View Full Version : Evo Engine / Turbo / Drivetrain
  1. exedy twin plate clutch judder
  2. Smoke from Hood
  3. Used Exedy/Cusco Twin Disc: What is it worth?
  4. Maxxed out stock turbo vs. Red or HTA Geen turbo
  5. White smoke from my muffler....please QUICK HELP!!
  6. acd reservoir relocation help
  7. waste gate dump question
  8. mod list..what do you guys think
  9. How big of a gain will I see going from GSC S1 > S2 on this setup.
  10. NGK colder plugs, smoother idle???
  11. Bad BOV?
  12. question about HTA 37 and GT4088?
  13. T Bolt Clamp
  14. 4g63 carnage - Post Mortem
  15. Fluttering with IX BPV
  16. Transmission diagram, top 3 bolts to engine block
  17. Camshafts.. how to choose ?
  18. My port & polish works
  19. Rear 02 sensor plug
  20. ACD Lights
  21. Missing Bolt at Hotside to O2 Connection
  22. Buschur intake fitment issues
  23. Transfer case locking up?
  24. Help me choose a clutch!!!!!
  25. AEM dry flow filters?
  26. Mod List...what do you guys think?
  27. 60k miles water pump: keep or change?
  28. Just bought a 2005 EVO 8 turbo AND a 2006 EVO 9 turbo.. Can't decide which one to use
  29. Ets intake w/o Tune
  30. TILTON Twin Cerametallic / Organic REVIEW
  31. high mileage evo rear diff
  32. Erratic idle after Sparktech non-Cdi COP install..WHY? Need suggestions..
  33. p0335 issue
  34. Clunking Noise from driverside (Another Clutch job issue)
  35. Keep coilovers thru winter? or not!?
  36. Rear Muffler
  37. DO hitting TC
  38. hks 3037 manifold problem!!!!!!
  39. possible bent valve?
  40. valve spring install question (without pulling head)
  41. Buschur's aftermarket water pump
  42. FP GREEN 73HTA Question
  43. Help, rain raped my motor
  44. JohnBradley's 2.2 long rod build
  45. WEAPON-R oil Catchcan setup>>pics
  46. need help(alternator)
  47. Evo 8 engine ticking/knocking noise (425 bhp)
  48. Intake Coupler Fitment
  49. FP Black Turbo
  50. exedy clutch help
  51. Intake pipe fittings/bungs
  52. Heater not working after radiator flush
  53. Time to change spark plug, what should i get?
  54. Need help or advice. (n00b)
  55. 03 viii 5spd into an ix mr
  56. Precission 60mm turbo??
  57. Clutch slipping
  58. Cam install costs
  59. Project: Evo6 Powered Mirage
  60. Hypertune Manifold
  61. comp 272 cam timing?
  62. 20G greedy turbo
  63. 2010 Borg Warner Airwerks Turbo catalog
  64. Oil leak after timing belt install...
  65. Looking for Clutch, Got $650 to Spend!?
  66. Exhaust question
  67. HELP Buschur Double Pumper not working
  68. Bad transfercase or just the cold weather?
  69. Exedy Twin Disc?????
  70. Bad diff of something else?
  71. Clutch question
  72. 4g63 vs 4g64 - 2.0, 2.3, 2.4L ?
  73. Can a bad Tune blown an engine?
  74. Blown head gasket or not?
  75. T-case
  76. Connecting brass fitting to intake pipe
  77. IC Piping Upgrade
  78. Cooling system question?
  79. misfire problem
  80. Cam gears from VIII work with IV
  81. Clicking metal on metal right front noise
  82. Turning boost DOWN in the WINTER?????????
  83. Converting to E85?
  84. Next Upgrade for Summer 2010, Crap Octane here!
  85. DIY oil catch can
  86. Some wideband ?'s
  87. My IX struggles to start??
  88. Evo VIII MR Turbo Question
  89. Balance Shaft Vibration , Help !
  90. hks gt2835 ball bearing turbo rebuild
  91. Highest HP FP GREEN on PUMP AND METH?
  92. help-ignition break up with 30psi
  93. WTF happened?
  94. 4 inch intake ????
  95. Strange Recall
  96. BBK Full or HTA FP Green?
  97. turbo inlet and outlet gaskets purchase
  98. GSC S2 Cam Settings
  99. The reason for my EVAP code - Check this out!
  100. Buschur Ported exhaust manifold, how much was YOURS ported?
  101. Will I have an exhuast leak?
  102. Fuel tank thump?
  103. No boost till 4th and 5th Gear
  104. 35R Comp Housing keep rotating towards the radiator?????
  105. Quick intake install question
  106. please help.in witch order are firing the cylinder when i oped the hood.
  107. Where can I get a QM Twin rebuild kit?
  108. Lifters help
  109. car is pissin me off !!
  110. building my 2.0L
  111. I just...
  112. Stainless Steel FAQ or WHY IS MY SS EXHAUST RUSTING?!?!
  113. Best Turbo for 600hp
  114. Verify cams..
  115. Suddenly Lean at WOT!
  116. Any new FP-BLK or BBK-XL info????
  117. Oil coming out my bov? need help?
  118. t3/t4 feed back
  119. Filling T-Case
  120. Compressor maps for FP Turbos (red/green)
  121. Tubular Manifold vs Catback
  122. Clutch Help!
  123. 5 bolt garrett O2 housings?
  124. Improving the Reliability of the 4g63
  125. evo 9 and 8 o2 sensors
  126. Hks 272?
  127. Tial wastegate
  128. O2 sensor help
  129. boost problem...
  130. ETS FMIC install thoughts (a few pics)
  131. Boost leak around TB
  132. Throttle Body "Drivability"...
  133. More PSI?
  134. bbk full vs sst
  135. Blue smoke after a boost leak test
  136. Evo gearbox rebuild. What wear is acceptable? several pics!
  137. ETS Intercooler Spacers - Help
  138. car makes a rattle when clutch isn't in
  139. EVO IX bov concern/issue
  140. Fidanza flywheel failure!!!
  141. turbo thinking about getting this..
  142. oil pump case Question
  143. A question for Dave Buschur about the Deluxe FMIC
  144. waste gate getting weak?
  145. Carbonetic Single??
  146. About Tran's Fulid HELP?!
  147. cleaning the head
  148. Mobil 1 FTL!
  149. Avid Motor mounts - Replace the sides with Stock?
  150. NEW PARTS!! See pics!
  151. Removing Injector Resistor
  152. engine builders i need help
  153. Boost Creep (not a usual BS thread)
  154. 9 trans in a 03
  155. Black Smoke
  156. Clutch
  157. Battery relocation question
  158. Please Help.. Need to identify what and where these go...
  159. Thinking of trying this
  160. Second Opinion: Radiator Issue
  161. LICP, which one????
  162. HKS 272 cams?
  163. head removal
  164. For the real mechanic
  165. acd reservoir???
  166. Driving issues.
  167. So.. My ACT clutch fell apart!!!!!
  168. shifting stick
  169. Larger T Case O Ring
  170. How many of you live with all 3 ACD lights?
  171. Opinions on FP red setup
  172. greddy ti or ets 3.5 inch exaust system
  173. missing / surging Evo 8
  174. How to test a Walbro 255 off the car
  175. when doing camshafts 272s
  176. Help Identify this FMIC
  177. Oil cooler help!
  178. Map performance ultimate rods
  179. Help with Avid motormounts
  180. need help!!! Stock ignition
  181. Can a vibrating crossthreaded EGT probe be causing knock?
  182. Grinding in second sometimes 3 PLEASE HELP!
  183. Front under panel
  184. Best 280 Cams
  185. Stock 10.5cm turbine housing divider cracking
  186. Worn Exedy twin disc
  187. OEM flywheel resurfacing - specs?
  188. What should be done first? (Head or Block)
  189. oil consumption? motor issues
  190. Crank Pulley Causing Knock
  191. AMS TBE Fitment Issue
  192. QM 7.25" V-Drive Service Parts(Clutch is slipping)
  193. New guy, I have some simple questions
  194. knocking noise from tranny
  195. P0401 CEL after missed shift/super high rev
  196. Which OEM oil filter should I use from now on?
  197. still having a problem- help
  198. Mitsu fluids or AMSoil for 30k
  199. diffrence between 8 and 9 turbo?
  200. Evo valve cover baffles
  201. Another cam question
  202. My evo is breaking up badly under wot help!
  203. Gearbox Or Clutch Problem, need advice
  204. ams Moustache Bar Eliminator
  205. 2.3l or 2.2l?
  206. Sparkplug cover with vents?
  207. Hks bov
  208. Turbo XS MBC???
  209. T.R.E. Stage 3 tranny, humming sound in 1st and 2nd gear?
  210. Greedy Counter weight and ebay short shifter combo?
  211. motor mounts
  212. need help choosing ignition system, plugs, and injectors
  213. AMS oil cooler on a MR?
  214. PITFA shifter issues...
  215. clutch flywheel combo???
  216. Anyone seen this sequential before?
  217. 'Short' UICP Kits
  218. hks exhaust problem?
  219. Smell of coolant inside the car? Also cooling issues?
  220. Re-Torque Head Studs?
  221. HTA35r or FP Red?
  222. 6 Speed vs. 5 Speed
  223. metal shavings in oil
  224. Custom moroso oil breather can (help with fittings)
  225. tranny....fluids
  226. Info and facts about the Wilson Manifolds D Rail for the Evolution
  227. Need you help fellas PLEASE
  228. Stock battery and airbox UICP?
  229. 6 speed to 5 speed
  230. IX Block Carnage
  231. High hp, stock block, High milage
  232. Jun 272 Cam specs?
  233. Ams downpipe rubbing tc ?
  234. Help turbo oil leak
  235. Vent to air BOV question. Please help!
  236. One step colder for my 9 with red not sure which to get ?
  237. Evo IX Mivec and Cams question
  238. Hks rs....absolutely need tune?
  239. Internal Fuel Pressure Leak ?
  240. GT3567R....any info?
  241. Fuel injector clips evo 8
  242. Spec clutch problem
  243. What's the best FMIC??
  244. stock block weight ?
  245. Stepped Compressor Wheel
  246. turbo mag best exhaust results?
  247. Does something look shady here?
  248. One shaft - two turbos
  249. Injen pipe size
  250. Competition Clutch owners..
