View Full Version : Evo Engine / Turbo / Drivetrain
  1. Which is less damaging to Evo drivetrain? slick vs street tires
  2. Fan Speed
  3. Need Some Help Guys. Much Appreciated.
  4. Evo 9 swap into 8, Has anyone done it?
  5. hks gt3240 vs apexi rx6
  6. Help EVO VIII Major Problems
  7. hybrid turbo experience - small exhaust & large compressor
  8. Evo 9 turbo question
  9. need help have a list of what to buy
  10. T3/T4 .60 A/R- Worth it?
  11. exedy hyper single rebuild kit
  12. Hi all from a noob. Quick question
  13. what should i gap my spark plugs at?
  14. can't get clean shifts, exedy twin disc clutch dragging
  15. MR T-case and Rear Diff OEM oils
  16. GSC S2's, stock turbo
  17. Exedy Stage 2 Clutch Feedback
  18. Blah, Clutch Problems :(
  19. ATP Turbo kit Dyno results,,,,
  20. I need a coupler
  21. clutch freeplay enguagment????
  22. Anyone ever think about running a cut out on the test pipe?
  23. Major Roadblock! Please Help!
  24. Anyone use the AEM Water - Alcohol Injection Kit?
  25. Who's out there running a 35R and Nitrous Oxide?
  26. estimated gains from bushur parts + others
  27. 6 SPEED OWNERS interested in special tranny fluid?
  28. clutch ?
  29. Driven Innovations Intake Manifold Saftey Notice
  30. SBR 2.5L Put to the test! Slowboy Rally engine takes to the streets!
  31. would this work
  32. QTP CUT-Out
  33. ACT Extream 6 puck?
  34. WOW!!!!! What a Comparison!!!
  35. Problem in wastegate/arm/actuator/MBC? HELP!
  36. Greddy Type S bov
  37. anyone have experience with these manifolds?
  38. Cosworth M2 and MR 02 Housing got 1 extra HP????
  39. Baffled muffler so the cops will shut up?
  40. timing mybe 180 degrees off (help
  41. need help here???????????????????
  42. Pre Lube Tank for Proper Engine Oiling
  43. Which stroker kit? Which crank? Which turbo kit?
  44. High hp but low torque on stock turbo set ups? Why?
  45. Best Oil for a Race Motor??
  46. 2.6L Engine almost ready
  47. PLEASE HELP I have evo 9 GR.A but
  48. Rebuild Head, now problems.. Need your help badly.
  49. Oil cooler before the turbo
  50. 280/280 cam on stock turbo
  51. Go Fast goodies just arrived in Puerto Rico
  52. Convert EVO 8 to Mivec?
  53. AMS 50trim kit on and tuned
  54. Fp green help needed
  55. Help Troubleshoot: 2 dead heater cores
  56. AWD Motorsports Evo VIII.. 378whp / 367tq.. PUMP GAS!!
  57. Exhaust Housing for FPGREEN
  58. Running out of cat converter
  59. HKS DLI 2 or Sunauto hyper force
  60. Effects of a faulty IACV?
  61. HKS 4G63 Engine Oil
  62. Cant decide which clutch?!?!?!
  63. Exhaust leak or normal? (pics)
  64. signs of a bad fuel pump?
  65. HKS 272's
  66. Turbosmart boost controller with AQ HSF-1
  67. turbo oil line problems???
  68. Should I sell my EBC for a MBC?
  69. Dyno Flash Evo ready to battle at next weekends Buschur Shootout ! (dyno video)
  70. Re-Tourqing headstuds
  71. Advice: Installing Head Gasket on my IX!
  72. STOCK BLOCK, Pump Gas record??
  73. Anyone use Jack's Transmissions???
  74. Cusco vs Exedy twin discs..
  75. Turbo XS TBE silencer?
  76. leaking turbo oil drain hose
  77. Ikeya Formula Sequential Shifter
  78. Idle noise!!plz help
  79. evo 9mr growling
  80. 18psi Wga?
  81. NEW EVO what bolt ons to get need help!
  82. Cutouts
  83. T-gt3071r
  84. next step for more power in my 8
  85. Long Rod 2.0L. Anyone have it?
  86. Will my Megan Catback and Megan Cat Delete for IX fit on VIII?
  87. What Rods should I use to run 40psi+ boost?(I have Eagle Rods right now...HTA37R)
  88. Anybody regret going Green?
  89. swaping out stock boost gauge
  90. Injectors for FP3065?
  91. Can I paint my intercooler?
  92. Installing Cams: What Do You Need To Replace?
  93. ETS HTA3076 It's Here!
  94. service engine soon light! HELP!!!
  95. Suman's Revenge Part II - 633 Whp on Pump w/ Meth
  96. Oil Smells like gas
  97. Injen intake with turboXs bov?
  98. Low Hp Need Help.!
  99. Gsc S2's Without Springs And Retainers?!?
  100. Looking to move into fp green territory?
  101. Plug wire arcing?
  102. Question about Greddy EVO2, Tanabe Touring Medallion exhausts
  103. Converting a normal Lancer
  104. 35r Dissappointment then Happiness
  105. Is there a video of an Evo with the launching aide... launching?
  106. Help boost sensor not reading correct
  107. Help Boost sensor not reading right
  108. Vent to atmosphere?
  109. o2 housing install from hell
  110. RPM Acting Wierd
  111. Injen HPK= LOUD
  112. Shep transfer case help (again)
  113. transmission trouble
  114. Belt Snap.... help!
  115. Buschur mini battery kit
  116. does my hp sound right for what i have done?
  117. Royal Purple Synchromax?
  118. weird clunking noise!??
  119. Camshaft Position Sensor Installation Help Needed
  120. cbrd- some different dyno plots...hta, etc..
  121. (MELT-AGE) PULSTAR PLUGS you've NEVER SEEN BEFORE Guaranteed
  122. Question for David Buschur - missing power on pump gas "baby Bish"
  123. 3076 or 3076R
  124. can someone help me decide?
  125. Something wrong with this manifold?
  126. Hitting 350 whp
  127. waste gate question... need help asap!
  128. GL5 75-90 in all tranny !!! Is it ok?
  129. Team English Racing Get's Her Done
  130. 30R vs 50 trim which is better for daily driving?
  131. Alternator
  132. Project 10 second daily......
  133. Evo green power difference
  134. Turbo Reassembly
  135. Pump Gas on the stock ECU wars
  136. Batt relocation
  137. Downpipe
  138. Coolant Leaking after car is turned off!
  139. Defective AeroMotive FPR... Somehow but maybe ?
  140. HTA3076R vs FP3065
  141. Oil leaking from my exhaust mani gasket
  142. Shep transfer case
  143. Where do you guys tap in for water temp?
  144. When do you need to O-ring the block?
  145. Intercooler piping kit
  146. Mustang Dyno comparison.
  147. UICP question
  148. Tuned - couldn't go over stock boost
  149. Turbo Kit Choices!
  150. Turbo Kit choices!
  151. 35r Profec B Settings
  152. Shifter Bushings
  153. aem oxygen sensor help.
  154. boost won't go higher then 15.9?
  155. 24R Owners And Experts; Need Some Advice
  156. Car wont go into 5th or reverse.. and got stuck in 4th.
  157. Install of BOV
  158. Boost Issue.
  159. got some questions on removeing engine
  160. Amsoil Ea Cone Air filters
  161. Top mount vs bottom mount manifolds?
  162. Question to EvoM members
  163. 6500 step not cutting it!!!
  164. Rnr 30r Turbo Kit
  165. Slipping Clutch
  166. Rapid Cylinder Wear??? w/pics
  167. My Goal is anything above 380awhp on my ix
  168. YES or NO on ACT
  169. quick dumb qeustion
  170. HELP!!! oil in intercooler and only boosting 12psi!!!!
  171. another CBRD twisted setup...
  172. Changed the Intake mani = lean air fuel
  173. Spring Type Noise
  174. D@#$ Radiator!
  175. hi i may be a novice but this is my question
  176. Please Help: Want to switch hotsides on AMS turbo Kit
  177. Evo 7 Injectors (Impedance Question)
  178. EVO9, California 91 octane, a little alky and 500+ whp
  179. Anyone use Fidanza Clutch
  180. Buschur Racing Dual Stage MBC Installed - PICS!
  181. Suggestion on what to buy
  182. Clutch Slipping?
  183. Rod bearings issues for Evo IX GSR
  184. AMS Vs ARC Vs HKS FMIC
  185. What's causing my misfire/rich condition
  186. Twin-scroll skeptics...
  187. resistance on egt probe?
  188. Buschur Pump Gas domination
  189. HAFE O2 housing problem
  190. Which Intake and IC Pipes do you have? New product in the works.
  191. EVOLUNCHBOX sets new pump gas record on BR's dyno!
  192. ACT XTSS vs HDG6 6 Puck
  193. Wheres the oil?
  194. EVOLUNCHBOX's build, big power.
  195. it just keeps getting better and better: i have evo9 block with evo8 head??????
  196. help want to reach 400whp
  197. Sneek peak of my new setup!! 56K better luck next time
  198. prosport exhaust manifold
  199. how much power before forging engine
  200. Gearbox Problem?
  201. Which Race Fuel Does everyone use?
  202. buschur racing transmission w/ stock transfer case?
  203. Turbo Change
  204. evo9 transfercase ?
  205. gt35r... help plz..
  206. Making 380WHP with $635
  207. moroso oil pan
  208. Oil Temp Problem
  209. Evo 8 Upgrade Questions?
  210. Video Clip: Cosworth M3 cams, Greddy Ti Catback
  211. typical post turbo charge air temps
  212. hta 3076.82 with cosworth m3 cams video
  213. E85 Evo Green best e.t 11.3 best mph 123
  214. Agency power gt35 on e85 gas results
  215. Greddy charge piping question
  216. Innovate Db AFR gauge issues
  217. Need a 02 housing?
  218. Clutch troubles
  219. Radiator Problem!
  220. Turbo upgrade gone bad
  221. ok i just got my tbe why do i have an 02 bung for the catback?
  222. Anti Surge housing problem
  223. Resurface ACT pressure plate?
  224. Confused: No boost leaks Idling 10.0-.8 afr
  225. Timing belt help (tension)
  226. Timing Question
  227. How many months before the Buschur 93 octane record is broken?
  228. IX turbo or 20g VIII
  229. stock turbo identification/info
  230. Exedy Tripple toasted with cheese please.
  231. Cam install problem on my new stroker
  232. Clutch Slave Cylinder
  233. O2 Sensor - too lean (Bank 1)?
  234. HO alternator yes or no
  235. Hks Dli-2
  236. skunk2 cams anyone used them
  237. experts needed
  238. Does Anyone Know If The Hks Intake Cam For The Evo 9 Is Stamped By Hks???
  239. NEW HTA GREEN tested at Buschur Racing
  240. Magnus Race Intake Manifold OR AMS VSR Intake Manifold?
  241. Buschur Racing-Indy Evo-Weld Tech
  242. Guys with GT35R what BOV do u use?
  243. Hey big turbo guys (GT30/35 Plus,,
  244. Turbo problems
  245. HKS or Greddy timing belt?
  246. Turbosmart E-boost 2?
  247. ultimate racing test pipe
  248. Just Received My ETS HTA 35r T3 Twinscroll Kit and More! Check this out!!! 56k No!
  249. Slim Fan ????
  250. Anybody dialed in their Comp 280 cams?
