View Full Version : Evo Engine / Turbo / Drivetrain
  1. CBRD TS, vertical, fun stuff...
  2. Is My Oil Supposed To Be This Dark?!
  3. What are the signs of a bad alternator?
  4. Clutch issue
  5. HTA 35 to HTA 37
  6. WTB: Complete Evo 8 2.3 short Block
  7. opinions on the K&N drop in filter
  8. FP 4r's & EvoGreen
  9. exedy twin problem
  10. Exedy stage 2, 15,000 miles, 60 drag passes
  11. Fuel Pump Question
  12. hard start problem...help!
  13. how to add awd oil in the back trunk help please!
  14. Those who paid up for a real turbo, opinions?
  15. HDTTP Clutch
  16. HELP!!! EVO Stalling out then locking up while driving
  17. Help!! Evo8 Wont Start!
  18. boost controller
  19. boost controller
  20. Very weird situation tonight please look
  21. I need help!!!
  22. Weapon-R Intake Technology
  23. DV Flutter: Synchronic BOV perspective
  24. NEW WAY TO CHILL YOUR INTERCOOLER! Anyone hear of S-Max??
  25. clutch questions
  26. loss in power after LICP?
  27. Should I run Mobil1 synthetic High Mileage?
  28. All ready for Pinks with new faster spooling and more powerful Gt37 turbo
  29. Mike Reichen thru the 200 mph barrier
  30. I can't pressurize my piping to do a boost leak test.
  31. Need advise on E3.46 plugs
  32. which injectors
  33. air/fuel ratio reading
  34. help! need advise from you guys
  35. HKS vs Greddy Turbo Timer
  36. plastic piece behind camgears
  37. Greddy Turbo Timer Problem Need Help
  38. Intake cam position sensor bust...
  39. IX with HTA35R spark plugs?
  40. HTA 35 or 850r?
  41. Boost control for 24+ psi?
  42. Finished install of HKS Inlet Manifold
  43. help with fuel set up please
  44. GT3076R Downpipe
  45. Timing Belt?
  46. exhaust manifold pipes id
  47. Need help please
  48. Oil pan crack.
  49. Fujita Air Intake + Upper and Lower Intercooler Pipes
  50. Who needs a clutch anyways???
  51. Need info on NGK LFR6A-11 for evo 9...
  52. Fuel efficiency
  53. Engine Problems
  54. Mobil 1 Extended?
  55. FP Exhaust Manifold Vs Stock ported Manifold
  56. Kelford 272s or Cossie M2s?
  57. exedy stage 1 or ACT for DD only.
  58. Fp Mani ?
  59. Top End Power
  60. Big Turbo, Little Motor
  61. Automatic transmission for Evo VIII
  62. ? about installing BR ported intake manfold and 65mm t-body?
  63. i melted a coil pack!?
  64. Does Greddy S BOV, Increase Power ???
  65. Apxi Turbo Timer question (car wont stay running)
  66. Strange wideband behavior
  67. quick question
  68. Boost Problem Help!!!
  69. Misfire...Help
  70. How do I know if I have a front LSD
  71. Anyone know what this could be?
  72. o2 bung for trust ti-r
  73. O2 Simulator??
  74. T-Case and rear diff oil
  75. OPINIONS evo reliability
  76. So in goes the HKS 3037s kit
  77. Vid of Definately blown T-case
  78. Cam Gears?????
  79. Good Head
  80. Problems shifting from 3rd to 4th?
  81. Does to small of a wastegate spring, cause the EWG to open early?
  82. High HP MR's
  83. Battery reading 13.8volts??
  84. Press in clutch - car dies....bad clutch master?
  85. Problem with tran need some help.....
  86. Parts for evo I, II, III ?¿? PLEASE ?¿?
  87. Clutch Access Hole Plug
  88. Choosing a turbo kit
  89. Evo 9 Front diff pooched?
  90. URGENT - PPIHC car blows TC and needs a new one ASAP!
  91. windsplitter/intercooler upgrade
  92. AEM truboost install - boost pressure source?
  93. Egr Valvle location
  94. will this bolt up?
  95. Is my clutch shot?
  96. go external Wastegate or not??
  97. Turbo/Build Question
  98. Video of (TC) Transfer Case noise.......
  99. TSB question
  100. car jerks and flutters any help
  101. Where can i get a fp green?
  102. anyone have any exp with a john shep rebuild?
  103. High load issue with normal boost
  104. Cosworth M2 Review.
  105. cam choice
  106. tc/tranny issue?
  107. Need help on part name!
  108. swapping evo 9 1st gear into evo 8 trans
  109. What valves to buy? Help
  110. Weird Clicking/Popping When Taking Off
  111. Where to purchase replacement battery to the Bushur mini Battery?
  112. help!!! rough idle and other things!
  113. Tranny Fluid Change
  114. I need some pics of the iac valve
  115. wideband sensor placement on QTP downpipe
  116. GSC S2 idle
  117. EVO Red pump gas/race gas dyno numbers.
  118. HTA35R: Tubular vs. Cast Mani on Pump and Alky
  119. Boost leak
  120. 30k service cost
  121. My evo issue #3,089,982
  122. colder spark plugs
  123. Found damage in my head- is it a problem
  124. full engine build
  125. Evo 8 Probelms
  126. guessing game
  127. FP RED, White And Green Shootout
  128. Clutch pedal vibrates? TO?
  129. MAF translator Install... (evo 9 pin out)
  130. What size is the stock alternator?
  131. Front end click noise when turning?
  132. ic pipe question
  133. ABS light-How to reset?
  134. a/c problems - can anyone help
  135. Poilishing Bearing surfaces during motor build
  136. Replacing Stock clutch @ 79k, resurface flywheel?
  137. coolant help
  138. Throttle Body Seals?
  139. Need Suggestions: Rebuild!!
  140. 6 speed strength
  141. Getting a "tune" - what to expect?
  142. Evo 8 and Evo 9 exhaust?
  143. full engine build help
  144. Whistle/whine under boost
  145. No Boost After Install!
  146. Injector size for E-85
  147. Need Help making decision on New CLutch
  148. FP Green Questions
  149. 2.3L build
  150. Intercooler Question
  151. stalling in neutral with a/c on only
  152. Oil cooler lines- Direction of oil travel
  153. Modified factory oil pan????
  154. Accusump install? - 2 motors blown in 1 month
  155. 2.3 stroker vs 2.0 - GT3076 vs HTA35r
  156. 1st Shakedown on PT 6765 Turbo - 9.80 @ 138.9 mph !
  157. EVO VIII power "cutting out" in higher gears
  158. Short shifter vs upgrading the bushings to the stock shifter
  159. clutch problem
  160. Ecu Ralliart Evo Ix
  161. Evo 8 Cam Gears
  162. gear popping out
  163. Disabed O2 sensor for test pipe?
  164. when is it time to upgrade stock injectors?
  165. Stick with my HTA35R or keep it simple?
  166. Funny noise @ high boost?
  167. Turbo Back Exhaust with test pipe question
  168. weird sound
  169. car pulls harder with AC on...
  170. Please help a noob
  171. Snapped a cam bolt today while installing HKS 280's....
  172. pls help...exhaust manifold on evo 9
  173. Question about ported manifold and 10.5 Hotside?
  174. first engine mods??
  175. Exedy High Grip Wear Carbon D Clutch Coming
  176. scheming new upgrades BIG POWER take a look
  177. Need advice
  178. Car suddenly will not build boost at a stop
  179. Bolt On Turbo Line Up
  180. Okada Projects' Plasma Direct coils
  181. Do I need to have Injector driver for 1600cc? (37R w double pumper)
  182. Real Problim Car not cranking up
  183. Hallman mbc and Tial Wastegate connections
  184. Driveshaft making noise
  185. Don't want to loose the evo...
  186. Video Request: HKS RS intake, with stock bov/turbo.
  187. 10.72 @ 129 Red Turbo
  188. Ingition issue, maybe knocking or missfiring
  189. Anyone have their accessory belt pop off?!!
  190. Walbro 255 and fuel filter
  191. Stock MR boost gauge inaccuracy?
  192. Easy to use clutch?
  193. hks 280??
  194. Sound Clip for FUJITSUBO SUPER TI exhaust anyone?!??
  195. HKS 272 or GSC S2
  196. Ticking sound
  197. PTE 56 trim to 3076r
  198. ebay turbo back exhaust
  199. 1g bov VS 9 bov
  200. Coolant Reservoir Help
  201. Exedy Stage 1 Racing Clutch
  202. Cam question?
  203. Connecting rod bearings question
  204. FPwhite + Evo 9 + 91oct
  205. evo viii compresson housing swap
  206. 23 psi on untuned EVO IX ok?
  207. Where to get an FP Green or similar in stock
  208. Redline?
  209. ceramic coating in nj
  210. QTP downpipe with electirc cutout and buschur exhaust fitment
  211. something is wrong
  212. Turbo upgrade?
  213. what filter?
  214. Apexi intake w/ Induction Box what hard pipe?
  215. time for a bigger intercooler
  216. best bov, APS twin vent?
  217. replacement oil temp gauge
  218. Dyno question
  219. Clutch not release at high rpm, or something else?
  220. HKS racing suction intake.. thoughts?
  221. And Now for the Mother of All TS T3 Housings
  222. Blown Turbo
  223. Did Someone say ETS 6262
  224. evo 8 trouble
  225. Any experience with this cat-back??
  226. Transmission Problem?
  227. oil return line gasket question..
  228. HELP! problem with my evo. new to site
  229. 2 Exhausts
  230. GSC S1's or GSC S2's
  231. SES light flashing all the time ! help !
  232. FP Green, Megan 02 housing, Forge WGA
  233. Anyone surging on their FPgreen setup?? High gear low RPM surging on spool up?
  234. ExoticSpeed Catback?
  235. Redline light shockproof and LSD additive ok in our rear diffs???
  236. Buschur Coil On Plug ignition system!
  237. Grindin 3rd & 4th
  238. Noob Question
  239. gas mileage poor after intake and exhaust
  240. Titanium Retainers vs. Chro-Molly Retainers?
  241. Indy Intake Manifold power bands and availability.
  242. MD dyno tune of my 03 evo
  243. Successful USDM Evo 8 ECU swap into Evo 6 TME
  244. NGK Racing series spark plugs for Evo 9
  245. plz help
  246. Hta35r VS Hta37r ??
  247. Heavy Rain
  248. AEM UEGO Install
  249. need some advice, p0300
  250. Invidia O2Housing
