View Full Version : Evo Engine / Turbo / Drivetrain
  1. Transfer case
  2. AWD Motorsports Turbo Manifold Hotness.. Out The Front!!!!
  3. bought 10w-40 by accident. question.
  4. LOUD WHISTLE...real bad...
  5. Q's about Evo 9 and 8 Stock Turbo
  6. Which BOV is better?
  7. help please breaking up in boost
  8. Need help deciphering evo 9 cam brand...
  9. Head gasket change during springs, retainers, and cam install.
  10. Clutch Question
  11. Hallman MBC help
  12. junk buschur mini battery where can i buy another?
  13. FP evo green Hot side question.....???
  14. Shaft seal install problems?
  15. Muffler delete
  16. QTP downpipe and o2 dump
  17. Get Gas, car wont start, WHY?
  18. How much power can timing get you? went to the dyno to find out!
  19. Another Stock Turbo E-85 Warrior.. +38whp/+53tq!!!
  20. nisei intercooler pipes
  21. Broke a stud...HELP!
  22. Need your assitance ASAP, MBC
  23. uh oh! o2 housing different size than DP??
  24. look at my GM MAF, i have a question
  25. SMC Water Injection Help
  26. EGR and Overboost codes?
  27. installed BR filter kit, did i gain hp?
  28. Fidanza 3.2 vs TTP ACT 6 puck
  29. timing belt tensioner stripped
  30. br piping on a turbo xs intercooler?
  31. 700 awhp/565 Trq.. HTA35r Strikes again!!
  32. 700 awhp/565 Trq.. HTA35r Strikes again!!
  33. Critique my car, 12.00 @ 119, 35r pump/meth
  34. Zaklee Cam Cover
  35. Boost Gauge Randomly Reading Wrong PSI
  36. Evo Red
  37. Click / Tick ?? Stumped, Advice?
  38. DC downpipe on my IX mr
  39. am i crazy or is my gauge broken
  40. boost leak test causing oil to come out of 02 housing?
  41. Exedy Hyper Single - MH01SD - HELP!
  42. Boost leak issue
  43. Anyone running the new S2's
  44. help! car problem bad sensor maybe?
  45. Help me choose Cams!!!
  46. flowmaster 40's Exhaust
  47. How long did your OEM clutch last
  48. Shifting has some kinks in it, normal?
  49. Is lifting a wheel while cornering hard on xfer case?
  50. Buschur's RS, first in the 9's on pump and nearly the 8's on race
  51. Exedy clip problem, and more! Take a look
  52. rre road tune review
  53. POS brand new TT just turns off with car?!?!?
  54. Anyone try the new 80mm comp wheeled GT42 yet???
  55. Stock Exhaust Mani VS. Others???
  56. how to adjust a hks eids?
  57. Spy photos of a new Buschur part
  58. clutch question
  59. Bov! Ricey Or Not???
  60. car won't run with brand new sparktech ignition
  61. fp red vs gt35
  62. Hallman or Forge MBC
  63. WORKS exhaust sound clip?
  64. licp difference
  65. What size Nord-Locks to pick up for my turbo kit reinstallation?
  66. will T3 flange manifold fit stock turbo???
  67. hallman pro rx in cabin
  68. Golf Ball Size Hole In Rnr Mani
  69. Cam Question
  70. Need Help!
  71. front 02 sensor
  72. 3 ACD lights, only during hard track use
  73. o2 dump vs aftermarket o2, done yet?
  74. Rear Diff replacement?
  75. head removal
  76. EvoRed Review
  77. Best Clutch For The Buck
  78. can CP pistons be reversed?
  79. Cam Install???? Why so expensive
  80. Did Kelford send me the wrong cams?
  81. help me w/ intake install please!
  82. my stock turbo dyno
  83. New o2 sensor $300 from the dealership?!!?
  84. Just threw a P0104 code.
  85. Oil on manifold...WTF?
  86. gt4082
  87. 8 turbo VS 9 turbo
  88. Cutch Assembly: OEM Throwout Bearing vs. Push Style?
  89. knock sensor setting SES light
  90. is any one running on GSC S2 and Stock turbo?
  91. Dealer Going under, Help with buying parts!
  92. hks intake safe w/o tune?
  93. Transmission problem
  94. help with engine knock on startup
  95. 65 vs 90mm TB
  96. My 2.6L evo 6 just made 623hp/559tq
  97. Evo just died on highway, fuel pump not pumping
  98. Ix Rs Build
  99. clutch started to slip, what should i get
  100. Boost leak, Vac leak, and serious sputtering
  101. Question about cat and O2..
  102. Oil Dipstick
  103. Where can I get a HTA upgrade for my 35r?
  104. Car sputters, dies out, then won't start...
  105. Cobb Exhaust Leak found
  106. Manifold Question
  107. whats the best set up
  108. Sputtering with new Clutch install
  109. Choosing a good piston/rod combo
  110. 2 injectors with no pulse
  111. Launching??T CASE??Breakages
  112. Reichen's EVO 2 breaks the 1000 awhp barrier
  113. Need to ID an engine!
  114. 30r????
  115. GSC S2 Idle Video
  116. Engine sounds....paranoia?
  117. Upstream O2 Sensor Removal???
  118. Slow VIII ?'s
  119. high compression for the evo
  120. rebuild options for pistons & rods
  121. Boost leak coming from my 65mm t-body?? Help me fix it!!!
  122. clutch options???
  123. What is the best set up for FPGreen ???
  124. run wont run past 2k rpm..need help and ideas
  125. Help me find the right exhaust
  126. triple plate..
  127. Turbo Noise ETS PT 61 ball bearing
  128. FP Red, E85, 454hp/408tq @ 26psi
  129. Evo7 DP and Clutch advice
  130. Occasional p0300 and "smelly" car...
  131. MBC - Blitz Boost Controller
  132. Compression, Idle problems...etc etc.
  133. Clutch slipping, how long does she have?!?!
  134. meth and red
  135. Turboback catless sound level?
  136. Wastegate problem
  137. Getting studdering at peak boost
  138. Need help with finding a 16" drag strip wheel/slick set-up
  139. SR*S exhaust (ebay) your thoughts please...
  140. clutch pedal vibrates when not warmed up
  141. very dumb question
  142. no start
  143. Parts Reccomendation
  144. Fidanza 4.3 Clutch + Flywheel
  145. injecters ma out ..help plz
  146. Should I pick a different cam?
  147. BOV flutter?
  148. Acceleration problem..or something?
  149. Clutch
  150. P0300 code on a stock Evo, any ideas?
  151. Montero coils...Anyone interested...
  152. Cam Choice with Large Turbine
  153. Question about the quartermaster twin disk
  154. Anyone deal with SWRacecars?
  155. need help with cams! installing
  156. do exhaust mods NEED a tune?
  157. Compression Numbers.
  158. R&R Knock Sensor?
  159. shifter bushings or under hood bushings?
  160. squeal noise while driving (not tcase)
  161. quick qeustion about cams.
  162. Cel P0170
  163. manual boost controller vs profec b II
  164. Drivetrain Lagging between Shifts
  165. Lag between shifts, help!!
  166. Advice for lowering exhaust sound?
  167. Replacing the Thermostat Question...
  168. Did your aftermarket clutch fail?
  169. throwing DTC P0172: System too Rich
  170. weapon r intake manifold evo 8
  171. FP RED - for the road course
  172. T-3/T-4 set-up
  173. How much longer for my fp red
  174. Which downpipe turbo XS MXPor Perrin
  175. New EVO 9 MR owner - Best Bang for Buck Mods?
  176. p0300 any clue
  177. UPS man showed up!
  178. O2 Sensor
  179. GM or AEM 3 port boost control solenoid...Stock ECU
  180. exedy twin clutch spec's helP!
  181. Trust ti
  182. ACT HDSS or XTSS?
  183. Stock cat back restriction
  184. need help with engine rebuild ?'s
  185. knocking noise from tranny
  186. Question??
  187. greddy type r bov
  188. When installing aftermarket Cams
  189. ND Short Wheel Base Longitudinal Engine Sequential Gearbox E9!!!
  190. Just installed a bunch of new parts
  191. Mixing E85 with pump gas???
  192. fp red actuator
  193. Is 5 gallon portable air tank 135psi max pressure enough for boost leak test?
  194. Exedy aftermarket clutch
  195. rattle issues...need advice.
  196. T4Z 88 HTA or Precision 6765 !?
  197. axle help
  198. Need help with ecu code
  199. something finally broke.. the trans... i need some tips and advice
  200. Defi BF gauge help
  201. Test Pipe.
  202. To METH or NOT to METH that is the Question
  203. What would you do if a shop did this to your car?
  204. Phantom knock free reving with Revolver cams on stock ecu
  205. checking tranny oil????????/
  206. Cooling Fans Question
  207. new version of mits dyaqueen for 6 spd
  208. Can i get a straight answer??
  209. mod install
  210. GSC S2 duration
  211. I need guidance
  212. I need guidence
  213. Engine off, key on, press gas pedal and loud noise!
  214. Losing boost above 10 lbs
  215. EVO IX HKS build-up lots of pics, needing some advice
  216. CAI causing drivability problems?
  217. Need Help Today!!! Swapping Turbos On 2003 And 2006
  218. Metal shavings
  219. weird engine hiccup help! plz
  220. Full Race Clone ??
  221. Anybody have Ralliart plug wires in stock?
  222. a few questions about evo mods.
  223. having some problems with boost
  224. engine oil light flashing
  225. injectors needed?
  226. AWD Motorsports Switching to Haltech E11v2 & Racepak Dash..
  227. exhaust tip question
  228. Need help please,down on power -25hp, -50tq after exhaust leak at o2 housing
  229. need help, what type bolts to get
  230. Exhaust leak
  231. Fidanza 3.2, ACT Prolite Flywheel and Stuff - Pics/Review (56k go run and hide)
  232. What makes engines rev differently???
  233. Random Misfires Please Help!!!
  234. Brian crower 280
  235. Ss Auto Chrome Manifold
  236. Boost Test Help
  237. Transmission issues
  238. tranny problems gear grinding tranny going out....
  239. Evo IX with upgradedcams- Yes or No
  240. Kelford 264's
  241. What would this cause? Q For Turbo Pros
  242. Getting an exedy twin plate clutch...
  243. 1000cc injectors at 650 help
  244. shep tranny..exedy clutch help
  245. C6 ZO6 vs FP RED?
  246. Defi / AEM UEGO
  247. Do i have to use Platinum Plugs????
  248. Valve Springs Choices!!
  249. Cobb turbo back, Good or Bad?
  250. My Thoughts on Short Shifters and Gear Grind
