- New Record 9.30@150 Evo Ix On E85........
- 1117 Dyno Sheet and going back to a 4202 Turbo! Plus a little Carnage!
- Exedy clutch problem solution
- stock boost guage question?
- Ferrea Springs&retainers issue HELP
- 4th gear lock out..now scratching
- AEM truboost install issue...
- 3" exhaust advice
- Correct AFR???
- Maximizing the stock turbo
- AWD Motorsports Evo Street Car.. 1001awhp / 622tq!!!!
- Info needed: Oil Jet location
- bad coil pack???
- Evo Crankwalk - Pics
- What happens when we are bored on a Saturday night at the shop...
- Now you see it!!!
- For those of you running EXEDY TWIN HD.....great mod here for to prevent clip....
- Evo 7 oil pump
- noisy pump
- What Do You Recommend?
- Clutch options in my 8
- Running Meth? Safe or Not
- What cause car to stalled out in neutral??
- Problem: Rpm rises by 500-1k after releasing throttle.
- Anybody with a big turbo with Buschur Magnaflow?
- Boost leak
- Looking for 350whp...
- Clutch retaining clip???
- intercooler repair?
- I rode in Dave Buschur's Bad Bish
- After Boosting This Happens???
- Clearing carbon in exhaust with degreaser?
- Injectors
- new clutch just installed and car wont go into reverse??
- BOV recirculating question.
- Went to dealer for service today 8-2-08
- are adjustable cam pulleys required ?
- Oil leaking from somewhere.....need help!!
- Did I get the right spark plugs?
- Full Race + ETS + 93 pump gas !!!
- drivetrain mounts?
- Car acting up strangley had for 2 days
- FP WHITE................................FTW!(dyno inside)
- People running a open dump tube?
- Who can help explain? Turbos??
- Best 02 Housing?
- PCV delete / Road draft tube.
- FMIC impressed :)
- Another clutch issue ( disengage)
- Something missing
- which throw out bearing for ACT clutch
- wheel baering issue... help
- 6265 Turbo porn...
- SparkTech Ignitions..
- ACD light comes on and off
- K&N or WORKS drop in filter?
- decisions,decisions????
- Clutch pedal high
- Blitz RVIT (COLOR)???
- Ultimate Street & Street Turbo
- p0300 dealer flash tsb
- Rear diff question
- Persistance+pushing the envelope+dynoflash power + ICS= Pump/meth BEAST
- Best LICP for a IX?
- cosworth M3 cam question
- super noob question sorry that i'm even asking
- FMIC testing with the speedy AEM air temp sensor.
- Magnus Cast manifold
- Skunk2 uses CARBONETIC LSD in their S2R1 Time Attack Evo
- Loudest Bov For The Ix
- Is this a stock Evo 8 cat?
- Question about Compressor Map for 35R
- Removing MBC for a few days
- car choked on 0.5 bar in sixth gear
- is royal purple causing my motor to tick?
- Exedy Twin HD...Throw out bearing came off the fork!
- ACT Street Doesn't Grip Like It Used To
- Evo Overheating problems Help!
- Clutch pedal squeeking/binding
- IAC sensor issues?
- Howling noise..seems turbo related
- un recirculated stock bov
- Load differences per gear
- blew it up
- 6262, 6265 or 850R
- Stock Intercooler
- What boost u guys running on 91oct with bigger turbo..
- Subaru FP green reliability
- need thoughts and ideas on motor build
- Is there an IC sprayer button delete panel?
- Evo BOV video I found
- Megan EVO 8 Exhaust Manifold - can it be installed on the IX?
- AC works sometimes
- Head Gasket Blown...
- Help! My Evo won't idle!
- Question about USDM rear diff
- What turbo to buy?
- SparkTech Fixed my Misfire on stock ECU
- Maximizing the IX Turbo Setup
- Clearing My Throat - Exhaust System Refresh
- Exedy Triple Plate clutch discs strip out....AGAIN!!!
- 4" stainless exhaust
- Excessive Transmission Noise/Harshness and Driveline Shunt
- Cracked Titlon cerametallic disk
- Would like some opinions on doing a Garrett turbo upgrade
- Engine rebuild questions.
- 20g-9-5 or 20g-9-5-lt?
- Weird pulley noise?
- Ivey Ems Tune!!!!
- question for the tuners and fmic makers!
- Car cranks differently...
- Finding out what kind of exhaust I have..
- Thought i'd share another car tuned by FULL FUNCTION
- high flow cat. vs. test pipe
- Is my TOB going bad
- Show me your fuel cell installations
- Evo 7 Clucht Options
- Buying a used Exedy Twin question
- Bbk 75
- Service engine light and P0335 code after jump start
- few questions from a newb
- is there anyone who actually knows?????!!!!
- Can't decide proper turbo for setup
- 20g or green
- EGT bung install?
- Boost issues
- 20 HP Loss? Help!
- Hood vent, and oil temps
- Jacks trans
- Ic piping help
- Starting problem
- custom manifold let me know what you think
- exhaust leak
- Evo 9 MR blown transmission.. NO Warranty !!! :(
- Ex. Mani and other upgrades advice
- Help Tcase
- Rear diff
- My setup, need advice
- Precisions 6262 Turbo
- NEW Tial Sticking Shut!!
- spark plug cover
- TOMEI Solid Pivots, instock anyone?
- ACD fluid out of transfercase
- Installed Powder coated Valve cover and Catch can System
- Pulled the intake manifold off and what we found
- Injen IC piping/intake question
- boost leak on evo8?
- question about my spark plug gap
- o2 sensor question
- welding Buschur exhaust
- low boost, cylinder misfire?
- plug blew out
- What WHP should I be at?
- Need help/tips getting transfer case on
- Vibrating rear diff evo IX
- Engine management for my Evo 6.5 ?
- Alky tuning???
- Code P0500 - Vehicle Speed Sensor Malfunction...Any idea where the sensor is?
- upper &lower icp
- 2.3 850R results 551awhp/429tq pump gas!!
- name that connector! lol
- TTP Sales Parts Service and Tuning - First Tune 374.9AWHP / 371.3AWTQ @ 26lbs.
- Evo Engine Building Books?
- FFTEC tuned EVO8 GT30R 91oct & C16 dyno results and video
- Would you consider this 3" muffler restrictive???
- frustrated and not sure whats going on.
- Anyone have any BAD experiences with Royal Purple in the tranny?
- Difference between evo 8 and evo 9 gearing
- Bad day for my MAF!!
- Ported Stock O2 or tubular 02 Housing
- Fidanza 3.2 Clutch or Clutchmasters Stage 3?
- 10.5mm Turbine Housing for 04 Evo VIII
- Help, I can't split transfercase from tranny evo9
- Buschur ported or Invidia mani
- Tranz Clutch line Restricter???
- t4z 88hta
- po139 only in rain?
- Worth it to replace panel filter with a cone before tune?
- TTP Built Stock Turbo 433 whp 497 wtq
- Thoughts on Bushwacker
- Megan Manifold Problems
- Evo 6 Spark plugs
- Need to order Exedy Twin Disk Suggestions?
- rear dif
- I'm gonna buy a TurboXS IC; should I buy Samco IC hose?
- Can I use Tilton Throw out bearing with Carbonetic Triple carbon clutch?
- Troubleshoot: Slow transition to vacuum
- Finally, My Evo build.
- What happened to the 850R!!!! "Owners" speak up!
- Cam advice needed...
- Motec MDC and JDM AYC diff?
- Boost guage reads lower than ECU.
- Removing AC and Power Steering
- GTSPEC UpPipe / Turbo Outlet (o2 Housing) Info????
- Purpose of fuel pressure regulator solenoid?
- engine sound
- fp red
- shorty radiator
- who makes the light-es IC?
- What are the important Gauges for the EVO
- What turbo, HELP needed
- How to tell 20g from 16g ?
- HELP ID Cams
- 20g Turbo for my Evo8
- vibration after front diff install
- Why does my boost peak, then taper off?
- no power but battery works...
- Samco Induction pipe ?'s
- Service Manual ?'s...
- after market O2 sensor
- The new Tial Recir BOV????
- Custom LICP for FP Red
- odyssey PC680 battery (pissed me off tonight)
- Who's shop can dyno test the Magnus Cast vs Indy V2 vs AMS cast in the future?????
- need a gooood goood clutch for the track!!!
- indy evo and 9sec9's airbox availability ?
- sean ivey did it again
- WG Flapper fell off on my FPGreen
- TIAL 30R Setup
- BC 272 cams
- Best Hotside for HTA35R: .63, .82, bigger???
- Bucking at WOT
- ugh downgrading question
- External Wastegate on stock turbo!?
- DNP stock turbo manifold
- Ported head and setting timing with stock TDC?
- Help needed in Rhode Island!!!
- Final Stock Turbo Dyno Numbers
- Changing to the GT850R!!
- Full Race TS 3076 results
- stock intake pipe
- Car runs fine but........
- Are all E9 rear differentials LSD?
- Oil return help
- Greddy Catch Can
- greddy gauges sensors
- Exhaust with Turn down muffler?
- speed sensor
- ACD & Aftermarket Wheels
- Just installed BR MBC, boost spikes at onset then tapers back just like stock??
- Exhaust system for track use only
- Best Cam Gears On an 8 ....???
- PCV Valve Relocation
- Boost leak test issue
- I'll be looking at this VIII tomorrow A.M., what should I look for?
- How much power 650 injectors are good for?
- Some tech insight wanted... Subie guy running a 35R
- Solution for Peakboost FTW manifold and radiator hose
- Who needs cams 440hp?
- Possible 03 Evo engine broken....help
