View Full Version : Evo Engine / Turbo / Drivetrain
  1. Manual Boostcontroller
  2. Major Misfire?
  3. hey guys question about evo front mount
  4. greddy type s bov
  5. HKS 272 Max Out
  6. MBC only boosting 10-13 psi
  7. 675whp 500ft lbs. TQ!!!!
  8. best stock fmic replacement!!!
  9. what do you think?
  10. Possible Boost Leak from BOV?
  11. Is there a power difference between a 4 bolt vs 5 bolt hotside?
  12. p0300 and 3001
  13. F/T : Perrin 3 inch TBE
  14. IX 100whp tune plugs?
  15. head gasket leak
  16. custom dumptube pics?
  17. decision on intake manifold..AMS or HKS?
  18. Stock turbo - how much boost???
  19. T4 Hta 35r?
  20. oil cooler leak????
  21. Question on Buschur TBE (fitment)
  22. Shifter bushings
  23. Need Some Help
  24. HELP! cel light after installing o2 housing
  25. Coolant leak, replace banjo bolt, gasket and ??
  26. more tq over hp?
  27. oil stabilizer
  28. Effect of ported stock exhaust manifold on spool up
  29. dumptube Help...
  30. when it rains it pores
  31. Coilpack question
  32. Help With Mods
  33. Timing belt cost??
  34. Upgrades/Rebuilds
  35. ACD transfer case in Non ACD Evo?
  36. GT3582R - Is this worth the headache?
  37. Carbonetics twin carbon or exedy twin carbon
  38. Replaced Buschur Mini Battery
  39. 4th gear problem
  40. Transfer Case Whine in 4th & 5th?!!
  41. Running Cool
  42. greedy E-manage
  43. Need Help Forge WGA
  44. Oil Catch Can Theory
  45. leaking gas
  46. need help and advice with a DTC
  47. My HTA dyno results (more boost)
  48. O2 Sensor or Evil EVO Gremlin?
  49. Blow Off Valve question
  50. Backfiring Problem
  51. Whistling sound when under partial throttle
  52. boost problems
  53. cam question
  54. 400 awhp
  55. Bone Stock IX knocking?
  56. alternator problems. need help
  57. Why is my car whistling??
  58. Changing timing belt...
  59. Which Hallman MBC is better for an EVO VIII?
  60. Transfer Case oil change interval
  61. Dyno Tuned
  62. Manley H-Beam Rods
  63. Got tuned BUT dont know spark plug gap.
  64. Some questions that I can't seem to search up.
  65. sbr manifold
  66. broken turbo fins
  67. Apexi filter and induction box questions
  68. Do DSM injector clips fit Evo injectors?
  69. DP hitting, how to fix
  70. Switching Camshafts
  71. Pressure Drop with Perrin FMIC?
  72. 600hp possible on 93 possible???
  73. Which moustache bar eliminator to buy?
  74. tdc mark anyone??
  75. greddy spec b prob
  76. Megan Gaskets
  77. TC problem in evo 9 6 speed
  78. Cosworth IX Idle Problems....
  79. Help, My EVO IX MR boosting w/ hestitation
  80. Compressor surge????
  81. Which oil
  82. broke my helical lsd.........
  83. Stock piston question
  84. Buschur HTA35R Exedy vs. Tilton (10 second street car!)
  85. T-case grease fitting
  86. Is the Works DP compatible with non works O2 housing
  87. EVO VIII Boost Problems
  88. boost activated cutout FTW
  89. Apexi Air Intake Install Question
  90. EVO 8 belt squeal,under load ( video )
  91. English Racing E85 Stock Turbo Package = Awesome!
  92. Tial Flange?
  93. Forge 1G BOV
  94. Prosport Electrical Boost Gauge
  95. BOV/Intercooler Pipe Help
  96. Clutch noise, Help!
  97. How I'm spending my tax return
  98. Norris Design 2008 Spec?
  99. Is it necessary?...
  100. ?Do you know This Problem?
  101. P0204
  102. New Product! AMS EVO Lower Clutch Line
  103. Sparkplug condition ok???
  104. Stock clutch vs. Aftermarket... longevity
  105. worst evo ever
  106. ARC Induction Box
  107. Diff Fluid Fill Level (Tire Rotation)
  108. Ball Bearing Conversions
  109. My Dilemma
  110. BOV DV question
  111. Stroker Kit???
  112. what other mods would i need to run the Buschur Racing FPHTA35R Turbo Kit
  113. clutch help
  114. Is the VIII and IX rear diff the same?
  115. Dual Fuel
  116. DTM 61mm Turbo Kit. Fantastic Results!
  117. fq400 turbo name? where to buy?
  118. How do my spark plugs look?
  119. winding noise after tc fluid changed
  120. Does removed airbox cover simulate cone filter noise?
  121. Fox lake ported head
  122. Transfor case seals
  123. help with idle and iac motor
  124. HTA upgrade + TB/Intake Mani Ported
  125. HKS 272 w/o Springs or Headstuds
  126. Pulley/Belt Noise during Cold Starts at 10K miles???
  127. Why AMS recommends Race balance shafts
  128. aftermarked oil cooler lines and fittings
  129. Quick PTE 880 question
  130. gt4080rl 2.3l or 2.0
  131. PLEASE HELP URGENT!! I need to know if I need a diff spring in my EWG 38mm Tial????
  132. 300 miles later oil is down to bottom of dip stick wtf???
  133. Squeaking noise during deceleration???
  134. 35r
  135. My clutch
  136. cam install
  137. Built trans issue. Experience Needed!
  138. Groden Aluminum Rods a must for serious power....Take 2!
  139. forced performance Evo VIII install kit
  140. rev limit
  141. need help
  142. installing cams help
  143. Upper Intercooler Pipe
  144. HKS light action clutch
  145. Cosworth 2.2 stroker
  146. Getting A Green
  147. Need suggestions
  148. Trace amounts of oil in the airbox? :(
  149. Exhaust Back Pressure Measurements?
  150. how much boost can a stock evo handle?
  151. oil pan RTV. what do u use?
  152. replacing clutch
  153. How much boost can a stock evo 8 can handle?
  154. BC SS Valves
  155. fuel pump??
  156. 50trim to a 35R? worth it.. or not
  157. RPM's UP
  158. Twin scroll Question
  159. Belt Tensioners needed with cam install?
  160. Forge EVO15 BOV/DV Issue?
  161. How heavy is the Tilton twin disc....
  162. Issue w/ turbo!
  163. Cams for EVO 8; keeping stock turbo.
  164. Buschur inline MBC; change lines?
  165. The Best Turbo Kit for my Evo 8
  166. EVO 9 TME (Magnesium) turbo Questions
  167. Question about Beatrush prop bushings
  168. Greddy Type S Spring..
  169. meth injection
  170. Which spark plugs should I get?
  171. shortest route piping
  172. help with valve springs and retainers...
  173. Cam Gears
  174. max out stock turbo's support mods? or upgrade to green?
  175. Need Help!
  176. Anyone Know Precision Ver. Of gt3082r?
  177. Clean MAF while car running?
  178. GSC vs. BR272 vs. JUN
  179. Dash rattle with Ralliart mounts
  180. Buschur Front Motor Mount Installed!
  181. Random Clutch Noises?
  182. Eagle 2.0L Evo VIII & IX Rotating Assembly
  183. Clutch Install Help!
  184. P0446 - Evap Emission Control System Vent Circuit Malf
  185. Need some help
  186. i need stroker kit recommendation
  187. Wow what a difference
  188. best turbo for the price?
  189. eBay Evo 9 IX Exhaust Install?
  190. Problem with injectors
  191. dumb question.. but still a question
  192. I Need Oil retun Kit for t3/t4???
  193. Low RPM Stutter / Stuttering
  194. Test Pipe
  195. Question about Exedy Twin Disk Clutch Engaugement
  196. When is a FP regulator needed?
  197. mikronite??
  198. Broken Engine Help!
  199. Cosworth Cams
  200. defi water temp install
  201. Hey Guys, EVO Noob here but pretty sure this isnt right, emergency question
  202. turbo problem
  203. PCV system
  204. Stage II Stock Turbo IX with Aquamist 464 TQ 416 WHP !
  205. Who makes a solid engine mount?
  206. Tranny noise...
  207. Anybody use SuperTech Pistons before?
  208. tanabe Blue G
  209. Where To Set My Cam Gears
  210. Calling out torque monsters...
  211. turbo conversion???
  212. Ivey Tuned Customers Please Chime In!!!
  213. O2 housing, manifold, licp, uicp = How much gain?
  214. Apexi N1
  215. Freeze Plug Size
  216. Do I need to switch my MBC install for my new turbo setup?? Please help me!!
  217. HKS GT3037S or HKS GT2835?
  218. Possible slipping clutch?
  219. Oil Cloud on decel. HELP!
  220. HELP Car not starting.
  221. new downpipe clearence issue
  222. revs don't come back to idle
  223. Mitsu turbo output range...links
  224. 1st post to share my ride
  225. stock spark plugs or 1 step colder
  226. Best season to tune???
  227. My EVO is running again, with pictures!
  228. Buschur Dual stage MBC
  229. Manifold Question
  230. weird overheating issue
  231. Bolt-ons for 350 whp?
  232. Who has succesfully replaced rodbolts from below?
  233. Recommended Code Reader?
  234. exhaust cam only
  235. Should I change my timing belt at 25K?
  236. EX POWER INC EVO 8 mani/downpipe. Any good?
  237. The Metal DV gonna be able to hang?
  238. Hks Evc Vi??
  239. valve covers?
  240. MBC Installation Procedure
  241. The Perfect / Ideal WHP Number for Road Track Racing
  242. Avid Motor Mounts
  243. I need a Quaife LSD ASAP:)
  244. Shifter linkage issues, need help ASAP
  245. Just received my Evo Green!
  246. New Clutch Recommedation
  247. Quick MBC Install Questions
  248. Thoughts on the XS Engineering 272 Cams
  249. recommended spark plug gap
  250. Has anyone tried this t3 manifold/downpipe off eBay?
