View Full Version : Evo Engine / Turbo / Drivetrain
  1. Wierd issue With CEL
  2. Mike Reichen clinched new standing mile records for Maxton
  3. Quartermaster Twin Clutch Information Please?
  4. I know this has been asked... Greddy Type RS
  5. transmission problem....need help
  6. fuel pressure gauge question
  7. any one try this act clutch? i just got it and its getting put on wed
  8. Need engine diagnosis help.
  9. Broken timing belt tool... EMERGENCY!!!!
  10. AFI Twin Scroll 3076 Dyno part 1
  11. URGENT HELP!! quartermaster twin disk
  12. transmission warranty voided by FMIC?
  13. Please look at pics. 35r bent turbine fin (barely)
  14. Intercooler End Tank Design/Theory
  15. Intercooler, Piping...
  16. Two issues, please help!
  17. Building my shortblock.
  18. Need exhaust help
  19. Prosport oil pressure sender leeaks!?! HELP :-(
  20. best way to drive with no tune?
  21. o2 housing causing severe boost taper?
  22. Stock intake hose flying off all the time!!!@!@!*@7!*@
  23. spun main bearings what to do
  24. FP Red or BR 3065
  25. new twin plate clutch slipping on launch
  26. E brake ????
  27. High Pitch Noise or Squeal coming from my car. (not brakes related)
  28. bad boost controller???
  29. Gears grinding at high speeds?
  30. Best hotside for 2.3 liter and HTA 35r .82 or 1.06???
  31. Mechanic put castrol gtx oil in my car >=[
  32. IS the USDM RS fitted with the JDM RS trannie?
  33. CEL: Random misfire code???
  34. 50 trim .86 ar?
  35. freak mini battery?!?
  36. Loud Engine BANGING
  37. WHICH 1s WOULD U USE?
  38. FP Red 18psi actuator touching outlet pipe
  39. ACD Error??
  40. Problem with Quartermaster Twin disk install.
  41. Timing belt question
  42. Did the Evo come with 2 different size o2 housings stock????
  43. best plugs/ wires?
  44. Sound camshaft Brian Crower 272/272
  45. Exedy triple cerametallic vs Exedy triple carbon
  46. FP Red and BR lower IC pipe fitment
  47. Which ACT flywheel would be best for me? Streetlite or Prolite??
  48. wierd noise at start up
  49. Running strait meth no IC
  50. Secret Number
  51. Exedy Triple Carbon went out on me...
  52. Someone Please help with measurements for injen hardpipes + intake
  53. Oil Feed Line Warning For Everyone
  54. Why did my turbo blow up?
  55. Blown transfer case prevention tips
  56. ACD pump not working
  57. sort of concerned about a long exhaust flame.
  58. Needed! High HP EVO's to Help Evaluate Carbon Clutch Technology
  59. Redline in Trans and T/C
  60. 4g64 setup. JDM evo VII water pump, no adapter
  61. Another Update on my BR Built Monster
  62. turbo-install tips
  63. 500WHP on Stock MAF&ECU
  64. hks dlii ignition system
  65. bolt size connecting hotside to o2 housing
  66. gap for my green
  67. First oil change.. used 5 quarts.. am I okay?
  68. best way to break in a clutch?
  69. Questions about some parts
  70. Evo Clutch???
  71. anti-siphon screen for EVO???
  72. SEXY Evo Red
  73. bleeding clutch
  74. Which fluids for ACD, Transmission, and transfer case
  75. Taking the T-Case Out...
  76. looking for evo 8 motor
  77. Fuel pump hot wire
  78. 30K Service Fluid Color ....
  79. Green Dyno Sheet Review
  80. P0401.. not sure what to look for
  81. Springs/Retainers with Kelford 272's and 2.3 Stroker?? Need Advice!
  82. Clutch Pedal Adjusted All The Way Out
  83. EVO 8 question
  84. evo VIII ECU on evo IX motor???
  85. Cheapest way to reach the 350 whp range?
  86. Buschur or AMS???
  87. Wilson Manifolds California Spec v2
  88. Greddy Ti-C and AEM UEGO placement
  89. Need Torque specs for a 9mr turbo (20g)
  90. What numbers should I be making?
  91. whats wrong with my car?
  92. New Plugs now a lopey Rev
  93. Can't understand JDM Gauges
  94. Aftermarket Cams with stock springs/retainers?
  95. NEED HELP tcase problems
  96. 1000cc's, 93 = loss of drivability?
  97. MAF, need some help asap...
  98. Changed timing belt and now car won't start
  99. Hitting the rev limiter
  100. Evo VIII Oil Press Guage Install
  101. Fluids
  102. plugs
  103. Help/thoughts
  104. Improving drivablilty.
  105. Stock Clutch - Chatter when takeoff - Time to replace??
  106. Reving the stock bottom end (calling the fast cars)
  107. Clutch Advise
  108. cam gears
  109. valve springs or not
  110. 4G63 Buildbook?
  111. timing belt-like noise
  112. Indy/Wilson V2 Intake Manifold on stock turbo setup???
  113. Fp Green With Nitrous?
  114. timing belt-like noise
  115. Looking for a oil filter housing!! HELP!
  116. f1 clutch and flywheel: URGENT
  117. Hta35r
  118. brian crower 280 cam gear settings
  119. Changing your timing belt!
  120. Need help choosing a Evo Manifold to Re-Flange
  121. Rear diff clunks? What bushings?
  122. 5th and 6th Gear Lockout
  123. boost control
  124. Couple clutch install questions
  125. HELP clutch draging!!!!
  126. Rear engine mount vibrating
  127. Stuff you just gotta do while the motor is out...
  128. Switching BOV issue! HELP!
  129. f1 racing stage 3 clutch kit
  130. Boost issue question. Please help.
  131. new hks type r intercooler today
  132. Clutch problems?!?
  133. This is slipping rite? (clutch problem)
  134. Evo IX - vacuum levels at idle?
  135. Turbo Swap Question!
  136. ebay fpgreen, do NOT buy!!!
  137. so close to 400, is it enough?
  138. where can i get my stock ex. manifold ported and coated???
  139. Any Test Results For Indy/Wilson V0 Intake Manifolds, Yet?
  140. Humming Sound
  141. E85, John Shepherd, Buschur Racing and some good power.
  142. Boost Pressure and the correlation to WHP
  143. Throttle Body Question
  144. Yes, I am an Amsoil Hoe
  145. Bov Recirc question!!
  146. What do you guys think of this?
  147. What size intercooler piping?
  148. whats better with the gt3540-
  149. GT40r stockblock???
  150. Installed ETS FMIC now some issues.
  151. Oil level
  152. tranny, TC or clutch?
  153. Is the evo 8&9 thermostat the same???
  154. how bad is it?
  155. need comments on ferrea beehave for valvetrain
  156. Where can i buy a gt35r compressor wheel and housing?
  157. Need help with injen IC hard pipes + intake
  158. Quick Question: What trim is the Evo 8 Turbo?
  159. Max power out of Evo 9 Turbo
  160. AEM Wideband AF ratio
  161. Are Megan Exhaust manifolds and 02 Housings worth it?
  162. piston problem, head gasket, or valve seals
  163. Compcams 272 help !!
  164. Swaping TB's?
  165. Stalling and Idling Problems - No Leaks! What the heck?
  166. Thinking of running Evo9 Cams HKS 272 and 280 combo ??
  167. cossie m3s or kelford 272
  168. GM MAF aka Blowthrough setups w/stock ecu power?? please chime in!!
  169. MAF - Honeycomb
  170. Internal to external WG conversation?
  171. turbo boost
  172. FP Green + Aquamist, which kit?
  173. Removing t-case ?
  174. Cam Gains? Current Setup.
  175. HELP! Need Turbo NOW!
  176. oil consumption, 20% leak down and leaky valve guides: engine builder's advice needed
  177. lc-1 grounding?
  178. Engine heat issues after isntalling a strocker 2.4l kit
  179. evo tranny tranfer oil
  180. Not so smooth shifts......
  181. CAM Part #'s Anyone know the size of these?
  182. clutch pedal problem...
  183. ACD control
  184. Need a shop to install a clutch GA/TN Area
  185. FP Red install kit
  186. What next, 2.1, 2.2, 2.3 or 2.4?
  187. transfer case oil
  188. brain crower s3 vs cosworth m2.. worth $$?
  189. 450awhp Power Goal on 93oct
  190. My GT4088 set up fabrication (pictures inside)
  191. Picked my stuff up. COATED!
  192. my car won't start up right away. help
  193. which housing is better
  194. EVO 8 cylinder head
  195. cv shafts
  196. Buddy Club vs HKS Cams
  197. redline question
  198. Ambient Air Temps?
  199. 2.0L or 2.3L? for the gt40r
  200. An interesting dyno comparison of two EVO's
  201. 4g64 W/evo head head gasket
  202. stock clutch question.
  203. Peakboost or Mynes manifold ???
  204. greddy profec b problem
  205. greddy ti or ets?
  206. Power Enterprise Head Gasket for EVO IX?
  207. Help where does this wire go ??
  208. !!!!! reaching 550whp on hta35r?????
  209. Connecting the AEM Tru Boost solenoid
  210. hard to put car in gear
  211. intake problem?
  212. Intake Manifold Gasket HELP!
  213. Is it normal for your CEL light to just turn off?
  214. Machine Shop messed up BIG TIME!!!!!
  215. How much boost on stock internals
  216. perrin intake worth claims?
  217. 16g6 wheel power
  218. So i have Decided on an Exedy Twin ... any downsides?
  219. PO234 and PO300 out of nowhere?
  220. Evo 9 OEM spark plug cover
  221. Transfer Case had no oil
  222. Possible Dead Ecu?
  223. blow off valve question
  224. T case gone bad???
  225. E-85 & 1000cc injectors
  226. What is needed for a 6spd swap?
  227. is upgrading motor mounts needed?
  228. motor mounts?
  229. AWD Motorsports 700hp RS Build... 7-14 Days Total!!
  230. Injen LICP fitment issues
  231. Intake Inquiry
  232. Biiiig issue - stripped bolt in exhaust manifold (tried searching already)
  233. Need Help... No MO' Fuel
  234. Question
  235. Best choice of cams for my ix mr
  236. Catback size
  237. I have joined the dark side:D
  238. S1s on an VIII...Vid inside..
  239. Small mod ?
  240. BR exhaust vs ETS exhaust
  241. Oil pump
  242. What does a IX need for a 10 ?
  243. Where!?!?!?!?
  244. Oil on valve cover, White smoke on decel, Dipstick popping up! Help!
  245. Resonators..how much flow...?
  246. Help with strange noise...please
  247. High Idle (with vid)
  248. BIG Electrical problem
  249. timing belt/cam install
  250. Anyone have the Jun BL Catback?
