View Full Version : Evo Engine / Turbo / Drivetrain
  1. Big turbo with stock intercooler
  2. Bleeding lash adjusters???
  3. Oil in intake manifold...what is the cause?
  4. rubbing noise from engine....
  5. GSC S2 Camshafts
  6. Source for Evo 16G compressor housing?
  7. Any front LSD solutions for 03 VIII without having to disconnet ABS?
  8. Who has the EVO 9 Brian Crower 272 Mivec Cams on their car Worth it for $350 Shipped?
  9. How do you know when the plates in you exedy twin need replacing?
  10. whining noise shift...
  11. EGR valve
  12. ARP Headstuds
  13. Is the Buschur MAF Intake a 3" pipe?
  14. meth injection
  15. AEM O2 Wideband Bung Material
  16. GSC 2.2L stroker??
  17. So I got my AMS 2.3RR motor today..and some ETS parts...sneak peek inside
  18. transmission help .
  19. HELP! Fuel cut cause it's too cold
  20. Balance Shaft Help
  21. Water pump suggestions
  22. Cam Gears
  23. Boost controllers
  24. TRE 3.73 or Simalar Help.
  25. PICS of my new turbo from Buschur Racing!!
  26. SRS light is on
  27. Launching a twin disk
  28. AMS Teams up to build a Standing mile EVO
  29. 3 inch DP recommendations
  30. WTF is up with this
  31. Bypass valve not working
  32. What Clutch Fo My 9
  33. Evo 9 and cams
  34. Building a trans to handle 5-600hp
  35. Are head studs Necessary for cams?
  36. Manual Boost Controllers
  37. Bov Decision
  38. cam question
  39. help please
  40. Buschur Racing 3" Exhaust Test Pipe
  41. Rough idle problem car dies at stops
  42. Boost Problem?
  43. Need help deciding what turbo will work best?
  44. Accel issues
  45. Exedy install question?
  46. Need help!!!!!!!!!
  47. Some exciting new builds at AMS!
  48. Coolant Smell BUT no coolant loss
  49. No Top End Power
  50. TTP-Engineering proactive Cosworth Announcement
  51. Anyone know the Correct Length of RS BELT.
  52. 02 sensor install help!
  53. Buying Buschur 3065 Setup, Question about what size injectors?
  54. PCV Valve setup
  55. Considering removing clutch restrictor
  56. Normal Oil Pressure?
  57. Exhaust Manifold????
  58. Cosworth Springs on FH35R and GSC S2 cams
  59. Crower 280s and Springs/Retainers
  60. Aftermarket Alternators
  61. EVO 6.5 RS TME Turbo ???
  62. EGR Question
  63. Cosworth M3 Race Cams - Results Anyone?
  64. A friend wants to know how he can get ayc and acd into his usdm 03 evo?
  65. HP advice
  66. boost controller/wastegate/spiking problems. please help
  67. weird noise!?!?!
  68. 2.3l stroker or 2.1l destroker
  69. Cam Help
  70. Camshafts
  71. GT40/94R vs FPHTA35R
  72. my plans.. what do you think
  73. clutch prob. please help
  74. Snow performance water/meth injection
  75. Turbo advice and other mods
  76. Mini battery is dying on me..
  77. cams...are they all the same?
  78. Intercoolers that are over 600 hp rating
  79. Shortest Available 5th gear?
  80. Intercooler Piping Materials
  81. Buschur Air Intake vs. Stock Box
  82. jolting problem
  83. My new Full Race GT42 Twin Scroll Manifold
  84. What Clutch should I get
  85. Car dies sometimes when going to neutral and slowing down to a stop?
  86. Need Help ASAP.. anyone please help
  87. wreaking my drive train
  88. Engine problem: in need of diagnosis
  89. My engine seized.
  90. t case question?
  91. wtb oil cooler and evo 8 or 9 front
  92. Twin Scroll Candidate
  93. How much torque for o-ringed heads?
  94. Nitrous for spool???
  95. Question EBC Solenoid installation?
  96. scary noises please help
  97. fp green suggestions:
  98. Would it be possible to use a 4b11 engine head on a 4g63?
  99. CDI coils?
  100. just got altered Exhaust ticket !
  101. I NEED HELP...Car shut off suddenly...
  102. Spool: Evo 9 stock turbo vs FPgreen
  103. Butt Dyno
  104. Evo IX VIN# on Transmission?
  105. air temp?
  106. car is stalling all the time please help
  107. 11's on stock turbo?
  108. Forge WGA
  109. 272 vs 268 cams on 16G
  110. Need advice on flywheels
  111. Need advice on flywheels
  112. Spark Plug question
  113. threw 2 codes after cam install (rich idle)
  114. Sleeper EVO exhaust
  115. After cam install....
  116. GSC Power Division CNC Cylinder Head! Dyno and track #s soon to come
  117. EvoM & Ebay = 500WHP for less than $4000 with built engine!
  118. Which LICP will work with stock turbo and 3065 kit?
  119. Okada and HKS?
  120. SC6152 dynop results
  121. cam tuning on stock cams
  122. help guys noob here!!!
  123. turbo upgrade?
  124. new compressor wheel
  125. Evo 8 tranny, how long will it hold?
  126. 2.3 spool questions
  127. anyone using civic alum. radiators?
  128. Lookey what I got in the mail this morning, just in time for an evo modfest...
  129. Buschur Tax Return Sale
  130. 924 whp EVO VIII and crankshaft
  131. Tune This Weekend!!!
  132. evo 9 turbo manifold
  133. cold weather overboost?
  134. My Car Graphs
  135. Sudden Oil Leak on my Evo
  136. got tuned at eip.
  137. Blow through MAF ??????
  138. Basic Mods Needed
  139. Do i need new oil lines?
  140. Cylinder #4 misfire and a spark plug question.
  141. cam question 264/272?
  142. Jerky clutch when cold!
  143. exhaust manifold temp
  144. Twin Scroll Testing...Let us know how you want it done!
  145. Hyper intake manifold- its here...
  146. Gague to read JDM Map?
  147. Tranny help / suggestion
  148. Installing and verifying the timing in a MIVEC cam! Hints?
  149. Tune?????????????
  150. Tranny recall?
  151. EVO 8-9 exhausts, help please
  152. anyone use this......
  153. going in for a tune.
  154. It's freezing outside and I boost creep.... :(
  155. Fidanza Flywheel not mating with 03 starter
  156. what causes this?
  157. turbo upgrade (question)
  158. What is a good price for Exedy Hyper Twin Plate
  159. transfer case ?????
  160. DTM stroker kit
  161. Very bad times...!
  162. Electronic vs Manual boost controller
  163. VIII w/ IX turbo power?
  164. Question With Turbos
  165. New clutch/flywheel install question
  166. IX - Spark plug gap options??? Heat range 8
  167. turbo kit
  168. spark plugs????
  169. Best Gear Ratio for EvoGreen
  170. Boost spiking like Crazy Help
  171. which dv holds high boost best?
  172. Full-Race on stock setup
  173. P0171, again yes i know but please read
  174. Please Advise!!
  175. My budget build up 50 trim results.
  176. finally got my FP HTA twin scroll gt3582R
  177. Excedy Hyper Single??????????
  178. Clutch Disengaging issue.
  179. stupid question
  180. ACt Clutch ??
  181. 2 litre + ? Turbo = Need to rev past 8,500 rpm
  182. Changing 5th gear...help?
  183. 2006 Ix Mr (gt35r)
  184. Are the evo 8 & 9 bottem end the same?
  185. New Numbers On All Out Pump Tune
  186. fuel filter??
  187. Obdii Po132!
  188. Does anyone have the eBay smoked headlight covers?
  189. What cams should I get?
  190. AVC-R... setting up for dual-stages...
  191. cam decision Please help!!
  192. 400whp with 98 octane.
  193. mis shifting ( help plz)
  194. Cold weather, high boost?
  195. AvGas?? (Aviation GAS)
  196. Florida Buschur exhaust owners..............
  197. T-Case fluids
  198. question about greddy profec b spec 2?
  199. GSC S1 -vs- HKS 272
  200. IX turbo install pics
  201. should i go with the gt35r or stay stock 06 evo IX? please help
  202. Blueish smoke from tailpipe
  203. Boost Creep, now Overboost?
  204. drop-in build @ 70k+ miles?
  205. intercooler question
  206. any buschur 2.3Ls in the house?
  207. Shifting - Evo VIII - New Owner
  208. Where to tap boost line
  209. who is using pauter rods and how much whp?
  210. New mods being purchased.
  211. better flywheel bolts?
  212. Maximum degree on the EVO IX exhaust cam!
  213. Putting Together Your Own Turbo Kit????
  214. bad spark plugs??
  215. Help with diagnosis
  216. Clutch knowledge
  217. Dyno tune tomorrow
  218. Switched to Royal Purple 10w30 today
  219. Exedy Stage 2
  220. Exhaust System Basics
  221. P0401 and p0420
  222. Heat wrap on downpipe, what temp?
  223. What cams are these?
  224. Recomended westcoast shop?
  225. what valvetrain?
  226. HKS Super sequential Vs HKS Super SQV Racing Single Valve
  227. removing exhaust manifold
  228. DP failure from Heat Wrap?
  229. P0234 code HELP...
  230. Want to get close to 350HP with out changing turbo.
  231. O2 housing
  232. output shaft
  233. Spark plug causing Backfire or is it my TUNE?!?!
  234. idle keeps dropping??
  235. tune needed?
  236. Does Walbro 255 LHP needs an installation kit for EVO 8?
  237. Test Pipe = More Psi
  238. Aftermarket clutch on stock car
  239. proper spark plug for mods??
  240. boost
  241. Is there an overboost failsafe?
  242. Manifold Studs
  243. Buschur Inline MBC installed and reviewed
  244. Is a tune needed?
  245. Cosworth M3 Idle Video?
  246. ix cams po11 code
  247. Please Br High Temp Coated Headers Pics!!!
  248. Tranny Problem!!
  249. Meth Injection Help
  250. AMS polished Turbo kit Pics...before and after!!!
