- new exhaust mani install help????????
- hks 272 cam question
- Boosting only 12psi...
- 05 EVO MR Help!!!
- 5speed conversion
- waiting for my FP GREEN TURBO
- How bad are these ####'s
- 2-step question
- 9sec9 and OKIX's new Sponsor
- Lots of codes help please
- need fast help w/ wideband
- I'm going through withdrawals needing some David Buschur threads!
- Megan downpipe and o2 housing for sale.
- Evo Green wastegate flapper failure
- FP Green vs. JDM IX 20g
- Straight VIII vs. MR Tranny
- Dealership Warrenty question..help
- Custom FMIC
- Code P0304 Cylinder 4 Misfire
- Final #s for today. More to come soon. 1117whp & 657tq
- Anyone have a stock fuel rail laying around?
- Thermostat question???
- Clutch recommendation for power level
- Car misses when cruising?
- Best manifold/housing??
- VII/IX 20G vs GSC S1
- 2.3 Liter Tomei Stroker Kit
- Electric water pump
- Whats the Best Recirc. Pipe? Apexi Intake/Induction Help...
- 1104whp 45psi 2 deg less timing. Changing out wastegate spring to get more boost!
- AMS Dyno Graph, What Mod Would You Do Next?
- PPI vs Buschur manifold porting
- Should I buy this car? (Compression Test Results)
- No Boost leak, car is boosting at 16-17psi MAX
- Dyno results with new manifold & 37R
- Anyone have experience with Scat rods?
- Waste Gate Actuator Adjustment?? ... anyone?
- Is this decel noise the t/c?
- Torque Specs for Flywheel & Clutch Assy
- Logging observations could save your turbo...
- Does anybody know where I can find a 3.5 inch downpipe for my evo?
- "Four turbo" kit
- Topmount Questions???
- ATTN: High HP Guys!Is Kevlar timing belt better than OEM's? and few more questions...
- Any Used Muse Ported Manifold?
- Has anyone used a Spec clutch in their evo
- Apexi intake filter: IX fitment issues?
- EVO engine swap to 3000 gt engine??
- Turbo choice
- I want to max out my stock turbo with stock injectors can I do so with a fuel pressur
- MAF CEL Light ...
- What else needs to be done with clutch install?
- New exhaust...eBay
- AMS boost controller
- Brian Crower 272 Cams Evo IX Reveiw? Good or bad?
- *AMS PRODUCT RELEASE* Track Only CF Front Doors
- compatability question...
- Signs Of A Bad Clutch Install?
- race gas + cranked boost, defeated by boost taper
- If your fuel injector seal is leaking...
- Solid ACD Lights -- Targeting problem
- stroker kit or built block
- Mivec Cam, Cam Gear hex cap cover question
- Tunning differences Between 70% & 80% Ethanol?
- My Custom Top mount manifold Build by DRIVEN
- HKS cams.. HELP!!
- rev limit question
- Rod-bolts & Exhaust Questions???
- Huge Tranny Problem
- 03 evo sputtering higher rpms
- BR3065 Supporting Mods
- Header help. Give me your recommendations.
- Exhaust flange measurement needed
- spun bearing final update!
- Qustion about BOV? please help!
- AMS 50 trim kit oil problem....
- Please help a service member with a problem
- WOT Problem
- getting close to that mark
- turbo + nos..a question
- ETS Super Value PT61 Dyno Results an quick video
- FP Green finished product
- Cam Question?
- While having a new clutch put in what else should i upgrade????
- 264/272 vs 272/273 cams?
- Boost Issue
- Help Me! AMS 30R, BR 30R or ETS Twinscroll HTA 35R
- Dipstick reading
- FP Green turbo
- looking for a used short block anybody????????
- 06 EVO IX SE interesting motor noise
- Gsc S2
- So it's that time...
- EVO IX Spark Plug gap w/ Big Turbo
- replacing clutch
- Hydrogen Injection
- Dealer Service Burnt Transfer Case
- Weird idle wandering issue...
- SBR Tubular SS Manifold vs Megan Racing Manifold
- 4th gear grinding?
- *PRODUCT RELEASE* Buschur Racing's New "Custom" In-line Boost Controller
- COP that works with stock ecu?
- EVO VIII RS: Install Pics from the weekend. 56K go die.
- What modifications do in terms of tuning... Part 1: Intake Manifold
- IC piping size 2.5" vs 3"
- compression test results
- Best Bang For $ intercooler? (No EBay)
- Best Manifold Header for Stock Turbo?
- Question about oil fill on turbo????
- Short Shifter Suggestions
- im going to be running 400hp
- My ETS Review (ETS Products INSIDE)
- K&N vs. Amsoil oil filter
- Stock turbo - header worth it?
- WTF, Exedy stg 1 clutch lasted 5K miles?
- FUSE repeating problem
- Help Install (GM MAF Sensor)
- OEM replacement spark plug horror story... im stumped
- is it necessary
- Journal Bearing 60-1: How do they Perform ? and what do they compare to ?
- New Record EVO Green! 10.20 @130.9
- aftermarket fuel rails compatible with factory return line hardware?
- coolant flush?
- Selling Apex'i N1 Turbo-back >>$200<<<
- Transmission Bolt
- All Different Evo Turbo Options (Turbos, Specs & Feedback)
- 20 g problems
- Noise from tranny.. is this ok?
- +++ Clutch has small vibration when shifting.+++
- Wheres all my boost at?
- MLR Thread: Full Race TS GT40 Dyno Results
- RRE Clutch and Flywheel + warranty?
- In The Market For Clutch/Flywheel Kit - ASAP
- compression test on a used evo
- Tilton C/C Clutch users, what do you think of it?
- Kiggly Beehive Valve Springs Vs. The rest
- [B]Im getting two different boost readings...[/B]
- HKS cam gears with stock cam cover
- Hunting down a HTA35R
- Forge DV fluttering
- Throwing P0037 - ideas?
- Tranny problems after rebuild!! Help!!!
- how much hp before maxing MAF
- megan manifold
- Misfire code P0300
- Dark Side of DI Intake Manifolds
- Compound turbos - why/why not?
- engine bearings
- New World record Evo Green 10.45 @ 129MPH
- intake manifold problem??
- NE1 running S2 cams with A 30R
- save gas with Ethos... okay to use in evo?
- StockVIII turbo+meth= what HP?
- Spark Tech vs AEM EMS
- drive shaft
- Spun bearing update
- JM Fabrications small battery kit
- JM Fabrication intake manifolds
- Boost problem after clutch change
- New - JM Fabrications tubular manifold + O2 housing
- GM boost solenoid
- what clutch to get 400whp...
- JunB.L exhaust in Chicago area???
- Just another 500+ pump gas EVO.
- How many 10 sec cars are running a SINGLE DISC clutch?
- 264 cams in an evo 8
- Curious what to expect with IC n piping?
- TS requires duals
- BOOST Controller To go w/. I have Searched also..
- What sort of HP gains can I expect from this?
- trans drainplug shavings: is this normal? (pic)
- Need help with an Intake for a 30R
- My HTA37r Buschur Pump Gas Evo
- Getting the HTA30R but which cams?
- Ebc/mbc Or Gm Boost Solenoid?
- New to Evo's, clutch question
- HTA sytle inlet came OFF. wow
- balance shaft reccomendations??
- a Mightier max
- Just recieved my E-cutout from DMH performance
- Whats the difference?
- Pistons????what to RUN
- help guys looking for clockspring asp?????
- HKS Super SQV Blow off valve VS Stock Diverter Valve
- GFB bov
- What Clutch is This? Trying to figure out this Clutch combo.
- Precisions Possible Rival to the 35r HTA???
- Fuel Cut??
- My Dynatek ARC-2 CDI just arrived, need advice
- help with dtc's
- My AMS exhaust has a loud, ugly rattle at 2K RPM. Help!
- ETS Intake / 3.5" FMIC / LICP / UICP / Minibattery Kit
- Want to max turbo out, Ignition and injector Questions???
- Spun Bearing
- Results from switching to a 9 bov or "jdm" bov???
- GT30 vs. GT35r
- GSCs1's installed, idles low now
- 2003 Evo VIII CEL Problem
- Heat Range of Spark Plugs
- Hydrogen powered Evo???, MitsuBeastly
- car bogs hesitates after walbro 255 install! help?
- How To know if ARP Head Studs Installed Any1 ?
- 50 trim only able to hold 23psi to redline?
- Loud clanking noise....T-Case?
- fuel not reaching rail
- Maxing out turbo...
- S1's and lowspeed driving
- Revolver Cams
- DSM shootout
- knocking noise from 2k -4k rpms
- What brand/size tires for 17" MR wheels
- RRE Stage 2E (E-85) 466 AWHP and 393 AWTQ @ 26 psi
- mod list just purchased !!
- loosing power
- Wheel hopping while doing a full turn not sure if its my clutch or not?Exedy Twin HD
- Head gasket issue
- Any results or times from the shoot out
- Eagle Rods and ACL Bearings. Right parts?
- whats the best spark plug to get?
- ISC valve variations...03 - 06 interchangeable?
- changing radiator. How much cooling fluid should I put
- Looking for a high flow cat
- gt3076r vs Evogreen
- Spark Plugs for 400++whp!
- What would you change?
- Miata battery?
- HTA 35R nipple pressure source location?
- Rebuild kit for a TIAL BOV....
- FMIC Upgrade
- Evo Part Out
- 50trim cams
- Basic Trans Rebuild?
- What size ICP
- Stock Turbo!!
- 80mm Test Pipe?
- my head flow gains
- Another pump gas monster 35r evo awakes
- HTA 30R's?
- Retorquing cosworth head studs required?
- Boost problem
- Tial Recirc. Valve
- plz help! shifting problem
- overheating issues HELP
- AEM Logs and Other stuff from Our 162mph pass. Dont make fun of my Granny Shifting
- 20g turbo wheel question
- Misfiring after spark plug install. Help!!!!
- Finnaly done....16G antisurge
- Boost gauge T placement
- T3/T67 HO on anyone's Evo? Results?
- Ok to Tee off fuel pressure regulator?
