View Full Version : Evo Engine / Turbo / Drivetrain
  1. Turbos on pump gas
  2. new turbo purchase
  3. RC injector lower seal fitment
  4. Engine swap question??
  5. Where do I mount this O2 for my WB ?
  6. What Turbo did I just buy ?
  7. Reusing the stock crank??
  8. Finally its here Buschur hta 3076. 82 turbo kit
  9. ETS 3065 kit installed with pics.
  10. need some turbo knowledge? any turbo scholars out there?
  11. Alternator bearings?
  12. Recommendations for HFC/Super Catalyzer
  13. 5th gear grind?
  14. Keep Blowing Fuse Number 8 - Help
  15. Maf adapter + cone filter = low boost???
  16. Misfire at idle
  17. hks upper hard pipe w/hks bov.
  18. help with transmission leak :(
  19. Finally found my p0171 issue!!!!!!
  20. Gt3037R turbo o2 Housing
  21. New motor and all
  22. running rich?
  23. bov/diverter valve??
  24. Ok to install walbro 255?
  25. Twin Scroll kits
  26. Camss??
  27. What the dealership said:
  28. Uicp pipe help
  29. To keep or not to keep...HKS 272 or 280s???
  30. Shameless EvoScan Gauge Layout
  31. Anyone use Motul trans fluid?
  32. Evo 8 Forge wastegate on an 9 turbo
  33. ACT HDSS clutch kit or DISC suggestion
  34. Universal Fit Cold Air Box - [BINARY]
  35. RPM jump then drop/Boosting then Dropping
  36. Will this help shield heat??
  37. Tranny Alignment
  38. lifter tick
  39. bad sound after 100 in 5th gear
  40. Timing belt jumped - PLEASE HELP!
  41. Im Stuck/Lost
  42. Ridiculous lack of testing from Vendors
  43. *NEW* tune w/ cosworths
  44. Bad Bish Is Sold!!
  45. Axel output shaft Drivers side
  46. Alcohol Injection specific question
  47. 06 Evo, looking for ACD pump
  48. stripped dp bolt...
  49. Exhaust smell inside
  50. Evo VIII vs Evo IX : tuning potential
  51. Just got My EVO IX tuned with GSC S1 cams
  52. Just got My EVO IX tuned with GSC S1
  53. ams vsr gains??
  54. What power should I expect with this mods?
  55. cam question?
  56. Slipped out of 5th Gear
  57. I gots Mynes today :)
  58. Idle and a/f question
  59. My car feels jerking/hiccup a little bit while cruising...Is it my MAF???
  60. Cams for a 50 trim on 93
  61. Request for Tanabe SMH exhuast
  62. Who makes this turbo?
  63. Buschur cams with a Green???
  64. 780's or 1000's
  65. Lean A/F at peak torque?
  66. Dipstick....
  67. COBB accessposrt p0171 + p0300 fix ATTN: U2SLO
  68. hta 3076
  69. 2-step after blox front engine mount
  70. where to buy .82 housing?
  71. What's wrong with K&N Typhoon?
  72. need help please
  73. The quest for the record.............
  74. what turbo should i get
  75. Exedy Twin HD
  76. opinion onthus turbo and exhaust setup
  77. Coast Fabrication
  78. pulsating suction sound from my blitz sus open pod during WOT
  79. front LSD = stronger Transfer Case?
  80. which mivec cams work best for evo ix?
  81. do i have everything
  82. Need a new clutch
  83. difference between 8 and 9 turbo
  84. Tial Bov
  85. Brian Crower Cams
  86. WHP goal question ( Evo 9)
  87. ACT clutch
  88. e85 and 1200cc injectors
  89. Just got retuned at DTM
  90. Buschur Racing's newest project, higher mileage EVO under the knife.
  91. Part interchange manual.......clutch slave cylinder?
  92. i am stumped
  93. Bad clutch maybe?
  94. The Answer To my very wired problem...
  95. Best MAF pipe?
  96. Just installed Exedy HD tiwn disc, should I remove the restrictor?
  97. Why not all 20G's are equal
  98. Benefit of Factory Air Intake Duct?
  99. Leaky VIII and MR BOVs, is this normal?
  100. HTA on a TS
  101. So, I changed my tranny fluid today and found...
  102. Agency Power
  103. Occasional lag/unresponsiveness
  104. Tial exhaust housing for turbo?
  105. Buschur HTA 35R help
  106. Shifter Question (seems stiff)
  107. Help
  108. 35R Coolant Line Hookup
  109. M3 Cams Results
  110. Got my PPI ported coated hotside :)
  111. 670 AWHP Daily Evo
  112. Biggest Turbo Kit that has no lag, stock spool ?
  113. Evo4 4WD stuffs onto 1.8 4G93 GSR CM5A
  114. Just made 1201 whp!!!
  115. Most Accurate Boost Gauge
  116. Oil light flicker fix
  117. Evolution IX MR 6speed
  118. what to upgrade on my evo 8 turbo?
  119. Car shakes when engine starts
  120. Finally Installed my LICP
  121. warranty issue!!!
  122. Minimum Stock Flywheel Thickness
  123. Installed Cams and tach is not working. Any Ideas
  124. Options for Upping the Boost on My IX
  125. MR won't shift into 6th gear?!
  126. Engine Stuttering/Farting when punching it in 3rd gear?
  127. How long do the ARC filters on the induction box last?
  128. Greddy Profec B-spec II
  129. Buschur Mustache Bar install
  130. Best Turbo Upgrade for my stage 4 VIII under $1000 ?
  131. AMS 1000 HP Fuel System
  132. BOV replacement
  133. how to change driveshaft
  134. Need More Fuel!
  135. HEAD REMOVAL..Some ?'s i need answer too
  136. Evo Balance shaft
  137. 1062 WHP - back tuning on the Dyno Flash Evo 8
  138. Turbo fitting problem
  139. engine "knocking" noise diagnosis
  140. Real quick questions please about Exhaust
  141. Megan test pipe bung location
  142. Gt3065 on Stage IV IX - 2.0 L vs 2.3 L
  143. O2 sensor output
  144. how do i log aem uego wideband to evo scan
  145. installing bigturbo and driving untuned
  146. Help with P0441
  147. 6sp Transmission problem
  148. HTA 35R Coolant Lines
  149. boost question
  150. need an opinion on clutch
  151. idle problems
  152. hesitation problems! i need some help
  153. My last dyno before going Green
  154. first mivec s2 on fpgreen
  155. Would you Recommend this DP?
  156. Needs some help from you tech heads
  157. DC sport downpipe install
  158. Injector Upgrade Advice
  159. Evo 9 FQ...
  160. 1081whp 41psi best so far. More to come next week
  161. black smoke??!?
  162. Help!!
  163. Which Wiseco's for 2.4/evo hybrid swap?
  164. tranny problems
  165. Need an opinion
  166. What Valves to buy?
  167. Is it ok to use a mityvac to bleed the clutch?
  168. weird noise from head
  169. I'm looking at getting a boost controller.
  170. Arc Vs Ams, Etc Ic
  171. 1st pull 28psi 813whp 2nd pull 983whp 679tq37psi WOW just started!!! Going to 55 psi!
  172. Wastegate Pressure Help
  173. Greddy Profec, wtf?
  174. full race ebay knock off!
  175. Best Way to Make 500+ HP Street Car... Wish List
  176. 50 trim dilemma
  177. need quick advice
  178. Need some info guys...(turbo specification)
  179. More lightweight parts to keep the differential in place
  180. While My Engine is Out??
  181. Best price on a Perrin 3" HFC (high flow cat)?
  182. Power Discussion
  183. shift lever feels notchy
  184. My 700+whp build...what am I forgetting?
  185. Spark plugs?
  186. Test Pipe Vs. 100 cell cat
  187. Pressure Plate Wedge Collar Question
  188. Comp 280 Cam Users!
  189. Inside a JAM shortblock.
  190. at what psi is it needed to get ARP headstuds?
  191. New Transfer Case from Dealership.
  192. Help Oil Light On!!
  193. 272 cams..what else needed?
  194. Anywhere to get new version of HKS Cam gear in stock?
  195. Rear diffrential
  196. t3/t4 turbo on evo?
  197. cosworth cams worth it???
  198. whats next..
  199. MBC vs EBC
  200. My Evo at idle (1600cc, 2.3L, PT67, Jun, etc...)
  201. got tuned
  202. SPring racing!
  203. What would you guys do
  204. Ugraded FMIC on stock turbo ?
  205. Downpipe Dilemma
  206. Tial Wastegate spring question
  207. Center Diff - In the gearbox or transfer case
  208. HELP turbocharger evo 9rs
  209. Blue timing belt warning.
  210. Best BOV
  211. *****What PLUGS for my SETUP???*****
  212. Aftermarket power steering cap
  213. EGT gauge sensor question
  214. Losing boost...and didnt do it before..
  215. upgrading spark plug to colder range...
  216. boost lines
  217. 47k and clutch is finally slipping
  218. Cosworth 272's
  219. engine noise
  220. changing timing belt, TDC marks
  221. All GSC S2 users+anybody using S2's on stock valvetrain?
  222. GSC S2 vs. Revolver 272
  223. Knocking in front drivetrain area
  224. Front Diff Recommendations?
  225. Fluid Leak
  226. Beginning my engine build by Ron at Axis Power Tuning
  227. GSC S1 cams
  228. Greddy Rs vs IX stocker
  229. German Castrol VS Amsoil
  230. Turbo kit and gauge decision opinions needed!
  231. Car does not start...
  232. Q Horsepower Synthetic Oil....
  233. Aem Ems
  234. oil filter replacement
  235. Cut up my stock UICP
  236. Best clutch for DD need help
  237. invidia o2 fitment with tanabe dp
  238. Axle seal nightmare...
  239. how many hrs to swap motor?
  240. Prelim Numbers for Twin Scroll Setup
  241. Cloud of white smoke coming form exhasut?
  242. stiff shifter base bushings for MR 6 speed
  243. help a noob, what did I break
  244. photo request: Perrin "stealth" FMIC
  245. 70mm Throttle Body made in Japan! (EBAY)
  246. Anyone Selling A Shep Tranny?
  247. Forced Performance camshaft....Are they any good?
  248. Shep Tranny Help?
  249. Help my car run right
  250. Chattering/Vibration
