- Ebay timing belt kit???
- Need Help Please
- Need 35r rebuilt
- Will a stock EVO 9 Turbo fit an 05 WRX?
- The turbo's full potential
- Need help. . .
- Buschur Racing, HTA35r, 93 octane and 10.0's
- Engine Guru's in here (vendors welcome)!
- grind from 3rd to 4th
- Boost issues?
- New GT35 Killer Turbo - GT850R
- witch mbc should i get hallman pro or hallman rx pro??
- new clutch?
- 4th year in a row into the 9's - Buschur Power FTW! Wild 9.69 pass on a slippey track
- boost leak?
- boost controller help
- TRE vs Shep T-Case Rebuild.
- FWIW, Just DATE your parts, Don't MARRY them...
- What kind if A/F's are you guys seeing
- Full Wiggen's clamp'd intake tract and more custom fab
- Evo 9, GT35 and cams for stock Valvetrain
- Turbo break in?
- 3rd gear grind
- Wire Question
- Regular garrett to HTA? Buschur,AMS,ETS
- AMS FMIC install pics
- vid of stock clutches last day at the track
- 30R / FP Green / Stock IX Turbo Comparison
- problems with using used hks cams?
- Help Quick..
- Ultimate Racing Downpipe question
- New ETS Stuff!!! UICP/LICP/Intake pics!
- engine cleaners??
- Record DSM 35r Dyno Numbers.
- BF272's
- What are the best cams out for the EVO 8????
- s3's on a stock turbo 9
- Ams Evo Cam Test
- 4G64 Crank - Which Mitsu did it come in?
- Not the pump gas dyno record I was looking for.
- Evo IX compression check
- AFI TS Data
- FPGreen Owners: Anybody notice their FPgreen surging during low RPM hard pulls???
- AEM and Knock - eg: Paul Nelson Datalog
- TPG Tuning in Pittsburgh
- BBrooks tuned 600hp pump gas
- Act clutch problem
- Best turbo kit for the street not track
- (superscout03) my 2.3 monster build, tons of pics
- Turbo size =Efficiency
- Which turbo to pick and how to choose
- Which 35R setup is the best? Three Different Shops, Three different answers.
- a/f ratio
- My Stock turbo dyno#
- NEW PARTs
- Dll
- Buschur Skunk Works
- Gsc Or Hks
- Help on tranny/diff how to replace fluids EVO with ACD
- mobile 1 synthetic oil~ what do you think?
- Evogreen + EvoIX= low hp gains
- Testing out my new build today. 38psi 160mph!!! Aem log and more
- AMS 50trim + stock block
- Diff / TC oil change result pics
- Dallas Fort worth help
- 1680WHP - Buschur Racing Pump Gas Domination!
- Buschur Pump gas Evo's hit the track **VIDEO**
- Downpipe/test pipe/O2 housing questions
- 110 leaded?
- Forced performance cams anyone??
- Another flutter issue
- Evo VIII Engine Build
- Clutch Needed (Not basic Clutch)
- strange noise when clutch is floored,please help
- New "Indy" CNC cylinder Head
- *help* possible fuel cut out in MR
- Full Race 35R Twinscroll going on
- Works Evo IX Short Shifter with Bushings Review
- Gear Oil Gurus!! Redline Oil And Oem Fluid??
- detonation?
- How much will it take me to upgrade my 20g 10.5 turbo to a green.
- Pulled the head on my IX and found this! Any ideas?
- Broken front Diff...What next???
- Dyno tuned 357awhp stock turbo on 93 open dump *video* Top Speed tuned
- 353whp on stock 9.8hs,stock cams, stock o2 housing.
- Has anyone heard of BYC racing?
- throwout bearing help???
- Would you do it?
- Hks 264/272
- What Intake for the 35R?
- oil leak help
- Cam differences and Performance
- Greddy Profec B-spec users help!
- Cosworth M2 Mivec IX Exhaust Cam No Engravings.
- Oil Pressure Drops With Throttle?
- i have an odd boost leak anyone with ideas please?
- Is my idea in the right place? MAF Translator
- Whats the cheapest place for Excedy twin plate?!?!?!
- JAM 2ltr shortblock with fp green mapped today.
- Spring and Retainer install ?
- Help diagnose clutch issue
- Hey guys! HP on this evo = ??
- Brian Crower 272 cams/dyno
- AFI Twin Scroll Gt3076r kit.... 56k click before your nap...
- Eliminating the emissons/charcoal canister..
- HKS mivec 272
- Does ECU have any control over boost?
- *sigh* flooded engine
- 499 awhp on pump gas on MD
- PPI Ported Exhaust manifold. Extreme Porting or Regular
- Norman Evo: 10.6 @ 128 with green turbo
- 20g compressor wheel evo8
- Extreme Turbo Systems - Twin Scroll HTA35R Turbo Kit - Twin WG Dumps!
- atp gt35r or greddy t67 25g
- WORKS ABM and 76mm IP
- Using a evo 8 wastegate acutuator on a 9 turbo
- best cams for DD FP hTA turbo
- Buschur Exhaust bits and FP Turbo
- New clutch needed
- Coolant Pump Exploded...
- pretty simple clutch question
- Oil light on dash Problem with Oil pressure sensor
- vacuum hose for boost gauge
- help plzzzzzz
- Tranny and Tcase carnage
- Switched 12V
- CBRD secret sauce turbo upgrade!
- Need help with P0172
- preloading the evo9 actuator
- Drop In Filter VS. Cone Filter
- Buschur Racing Double Pumper Fuel System
- Where to find 1G Flange for Forge RS
- "Indy Technology" for the EVO intake manifold
- Ralliart LICP question
- Power Coming out of the woodwork in the last year?
- Injector Size Recommendation
- ACT clutch questions
- Whats BETTER a KOYO or PWR Radiator?
- 4g63 or 4g64?
- MLR Thread - Remapped Evo X on Dyno Dynamics
- Nice thread off MLR on a 2.3 build with pics (also TS 35R)
- 50trim and hta3076R dyno plots.. and notes..
- Questions about crack in head
- HTA question?
- Do upgraded cams change
- bore size and piston clearance
- Engine Damper? Best?
- How would you go about removing this bolt?
- should I preload
- Air Filter Question
- Has anyone heard of this company???
- My Evo Green vs. Stock IX Turbo Dyno Results
- New CBRD build.... some cool stuff..
- Cam Timing
- Smoke on startup
- Switching Tcases
- My eBay gt35r Kit
- Cosworth M2 Mivec IX Cams need Valvesprings?
- wideband info
- Just got my Buschur 35r turbo kit in!!
- MBC hose size and spool/taper
- 272's or 280's or mix
- rear diff
- what are these?
- Does your transmission chatter with the A/C on?
- More 93 octane numbers, another record by just a few HP
- Stock IX boost reading on OEM gauge?
- borg Warner
- knocking noise..please help
- engine rattle noise
- How to rebuild an APS BOV
- Anyone using the recirculating Perrin BOV ?
- Anyone using the Samco BOV / BPV
- HTA35R First Impressions!!!!
- Why stock gear for drag?
- 370AWHP 341AWTQ now what?
- Boost on 3rd gear pull vs boost at the dragstrip
- Cams, meth, or front mount?
- Fs: 6 Speed Trans
- Redline Water Wetter-other products?
- exhaust manifold
- camshaft upgrade
- Gt35hta on a stock block
- Boost to high?
- downpipe boost spike
- Car not starting again.... P0335 code
- Flywheel question
- Are these numbers average?
- drivability issues
- TF is leaking BAD!
- Crush the IX BOV?
- Tial 44mm wastegate
- Fixed my Lockout problem with my ACT HDSS
- Trouble Removing Oil Filter
- now that the X is on the way, time to start modding the IX, exhaust Q
- What are the best clamps for Diverter Valve?
- Turbo kit install
- Big Oil Leak Problem!!! Help!
- Quick Fix?? P401 Error Code, EGR?
- test pipe question
- Which stock BCS port goes where?
- F1 Racing flywheels
- flywheel bolts
- 35R WHP record?
- *Wastegate debate*
- 10k miles on my IX and the clutch seems to be going
- New TB gasket & still leaking?
- 560cc injectos
- 35R WHP record?
- Cat-bolt dimensions
- car is back together, tuning done with video
- oem transmission parts?
- new turbo time
- Wait time on IX to Green?
- evo9 10.5 turbo
- Anyone use Quartermaster clutch?
- strange noise when taking off in 1st
- mbc hook up for ams turbo kit ?
- Installed my 3" QTP Electric Cutout - Pics & Video
- Hey Guys, please help w/ mods gone wrong...
- 4" intercoolers, ETS or Buschur?
- help newbie in ny
- unequal or equal lenth manifolds ??
- GSC Stage 1 cams installed, wow!
- Start up precautions after long down time?
- FPgreen and 05' differenes
- Tale from the Dyno: ETS 'Super Value' Ball Bearing 58 Trim on VP MS109...
- Diagnose this sound - Video Included
- notchy shifting, goodbye OEM clutch??
- NEW Pump gas record on MD....603WHP
- HTA35r setup, do I need anything else?
- 35hta vs 35r vs Evo green vs 37hta
- What's the maximum Reliable RPM Limit on the 4G63 Head
- STOCK Evo 8 Turbo ????'s Bumping her up to 9 turbo..
- BF 272 Cams STOCK ECU!!! Video Clips
- AMS 2.3RR 42R car from Denmark
- Injen intake with stock upper pipe???
- The evo is alive!!!!! VIDEO
- Solid or 6 puck clutch?
- post your PSI drop for you LICP
- Idle after ported intake manifold and 65mm TB
- Quick Question on Air bypass Hose
- All put together 3065,780's,AEM,etc
- some boost Q
- cone filter or drop in?? please help!!
- question about open downpipe
- Mustang dyno load = street load?
- Pump gas turbo choice
- Tcase bad or something else?
- Best engine OIL for IX
