View Full Version : Evo Engine / Turbo / Drivetrain
  1. My Thoughts on Short Shifters and Gear Grind
  2. 6 Speed Evo 9 Drain and Fill plugs
  3. Fp Green hot side options
  4. I want cams that sound like this...
  5. New Tomei ARMS turbo kit
  6. A few parts..
  7. help with new exhaust!!
  8. Loud bang big problems
  9. springs and retainer help?
  10. throttle bodies
  11. Wilson Manifolds Billet Runner intake manifold
  12. MBC install gone wrong?!
  13. Drop in Pistons+Rods: BS Removal?
  14. Rattling MIVEC - Help!
  15. how to Confirm Clutch wear/replacement
  16. Coolant temp problem. :(
  17. Turbo compressor wheel question
  18. Transmission concern
  19. 4G64 w/ MIVEC Head, What head gasket?
  20. How can I improve my Evo 9 gas mileage?
  21. Need a hobbs switch?
  22. Worth Going HTA?
  23. Trany problem please help
  24. spitting grey smoke....help!!!
  25. Is my boost guage inaccurate?
  26. Video: Dsm/evo shootout..
  27. Antifreeze...
  28. AWD Motorsports FP Red Evo IX on Pump.. 446hp!!
  29. Need Help!!!
  30. Part install questions
  31. Part install questions
  32. car wont go in gear
  33. Power steering fluid question
  34. Found a little suprise while doing a clutch job...
  35. Info for Clutch install/replacement for 9MR
  36. greddy ti silencer
  37. 496hp on 93 octane pump fuel and ??? with VP C-16...
  38. problems shifting in to reverse.
  39. Cam/idle Question
  40. Twinscroll + HTA
  41. Labor hrs for Head studs, Cams, & Spring/Retainer Install
  42. 35r with HKS racing suction intake
  43. A few questions about driving with a bad o2 sensor
  44. tubular manifold
  45. removing egr and other junk.... need some help
  46. Installed BR 65mm t-body, ported IM, and EGR blockoff... now some ??'s
  47. a few questions about high boost on stock turbo
  48. 20g on an Evo 8!?
  49. need help
  50. Water in engine
  51. Vendor with the best price on Exedy twin hd
  52. Is it possible to dyno my evo fwd only?
  53. Desperately need help
  54. HTA35r Dyno Results: 635hp 545trq pump w/ meth
  55. Rough Idle
  56. Just installed my HKS Camshaft and Cam Gears... Need help
  57. Balance shaft
  58. Switched to Amsoil
  59. which springs and retainers? revolver cams
  60. MBC Problem
  61. stock exhaust manifold???
  62. how to make your ix spd smooth?
  63. egr cel problem
  64. boost leak at fuel injector
  65. Water Return Hose Leaking !
  66. How bad is this??
  67. Stock Sport Meter Kit Question
  68. Perrin high flow cat - Don't waste your money
  69. Cams for Stock Turbo EVO 9
  70. What Manifold 02 and DP??
  71. Just curious where my car stands with its power?
  72. cam degree
  73. Rattle from Megan DP
  74. Spark plug condition
  75. Can anyone identify this J-pipe?
  76. Profec B Spec II setting question
  77. couple intake ideas, need input.
  78. Whining Noise only in 1st goes away when clutch engaged.
  79. Megan DP
  80. Car wont start
  81. Oil report
  82. Engine pull thread or write up?
  83. 6 speed motor/5 speed motor differences?
  84. Does the 04 RS have a center diff???
  85. Apexi RX-6 Turbo Manifold
  86. Help, Ackward popping/clunking noise
  87. HELP. Wont go passed 1500rpms
  88. help car cutting out!
  89. cv joint going out?
  90. Strange miss at idle when fans kick on
  91. noise coming from front driver side axle???
  92. Drivetrain Problems...
  93. Slowboy t3 flange ss manifold, does it work?
  94. Evo GREEN for $625!
  95. Max psi using Greddy profec B spec 2 boost controller?
  96. new fujita intercooler kit?
  97. to port or not to port my FP green
  98. Who thinks this would be the ultimate cam test?
  99. Oil Pan Removal Question
  100. to port or not to port my FP green
  101. cams decisions decisions
  102. evo 9 turbo
  103. Change 6 speed gearbox to 5 speed?
  104. Who can make a recirculated dump pipe for 38mm Wstgt?Best price
  105. Who's Manifold??
  106. Putting a T61 turbo on the Evo
  107. Cutting honeycomb out of stock MAF???
  108. Bad Clutch. Help.
  109. fp green
  110. Wastegate Adjustment
  111. Forged Wastegate VS FP Wastegate
  112. just did timing belt, vibration
  113. IX Turbo Installed on VIII Impressions...
  114. Whining, but definitely not the usual TC whine
  115. valvoline 75w-90 gear oil?
  116. swap front lsd into 03 evo 8 trans??
  117. Tell me about your Stock turbo setups (also green and red setups)
  118. Noobie question........ what is a Knock?
  119. Looking for a fitting
  120. Witch size block for hta37
  121. ACD fluid
  122. clutch install help please, fast!
  123. Overheating some help please
  124. driveshaft
  125. Exedy Triple Disk Picutures
  126. BF 272 Cam Specs
  127. Shop/ tranny work
  128. Evo 8 Compression Test
  129. Thoughts on buying used turbos?
  130. 30k service?
  131. What's the best valves $$ can buy?
  132. Car moving at neutral gear position
  133. tranny problem help....
  134. Spark Blow out.
  135. What exhaust is this?
  136. is that safe?????
  137. Clutch engagement changing randomly
  138. TM works Individual Coil Pack
  139. HELP!!!! Code p0069
  140. Evo IX cams: Kelford 272 vs. Cosworth M2
  141. ACT clutch slipping? (videos inside)
  142. False knock, stock ecu, built motor
  143. How to tell TME 6.5 Turbo?
  144. Video/Sound clip request of HKS SSQV reric
  145. Help w/ motor issue
  146. can't boost over 28psi help help
  147. Fp Green Vs 3076 Kit
  148. small filter robbing power?
  149. Turbo doesn't spool high anymore
  150. How should I break in my engine?!
  151. HKS EVC 6....english manual?
  152. how to get 30lbs out stock turbo
  153. ? for those who have removed the OEM EVO 8 intake manifold...
  154. Valve Cover
  155. reverse block
  156. which cams hks 272 or gsc s1
  157. xtd clutch???
  158. A good 91oct setup for my IX MR
  159. Do I have my bov on backwards?
  160. Took throttle body off and i think the TPS out of adustment
  161. O2 Sensor answer!
  162. Need Help from Mitsubishi Technician Please!
  163. Motor work?
  164. Buying used injectors... Good or bad?
  165. Evo8 And Evo9 turbo Difference?
  166. JDM ALS valve
  167. Where is the rear o2 sensor on a 2003 Evo 8 located?
  168. All-New Precision Billet 3562R!
  169. evo 8 exhaust help
  170. Many "maps" in Evo9
  171. new to the evo world
  172. Anyone know if Avid billet mounts are lighter than stock?
  173. best way to get another 50 whp for price
  174. Which Trans Fluid?
  175. Lose of Power after 4500 RPM 350HP Peak
  176. 03 evo still getting p0300 code
  177. Evo 9 w/an evo 8 turbo
  178. air filter
  179. rpm's stay high during clutch in/neutral
  180. Manifold question...
  181. intake recirculating bov plug
  182. clutch break-in
  183. Clutch Problem
  184. Tubular Manifold Question
  185. Green vs. Red
  186. Problem installing Buschur under hood shifter bushings
  187. cosworth m3 cams
  188. Stevo8's most recent build.
  189. rev ,question
  190. DSM/EVO Shootout Video !!!
  191. help to get bare block
  192. Stock Cat
  193. Cams for a 9?
  194. evo 8 with fp green alchy boost tapering???
  195. strange noises
  196. Engine stuttered on hwy, then CEL.
  197. ACD Issue? Please Help!
  198. **ams Engineering Update** Wet Sump Oil Pan
  199. Water to Air Intercooler
  200. Works O2 or Titek O2 housing?
  201. Anyone Running FP RED YET?
  202. Exedy Twin Vs Quartermaster Twin Vs Fidanza 3.2
  203. GT 4088R - Set up (advice)
  204. Single vs Dual Valve Springs/Valvetrain wear
  205. What clutch to buy??
  206. FP Red Question???
  207. HELP! something went BOOM
  208. clutch choices, decisions decisions.
  209. Mellon Tuning/RaceVideoForums coverage of the 2008 Buschur Evo DSM shootout
  210. Exhaust heat shield replacement bolt?
  211. Powerflex insert vs. Agency Power full billet side motor mount
  212. Test pipe or High flow cat...what are you running?
  213. AMS 2.3rr and Cosworth 2.2 short block
  214. Cam/valve cover questions
  215. Replacement O2 Sensor
  216. Is there any exhaust out there that is quieter than stock and still free flowing?
  217. Help me find my boost problem (vid inside) HELP
  218. AC took a dive...HELP
  219. Where to find a starter?...
  220. any reviews/opinions on this fuel pump
  221. Should I get headstuds or can I wait?
  222. Where did you get your Walbro?
  223. Install my 02 dump this weekend.....
  224. is it safe to run untuned?
  225. Apexi Power Fc D Jetro intake manifold question
  226. diaqueen on other cars?
  227. What's wrong with my car? PLEASE HELP
  228. Need Help Please!
  229. Spot for one more gauge
  230. Battery getting ready to die?
  231. Oil Cooler Thermostat.
  232. would that can cause any damage?
  233. boosting too high?
  234. Smooth shifting?
  235. Apexi Power Fc D Jetro intake manifold question
  236. 2.3 Stroker W/50trim On Pump Meth.
  237. Po403????????????help Please How Do I Fix These Code
  238. Fix my leaking TB seals...still leaking (vid inside)
  239. Update (Includes MAF Translator Review) **Photos**
  240. best plugs for fp green/alchy
  241. test page
  242. Transmission, and clutch pedal problems
  243. output shaft
  244. Exedy twin install... help? Phoenix
  245. Board of the green
  246. P0401 EGR Flow Insufficient fix?
  247. Idle???????
  248. cam gear settings
  249. Need info on 5 speed swap
  250. Dyno tuning tricks
