View Full Version : Evo Engine / Turbo / Drivetrain
  1. oil recommendations!!!
  2. Anybody Seen this downpipe?
  3. axle questions
  4. which downpipe
  5. Changing drivetrain fluid made easy!
  6. UICP or not?
  7. Greddy Evo2 Catback
  8. ACD fluid??
  9. Megan Type 2 stealth
  10. HTA 3076 turbo owners What injectors are you using?
  11. installed cams, fuel problem
  12. To Cam gear or not to Cam gear?
  13. Evo IX FQ360 tuning help
  14. Fuel System
  15. which plugs?
  16. Green hotside vs. regular 10.5 hotside: different?
  17. F1 stage 3 clutch
  18. Injectors needed w/ cam install
  19. Installed Mynes turbo manifold
  20. Axle Seal Question
  21. what size injectors??
  22. Blow Off Valve Question
  23. Dont know where to go from here...
  24. desial engine sound after build
  25. What's this clicking noise?
  26. Buschur mini Radiator??
  27. hallman pro question!
  28. Hyper Ground System?
  29. Help with test pipe
  30. Whats the best single scroll t3 manifold that gives the fastest turbo spool and best
  31. tme turbo
  32. Problem With Tranny, I Cant Get The Gear In At High Rpms
  33. hks exhaust resonator/driveshaft problem
  34. Spark Tech's 1000+HP Pro Drag 4 System..
  35. Why is my idle not stable???(It went lower) Feels like its misfiring....
  36. 8 vs 9 O2 housing differences ?
  37. Is it my synchro?
  38. Cam gears needed? Advantages?
  39. Mishimoto radiator
  40. new engine soon :(
  41. Gt28
  42. Help With BOV flutter!
  43. check engine light due to no cats.. anyway to shut it off?
  44. need help on curing compressor surge
  45. some maintenance and upgrades to the car with pictures 56k stay away
  46. One step colder plug or 2???
  47. AMS PUSH style clutch install (pics)
  48. Unofficial HKS EVC VI thread.
  49. ETS - Ridiculous Water-to-Air Intercooler + 45R for Paul's (ifarted2) 1000whp+ Beast!
  50. Drivetrain
  51. Help with Forge RS and uicp decision
  52. How do I remove the crankshaft sprocket? *Pic*
  53. ECU patch harness....
  54. High output Alt
  55. Should I get a IX Turbo?
  56. Stay W/cosworths M2 or upgrade M3 or S2 ??
  57. twin scroll 35R spool
  58. Transfer Case
  59. 02 Housing for Gt3076r?
  60. Car is acting up, please help.
  61. Intake and IC Help
  62. Tune or no tune?
  63. O2 housing
  64. Evo9 turbo or 20G whats the power difference???
  65. Tail wastegate
  66. best turbo for 450-550 whp on pump gas
  67. Tach not working please help
  68. evo 7 & evo 8 engine plz help
  69. Here goes again 2nd time ordering a turbo kit...i ordered my AMS HTS 35R
  70. problem need help
  71. front axles
  72. Boost Leak
  73. Installed my Injen intake and IC pipe
  74. Cosworth Mivec 272's Idle problems
  75. turbo/ boost problem need help
  76. megan racing or QTP
  77. 100oct. and stock injectors?
  78. p0335 HELP!!!!!!!!
  79. which meth kit to get to hit my 500hp goal
  80. Alternative Boost article
  81. Q for Beatrush diff bushings users
  82. tps code...car dies when letting off throttle
  83. FINALLY installed my header!!!! VIDEO
  84. Evo top mount manifold
  85. Should I just resurface my stock flywheel?
  86. boost solenoid over boosting and spikes 20-25psi
  87. Question about Megan Manifold/DP
  88. 54 Trim?
  89. AMS NEW PRODUCT RELEASE: AMS EVO VII/VIII/IX Lexan Window Kit
  90. HELP!!! broken turbine tip
  91. MR six speed cold shifting
  92. Gears Hard to Engange on Fresh Rebuild
  93. Shearer Fab... Bling Bling
  94. Hole size for SMC nozzle????
  95. All exhausts that fit Varis Diffuser?
  96. Buschur Racing tests the new HTA3076
  97. Garrett Twin Scroll
  98. 50 Trim +
  99. Length of axles...
  100. Inside my lightly cooked tranny
  101. Bent shifter cable?
  102. Hotside Pipe and Outlet
  103. Tial BOV Question
  104. alright i need some help
  105. AMS 35R plus meth on 91 octane #s
  106. big problem!!
  107. P0090 Fuel Pressure Solonoid Circuit
  108. Stock turbo VS GT3076R Spool time...
  109. Now Available: Push Style EVO Clutch Kits
  110. Help!! No spark
  111. Opening up the hotside on the FPgreen
  112. 35R untuned, can I drive it? AMS
  113. Another cam question.
  114. Code P0125
  115. Question on HTa
  116. Turbo Boost Help Whats the differance?
  117. GSC S2's with stock turbo and ecu
  118. Anybody with the new Tial Q?
  119. Head skin is it ok?
  120. o2 sensor break in period? help, p0171 related
  121. Wheel locks up
  122. Intercooler Question/HELP??
  123. new boost controller problems
  124. Quick Update On Build.
  125. WHICH JEGS/QTP cutout size??
  126. Bruce Crower 272/272 and gears question
  127. What RPM am I capable of??
  128. Another transmission issue
  129. Who sells just the lower I/C coupler?
  130. Exedy HD or SD?
  131. Stock 249HP
  132. Are the IX & VIII wastegate actuators the same?
  133. Need some input
  134. Hks Cams
  135. BC 272 to HKS 280's
  136. What injectors to use (HTA)
  137. power distribustion between wheels
  138. Meth Question
  139. Stock turbo 20g upgrade
  140. People who have changed the Evo8 oil pressure sensor/switch help please
  141. Ultimate Turbo Kit build under 3k
  142. 6-speed MR clutch in a 5 speed?
  143. How Long Did U Wait To Get Your Hta?
  144. My Dyno Dynamics pulls...
  145. egr elimination
  146. Evo Electronic Cut Out Downpipe?
  147. Tranny locked in 5th, yay!
  148. hta turbos vs. pte boosted turbo's?
  149. clutch problem?
  150. E85 stock turbo english racing tune, dyno graph inside.
  151. Force Performance Evo 9 Cams...........
  152. Help identify these injectors
  153. lower intercooler piping
  154. Oil light flickers after WOT runs???
  155. So I changed my diff fluid today, found this...
  156. Gsc S1 Cams
  157. 44mm wastegate VS 38mm wastegate
  158. MBC problem
  159. HKS EVC VI REV grid axis help
  160. car whines when slowing down??
  161. Dejon Tools 4" Intake
  162. E-85
  163. Do I need a new wastegate actuator?
  164. Evo II & III tranny gear part #s
  165. arc intercooler piping?
  166. problem with stock clutch, any advice?
  167. extended or shorten release cylinder pushrod on stock clutch??
  168. Weird Sound Right before Boost???
  169. Full race gt35r twin scroll
  170. drop in piston on mivec EVO 9
  171. evo 8 16g to 20g
  172. ARP headstud torque
  173. Okada Project Plasma Blast Ignition Coils
  174. 16g to a 20g
  175. Drop in pistons, to do or not to do “that’s the question”??
  176. Question on dif fluid
  177. Aem uego widband Help
  178. Perrin boost control solenoid
  179. Brian Crower 272 vs GSC S1
  180. First mod haltech e8?
  181. Hesitating and sputtering?
  182. Who has an APS intake? and how do you like it?
  183. Exhausts: Titianium vs Stainless
  184. Full Race T3 Twin scroll manifold needed
  185. Alternator Installation
  186. new build..... starting problems
  187. Bypassing Factory Boost Solenoid
  188. whats the next step up from a green 20g?
  189. Does anyone use a Slim fan on stock or koyo radiator?
  190. Adjusting Bearing and Carrier Preloads in Transfer Case.
  191. To Wrap the Downpipe or Not?
  192. PCV Valve Question. which vac line goes where ?
  193. WOT-- always 7.35 on the wideband
  194. 50 trim or bigger?
  195. Fluidampr's..........get them while you can.
  196. GT30R Results
  197. short shift ot not to short shift?...that is the question!
  198. br 3065 or hta 35r
  199. quick question about perrin MBC
  200. JDM Evo 9 problem, only 11 psi stock! HELP
  201. A very odd thing happened.......we have turbos in stock.
  202. turbo xs blow off valve
  203. Whats the stock turbo worth?
  204. What springs and retainers for gsc s2's?
  205. Strange power loss problem...
  206. Boost Question
  207. Car wheel hops out of first gear?
  208. Fuel Question Help!
  209. New Launching Aide Innovation
  210. Breaking parts to go faster !
  211. Muffler Delete question
  212. Me and My clutch job!
  213. Need Turbo Help Fast!
  214. My head is spinning faster than a turbo
  215. BR3065 Dyno #s, photos, videos...
  216. flash & cams
  217. help with modification plans
  218. gauging effect of high flow exhaust on turbo performance
  219. Need Help Choosing Turbo Size!!
  220. Clutch issue
  221. 50 trim Pump dyno...Round 2 soon!
  222. Wiseco Wall clearance
  223. Exedy twin SD disk specs
  224. Sickest Evo Fabrications...
  225. Good 12v Keyed Power Source for WB ?
  226. 4th gear grinds sometimes
  227. OFFICIAL: Tanabe Medalion Touring Exhaust Evo 8 and 9
  228. Exedy HD Twin users - I need the installation diagram
  229. 272 cams OEM Lifters is it ok?
  230. BEST Turbo Kit ETS provides...
  231. Removing/Installing Outer Tie Rod and Assemply Passenger Side HELP HELP PLEASE CONFUS
  232. The Box
  233. Factory boost solenoid Problems
  234. Evo OEM Air Filter Replacement.
  235. Meth or Intercooler?
  236. mishimoto radiator
  237. Which clutch to go with on my setup??
  238. Evo IX, 91 Octane, Meth Inj, Cams 390whp/380trq
  239. Exedy HD Twin Weight?
  240. Who here runs their 2.3 stroker motor to 8500 rpms on their daily driver?
  241. Oil change an car is ticking like crazy...
  242. UICP help
  243. Removing Front Axles....
  244. Does anyone know the lenght of the ams resonated test pipe "newer version"
  245. found cause for my random misfire
  246. Exhaust Header Flange?
  247. Things to do while pulling head.
  248. Will i pass smog with a turbo upgrade?
  249. MAP censor placement. What can and cant i do ?
  250. !HELP! gear jumping out of 4th gear
