View Full Version : Evo Engine / Turbo / Drivetrain
  1. found cause for my random misfire
  2. Exhaust Header Flange?
  3. Things to do while pulling head.
  4. Will i pass smog with a turbo upgrade?
  5. MAP censor placement. What can and cant i do ?
  6. !HELP! gear jumping out of 4th gear
  7. Innovative LC-1 WB troubles.
  8. need help on tuning..
  9. spark plug problem???
  10. Losing gear oil from TCase after clutch job
  11. Review: Magnus Sheet Metal Intake Manifold w/ Dyno Gains
  12. HKS Final Drive
  13. 50 mm Bov Fluttering on GT-35r?????
  14. BR 40R kit. Does anyone use it?
  15. Which exhaust would you pick?
  16. TME or IX turbo upgrade
  17. Another Buschur HTA GT35 Record w/ Bad Bish !
  18. atp 3071r results
  19. big problem with my evo
  20. bad idle 2000rpm
  21. HKS bov problems help!!!
  22. Weard metal noise, Please help.
  23. Which engine builders use rod bolt stretch guages?
  24. Cosworth M3's too big for FP Green??
  25. problems with my evo
  26. This mark on my TC mean anything?
  27. Anyone with Aeromotive FPR Experience ?
  28. Where to find over size rod bearings?
  29. Spun rod bearing. What to do ?
  30. Fuel Injectors
  31. spark plug gap
  32. Are topline hidraulic lifters good?
  33. so my tranny is stuck
  34. Hidraulic lifters issue
  35. FMIC question
  36. stock intake mani pics, who has them?
  37. to twin scroll or not to twin scroll. T3 housing comparison
  38. Magnus Motorsports proves that their Intake Manifold works on an EVO
  39. bigger turbo
  40. This time, I am in need of help
  41. Who has tranny building services?
  42. Valve Cover Breather Filter
  43. Max boost on FP GREEN
  44. Superscout03's bad ass IX with Gt3065 507 whp pump gas and meth
  45. what have I done
  46. stock intake manifold
  47. Fpgreen+gsc S2 Cams
  48. need a clutch ASAP
  49. Where to buy upper radiator hard pipe?
  50. evo 8 engine problems
  51. Max safe power stock internals
  52. In Need of Harness or Connector
  53. boost controller not controlling boost?
  54. Clutch Engaugement has moved itself from bottom to very top, why?
  55. EVO RS Serpentine Belt
  56. 85mm drop in's, what checks to do??
  57. Car is POSESSED PLEASE HELP!
  58. MR 5th/6th Gear Problem Revealed!
  59. New Clutch? Or Not New Clutch? That is the Question...
  60. boost drop
  61. Tried to search. SUPER response
  62. p0171 code too lean
  63. why wont it move
  64. JUN 272 or GSC S2
  65. hta 3071r?
  66. Line Lock for an Evo?
  67. new green turbo
  68. HTA 35R really worth it?
  69. can I leave the stock BOV in place with no vacuum?
  70. Weird clutch episode
  71. front motor mount
  72. Raising the boost
  73. Anyone use Brian Crower Pro series rods in there motors?
  74. Tax Check... Cams + tune or FMIC + tune
  75. exhaust issue's, need opinions
  76. ETS uicp vs Nisei uicp
  77. Pressure in valve cover?
  78. Wastegate ?'s
  79. Buschur Uicp 1g Question ?
  80. whats this hole in the exhaust port for?
  81. TS or TIAL housing?
  82. Mechanical Advantage(s) of Multi-Plate Clutches?
  83. Will a 65mm throttle body help any?
  84. What do these codes mean?
  85. exhaust choosing help!
  86. hey guys i need help! sputtering and low power problem!
  87. TILTON or EXEDY... PLEASE CHIME IN!!!
  88. quick question boost controller related
  89. Straight pipe?
  90. Problem
  91. Just started up the soon to be Highest HP 2.0 EVO again! (sorry no bro's)
  92. Results On Cossworth M3 Cams???
  93. HTA TURBO'S CHECK IN,HTA-35R,3076,-3065- T4Z 88mm-ect-ect-
  94. Annoying sound!!!?
  95. Buschur Hta35r Cast Mani Or Tubular?
  96. AMS to now offer the FP HTA series Turbos
  97. Will not run right...please help!
  98. Calibrating VEI AFR
  99. Low ACD Fluid?
  100. HTA35R vs Fullrace GT35R (twin) vs AMS GT35RL
  101. Another best bang for the buck mod!!!
  102. fuel pump questions
  103. leaking bov
  104. Anyone try the Forced Performance IX cams yet?
  105. What down pipe for Buschur 3065 cast manifold kit?
  106. delco remy bcs
  107. Best downpipe/ecu combo?
  108. Highest HP 2 liter EVO
  109. Ceramic Cat vs. 100 cell Metal Substrate Cat
  110. HKS DLI II Problems
  111. Cosi M2 vs GSC S1 Evo 8 dyno compare / FP-Grn on 91 octane
  112. SUPER lightweight Carbon fiber rotors, interested?
  113. Ask AMS and Buschur Part 1: 2.0l or 2.3l?
  114. Results of a blown HTA 35r (Pics)
  115. Increase in boost
  116. ETS 61mm kit has arrived + some misc. parts
  117. Anyone running tomei ix cams
  118. HKS 2.3 Stroker+ HKS Cams+ Cosworth heads with ferrea valvetrain+Full-Race GT35R?.
  119. Guess what went wrong
  120. power steering
  121. Exedy twin plate almost broke my tranny!
  122. how can I cover the turbine housing
  123. Important question for the tranny experts
  124. Test Pipe VS 130 cell MS high-flow cat
  125. What intercooler are you running with your 3065?
  126. Decisions, Decisions???
  127. So i ordered my full race twin scroll 30r 3076 .78 full turbo kit today!!
  128. Cam gear options???
  129. Turboback with E- cutout
  130. ACT Street Clutch/ Gruppe-S Flywheel (OR) Exedy Stage 1/ Gruppe-S Flywheel
  131. zEvo: New pistons and rods for the 2008 engine setup.
  132. Evo 8 tranny
  133. Results for FP Green WITHOUT doing up engine
  134. Brian Crower or Supertech?
  135. EVO VIII Head...on a IX
  136. What BOv has v-band?
  137. VP Import and stock Gas tank is a bad deal
  138. Pauls Build for 2008
  139. Water in catch can???
  140. how to tell if camshafts are really brian crower 272s
  141. evo green manifold options
  142. turbo xs down pipe what o2 housing will work
  143. Clutch Suggestions
  144. Another Slim Fan Question
  145. Another BR, 93 octane, 500+ whp build, no problem
  146. Cams Question
  147. Worth upgrading to HTA 35r ?
  148. 50 trim
  149. Please Help!
  150. Is the Injen LICP any good?
  151. Intake help
  152. AMS 3" Turndown
  153. F%$& lots of damage to MOTOR???
  154. Straight Pipe no cat Video GT30R
  155. LSD problems?
  156. upgraded oil feed lines
  157. weird problems helpp!!
  158. Drop in Dual Valve Springs set?
  159. Arc Fmic
  160. BR Cams-Need Info on these please?
  161. tranny/gearbox?
  162. Hood insulator necessary?
  163. leak found, need advice
  164. Full-Race twinscroll GT35R+Cosworth Heads and Shortblock+Cams.
  165. Aeromotive fuel pumps?
  166. Jun 272's, GSC S2's, or Revolvers for new setup??
  167. USA Pump Gas Dyno and Track #'s
  168. Peakboost FTW kit with GT3076R
  169. Hydraulic TOB failure
  170. TRE drivetrain fluid recheck recommendation
  171. ? Best turbo for running e85
  172. Turbo not kicking in!
  173. What kind of press do I need to swap out motor mounts?
  174. need help deciding which clutch kit & flywheel
  175. Green + Meth + 2.3L?
  176. atp 35r numbers
  177. Injen UICP and LICP
  178. Shifting problems
  179. My AMS 2.3RR 37R Build
  180. Anyone running dry sump
  181. Time for a race head! BR, AMS or JAM?
  182. Idle issues after cams/tune
  183. battery/alternator problems
  184. Very low vacuum and terrible idle
  185. Evolution Ebay Front Mount Intercooler
  186. 1000cc or 850cc
  187. Tranny Question???
  188. Question about timing belt change. . .
  189. Water Pump Pulley
  190. Having a misfire issue between shifts, will HKS DLI fix this?
  191. PLEASE!!! ANY ONE using Supertech DUAL Springs and Retainers Chime in!
  192. Walbro 255lph fuel pump
  193. hks mivec 272 cams no rough idle
  194. Should I upgrade my valves?
  195. Which turbo should i get
  196. P0301 and P0300 Misfire Codes MR 6 Speed Specific Mitsu TSB!
  197. Evo 9 Turbo Or FP Green??
  198. Alright. This 0300 (and related codes) is something that needs to be solved.
  199. Loss of shifting feel
  200. What brand fuel do you use to gas your evo?
  201. which cams?
  202. Transmission Help?!
  203. Gt3076 Hta
  204. What am I missing?
  205. Just got tuned by Ivey overboost?
  206. exhasut question about knock
  207. Head O-Ringing???
  208. Forged Recirculating BOV Boost Cut while Cruising
  209. Honest opinions on short shifters?
  210. 30K Service
  211. ams 35r or ets 57trim ??
  212. Throttle Body
  213. Dual Valve springs set question. Urgent!
  214. How to tell the difference in a 30R and a 35R compressor wheel?
  215. Greddy Racing Ti
  216. anybody runnin these plugs?
  217. Help Me Adjust Greddy Type S Bov!
  218. Anyone running Injen UICP with stock intake tube
  219. Another day of dyno testing with Buschur's RS.
  220. Looking to get into the 11's
  221. Engine Build questions?
  222. Intake hard pipe question
  223. please help.. engine keeps dying
  224. Lower intercooler pipe gasket part number
  225. Part # for coolant overflow?
  226. Adding a "cherry bomb" to my AMS TBE??
  227. Eneos vs Amsoil
  228. ngk b8eix
  229. GT4088R on a 2.0L, searched..but haven't found much!
  230. Two great tastes that taste great together...
  231. How many people have made OVER 550whp WITH:
  232. Evo8 20g
  233. Borg Warner s256 VS. Precision 50 trim.....
  234. turbo xs fmic...
  235. Rear o2 Sensor (Cat/TP)
  236. motor and trans back in...motor acting up..at idle and stops
  237. Damaged Transfer Case pictures
  238. Greddy Titanium Cat-Back For Stock Exhaust and $450
  239. Where Do I Start With Engine Mods????
  240. Aem Gauge Problem
  241. Help Installing Exhaust Manifold
  242. Evo IX Compression / Leak Down Problem - Need Advice (Long Post)
  243. what size to get?
  244. Which would be the better cam set for me?
  245. Financing?
  246. BorgWarner S256 Dyno Results!
  247. Borg Warner s256 NO COOLENT THROUGH TURBO????
  248. should i bother with UICP?
  249. Does Exedy Twin Hd really make a noise when you release it hafl wayf???????
  250. Head Studs really needed?
