View Full Version : Evo Engine / Turbo / Drivetrain
  1. Knock sound
  2. second gear notchy, feel like grinding when it cold - 6speed mr tranny
  3. About Exhaust Mani HELP!
  4. FP HTA3586 Not so sure???
  5. help request, my lazy Evo 8??
  6. boost controller question
  7. Will the FP Red work on the EVO 8
  8. Frequent Oil Changes Bad ...
  9. please help
  10. starter solenoid?
  11. which exhaust?
  12. Bad Boost Creep... After porting ss o2 housing...
  13. Boost Leak Test Problem
  14. bogging inbetween shifts...... why?
  15. Were to Start......Advice
  16. Boost leak test concerns...
  17. Fp red oil line help!!!
  18. HELP: Installing AMS Turboback
  19. tranny plug thread sizes
  20. engine fure keeps blowing
  21. the chump is stumped
  22. ticking noise coming from engine bay somebody help please?
  23. Aftermarket Wastegae on 9 turbo
  24. Weird rattle when idling
  25. Very rough Idle with A/C on
  26. Car Broke AGAIN!!!
  27. is this really a helix downpipe
  28. 4G64 120K engine service
  29. Me and my wife installed then GSC 272 cams today :)
  30. fuel pump help!!!!
  31. Problem with the ACD
  32. What fluid should I be using for here?
  33. Throttle Body Shaft Seals
  34. When Are Springs/Retainers needed
  35. Turbo upgrade help
  36. Question on Boost Leak Test
  37. Transmission Installation
  38. Removing a mangled TOB
  39. ebay o2 housing wastegate port
  40. How to identify a TRUE IX turbo
  41. About BR FMIC
  42. front end noise ? Drivers side
  43. Mysterious Boost Leak Under Intake Manifold
  44. ACT CLUTCH not for me anymore!!
  45. Piston Rod install direction? Scat - Need help ASAP
  46. New turbo install, nasty smell
  47. Synapsis BOV Installed
  48. SpoolinUp COP installed
  49. Slightly Modded Boost Levels
  50. Oil leak after turbo swap!!! HELP
  51. Where does the AMS TBE stand in horsepower vs. noise and what's better???
  52. Transfer Case Problems Please Help
  53. Fuel pressure testing with the BR double pumper
  54. Apagan01 riddle me this.
  55. Mechanical issues diagnosis
  56. help: Clutch or Sychros??? or WTF is it???
  57. ralliart clutch kit
  58. EVO Tuners near cleveland???
  59. Will a Injector driver box help drivability on 1600cc inectors?
  60. Ways to hold boost at higher rpms
  61. Overhearing Issue
  62. Pic request: STD ams tbe tip with jdm rear
  63. Doing my clutch saturday, heres my checklist
  64. Fourth and fifth gear pull feels werid?
  65. Motor stumbles a bit after filling up...
  66. Noob: Are clutch release bearing & throwout bearing the same thing????
  67. Dealer quote for 30k service
  68. New Turbo, To Cam or Not to Cam? - That is the question
  69. Idle Problem and Throttle Lag
  70. spark plug gap, and power loss...
  71. Injector Placement Discussion
  72. guess the brand
  73. need help!! stage3 TC sheperd
  74. small hole in axel boot
  75. Anti sieze on hotside parts?
  76. Buschur Racing Solid Rear Diff Bushing
  77. Need Fuel Pump Help
  78. stock 4G64 crank
  79. Seeking a Clutch.. Help
  80. Help me fix my Trust Ti-R exhaust please!!!
  81. High Compression Help
  82. 37R on stock motor?
  83. tial 50mm bov
  84. small trans problem, rebuild?
  85. Whats a used Cabonetics cc twin worth?
  86. Turbo Pressure and Engine Damage
  87. Help Diagnosing
  88. Decking the head
  89. MT-90 in MR 6 speed tranny?
  90. What is needed to put a viii turbo with a 10.5 hotside on a 9.8 car?
  91. 6sp shifter counter weights removal help
  92. Exedy Clip Pop Problem... does it affect the triple disk?
  93. New TC but ACD still on?
  94. FP white turbo what do you think
  95. GSC S1 vs. S2 vs. 272
  96. Buschur Racing Fabricated Intake Manifold
  97. Twin battle: Exedy vs SPEC
  98. New Evo Owner needing some advice
  99. Can this be done evo 8 with mivec
  100. In Need Of Help
  101. Should I radius this edge?
  102. Beatrush Undertray And Aftermarket Intercoolers
  103. Exedy Twin Rubbing Sound
  104. Which turbo kit is this?
  105. Drivetrain??
  106. Oil Pressure Reading
  107. Evo 5/6 RS diff to replace AYC diff
  108. Reminder - Check Your IC Piping Couplers!
  109. Interesting case of problems on the dyno
  110. Best drop in cams...
  111. E-85 setup, not hitting 11's
  112. Anyone have a Walbro that wouldn't prime?
  113. O happy day
  114. Fuel System for e75... run out of fuel @ 32 psi..
  115. Turbo problem/suggestions
  116. Clutch help!!
  117. LSD Diff
  118. Spark plugs on e85
  119. 03 Evolution 8 Motor Question..
  120. Well... i'd like some advice
  121. stock evo 8 tranny
  122. Balance shaft delete
  123. backfire/popping
  124. percision 1200cc
  125. Downpipe rub: Get tie rod spacers or kart boy hangers?
  126. question about HKS 2.3l stroker
  127. compressor wheel-housing clearance
  128. IX plugs and ignition for 650whp
  129. Whine when turbo spools?
  130. Help: hallman MBC
  131. shifter is very stiff in neutral
  132. What Weight Oil Are You Using
  133. T-case rebuild kit
  134. New fuel system, Aeromotive/Injector Dynamics *PICS*
  135. TPS cel? bov?
  136. Swapping clutch discs
  137. 2.3L Crankshafts?
  138. Oil leaking from temperature sending unit
  139. wedge collar popped off NOW WHAT
  140. found this under my hood!!
  141. 700 whp maybe ?
  142. Buschur Dual pump, how much power?
  143. T case with LSD crush washer
  144. Anyone have good results with BC cams?
  145. HELP!!! Torque tube broke do I need to pull the whole tranny to replace it. Help!!!!
  146. New Exhaust Preview
  147. megan racing 3" turbo back or ?
  148. only running on 2 cylinders
  149. Blow Off Valve Question
  150. High RPM hesitation-HELP!
  151. clutch!! pita
  152. AMS Hardpipes?
  153. Donut Gasket help
  154. help please i have a tick!!
  155. bad oil pump
  156. HELP!! Whining noise at 50-65 MPH in 5th
  157. Tranny Install
  158. Major issue need help!
  159. HELP REMOVING HEAD FROM BLOCK please !!
  160. Build Suggestions-4g64
  161. cam gears
  162. Front drive axles need help!
  163. Higher rpm...into 5th grind
  164. Best Tcase solution?
  165. cel codes p0300 and p0420
  166. Easy 315awhp possible??
  167. turbobackk no tune
  168. Somethings in my intake
  169. sputter plz help a newb
  170. 2006 evo 9 rear diff acd or no acd ??
  171. Upgrading parts?
  172. Swain Tech Heat Treating Vs. Ceramic Coating
  173. Help pls. Huge problem.
  174. Tranny Swap
  175. new rods and maybe pistons
  176. Engine Rebuild Advice
  177. Tanabe Medallion
  178. Mobil 1 5w-30 time to change?
  179. please help!!!!!!!!!!!!!!!!!
  180. Opinions on a good turbo for a 2.3 liter stroker.
  181. can i get a T/S hta 3076?
  182. cams
  183. do i need to get Exhaust gaskets
  184. Looking into my O2Housing...
  185. Evo 8 Valve Question...
  186. RS LSD Diff - who do I turn to?
  187. 10w40 for 380WHP
  188. stock evo vacuum????
  189. FP RED 64mm VS 80mm
  190. Need some help with head removal !
  191. Does my Evo sound Right (sound clip)
  192. need help tranny? misfire?
  193. Need Help!! What is this?? Pics inside
  194. injectors install?
  195. help identify this cam
  196. Ultra-High RPM Dual Valve Spring / Titanium Retainer Set
  197. exhaust leaking at most joints.
  198. Best clutch for a dd??
  199. Exedy Clutch Question
  200. High Compression Engine Build
  201. Seriously confused about spark plug gap
  202. Knock up top with HKS 280's on stock turbo
  203. MAPerformance BS
  204. Having Issues with my car..
  205. Billet Aluminum Fuel Rails for EVO VII-IX
  206. E85 or Meth- Which is a cheaper setup?
  207. An Affordible O2 Housing w/ External Dump? Fairy Tails and Make Believe?
  208. Intake Pipe!
  209. Valve train noise?
  210. Bent LICP
  211. Turbo not boosting
  212. wedge collar trouble
  213. Clutch not engaging or broken trans
  214. boost issue on my buddies 03 Evo 8 GSR.
  215. Compressor Wheel is White and Pinkish???
  216. It sounds like a counter (clicking)
  217. Blown turbo?
  218. need help
  219. Vacuum hose size?
  220. 2010 all out build
  221. Boost compression (what affects it)
  222. Which turbo to gain 400hp atw on pump.
  223. Does jm fab o2 dump cause boost creeping?
  224. four channels egt monitor
  225. Major clutch problem! Help
  226. '03 Evo 8 running warm, possible causes?
  227. Help Needed ASAP! Car not running properly!
  228. Evo 9 MR tranny
  229. only boost controller
  230. 80mm fp red speed density intake choices?
  231. Hks gd pro twin clutch install help
  232. Clutch engagment changed on me.
  233. Nitrous kit questions
  234. Intercooler comparison
  235. The EVO IX Transmission Upgrade!
  236. clutch master bango bolt, How do you tighte /loosen??
  237. Help!! oil leaking.. but from were?????
  238. Help! Need new clutch.. Suggestions!!
  239. 06 mr finally where i want to be 430!
  240. Boost Spike And Running Lean
  241. Help! Cant get transfer case out!
  242. Why'd these rod bearings spin?
  243. Cost to tune an EVO-VIII
  244. mobil one tranny fluid
  245. has anyone run the act MB7-XTG6?
  246. Weight reduction mods
  247. Who makes a better wideband kit? AEM UEGO or Innovate LC1?
  248. replace transmission housing
  249. Exhaust hanger broke off, left hole in exhaust.
  250. are valve springs needed with hks 272 cams?
