifold hurt performance
  133. Cobb Exhaust
  134. Spec clutch 2+ Shifting Issues
  135. Need Info on IX Setup
  136. ??? Anyone gone from HKS to Kelfor or S2s???
  137. Coolant issues
  138. Cant shift fast!
  139. Rear Main Seal Question.
  140. possible to remove pressure plate bolts while tranny still in car?
  141. Axel bolts what size help??????/
  142. Fan controler
  143. tranny issues
  144. Drivetrain Noise ( Surprised ?)
  145. Changing Serpentine Belt
  146. RED Build
  147. Reuseable Gaskets
  148. Motor / Setup Thoughts
  149. Turbo making odd noises, in high gear only
  150. NEED HELP on Clutch and Tranny
  151. Second gear won't go in
  152. 6sp Tranny How much does it weigh
  153. Best cams for TS HTA3582R setup (Evo 9)?
  154. Did the 6spd to 5spd conversion, need to re-tune?
  155. AMS O2 Housing?
  156. TBE fail ...
  157. Oil Filter Housing Question. Please Help!!!
  158. Help! Rattling sound coming from drivetrain...
  159. mitsubshi td06 20g questions
  160. Inline Fuel pump?
  161. Reading valves?
  162. overheating
  163. AMS 3" Turn Down
  164. weird boost issue.
  165. cant pick a cam..any help
  166. FP Green HTA Pics
  167. RPM fails/failed to read car = dead
  168. oil pump flange busted?
  169. Controlling boost with ECU vs. MBC
  170. new Fuel pump, injectors, installed: Starting issues?
  171. Recent change of BOV sound & stalling? wtf
  172. Clutch Material Question
  173. which epm o2 dump clearing niesi?
  174. Car Not Boosting
  175. BC 2.4L stroker kit into a 4G64?
  176. Low compression cylinder 2
  177. black smoke when decelerating
  178. OEM wedge collar question
  179. kelford 272 question
  180. New Turbo Setup
  181. Can Greddy Type S bov be recirculated
  182. gt35r install over the weekend
  183. greddy boost control valve
  184. 1st gear grinding
  185. Springs and Retainers? What to choose?
  186. Turbo oil line problem
  187. o2 sensor question
  188. quick question help please!!
  189. GSC 2.2 stroker reviews??
  190. No reverse
  191. BBK Lite Turbo
  192. Upgrading to the evo 9 turbo
  193. boost and duty cycle?
  194. Rate MY build
  195. Need advice on fpred upgrade and which manifold*pics
  196. Weird Boost Problem
  197. HKS EVC-S Boost Controller - anybody?
  198. Testing the AWD 1000R Billet 67 mm Turbo - 820 whp
  199. Fried ECU
  200. Who makes manifold for stock turbo
  201. clutch restrictor pill removal... speed bleeder?
  202. question about TB Gasket
  203. wedge collar help!!
  204. throttle body leaking
  205. Modifying stock air box
  206. Upgrade O2 housing question
  207. GSC 2.2L & twinscroll HTA3076?!?!?! TUNERS OPINION NEEDED PLZ!!
  208. rear diff bearings
  209. Help - Lean Idle
  210. Noise coming from BR double pumper???
  211. Engine code 0069
  212. how is the quality of clutch masters
  213. blown clutch, or ... ?
  214. Cam upgrade worth it???
  215. Smoking from engine bay?!?!
  216. aftermarket clutch help
  217. 65mm id flat exhaust gasket, where?
  218. O2 questions..
  219. will evo 8 turbo fit on 2nd generation eclipse?
  220. cluth labor?
  221. Fp red little gains ?
  222. fp red..Stock cams..evo 9?????
  223. need help
  224. ATP gt35r manifold bolt size
  225. symptoms of a warn clutch?
  226. new comer few simple ?
  227. Oil pooling
  228. MAF protection??
  229. Fuel Tank
  230. that's the limit for HKS 3037s
  231. Recomended oil for evos
  232. Need some HELP!!!
  233. hesitation?
  234. Been out of the loop for a while
  235. AMS catch can help??
  236. new clutch new problem??????
  237. Evo 8 10.5th turbo vs Evo 9 turbo
  238. Help! Loud Pop After Spark Plug Change
  239. Mods for a gt35r upgrade???
  240. Fp red , weird noise ??
  241. OEM looking heat shield to fit over Mil Spec cat?
  242. Opinions please.
  243. causes for coilpack to fail??? Or better yet, why is my engine bay soo hot?
  244. WTF.. Brand new Exedy Triple Disk Slipping?
  245. Tranny removal Suggestions..
  246. HKS BOV to recirc or not?
  247. Finally Running Again :)
  248. 2.3 stroker vs 2.0 long rod, opinions pls
  249. Bringing Evo back, my new built 2.0 almost assembled.
  250. Spark plug part number!
