View Full Version : Evo Engine / Turbo / Drivetrain
  1. cutting out between shifts? NEED HELP
  2. P0300 and P0138 codes. Need some insight.
  3. Ams 3076 Turbo Upgrade And Minor Headwork?
  4. Meth Injection ratio?
  5. resurface fidanza??
  6. Nitrous in Evo IX
  7. The perfect transmission oil
  8. P0243 Boost solenoid error
  9. fidanza clutch
  10. Check engine light
  11. 2.3 35r 880cc injectors need help confused
  12. Just some praise for EvoPowerMods
  13. boost gauge
  14. Vaccum at Idle on boost Gauge
  15. which wideband?
  16. 3" Intercooler piping.
  17. Car starts running bad when warm...
  18. Best Break in for an Exedy Twin??
  19. evo8 turbo compressor wheel
  20. downpipe clearance question?
  21. what clutch
  22. pill for 27psi
  23. Odd smell from AC?
  24. Need help with powersteering hose removal
  25. CRACK!! What to do
  26. Rod Knock? Need help please!
  27. Clutch VIII Posted in wrong forum...
  28. Prototyping 8MR UICP: Looking for input
  29. New o2 sensor and still codes????????
  30. Tanabe Concept G Blue?
  31. Replacing o2 sensor
  32. The quest for more speed, further improvement of the aero.
  33. What Are the Drivetrain's TQ/HP Limits
  34. forge wastegate actuator boost problemsh HELP
  35. Lancer evo stock turbos
  36. Need help with a couple motor issues.
  37. REALLY HAPPY with my results.
  38. Rough Startup
  39. !!! Short Shifter & Bushings & Motormounts!!!
  40. Evo 8 no power?
  41. fuel pump question
  42. rear diff question
  43. act clutches
  44. 2.3L Info Thread... Any one with a 2.3 please chime in!!!
  45. MY 2.3L/3076R Build. (56k....haha)
  46. clutch makes loud growling metal spinning sound
  47. Piston choice
  48. FP Red =]
  49. P.R. GT35r presicion 628hp@ 35psi
  50. Out with the Green in w/the Red, Kelfords & porting! NEW VIDEO ADDED!!
  51. leak in differential sys.
  52. Calling all AWDmotorsports Manifolds....
  53. 9 & 10 Second cars --Drivetrain??'s
  54. Please help with brand new slipping clutch!!!
  55. Engine light is on after cam install
  56. FPred vs FPgreen on 91 octane
  57. resonator removal / test pipe fitment
  58. Front uniwersal 02 sensor wires
  59. help plzzz
  60. Ic pipe size question
  61. FP Evo Red 1st. Dyno Testing Done, numbers and pictures.
  62. transmission drop??!?!?!?!
  63. FIC injectors: Am I being paranoid?
  64. @ 60K what next:(
  65. Evo Green Dyno Results
  66. help with clutch line issue
  67. supporting mods need w 3076r turbo
  68. Looking for a licp, which one?
  69. Fuel filter?
  70. AMS does it again... 2.3RR 850R 560whp on 92oct!!!
  71. 9sec9/OKIX's EVO, Red build, racing and VIDEO
  72. Boost problems. Will not see past 0psi
  73. Evo occasionally dies upon deceleration
  74. balance shaft
  75. slight hum on deceleration.
  76. Red fluid in my airbox????
  77. In-tank fuel pump options for evo's?
  78. Need help, Fuel Rail and Injectors
  79. ecu code on my evo p0170
  80. Help With start up issue
  81. Check Engine Light out of no where?! Please Help!
  82. green to red
  83. Stock return line please look.
  84. Weird humming/howling starting at 3k rpm's
  85. transfer case
  86. Help me finish my FP Red setup
  87. Clutch Line Thread Size
  88. Test pipe gains??
  89. Thank you!
  90. Im Doing Cams and "Maintainence"...I got a few questions
  91. NEED HELP car problems
  92. NEED HELP car problems
  93. How much power can i hit???
  94. vwjeffs big adventure with the 37R
  95. fp red vs gt30r
  96. What do the seatbelt bolts get torqued to?
  97. FP RED 93 vs 100oct
  98. still having weird boost problems, same thing for about 3 years.
  99. Which invidia testpipe?
  100. oil feed banjo bolt
  101. Deciding between the 35R and 37R
  102. wastegate problems??
  103. Perrin Ebc
  104. Suman's Revenge - Part II - PT62/62 - 679 whp on pump
  105. Stage IV Evo 8 with FP Red 408 Pump - 509 Race whp
  106. Oxygen Sensor ...OEM or Universal
  107. Can i hit 500awhp?
  108. Which cams/valvetrain is this?
  109. rough idle
  110. help o2 bolt size pitch can't search on phone
  111. lookin for options
  112. What is the procedure for measuring exhaust sound (decibels)??
  113. future plans
  114. New Parts, Car wont start... Help
  115. built shep 5sp only goes 98-97 @ 7k in 4th?
  116. AFI on the car!!
  117. Exhaust Manifold Upgrade?
  118. [Problem] Louder turbo, and smell.
  119. DD AMS 42R? Is anyone doing this? ANY 42R.
  120. Tranny Experts needed, Wierd issue after track night?!?!
  121. Drag Racing 2nd gear lockout
  122. kelford 272s w/ stock springs?
  123. ACD repair
  124. EVO8 piston/rod specs
  125. Help Me Decide...
  126. tilton twin installed, noises normal??
  127. Turbo install how many hours did it take you?
  128. oil from downpipe after FP green install?
  129. stock clutch go bye bye
  130. boost flutter
  131. Full Bolton Evo 8, What am i missing?
  132. (BR37r) My Plans, but no idea where to start
  133. FP RED dispelling twin scroll myths.
  134. What manifold is this?
  135. 344whp and 368wtq on stock 8 turbo
  136. Hi everyone, first post.....radiator help!
  137. silver`s engine damper ???????????
  138. Evo 7 map sensor
  139. Weird thing happened today
  140. help! my evo's running terrible
  141. noob question, wastegate control
  142. FULL FUNCTION's first car to be tuned on E-85 / 40R / 2.1L
  143. Backpressure Ratios?
  144. add 5-7* timing = no difference?
  145. AMS 2.3RR GT850R CNC Race head Test!!!
  146. What Piping?
  147. Spanish 4G63 tuner!!
  148. 2.3 850r Pump Gas 530whp/462ftlbs
  149. HELP!!! OIL Leak
  150. greddy Ti and DC downpipe issue...
  151. 4G63T MIVEC Race Engine Build
  152. Help diagnosing issue
  153. CBRD/Kreionic/ETS
  154. badly in need of help. please read
  155. Question??? Help!
  156. 2.4 4g64
  157. VIII and IX axles
  158. help Help Help
  159. Anyone Running EvoRed + 2.3L Stroker?
  160. just got my car tune but the everytime boost 26 my service light starts blinking??
  161. need someones opinion
  162. FP Green on a 2.2 Stroker
  163. FP Green vs FP Red Dyno Results and Review (from my perspective)
  164. The World's Fastest EVO 221 MPH in-car video
  165. Engine Oil Analysis
  166. Synapse BOV install problem in stock Evo9
  167. How Can I Get More Power Without a Turbo Upgrade???
  168. Are the under-the-hood shifter bushing and the center console ones the same?
  169. evo 7 manifold
  170. What octane would you run at 26psi?
  171. evo green spark plugs
  172. no boost after hallman install, help plz!
  173. Clutch slipping
  174. Suggestion on my final mods list and build up
  175. Knock at 2step?
  176. Who's running BF 272's in a stroker?
  177. Another Bad Misfire Thread!! Please Help
  178. Help urgent! Car makes really wierd noise.
  179. turbo + water lines
  180. Kelford 272's - Evo 8
  181. Lightened Flywheel Info
  182. Open Exhaust
  183. Need suggestions on these mods
  184. Broken 2nd gear comfirmation.
  185. Stock Radiator Cooling Fan
  186. Cobb turbo back installed! (pics)
  187. same OEM flywheel on 5 and 6 speed?
  188. Are Evo 8 & 9 rear diffs interchangeable?
  189. Mitsubishi Turbo Nomenclature
  190. wierd clicking noise...help!
  191. something is wrong
  192. Do I really need a tune?
  193. Red on 03 50k few mods
  194. Why is SBR stroker kit so cheap?
  195. What are the stock IX cams good for? 50 trim?
  196. Help me please slipping clutch problem!!!
  197. cylinder missfire
  198. 3076 turbo kit
  199. Exedy twin plate?
  200. Oil light and temperature
  201. ams dnp buschur manifold with A/C
  202. Less than 5 miles on a new rebuilt tranny and look what comes out!
  203. Head rattle/tap help
  204. Timing Curves for 30psi on pump
  205. Leak from between t-cas and trans
  206. Are HKS Cams stamped with HKS lettering?
  207. AMS UICP And Mini Battery Questions
  208. i need a turbo!!
  209. o2 bolts
  210. E85 budget track motor build
  211. P0300 on Evo IX after HKS 272 intake cam install.
  212. sudden loss of boost
  213. whats going on with my plugs?
  214. Am I the first to buy a USED evoRED??
  215. Front Fender Splash Shield Clips? Where to buy?
  216. how do you remove the philips head clip
  217. Need advice on mods
  218. 610awhp@32psi.. E-85
  219. I'm Giving Up! Help!
  220. Should I turn my boost down?
  221. Green Turbo install tip
  222. What should be next.
  223. Switching BOV's
  224. need help i think i blew up ?
  225. HVAC problems....
  226. boost .... help plz
  227. overheating issue
  228. After reinstall TPS sensor, it reads 98.823 at WOT. Need help
  229. 6 speed 4th gear grind
  230. 637whp @ 30 PSI (video inside!)
  231. FP Red installed and running!
  232. Fuel/air ratio
  233. help plz
  234. HELP!Wont Hit 1 PSI of boost
  235. Help!wont hit 1 PSI of boost
  236. Help removing HKS BoV from UICP
  237. Exhaust, test pipe, and downpipe... safe AFR's???/
  238. Is my car underpowered?
  239. wierd place for boost leak or no?
  240. TPS is at 98.823 under WOT???
  241. Car Won't Start!
  242. Wierd issue With CEL
  243. Mike Reichen clinched new standing mile records for Maxton
  244. Quartermaster Twin Clutch Information Please?
  245. I know this has been asked... Greddy Type RS
  246. transmission problem....need help
  247. fuel pressure gauge question
  248. any one try this act clutch? i just got it and its getting put on wed
  249. Need engine diagnosis help.
  250. Broken timing belt tool... EMERGENCY!!!!
