- output shaft
- Exedy twin install... help? Phoenix
- Board of the green
- P0401 EGR Flow Insufficient fix?
- Idle???????
- cam gear settings
- Need info on 5 speed swap
- Dyno tuning tricks
- Short Runners Vs. Long Runners
- 4th gear grinding
- My new AMS goody......Bling...Bling...
- highest boost i can safely run
- can anyone tell me exactly what kind of bov this is?
- Starter issue?
- Problems with the Evo
- new clutch installed into 6spd, hard to get into reverse
- stock cam lift?
- please help! underhood shifter bushings
- Warning/Cam gears w/o cover
- Found tooth on magnetic plug when draining tranny...
- Stroker rod clearance
- FP Green+ Iveytune= power
- Clutch sticking
- Clutch problem, need help fast
- valve tap, bad lifters?
- Balance shaft bearing question
- ACD Warranty question
- Car won't start, randomly.
- throw out bearing removal
- Injen Intake Question
- 1G BOV on Evo
- Walbro question...should i be worried?
- Exhaust Manifold to Turbo Gasket
- got my evo red today!
- no spark no fuel....
- Throttle hang (again)
- mbc choices
- ETS quality work!
- Need help solving boost problem
- help help
- upgrade to Forge WGA on stock turbo + meth?
- Make your own balance shaft eliminator kits
- just got car bac
- HEAD and CAM GEAR TORQUE SPEC?!?!?
- help rev limiter!!
- Questions for Quartermasters Twin Disc Clutch Users???!!!
- What race fuel to use?
- Titanium exhaust tip covers
- Car setup Advice needed!!!
- interesting question about quarter master twin
- walbro fuel pump install
- Time to replace a clutch
- *ams Product Release* Evo Viii/ix Jdm Bumper Catback Exhuast!
- Low Boost - help
- Tapping Valve? Parts Advice Needed!
- quick bov question
- Gizzmo MS-IBC
- Clutch got stuck engaged
- lean idle
- Confused
- db exhaust evo!
- Turbo XS MBC info
- Camshafts for Evo red... idle, revlimit, power
- Clutch/Flywheel Rotational Weight (Pics): Exedy Triple VS. Quartermaster Twin.
- 2.3L GT3076Build
- 3" Downpipe Problems
- 9K miles Service Engine Soon light ON
- 2nd Time took the tranny off in 3 weeks...Exedy clutch clip broke again!
- Tuning Technologies performs magical tune!
- coming in HOT...Spark Tech!!
- Motul 300V vs German Castrol
- Anyone Using Spec Clutch?
- If your ARP Headstuds were Installed 1x1 Please Vote!
- Should I get an aftermarket Intercooler?
- Need help with Fluids! (Tranny, Diff, etc)
- Does invidia downpipe fit skunk2 testpipe?
- Who's Turbo Kit is this?
- Turbo IX GSR vs Turbo IX RS Mag. (Power-Spool up)
- Need Help - Oil Pressure Low
- Tial wastegate...need help
- My Exedy Twin SD is gone. Rebuild,Up to HD, or ACT combo???
- How long did your clutch last after it started slipping?
- DSM Shootout Prep - 800 whp Gt37
- How high can you REV on these Beehive valve springs? (9K+ fine?)
- Colo & Monroig FP RED EVO Video
- A full day of work
- clutch questions??
- Driven Innovations Intake Manifold "Black Magic!"
- Buschur POWER!
- my arp headstuds, headgasket, and me Questions
- Deceptor BOV and Works Exhaust...removing Mitsu logo
- Backfire at redline???
- Kelford 272 and stock ECU
- Exhuast manifold
- FP Green
- My TB seals are out!
- fp3065 Vs. HTA3076 Vs. RED
- 1st and 2nd gear soft, neutral is first, wont go into gear WTH!
- Which headgasket?
- Who else has a 2.4 stroker???
- Stock Exhaust Bolt Pitch (test pipe)
- misfire 4k limp mode
- new intercooler, did i lose power?
- HKS Cam Gears
- Idle
- Time to buy an intercooler?
- Your Opinion...
- what timing belt for a dohc 4G64?
- Meth kit install/advice
- With my supporting mods in my signature is the exedy twin disc a good idea with an MR
- Back in the shop :(
- Have Syncro Problems? - FILE A COMPLAINT
- I need immediate help please
- knock in first gear?
- My Evo is shooting out smoke
- Dsm Shootout Racers
- Separate Ignitor/Coil system working on stock ECU :)
- p300 after installing
- noisy clutch
- Fp red on e85 525hp and 462tq
- EVO8 low boost (11psi)
- Teaser pictures of the new RPS billet twin plate carbon clutch
- Boost Spike With Built Evo9!
- Boost Spike Problem
- Stock Clutch power
- What is this for??? **PICTURE**
- 1.2-1.3 Bar on stock 8? Not Right?
- Buying a car that hasn't been started for 3 yrs! what to do?
- Just did my Walbro
- Wierd surge at full throttle
- Borg or Garett
- Borla Headers?
- broken crank:S?
- Will intercooler piping size affect throttle response.
- need clutch.suggestions???
- Anyone know what this thing is?
- FP Red......565awhp/557awtq on E 85!!!!!!!!!!!!!
- hard to shift, especially when hot
- cylinder matching/cylinder compression
- Just finished installing my LICP and....
- Jdm Map Sensor
- Will the IX buschur licp work w/ the VIII?
- If you have a Synchronic BOV try this
- Tial Wastegate Issue
- Impressions on my precision 6262
- Dnp Evo Polished Ss Manifold
- Aem + Anti Lag Launch Control Kills Motor (evo9)
- amsoil series 2000 for transmission ???
- need help diagnosing my timeslips!
- Blown Engine, Changhe Oil Cooler?
- My Evo 9 600+whp on pump gas 700+whp on race gas
- first gear whine, any ideas?
- Dc Sports Dp Rubbing?
- Perrin Boost tube. Who has it?
- FP RED vs 35R
- What do you guys think of this Intercooler?
- Cam Settings; Road Racing, Time Trials
- IX bov
- need help p0403 code???how can i fix or ddelete this code??????
- HKS Hi Power Silencer
- Ran outta fuel :(
- Need help: Lower Control Arm
- Exhaust Stud Broke
- Exhaust Bolts
- Rubbing Noise When Taking Off
- What header is this??
- Exedy twin disk question
- Tranny Fluid Changed
- Shifter Linkage Popped Off ...
- Meth Line Broke (Misfire & Knock ... Help!)
- To Stroke or Not to Stroke
- Blown Head Gasket?
- Anyone got Stealth Perrin Exhaust?
- 500 to 600whp drop in setup.
- Wilson Manifolds V2 w/ 65mm Throttlebody.. Pics Inside!!
- old EGT sensor...
- What Valve Springs?
- Need some technical answers,,2.0L vs 2.3L
- Cam Install
- Car cuts out under full boost
- 02 Sensor Question
- Power Fc, HKS 280s, crappiest idle ever...
- power problems on evo 8
- URGENT: My JDM Evo IX Goes dead @ 5,800 RPM
- tranny question?
- Injen LICP
- evo gear
- OK, need some help for a change.
- 37R W/stock internals
- oem crank hp???
- The rear motor mount
- question guys can i still use my old headstuds on my new engine??????
- looking for info on revolver cams
- cam timing question/problem
- TBE Exhaust...
- porting on 10.5 housing
- couplers size for stock intake
- too much heat for carbon fiber hood vent?
- Lets Compile the data
- help understanding a basic PSI question
- Vac/Boost Problem?
- Snow meth Kit $150 good deal
- Race fuel?
- mitsubishi GDI engine?
- Couple knock questions
- FP EVORed 470whp on 26psi with 100oct UL fuel
- ETS 42R Turbo PrOn
- Post cam instal idle questions
- GT35RL Kit and supporting mods
- my precision 6262 has arrived
- Tune necessary with aftermarket o2 housing?
- Evo gear help!!!
- header
- Spark plugs...5-600whp...
- My Evo 9 made popping sound w/ black smoke and oil leaking from o2 housing.
- Quick Question about TurboXS intercooler
- Metal against metal on start up...
- Estimated Power Numbers from Set up
- shaft play?
- ETS or Turboxs
- How is everyone getting manifold and dp bolts loose?
- Need opinionon Turbo upgrade
- hta35, cast vs tubular??
- HTA GT35R Spool Data
- Need info on 4g64 motor
- Clutch experience!
- Evo MR Full Fluid Change.
- Whose fault is it???
- Help, me find the best turbo for my Evo IX MR?
- Need recipes for 550awhp
- Cusco=Exedy?
- Custom airbox
- This was a first....
- quaife lsd
- ACT Hdss Clutch question
- manifold and turbo bolt ?
- JIC Spartan DE ( Titanium Canister )
- Got some new personal bests........but now have lots of decisions to make! HELP.
- 3582HTA vs 6265 Dyno Comparo
- Mitsu dealer gave me the wrong fluid for rear diff and transfer case
- Idle after resetting the ECU
- Intake opinions
- Insecure wrist pin clips
- New Record 9.30@150 Evo Ix On E85........
- 1117 Dyno Sheet and going back to a 4202 Turbo! Plus a little Carnage!
- Exedy clutch problem solution
- stock boost guage question?
- Ferrea Springs&retainers issue HELP
- 4th gear lock out..now scratching
- AEM truboost install issue...
