View Full Version : Evo Engine / Turbo / Drivetrain
  1. Clutch grind/creak/rub???
  2. Aggressive Cams for MIVEC? Evo IX
  3. How much will it help
  4. Borg Warner s258
  5. Buschur O2 Housing Fitment Question
  6. cosworth head build (pics)
  7. STM *** New Product release***
  8. BUschur Stage 3 long block Full race 4088r ...Kansai
  9. how much can i get?
  10. Knocking engine help LONG!
  11. FP Red or 30r?
  12. Deciding on cams for my mild setup...headstuds?
  13. Rubbing noise in engine area?
  14. boost creep
  15. greddy type rs???????
  16. Any way to clear( DTC's) CEL without removing battery power?
  17. Reducing drivetrain lash
  18. I need help!!!
  19. How Much PSI the Stock Int ...
  20. best way to clean lifters..??
  21. Helix Down Pipe Question
  22. What spark plugs to go with?
  23. Cosworth piston issue... photos inside
  24. thoughts on the fidanza 3.2 clutch
  25. need a new radiator
  26. Cyclinder Misfire. Help
  27. revolver 264s vs kelford 272s
  28. Testing new Wavetrac front Diff...
  29. Need Trans Suggestions
  30. just installed FP red. have some q's
  31. Which 02 Housings fit with AMS downpipe?
  32. Who's running 1600cc inj on the street?
  33. Evo Ix Dyno #
  34. evo Rs transfercase overfilled... by +16oz
  35. Pics of your boost controller
  36. More power with bigger intercooler?
  37. Will Evo IX 6 speed trans. fit in Evo VIII?
  38. Flywheel Bolts
  39. Is Front OEM Undertray Necessary?
  40. Bleeding The Coolant System
  41. 100oct vs E85
  42. ACT Clutch Poll!!!
  43. tranny build ?
  44. I've need your help!
  45. Used cams - Useable or not? (Pic)
  46. Slightly used cams
  47. clutch pedal gripping?
  48. Max HP/TRQ on the stock clutch
  49. What turbo kit?
  50. tranny code
  51. Larger FMIC+winter temperature+same tune=lean condition?
  52. Hks Racing Suction Intake Trouble!!!!!!!
  53. ACD transfer case specs
  54. JIC Ti catback w/resonator
  55. Air Fuel Goes to 10 when slightly lifting foot off gas?
  56. Clutch Engagement ?
  57. low end response versus top end power
  58. Cx Racing Radiator
  59. Cam gear settings?
  60. transmission problem, fifth gear
  61. Convince me to not pull the motor and build it...
  62. Side Mount Turbo for EVO?
  63. FPRed Vs 35R
  64. rerouting the throttle cable
  65. Car cuts out with Test Pipe installed
  66. 860 WHP on the Buschur Dyno
  67. new clutch!!!!need help
  68. My AMS 2.0L build
  69. Evo 4 and Evo 8 differences
  70. FP Red custom LICP
  71. spark plugs and 02 sensor
  72. 3" to 4" filter 60whp gain!
  73. Boost response really slow? wastegate stuck open?
  74. Possible blown head gasket or coolant leak... help
  75. Difference between EVO VIII and IX head gaskets?
  76. Random Tech vs 100 cell cats?
  77. idle Vacuum and Recirc flutter
  78. Can your stock appearing turbo do this?
  79. Wich Fluid Help Plz
  80. FP Green Hotside Question
  81. AWD Motorsports RS.. 9.63@149.95.. Round 1..
  82. Making the car shift better.
  83. TurboXS FMIC Fitment
  84. Tranny Failure... Need Help!
  85. Weird shifting problem
  86. Clutch grinding at take off
  87. wastegate failure
  88. AgencyPower short shifter sitting off to the right?
  89. 20g TME turbo?
  90. FPRed vs 35HTA
  91. Weird Tranny/Clutch Issue
  92. EVO 9 TD06 20G Turbo?
  93. Best high HP and quickest spooling Turbo??
  94. ARP Main Studs? should I install them also. ARP Rod Bolts, ARP Head Studs
  95. Clutch Suggestions
  96. cam question.
  97. wrap for upper radiator hose?
  98. Help 5th gear grinds a little
  99. STM's Ricer goes on a diet...
  100. 4" aluminum tubing
  101. Flames
  102. Quartermaster Owners Chime In... Install Help
  103. need help asap!!!!
  104. My starter died. I need a new one.
  105. Cam install Part 2...new problems!!!
  106. Aftermarket BOV on Stock UICP
  107. Need Advice (Gauges, Mounting, etc.)
  108. To E85 or not to E85. That is the question
  109. help ,plz
  110. rwd evo?
  111. Boosting Problem - Any Ideas?
  112. Hi, guys. Your help needed. EVO8 390 whp burned 2 coils
  113. Evo 9 20G Turbo AWHP Numbers?
  114. Forge MBC?
  115. Blowing the rear end
  116. buschur small battery
  117. Stock Cat-back max power numbers
  118. Turbo headaches...
  119. A little Help?
  120. CEL Engine Light came on out of the blue?...help!
  121. Build questions
  122. Cam install...having problems NEED HELP ASAP!!!
  123. Whinning noise?
  124. Fuel injector clips missing. Needed?
  125. boost goes,hesitates,then goes?
  126. 382whp 332wtq stock turbo IX, built and tuned by AWD Motorsports
  127. Excessive smoke from exhaust? Causes?
  128. Kelford 272 Springs and Retainers
  129. Time for new clutch =[
  130. 4G63t Engine Book? Engine Build
  131. Battle of the turbo's FS635 vs. GT850R
  132. Kelford 280I/272E evo8, who's running them?
  133. Cosworth 2.2L Rod Length and Rod Ratio
  134. I think i have a problem
  135. Tranny Noise??
  136. Am i missing part of exhaust?
  137. Flywheel Good? (Pics)
  138. problem with testpipe
  139. MAF gone bad?
  140. Axle Problems
  141. Show Off: Synapse Synchronic or APS Twin Vent BOV?
  142. need little bit advice on catbacks.please help
  143. Pistons rings clearance
  144. White smoke from engine when under boost
  145. HELP?! Flywheel...ACT or Gruppe-S
  146. Gearbox identify ?
  147. ported and swain coated where from
  148. Explain the tru-boost settings
  149. ACT clutch disk question
  150. Short Shifter?
  151. Messed Up With Test Pipe
  152. Need some opinions please! Getting ripped off?
  153. help with pictured tcase leak below, please!
  154. Anyone running a T3 setup if so what are Good Trims
  155. Does anyone else have compressor surge?
  156. 12x12x2" radiator is it enough?
  157. EPM 02 Dump hitting Radiator??
  158. Gauges
  159. Driveshaft studs
  160. Oil pressure is WAY to high HELP new motor
  161. possible to bypass or delete the stock fuel filter?
  162. How does Twinscroll Work?
  163. Spec stage 4 clutch???
  164. help ,plz
  165. First impressions:Twin scrolling the T4Z HTA88
  166. FP RED W/Ext Wastegate?
  167. stock turbo possible leak??
  168. Battery Issues! Need Help!
  169. Oil Report(Blackstone)&K&N Air Filter
  170. Confused? suggestions!!
  171. FP4R cams
  172. Question on removing head and timing belt..
  173. Pistons part numbers Need help ASAP SOS
  174. proof of break in of an engine
  175. Who makes this header?
  176. Oil Leak + Popped out dipstick
  177. Stock Wastegate Arm
  178. FP RED How long did you wait?
  179. A few pic's from my buster rear end
  180. Question about exhaust
  181. Megan Turbo Manifold. Good or Bad
  182. big turbo input needed
  183. 9 turbo or something slighlt bigger?
  184. Feedback on ssautochrome t3/t4 manifold and downpipe?
  185. Carz Performance *TEASER VIDEO*.. Thanks JohnEB!!
  186. Does the wastegate stay open at idle?
  187. Short shifter?
  188. EVO9 Turbo on a 240SX?
  189. Did a boost leak check... heres what I found
  190. Clutch Install = Me Stressed
  191. School me up fellas
  192. boost leak issue...or not?
  193. Stuck manifold bolt
  194. new head gasket :mad:
  195. I think my clutch master/slave cylinder went out
  196. 400WHP on pump?
  197. 2.3 35r 880cc stock ecu
  198. Difference between evo 8 and 9 turbos (pics)
  199. Stock evo 8 piston question?
  200. Pure Tuning Borg Warner S259 Dyno Results!
  201. transmission question
  202. Evo Red For An 8
  203. Can my 500 WHP EVO VIII benefit from a 4.11 FD??
  204. viii block ix head
  205. clutch repair price$
  206. Help my car wont start!
  207. Oil squirters close to piston skirts
  208. Drivetrain making weird sounds! Need some help.
  209. Turbo wont spool until 5K, stock evo 8 turbo, no boost leak..HELP
  210. My evo 6 so far......
  211. Dont know what to do. Need Help!
  212. No Boost!
  213. FP Red + Meth?
  214. Can't decide on turbo kit.
  215. CBRD possible drag radiator...
  216. Little help/Info
  217. Piston to valve clerance problem
  218. Convince Me: E85 or Meth?
  219. My FP Red Setup
  220. The Correct Way to Install a Head Gasket?
  221. stock boost questions
  222. Shifter cables popping out of the console assembly...
  223. Stock Intake Mani VS. Other
  224. Oil Return pipe bolts
  225. Cosworth M3 Mivec Cams
  226. Cosworth M3 Mivec Cams
  227. Cosworth M3 Mivec Cams
  228. Turbo Suggestions for EVO IX
  229. EVO 9 Turbo problem.....
  230. FP Red... What Valves/springs?
  231. insane bov flutter
  232. Hks Bov??
  233. Oil on turbo housing makes me nervous...
  234. EVO Heater Core Removal - Help
  235. stock cam markings
  236. price of ams tcase rebuild?
  237. HKS 264's
  238. In-car Hallman boost controller question!
  239. Clutch needed: withstand MANY launches & 450 TQ
  240. Coolant Temps some what disturbing?
  241. ams or buschur for mustache bar
  242. Clutch or Tranny Problem??Help
  243. coil on plug system
  244. Engine Tick
  245. transfer case repair manual
  246. 4th Gear Problem
  247. boost fluctuation
  248. oil light flickering what's it mean?
  249. high 400+ hp owners chime in
  250. 9sec9/OKIX, BUSCHUR RACING, ROUND 3..
