- titanium exhaust...
- intake manifold .
- HTA35R Cams?
- Anadized black ETS intercooler durability?
- Need some help and guidance......
- Need help! Car runs bad.
- Cosworth M2 Issue
- Need Exedy Twin Plate Clutch Instructions
- Quick question about Exedy HD Twin Plate
- Intercoolers? How bad are generics?
- Clutch Problem
- ICS PERFORMANCE- George K
- Why ETS is just better then the rest!
- Is this a sign of bad things to come?
- is it okay to resurface an ACT 3200lb pressure plate?
- G-Tech pro timer RR, Does it really work???
- I Miss the Low End Torque
- Pink's ALL OUT ! (New Turbo, New Direction)
- Boost Leak?
- Help!Full throttle = No boost
- Autometer Wideband
- HELP: how is your OEM W/G hooked up
- What clutch and flywheel should i use???
- Buschur pipe with CEL
- Anti-Lag
- does anyone have the fighters garage LICP??
- CNC ported FP Green hotsides and O.E. exhaust manifolds
- how much power i should get from my setting?
- Syncros getting replaced, what else?
- Is radiator fan required?
- Question about exhaust...
- need some help, exedy triple carbon disc alignment.
- works clutch kit 2?
- act street clutch question
- buying a clutch
- Quartermaster Twin Disc from Devo Tuning
- XTD STAGE 3 clutch?
- turbo question
- Clutch Noise?
- Aftermarket Intake Manifolds - whats the deal with EGR?
- whats more streetable act xtss or exedy twin hd
- MBC: What does yours do?
- HTA 35r VS GT850R????
- HELP!! FLUTTER and not holding boost!
- got my slowboy fmic!
- If I decided to buy tomei 280's for evo will their be any negative effects using with
- help needed! stripped downpipe to o2 housing bolts
- Tuned HTA37R @22psi pump gas
- Buschur Cams or Kelfords, stock ecu
- Rear Diff Axle Seal leaking?
- Bruce Crower Cams Anybody???
- Gt3071r OIL RETURN FLANGE?
- Any Advice??????
- ETS 50, 54, and 58 trim
- Stock Intercooler OUtlets
- O2 housing sensor question (had to cut wires, wire question)
- queston about cams
- Clutch adjustment question.
- Best spot for Wideband & Egt Gauges???
- Intercooler tests
- Indy Intake V2 done and tested.
- ACD Problems
- Again...Which turbo should I go with?
- Tcase removal
- How much boost can I run?
- My IX is grinding 5th.... any ideas??
- longitudinal engine in evo ix
- lightweight flywheels and pulleys?
- quston about cams
- Precision Turbo 6765.. Pics of New Design!!!
- I bought a ETS mini battery kit and the positive terminal does not fit snug to the p
- Manual Cut-Out ?
- How long did you wait for ur BR20g-lt?
- Coolant Leak
- Help! IAC or vacume leak??
- Mpg
- fp green not making low end tq
- Precision Turbo 6262 vs 6265
- Is it time for cams?
- tranny starting to go
- Head Studs Question.
- Maxed out 8 turbo, or is there more?
- GT3071R-WG Dual BB, 86AR vs Fp Green
- Mitsubishi OEM genuine head gaskets!!!
- wedge coller popped off
- evo 8 not
- To port my turbo manifold or not to port?
- evo8 and evo9 i ntercoolers the same ?
- Buschur Racing/Indy Evo Carbon Fiber Block Off Plates **pictures**
- best set of cams for 20g evo green?
- If i was to upgrade my internals on my evo motor would i be able to run 30+ psi on 93
- t-Case/Tranny
- Fuel pump options for E85
- Race Fuel ...Too many to choose form?????
- spark plugs
- Where to buy Evo 9RS turbo's?
- QuarterMaster's Lightweight Driveshaft Replacement
- What is the best 2.3 stroker kit on the market? Their are so many choices out their.
- 4th gear....
- GSCS1's + Mellon Tune = 360whp+
- RRE Rally Cat Rattle
- Greddy type s or the profec B spec II
- is there a exhaust section?
- •Greddy Oil Cooler AN fitting•
- Clutch not engaging?
- ATP conversion
- Brian Crower 272 Impressions
- AMS Base Flash
- Maybe it is a dump question?
- Short Shifter & Clutch Help
- Looking for New Clutch/Info
- Random Idol Problem Please help
- What valve springs are these?
- Transfer case
- Brog s366
- Next mods to do
- Converted my 3" AMS catback to the RRE 3" set up
- turbo lagg!!!
- Gearbox wont go to neutral after clutch install!
- 2003 evo 8 Compression
- looking for turbo ideas
- "Help needed" Twin wasegate vacum/boost lines
- Push Type Clutch VS. Pull Type Clutch.........(which is better for 500whp+)
- maximum safe boost
- 2.3 stroker or 2.4 ? help please
- evo 8/fp green/hks 264cams 360hp/310tq
- kinda curious
- Good Mid Range (autox cams) for VIII?
- evo 8 to evo 9 turbo
- Attention all EVOM vendors and members-BR DSM/EVO Shootout.
- Ebay evo 8 TBE fit evo 9?
- How can I make more power?
- water temp apapter
- Cam lift and Rocker Ratio
- Precision Billet Compressor 6265 Turbos Are HERE!!
- Headers
- Whats the best test pipe?
- Is this a Buschur HTA3076 kit??
- Fuel pump and tune question.
- pcv valve comming out of head ???
- Axle question...
- Powdercoating and ETS Goodness
- who makes the best blow off valve? and what problems might occur from installing one?
- Almost stock evo w/ Full-Race Twinscroll 42R and Justice Engine 872whp 700lbft
- What do people rate the forge bov?
- High RPM lockout...help
- evoix+cosworth m2's...forged performance tune.
- 8 turbo vs 9 turbo
- wnat to see dyno sheets of 272's cams with stock turbo
- what next?
- HTA 35R Questions
- Putting in a walboro (sp?) 255 fuel pump saturday
- Exedy hyper single rebuild to twin?
- Hey guys are their any graphs or anything of a evo 9 turbo holding 350tq by redline o
- Green worth the $?
- Exedy Vs. Carbonetics?
- Question about torque and my clutch.
- New GSC S1 Evo 8 Cams for the summer of 08
- who got ams gt35r please tell me your power
- Is this Megan Exhaust?
- Boost Control Issue. HELP!
- Want to get a bigger turbo..
- New Evo.... HKS problem.
- EVO 9 Cams
- Port matching OEM intake manifold to ported heads?
- Excellent PlugIn ecu option (EVOlink G3)
- MR 6speed tranny fluid change question.....don't want to screw it up
- Stock clutch Engagement noise
- 10.5 hotside
- Boost Question-Strange issue
- NEED help with TC and Tranny fluids...i screwed up...
- boost staying the same !!!!!!
- SS Bolts for Exhaust Manifold
- evo8+ fpgreen+ hks272 = dynographs
- Is a Front LSD worth it?
- what type of flange is 18G
- Camshaft seals
- Ebay TBE's?
- You gotta play to pay, I am paying now.
- Vacuum leak? Found lose hose coming off sensor...
- How are my numbers?
- stage 2 Almost Complte!
- Precision Injector Size???
- question
- Header/o2 housing combo - recommendations?
- Oil Temperature gauge replacement
- power steering bolt snapped!
- Short Shifter for 95'????
- Best Clutch and Flywheel Combo for Sub $1k
- 28psi on stock motor and stock turbo?
- Burning a ton of oil??? HELP! AMS stroker
- Mirage VR-X JDM Spec
- boost lag :(
- Head porting. *pic inside*
- +++ Rear diff problem/transmission...Comments plzz +++
- 5 speed...
- co2 intercooler spray help...
- new clutch
- Update on my BR built monster
- Whos actually running a 2.4?
- Oil leak?
- changing boost
- evo 9 stock wastegate actuator vs fp 18psi actuator
- What's the Hottest you have had your Exhaust or Oil Temperature at?
- Size adapter for a compression test?
- car died on a exit ramp
- Its time... 2.0/2.1/2.3 or 2.4 build ?
- Stock Turbo and Alchy dyno Numbers
- Help identify these cams!!!
- Does Anyone Sell A Silicone Hose Kit ???
- Unofficial 28psi+ BOV Thread
- Why Does My Intercooler Hose Keep Coming Off At The Track ???
- Looking to make a 10 sec evo
- Need Help, Oxygen sensor.
- Clutch slipping...kinda
- ean A/F, need assist.
- Anyone using Greddy Ti-C?
- Huge Hallman MBC problems
- Greddy Ti-R
- knock sensors
- Quick Misfire thoughts
- Megan header/External Tial gate
- HELP: Clutch is done in my EVO IX...
- mivec cam install / problem
- good turbo for the stock motor
- Serpentine belt other options besides stock replacement??
- I think then "ics" sensor burnt up again
- evo9 mods what next...
- HKS EVC Vacuum Line Routing
- ? for CBRD radiator users
- Turbosmart BOV Problems! help?
- Evo 9 Cat O2 Sensor
- UICP popped off...anything else wrong?
- Pics of my ACT clutch 423 ft/lbs & 500+hp ...... maybe the cause to my problems....
- Turbo Xs Fmic
- injector question
- chipped muffler tip?
- Finally, an Offical Evolution 02 DUMP!!!!
- Which EBC? AEM TruBoost or Greddy Profec B Spec II?
- Extreme Motorsports 2 piece Aluminum Driveshaft
- Help: My Engine shuts down
- car wants to cut off
- ETS Bits Get'n'r done!
- new exhaust mani install help????????
- hks 272 cam question
- Boosting only 12psi...
- 05 EVO MR Help!!!
- 5speed conversion
- waiting for my FP GREEN TURBO
