- A full 37r build top to bottom...COMPLETE!
- Car trouble, Died while driving
- Evo VIII - HKS 2835 KIT
- An fittings on stock hardlines (fittings?)
- Forced Performance Evo Red Turbo data
- what is GM boost solenoid?
- Car died when alternator went out, Now no power, Please Help.
- who has a Eco maf translator in stock?
- clutch for light upgrades?
- Please help diagnose an issue with my setup
- Lars takes the AMS 2.3RR/GT42 and runs 9.36@152...ON E85!!!!
- Oil Pressure Concern
- Tapping Noise!!??
- Wow the IX bov can be loud!
- White smoke?
- Oil Pressure
- i Hate My Evo! help me!
- Greddy TT features?
- Load before & after mods
- Low Boost
- need help, broken pressure plate bolt
- GT4294R preliminary results....
- need help: installing exedy twin HD clutch
- Soon-to-be EVO IX RS owner looking for 400whp on stock turbo...
- Has anyone actually dyno'd a Fujitsubo RM-01A Exhaust and seen if it lost sig. power?
- Rear Diff bearings?
- Are there 2 version of the Invidia o2 housing?
- Broken Front diff
- pump issues
- Devo Quartermaster vs carbonetics twin/triple
- New Agency Power GT30R Kit
- my evo wont start
- Clutch Master cylinder or just cylinder
- Subframe Bolt Stripped - Any Ideas
- Cam gears now or later?
- Boost issue
- need help
- Really Hard To Shift In and Out 6th
- ShepTrans or Team RIP
- GSC Single Valve Springs w/Chro-Molly Retainers...
- The Perfect Turbo-Back Exhaust?
- Buschur V Full Blower in-tank dual Pump
- Making less power - and having more fun ? Gt42 to Gt37
- hks264s to hks272s on fp green
- APS or GFB????
- where to find evo 5 push style clutch cover
- Walbro Whining Noise
- Anybody have the apexi rx6 turbo kit? I have ?'s for you!
- Buying A New Clutch
- Abnormal noise...
- Full Blown Dual Pump System - Things You Should Know
- Oil Temp in Extreme Hot Weather
- CEL flashing..NO CODES??!!
- T Case Ring and Pinion
- Check Engine Light: Speed Sensor Code!
- Was sold the wrong f-ing clutch
- I need a hot side for stock IX turbo
- Calling out all GSC S1 cam owners..
- Should I upgrade APR head studs?
- sparco intercooler?
- fidanza 2.1 vs ACT HD
- Exhaust Help...think I got screwed
- Cam timming: one tooth off = how many degrees +/-?
- will this pass smog?
- GT35R to 30R
- Exhaust help
- CIMOTORSPORTS??! HELP anyone dealt with them??
- Kelford 280's Idle
- Transfer Case questions
- Gruppe S manifold
- Reverse gear problem
- Another pump gas beast hits the streets of Ohio
- Exedy Twin to Triple from AMS - Plus poll: How long for break-in?
- Boost Leak Test
- 180 psi is this too high
- New Mods, Suggestions???
- Installed Forge UNOS MBC!!!
- damage to intercooler... Can it be repaired???
- Gates Timing belt vs. Greddy or HKS timing belt. Which is better?
- question on mechanical CEL Fix
- ACD Lights/Warranty Rouen Mitsubishi
- Who needs the A/C?
- 9sec9/OKIX's EVO, ROUND TWO!
- 373ft-lbs / 352awhp stock turbo, 91 octane
- Ported Head Gains...
- clicking sound after exedy stage II and fidanza flywheel install
- DTM's RB 2.3 and HeadGames Make a Perfect match!!
- Hks Twin Disk Or Exedy Twin Disk Hd
- What next?
- Epoxy Resin Maf Honeycomb
- Mistake not doing O2 housing with fp green
- GSC1's VS. Cossie M2's
- Fuel Rail Problem
- Buschur 3065 Turbo Upgrade Q's
- turbo and coolent
- need some help guys ,,,plzzz
- acd fluids low!!! help
- Hissing sound at idle near firewall
- ets exhaust
- bad fan belt sound
- Cold Clutch/Flywheel Howl
- How Do These Plugs Look (PICS)
- 750cc injectors & 255l fuel pump - Maxed out?
- Clutch?FlyWheel Questions
- stock turbo taking a dump?
- Alternatives to mini-battery on blow-thru setup?
- First time Evo 9 Transmission replacement
- HELP! licp keeps popping off
- Questions... HKS DLI, 1000cc and more
- Urethane bushings specific to Evo? esp. the rear hanger bolted to the Subframe?
- Can someone help w/ AEM NLTS
- Time for new timing belt
- t3 manifold
- twin dump vs single dump
- acd fluid level check
- help with turbo upgrade!
- Valvetrain rattling, major misfire.....
- greddy intercooler
- Got dynoed today, not sure what to think
- NLTS questions
- Got about 300$ what should next mod be?
- Atp
- MR OEM oil drain plug vs non-MR
- Redline for HKS 272
- Car shakes at idle with AC on.
- Aps Bov Help!! Asap!!
- Magnus Intake
- Help Please!!
- Turbo Guru's Opinion
- Think I fried my clutch tonight
- Idle Problems...need new IAC?
- clutch question
- BR Racing, parts testing, new best MPH and some thanks.
- HELP! No Boost!
- blew motor, suggestions?
- Nitrous on stock head and block?
- We did Steve's Clutch job yesterday!(TTP Tuned 377 WHP Mustang dyno)
- What's this/wrong?
- Could a Clutch cause loss of power?
- My Transfer Case whine problem solved... or solved?
- what else should i do???
- AWD Motorsports/Jestr tuned evo ix fpgreen. 424 on pump!!
- Difference between Exedy Twin SD vs. Exedy Twin HD?
- Boost pill and truboost
- Additional Parts Needed for AMS GT35RL Kit?
- What Happens...Valve Float Video
- Evo 9 stock turbo,upgraded intake manifold and throttlebody ?????
- thanks fsms
- Boost Issue
- leakdown results... suggestions?
- clutch question?
- what do u think???
- my shifter feels clunky...
- Exedy tripple matallic clutch problem!
- RRE Perforated/Louvered Resonators Question
- My Twin Pump custom build
- Oil return line..
- Shift noise??
- New for 2008. HKS AFK
- Cant get Diaqueen in time...Redline?
- any one using these?
- Results from Precision 6265 Turbo on Evo IX!!! 469whp on Pump!!
- Boost controller problem(maybe)
- blown oil pump seal
- sbr stage 3 head how much hp gain ?
- Evo ix T Case
- HKS valcon pro
- Blew my stage 2 shep transfercase tonight.
- Race Head
- Fluid capacities and recommended lubrications
- Need a little help here please
- Dyno sheet of E85 Tunned @ AMS
- Just how bad are the MR 6-Speed Transmissions?
- Oil Light Flickering
- Is there a slightly bigger turbo than the Green?
- Cams or Fuel pump?
- 320 Whp 309 Tq
- oww, my drivetrain! =(
- M2 Questions
- Unstable AFR at low throttle
- New FP White turbo
- BR Evolution Custom Dual Valve Spring ?
- Anyone running the TURBOXS HYBRID 50/50 BOV?
- Clutch Suggestions...
- Got my car dyno tuned at AMS today...you will not believe what they found in my BOV!?
- 5and6 Speed Manual which is better?
- Blown clutch<good news
- tranny/t-case fluid question (no, not about what kind to use)
- Difficulty getting into 5th after shifter bushings
- problems...knock sensor?
- Evo 8 5 speed with evo 9 first gear
- Help, engine shot dawn
- who sells aftermarket oil coolers?
- Popping noise @ high RPM @ 6500 til rev limit, poping noise then Stutter..SPARK PLUG?
- Should I change my spark plugs? Please advice!
- Top Level Hot Import Nights 769hp/601tq
- HKS SSQV Racing type II vs Tial vs ....
- E85 numbers from AMS and other issues..
- Steady boost (tru boost)
- ETS Turbo Back?
- megan exhaust
- mind boggled
- ACD Fluid??
- Boost stays at 12 psi
- Compression Results
- VIII turbo vs IX turbo
- evo 9 front o2 sensor q.
- Engine help
- Engine Problem
- CBRD and JMfabrications stuff...
- Max WHP on 680 injectors??
- Vendor Help, exedy Triple Cerametallic Disc and plates
- What do you think? (exhaust question)
- Installed a HeadGames head: dyno tested – new records!
- Indy Evo / Wilson V0 Street Manifolds In Process!!!
- ACT clutch/flywheel jobs. Lots of pics!
- Megan or Greddy Ti-C CBE
- Front Clunking noise
- BR's dyno testing and new parts development continues...
- Temps of our exhaust manifolds?
- Are O2 Sensors Delicate?
- New Synapse MBC: Looking for pre-market feedback
- ARC UICP Fitment. ??? Please help...
- Getting the EVO ready for action!
- head gasket and studs or not?
- External wastegate
- Dilemma! I need exhaust advice!
- Whats Next:
- ams turn down pipe?
- Evo IX turbo and altitude
- Stock IX Turbo: Race Gas
- Installed: Buschur Racing Mustache bar and Side supports
- GM synchromesh
- Problem with Zaklee Clear Cam Gear cover
- big turbo gas mileage?
- HTA 35r 633hp 496tq
- mobil 1 oil filter
- Greddy Profec 2 + CEL = :(
- 23.5 PSI with stock internals OK on IX?
- List of my mods lmk!!!
- TTP piston drop in project - amazing!
- RNR O2 Housing Exhaust Gasket Help!
- 37R help
- Stock Engine FP Green 93+Meth Dyno Results
- CAS discs and crank triggers?
- BOVs and You....help me.
- titanium exhaust...
- intake manifold .
- HTA35R Cams?
- Anadized black ETS intercooler durability?
