- Transfer case oil (sorry)
- 2qtrs of Oil but Oil level on dipstick is sky high!?
- Misfire!!!!
- Evo 8 Vs Evo 9 Block Differences?
- DSM 4g63 t3 headers Fit on evo 8 stock turbo???
- Shifter very hard to move.
- Buscher 35R Top Mount Kit?
- AEM Wideband
- Car sputters and bogs at higher RPM?
- hmm, weird oil leak.. help!!
- Measured backpressure on stock turbo
- Hta Fp3065
- Intercooler Pipe w/Magnus Intake
- To stroke or not to stroke PDF
- Need Help
- Mod help?
- 550-600WHP 1/4 Times
- Need pics of 9 and 8 hotside pics for project
- This has been bothering me for the longest time...
- Best drop in 85mm piston rod combo
- Sweet!
- Tensioner tool
- Low boost question..Help
- p0138 code
- lost power - where?
- new clutch?flywheel?rotors? your take
- Question on Buschur Turbo Kits
- Buschur 3065 cast manifold kit whos running it and what do you think of it?
- HELP! Fused Throw out bearing
- Weird squeak I get when I shift fast...? **Video inside**
- FPGreen Dynos @ 452whp and 442ftlbs on VP MS 109 (unleaded)!
- Cam Timing Changes After Block/Head Work
- Where to buy a Stock Air Intake?
- Clutch Review I read
- E85 question
- can't decide
- can't decide
- Ebraking with ACD
- Serious Help Needed with 2.1L
- OS Clutch VS Exedy twin plates HD
- oil leak near intake manifold
- uber fluttering after IX DV install
- intake manifold
- Nuts/bolts for mounting propeller shaft
- Thermostat to hot?
- 2.3l + Gt3071r?
- New Engine Time But Not Sure Of What To order
- what else do I need?
- Evo IX turbo worth the upgrade?
- purchase 3-3.5" blow thru?
- cosworth cams evo ix people
- Pic Request: Aftermarket o2 housings with stock heat shield
- New Transfer Case??
- project car
- Pics of installed intercooler piping
- best ehaust for evo 8?
- agency power turbo kits??????????
- New to Evo's- Please help
- stock evo 8. . . what are the 1st performance to buy for it
- hks blow off valve
- p0300
- 400WHP Clutch suggestion
- question about a downpipe
- Question about Intake Manifold!!!
- Tubular T3 exhaust manifolds
- anyone have HTA35 with cast manifold?
- Things to know about the diffrent Transmissons per year and model
- Going to bleed clutch, which brake fluid did you go with?
- Blow thru MAF?
- 272 or 280? And what injectors?
- idk what turbo to go for
- Downpipes (Mine's & Monster Sport)
- which electronic boost controller are you using
- 50 Trim 03 Evo
- replaced throttle body shaft seals, now throttle sticks.
- Opinion on Clutch
- Tanabe Exhaust Horsepower
- Upgrade Turbo question How more power can FP Green produce for me?
- I need a complete boost leak solution
- hey guys i got a SMOG question.
- boost controler question
- how to get over 400 hp
- clutch slipping?
- cams or upgrade to evo 9 turbo
- BR 37R HEADER COATED and BR COP INSTALLED!!!
- What Would You Do???
- stroker questions
- Has anyone toyed with the idea of dropping a 2jz in their Evo.
- need help for final step in rebuild!
- dp to o2 install
- which intercooler..
- ANY 1 have AMS FMIC ?
- How far will 780cc injectors take me?
- Exhaust Manifold pics
- the fq-400
- Rear LSD Problem?
- injector stuck open
- 1st Gear Issue
- motor install almost done
- Condition of my 30K stock spark plug
- evo 9 turbo in evo 8 and evo 8 turbo in evo 9????
- Why people should heed the advice.....
- 2.3 IX, 37r, 600+ whp pump/meth
- Qucik injector question
- exhaust dynos
- Evo 9 MR oil drain plug crush washer question
- turbo question
- Where to look
- release bearing came apart?
- Pics of external wastegate on stock turbo?
- Dyno runs on Sharkbite2000's amazing AMS Evo IX
- EVO8 KAAZ rear LSD setting
- Ebay N1 Catback Exhaust Evo
- i cant decided on boost controller
- When Do I Need......??
- my custom built hybrid 6 puck
- Need part# for T-case bearings!! Help!!
- Two circle/dots - what is this in the trans?
- Questions about parts n such. Need some help
- Turbonetics GT-K turbo kit, is any one using this turbo?
- Exedy Triple HD
- i looked for my answeres and i couldnt find them, cam Qs
- seriously guys, last one about bovs, i swear,just answer my question honestly
- Buschur Racing..... Coil on plug ignition clarification
- My throttle cable has shifted itself? Pic inside
- Just upgraded to a BR3065, should I put the heavy RED spring in Forge Diverter?
- Transmission oil
- Spool on an a FP green DBB conversion
- Another new PUMP gas record, thanks Driven Innovations
- **Stock Manifold porting debate**
- HP level and drivetrain
- hks hi power 30th anniv
- Hi-flow 3" Cat By Perrin JDM compatibity
- Just the first of many new parts I'm building
- quick question
- o2 sensor help needed.
- My poor 35r
- ACT 6 puck sprung or unsprung?
- ACT HDSS Needs Adjustment?
- does anyone have any videos of there bovs, and i gota question
- Overboost problem
- Funny smell, probably okay?
- fuel injector upgrade needed?
- Stainless, aluminum, titanium bolts/nuts
- Wanting to have my 2.0L built by Buschur, but need a little imput on the total cost!
- 91 oct. + FP-GRN = 409whp on a dyno jet
- Boost Pill advice
- Stock turbo question
- Opinions on what to do...
- throttle body vacuum ports
- need help greddy profec b spec II wiring
- 3071..3076...3065
- Should I be disappointed DYNO GT30R
- Intresting Engine Pic
- Stock MAF Blow Thru?
- Anyone know what boost controller this is?
- Transmission/Drivetrain Info
- piston four chunk gone
- Got GT3582FP turbo
- blown engine in a evo 7
- Is this possible?
- question on trans case
- weapon-r intake manifold
- Benfit to Replaceing O2 Housing?
- proper leak test question?
- What is the fastest spooling turbo?
- bearing question
- Walbro 255 variations and that pressure relief valve ...
- Even More Boost?
- random cylinder misfire problems
- check this out for me
- P0234 + 3" turbo-back
- ebay clutchs
- What's important and what's not for making power...
- Just got my DNP manifold ?!
- Anybody running that HTA37R yet?
- 6 speed bad?
- Will I gain or lose power..2.75 or 3 in O2 housing?(HTA 35R)
- BR cast mani vs tubular
- Issues with fitting Buschur Heat Shield
- Cosworth ix cams, arp headstuds, install: how much did you pay?
- Engine rebuild Evo 5
- Greddy turbo kit for e9
- Borg Warner s256 VS Gt30r!!
- Extremely rough idle this morning
- Help with slave cylinder install
- Boost Creep.
- Tanabe Downpipe?
- Crower titanium retainers
- Tranny rebuild time
- Hooking up Tial wastegate to MBC?
- OMG,will someone tell me what bov to run that is loud and wont screw up my car
- Is there like a 11.2 hotside for the stock 8 turbo?
- Engine Noises!
- Gscs1 Cams, Are They Marked???
- AEM or ECU FLASH
- Hey does anyone know if Blitz Nur Spec R drones at freeway speeds?
- shep tranny/ 1 & 2 doesn't work
- Differences between housings
- BW ET50 Trim Dyno
- Fifth Gear Slip?
- Boost noise
- Another Engine Whine Thread
- cosworth crank scraper
- ACT clutch - real or fake?
- Fuel Injector Question
- Weird problem with the car being in neutral
- Where and how much u pay 4 tune?
- No I Do Not Have An Hta37 Or A Red.
- Is my clutch starting to slip?
- RRE X Clutch and Flywheel! Noname
- Megan Exhaust Mani Arrived
- Tomei Powered Stroker Kit!!!!!!!
- has anyone heard anything about skunk 2 parts
- so what about a greddy bov
- P0171 Lean Condition - Could be EGT Sending Unit???
- Stock block with Gt35r and nitrous
- Brian Crower Camshafts??
- WitchHunter Performance or RC Engineering for Injector Cleaning?
- Hotside porting and coating...
- DC Sports exhaust manifold
- Oil fittings
- Stock IX JDM MAP shows full boost at 4000RPM
- abs fuse and the acd
- Running atmospheric dumptube with beatrush undertray?
- Prosport Manifold
- tuning questions, just a few
- Megan Manifold Precautions
- Got more parts today to complete my 10sec street car project
- anyone running this?
- Titek downpipe and Ebay o2 housing question
- Tranny issues?
- Comp Cams For the IX
- Check this out. Timing Belt/Head Gasket
- Pedal Vibratation. Need Sherlock Holmes
- What are the Best Evo IX Cams??
- Evo making a couple strange noises??
- Air Filter for GT35R Evo8
- Opinions on Brian Crower cams!
- new clutch
- Exedy Stage 1 clutch...questions
- Divided housing number?
- 500whp on stock rods and pistons?
- Shops in my area
- SIZE="3"]Since venezuela That turbo? Gt35r or t67 ballbearing
- How is this TDO6 20G?
- Sheps Syncro trans or Sheps dogbox
- Which power pakage ?
- Another Clutch Thread
- WORKS 70mm DP and aftermarket o2 housing compatibility
