- Cant boost past 10psi
- Attn: Martin of VIP
- car will not stop throwing p0172 and p0500 codes
- Read My Plugs
- risks with cams?
- compression test. need help/info please
- drivetrain help
- fidanza clutch
- dp - o2 housing leaking
- OFFICIAL: Tanabe Concept G Blue Evo 8 & 9
- meth or turbo?
- oil cooler
- dp help
- DO NOT USE PULSTAR PLUGS!! i repeat do NOT install these in EVO's
- ARP head stud failure.
- BR Turbo Kits...Post what ya got!
- E85 usage
- O2 Housing Question...
- ATP kit strikes again!!!!
- Intake Manifold
- Problem with FP EVO Green Turbo
- question about my new setup
- JAM lifters
- I have 2 questions for all you EVO owners..
- BR 3065 turbo kit w/ tubular manifold lots of photos!!!
- Evo Not Running Right After Storage
- Greddy intercooler?
- ETS Water to Air Intercooler. In progress...
- boost creep
- "Neutered" my EVO 8 today, didnt want to though....
- NGK Spark plugs gapping?
- boost problems HELPPP
- Weird clutch issue....
- Buschur Downpipe and SS 02 housing issues...
- AYC in a American Evo VIII?
- TD06SL2 Reverse Turbine details ?
- Byc Fmic ?? Any good
- GT3076r or GT3582r ??
- Profec B Spec wiring routing options?
- FP HTA35r Dyno #’s w/ Meth
- p0031 and p0130 - Help!
- Fuel Injector to Manifold ring/plastic?
- Weird MR Tranny problem
- JUN 264's on a Green
- Will a SlowBoyRacing DSM GT35R work on an EVO?
- EVO 9-20g 6 blade
- Anyone Tuned By ICS ?
- Idle Surging Problem
- vaccum lines
- fp green typical track times
- Bye-bye BOV flutter
- How much HP can a EXEDY ORGANIC CLUTCH hold???
- Injen UICP havin weird???
- What could be causing my turbo not to boost??
- Evo 8 and Evo 9 LSD's
- 2.6L EVO - every been done in the usa
- 4G64 2.4 stroker with evo MIVEC head......Help!
- Very small chips on Exhaust Turbine...
- Problem when accelerating
- Is this really just a 9.8 hotside?
- Evo VIII Build - Dominican Republic (pics)
- gscs1 cams Ok with std springs
- Greddy Type-S on stock ECU?
- 20glt
- Something wrong with my clutch
- puzzled by low compression #'s
- Q16 Fuel
- Will the 4B11 coilpacks fit 4G63???
- 2.3 build in progress.
- Help with possibilities please...
- 9:1 Compression
- what do you guys think of this cam setup
- suggestions on cam for my set up?
- Evo IX Problem Help
- MBCs: What you don't like
- New Redesigned AMS Evo Pistons
- Rear subframe torque specs and others
- what exhaust should i get
- Clutch pedal doesn't fully return to resting point?
- Short shifter for 6mt
- P0141.. some help please?
- 93+Meth vs C16 vs VP Import
- Apexi AVC-R boost and setup problems please help.
- Help with identifying some gaskets
- Infinite Speed & Performance Turbo Kits
- Green or Gt3076 ?
- Which ACT EVO Street Disc Clutch Kit?
- Fast Dd Evo
- new at this new 2.0 build
- Some positive input on testing intake manifolds
- HKS Carbon-Ti vs A'PEXI N1 GT-Spec
- Where is everyone getting there 12v switched power for Wideband?
- Spark Plug Question?
- Spark Plug Indexing?
- Is anyone running the FP Green with only minor Bolt-Ons?
- RRE X Clutch Or Exedy Stage 2
- bov on 06 mr?
- 16 year old Harry's Buschur Powered Gt35 R 2.3L Stroker Street Sweeper
- HKS EVC VI settings??
- 50 trim dyno'd
- Starter problems
- Intake manifold for 3076r?
- o2 Housing Install
- EVO STARTING PROBLEM.....(electrical)
- HTA owners quick timeframe question
- Can Gt3076r hit 460 whp 93 pump??
- Where to buy crush washers to fit stock coolant line on 3065?
- Front O2 sensor question
- What size is the coupler on the hotside of intercooler?!
- Can a GT30r run 11's?
- EVO 8 Axles and Evo 4 axles Are they same?
- Sudden squeal
- Innovate WBO2 & HKS HI Power
- Promised Pix of Ebay manifold
- Adjustable Cam Gears and effects...
- External Wastegate on Stock turbo
- WHP with these mods?
- will i have to do a retune
- NOS for spool up
- Boost issue help would be appreciated
- Active Center Diff Info Needed
- exedy twin plate clutch rebuild kit
- Borla turbo manifold???
- Options- i need more.
- brian crower 272s
- Spring/Retainer Install HELP!!
- just got my buschur racing hta 35r kit in the mail... pics inside
- ARP flywheel bolts
- rod bearing
- Transmission Fluid Mystery
- What Cams
- Bad Motor Mounts?
- Bearings....
- why is this here???
- Anti-seize on spark plug threads
- ACD/Brake/idle issue. Please help!
- Extreme Turbo Systems Does it again! 45r working with a Stock Radiator and more...
- Ebay IC Piping vs ETS IC Piping
- Boost Problems
- INTAKE/EXHAUST stock vs. custom; PLEASE HELP
- Engine Light w/ Test Pipe?
- valve cover
- Ported manifold and 02 housingPorted manifold and 02 housing question..
- grind into 5th gear when fully stpping on clutch
- Bypass the Hot H2O in throttle body ?
- Where is your friction point set on your Exedy?
- stock turbo 26PSI
- What do you think about SeaFoam?
- rev limit (help)
- Need Pics of Installed Stock Intake Manifold
- 403whp Mustang Dyno FPgreen
- who has a cosi m2 evo 8 dyno chart?
- Forge WGA Issues (I think)
- Mishimoto intake
- 2,3 EVO GREEN & GSC.2. cams.
- backwards motor mounts
- Cam... Help
- 100% Meth burning up IAC Valve
- Help With Meth
- help! asap!!
- Evo 60 trim?
- Converting WR8 to TME turbo
- Misfire Issue, plugs not gapped correctly?
- engine dyno
- Mitsubish Evo Green Turbo
- Tanabe Downpipe 03-07 EVO
- Torco Accelerator Fuel, answer to unleaded race gas??
- Boost Leak at Throttle Body??
- MR 6-Speed Transmission Drain/Fill Plugs
- Suddenly Super Rich
- 57trim 100oct pump
- bearing noise
- Turbos: #80 vs #71. Cams??
- All headgaskets are not created equal
- Where to get injectors flow balanced & cleaned?
- Does the ETS Stock Battery UICP work with Buschur MAF Intake?
- What this sound makes you think its the problem?
- cosworth 2.2L?
- Necessary tools for degreeing cams
- jun cams
- Loud pop?
- Who makes the better turbo? Precision or Garrett??
- non chromed out pipes
- most reliable and consistant injectors?
- anyone running fp-grn w/gsc s2 cams?
- Precision turbo to AMS...for real!!
- boost spike?? or what
- another random misfire thread! P0300
- Just went large at GRUPPE-S
- Valve Spring Compressor
- What is oem valve retainer to stem seal clearance?
- Finally got my FP green installed
- MBC or EBC?
- need help...very advanced timing!
- Transmission Question Evo ix
- Idle issues and the vent control
- Pulstar spark plugs.. Anyone tried them?
- ACT MB7-HDSS Clutch Kit: EVO 03-06 any good?
- Upgrades questions HKS 2835 Evo VIII
- how-to 2003 clutch install?
- ACT HDSS and 6-speed??
- After Market Clutch Reliability!!!
- Have problem
- Gt45r
- EVO8 Flange "Full Race" Manny?
- Little help please PCV valve.
- MR Transmission Swap
- Another Evo 9 cam thread
- Evo IX 20g
- Best Turbo Back, under $1,000???
- BR cast mani turbo kit with ETS fmic
- Little Project: Porting & Polishing Evo IX Stock Intake Manifold
- evo ix oem catback ?
- clearance questions
- 500 to 550 WHP on stock engine?
- Sticky Throttle...HELP
- Honestly... what the crap
- Normal PTE880 fitment?
- Amsoil gear oil
- windage tray / crank scraper?
- HELP - what OIL? in carbonetic LSD's
- Which HFC?
- Green 20G 9LT Ball Bearing conversion ?
- Cosworth Cam Users on Stock Valvetrain? Need feedback please?
- Ball style tip injectors vs Pintle tip injectors?.....
- Code came on, VSS
- 35r anti surge compressor housings.
- do i need to gap oem stock plugs for the ix?
- FP evogreen SS race pipe fitment issue (PIC)
- Ralliart Super Direct Twin Clutch
- Well I got questions i hope you got answers
- Thoughts? Evo 9 setup.........
- 10.5 hotside?
- IX Turbo issues
- GSC 272 or GSC S1 series cams?
- Tial Valve Seat problem
- Intake manifold testing.
- Evo 9 Spark Plug List, Also how to read plugs.
- AMS Lexan Window kit... Any Interest?
- GM Maf install
- Tcase Blown!!!??? help
- Crank Pulleys
- Problem with Hotside Read plz
- Advice on Test Pipe
- How much top end in hp would a full race twin scroll gt30r lose compered to a ams kit
- Arp Head Studs
- Inectors and ARP head studs
- your mod list~help
- Big turbo with stock intercooler
- Bleeding lash adjusters???
