- 03 EVO 8 spark plugs
- The baddest EVO 9 pump gas we've built.
- Cobb stage 2 with manifold and 02??
- Flywheel suggestions and feedback please
- Test pipe question
- GT30r OR GT35r
- 5 speed trans X 6 speed trans
- Light weight pulley question
- Ix Rs Finale:) 410whp/437tq
- safe oil temps?
- What ignition for 700-800hp
- GSC S1s on GT35R??
- Stock EVO9 turbo, most power we've seen yet.
- Clutch Setup Question
- ported stock exhaust manifold
- SRS light (airbag warning)
- Autolite XP3924 spark plugs for a IX?
- Evo 5 with 6speed tranny?
- HKS Blow off valve help
- EVO 4 transfer case (Centre diff)
- AWD Motorsports Stock Turbo RS.. 427whp/423tq!!!
- 400WHP+ or BUST
- throttle issue need help
- P0171 Cause?
- medalion touring exhaust on evo 9 rear bumper.
- Big cams little Turbo
- deceleration rattle from engine bay
- lower front strut bar
- quick wastegate question
- spark plug rings leaking
- Ported my Exhaust Manifold
- Where can i found Quaife LSD?
- Is my clutch going out or do I just need a tune?
- Some serious bad luck...
- Pulstar Spark Plugs
- cams or turbo????
- STOCK IX turbo Dyno (374.26WHP and 314.91TQ)
- Hallman MBC leaking boost?
- bad mbc or bad wastegate???
- fuel pump???
- For those of you with an Exedy Twin Disc Clutch
- Drive Shaft Grinding exhaust down
- FP or Forge wga
- Need help... RPM hunting at idling
- Clutch question
- What turbo with stock mani. ???
- In the market for a turbo kit!
- clutch is almost 100% gone.. i got questions.
- Magnus intake manifold.... good bad?
- 6 speed shift cable?
- Turbo Lines Question
- AEM Water Injection Help
- 506whp Stock IX turbo E85
- best cams for fp green
- C16 Maxing out PTE 780's
- Garrett GT 32 series
- Stock Intake Mods
- Pumpgas, 35r-ish guys....
- just picked these up
- Shepard trans
- Oil light on
- Spun a rod bearing...what's the worst that could of happen ?
- MD031805 oil filter
- ???????????? Is full-race going to produce a 37r upgrade????
- HELP! Car wont SHIFT into any gears!
- newbie cam question
- Dual springs = smoke under load :(
- loud knocking on engine acceleration
- Boost issues?
- how high can crower valve springs rev
- Official HTA EVOGREEN thread by FP
- Urgent HELP! Cam install S2
- Ams 1130awhp Video!!!!!
- Can/should I use these cams?
- Anyone running the HTA35r with Buschur Cast Mani kit?
- Walbro wine!!
- what is wrong in this picture?
- Where to buy rear 02 Sensor?
- New 8 T-case Better Than Old???
- Intermittent miss on a IX...advice???
- evo 8/9 6-speed trans Q.
- 12.0 @ 119.8mph
- Stolen thoughts from Simon Norris on T04Z
- oil change + o2 sensor
- Funny idleing
- Boost problem
- used act clutch?
- car issue
- cosworth head + revolver cams compatible?
- burn smell
- p0106 problem... I've searched
- ams gt35 r turbo gasket/sealant questions.
- Unknown boost leak
- stage 3 clutch problems?
- where to buy stainless studs & nuts?
- Meth Or Intercooler
- Need your help Identifying this part!!
- cams installed!
- My fuel pressure??
- Help - Clutch Problem
- What is the latest on DynoFlash Evo?
- 2.3l + BR Stage3 Head + 20g Build
- Greddy Full Auto Turbo Timer
- 5th Gear Harmonics and P0300 - Does it Get Worse over Time?
- Built Head Questions
- Used turbo kit what manifold is this?
- Can 2 in-tank GSS342HP pumps supply enough fuel for a 2.2l / GT42R?
- Advice needed on setting fuel pressure
- I need your help!!! any mitsu mechanics here?
- royal purple 75-90
- T Case question.
- Suman's Revenge - 685 whp on BR cast kit with FP GT37HTA (I was wrong)
- were the HELL is the hole in the fire wall to run wires through
- HKS DLI II Issues????
- Fabled injectors it seems.
- Disconnected the batterie, now evo wont idle???
- mitsu part numbers for evo 9 turbo into evo 8
- differential cooler
- O2 housing =compressor surge?
- Drag Car... Start To Finish!
- IveyTune is BEST (for me at least!)
- SS flange for FP Green
- Potential power w/ 91 oct
- Vacuum Manifold ***Pics***
- Max power with evo 9 with stock turbo with mods on pump gas only?
- Car is acting up. PART 2, please help!
- White Stock Exhaust Manifold, Cracked?
- Power loss through drivetrain
- Boomslang harness compatibility?
- Rebuild stock turbo?
- How much boost in stock form?
- Should I use Loctite when installing my cams?
- difference in evo 8 and 9 throttle body?
- slipping clutch
- Intake questions?? i know i know.......
- Looking to buy a manifold w/external dump
- best 3in angled catback with jdm bumper
- Another IVEYTUNE 690hp
- Biggest turbo for street
- Race gas +2 psi advice
- Oil pressure too high...possibly?
- oem wga or fp hp wga
- Modification Math (stock turbo)
- dyno question
- Retaining Clip...?
- fuel injector installation issues
- 406WHP/373WTRQ, bolt-ons and meth on Evo IX, DD dyno
- ebay 70MM trottle body. plug and play. anyone have this or tryed it out????
- Best cams for the EVO 9
- Help! Im getting sick of asking for help but i could use some.
- 2005 T-case problems...
- Fp green lag
- Where's that elusive Ebay cone filter?
- ets 3' or 3.5'?
- Lift off, car wants to stall.
- How Much HP?????????
- More power with response wanted!
- radiator fan noise
- HTA 35R VS 35R Twin Scroll Pump Gas on both
- Can someone tell me what's causing this? (video inside)
- Red line 75w90 Safe in the TC for 100 miles?
- Bigger turbo stock applications
- Best camshaft for evo 8
- Clutch Clutch Clutch
- BOV Backwards
- Anyone running HTA 35R in a .82 "5 bolt" housing?
- FULL-RACE TWIN SCROLL 35R test results and data
- Ams Liquid To Air Intercooler !
- Info - Looking at the 400 whp question from a different perspective
- which front LSD? - Cusco, kaaz, Carbonetics
- Norris Designs - 830 ft/lb @ 5700 RPM (Shearer Manifold)
- Help!!!!!! Pelase!!!
- which piston for 2.4 ??
- OFFICIAL: Tanabe Super Medalion Hyper Exhaust for EVO 8 & 9
- P0134 and P0125 help
- tilton questions?
- Has anyone tryed ACT MB7-XTG6 clutch kit
- type s fluttering bad help!!!!
- injector question
- FSM Download
- Cosworth M2 dynotune
- Drivetrain Question..
- Switzer 627HP pump gas 35R dyno video
- Dealer replaced your clutch? How much $$$?
- Getting the fluids in the tranny/T-case/Diff
- AMS's WICKED 23rr Install pix
- Boost problems after turbo swap
- Exhaust Piping Diameter Question
- vacuum hose - Need Help
- Full Race Twin scroll Results!!! GT35r
- Turbos
- Sparkplug Help
- Full Race Twin Scroll Data
- Does it matter which springs,??
- The quest for for the pump gas record
- Installed new guages, WTF
- O2 Sensors on Espelir Downpipe
- First time changing TC fluid.
- what the 4th gear?
- 553 whp, 93 octane, just another day at the office.
- Question about replacing the turbo oil line-oil pan crush washers
- starting to think somethings wrong
- Car Fluid Alternatives
- Evo IX BOV stop leak mod?
- Aluminum undertray thickness?
- Noticed something about my shifts this morning...
- New Forge Spring Kit today - Any advice
- knock caused by dampner
- Got the cams now what to expect?
- Dumb question
- Evo 5 speed vs 6 speed help please
- Need help and opinion
- 2.3 guys how do you like your turbo setup?
- Zaklee shifter bushing install?
- 03 evo transfer case
- Does the Greddy Evo 2 exhaust taper anywhere?
- Wiseco-Eagle build...Pics inside!
- Greddy type s Problems :(
- engineers please answer
- ***DTM T3 Twin Scroll Results for 83MM Turbo***
- How to repair crankwealk?
- Time for Clutch...ACT HDSS or Exdey Twin plate?
- Where can i find Turbo Manifold gaskets.
- What does this add up to?
- new cosworth cams? cleaning?
- This ever happen to anyone??
- Photo's of my Green install
- E85 481whp Stock ECU and IX turbo
- 10% Ethanol
- Clean My Pistons????
- Are springs and retainers really really!!
- *vendor* Testing & Product Overview Since 2003
- 2 World Records Set Today!
- Boost Gauge ?
- I have OIL LEAK somewhere<<<<<----Please Help!
- 5th gear grind?
- Turbos on pump gas
- new turbo purchase
- RC injector lower seal fitment
- Engine swap question??
- Where do I mount this O2 for my WB ?
- What Turbo did I just buy ?
- Reusing the stock crank??
- Finally its here Buschur hta 3076. 82 turbo kit
- ETS 3065 kit installed with pics.
- need some turbo knowledge? any turbo scholars out there?
- Alternator bearings?
- Recommendations for HFC/Super Catalyzer
- 5th gear grind?
- Keep Blowing Fuse Number 8 - Help
