- FP Green VS stock 9 turbo. Looking for feedback
- P0301...help.
- dumptube?
- Which axle sub shaft goes on the drivers side?
- I need help please!!
- 5 spd. vs. 6 spd.
- Tarmac/Gravel/Snow lights are all on!!!! what's the issue?
- Grinding on fifth !!! Synchros ???
- ic piping tought
- Just for curiosity, how 162 rods on a 102 crank?
- Loud Exhaust
- RC vs Clinic
- Forge RS Atmospheric
- I hope this Intake Manifold will bring me to 10's!(pics)
- Stock Head?
- Who is running 4g64 motors? Chime in!
- BOV Flutter?
- Battery that Fits AMS Intercooler piping set up...problems...
- could a evo8 TRANSFER CASE work on a evo9
- Switch to E85 or Kelford 272s?
- Dogbox or something else?
- Help: Spun A Rod bearing
- What FP Green is that?????
- anyone with high HP with balance shafts?
- battery relocation
- 3rd Gear Wont Go In Easy, Why?
- clutch locking me out of gears pressed in
- Clutch Question..(very specific)
- radiator install. No more heater??
- Sparkplug questions???
- TOB will not engage!
- Gsc S3's VS Tomei 280s???
- something wrong?
- Water pump location question
- Perrin Intake kit installed (pics)
- HKS RS Reloaded Intake to fit an Evo 7
- Exedy or Tilton?
- FMIC thickness?
- Difference in 03 and 04 trans /transfercase
- Best MBC???
- Adding a Silencer to my turbo XS 3"
- 5 speed MR swap
- Exedy Twin HD Install Question?
- Evo 9 Cam Install
- Weird buzz in higher RPM?
- O2 Housing/Heat Shield Question
- cam install...need some help
- Cleaning Lifters and Rocker Arms???
- fuel rail?
- Just finish installing the Perrin FMIC and Nisei LICP (Pics Inside)!
- Stock Throw Out Bearing Rattle
- JM Fab Tubular Manifold
- Is this a 10.5?
- Cam Choices
- FP Red HP wastegate and boost..
- Dtc P0234 On Safc2 And Avcr?
- 1st gear vibrations!!!
- Tial Q 50mm spring problem
- Rpms Jump?
- 3 CEL Fix and still an SES Light
- hta 86 with drivetrain questions....
- Mmm...a taste of RED to quench the thirst
- Leak at O2 housing and Downpipe
- question about OEM clutch
- test pipe or high flow cat?
- Shift Clunk (NOT Rear Diff.)
- Catalytic converter backup = engine quit
- Moaning sound when downshifting
- stainless steel UICP
- Who goes out drifting/sliding around often? Bad for the drivetrain?
- Evo 6gsr
- HKS Turbo Manifold for the 4G63T
- Red options
- Tubular manifolds??
- Very Confused Evo Caught On Fire!
- FP Red Turbo & ACT HDSS Clutch
- EPM 02 Housing + ETS LP2? Will it work
- Is there something wrong with my AEM Tru Boost?
- Ebay Full Piping
- Motor help
- Odd noise during deep snow or heavy rain...
- P401 - Weird Code
- crank pulley?!
- B&M shifter install Question
- My Summer Build: Suggestions and Vendors Welcome!
- greddy td06-25g or hks gt3540r kit
- best cames for an MR
- Any Evo Holset setups on here?
- Headgasket advise!?
- BR Deluxe--> Evo 9 turbo solution?
- my 14yr old son doodle
- what turbo ?? plz help :)
- Ebay FMIC toughts?
- Modding a stock evo
- help my car is cutting out
- rpm raise??
- Check engine light? O2 Sensor?
- Crank pulley
- Plugs Look Good?
- HG swap questions: block clean? CAS orientation?
- What size bolts?? Need help ASAP please! EPM o2 Housing
- 420 HP @ 20psi on E-85 so far should be done Monday.
- How many amps drawn when car is off?
- low end power
- Lean Idle 18.4!!!!!
- Valve spring, retainer, seat pressure questions
- evo 8 tranny amount
- Stupid 02 dump
- oil leak
- throttle and boost pressure?
- need help with my Exedy hyper single
- Power steering delete????
- Crazy noises under de-acceleration (vid inside)
- Hobbs pressure swith installation
- Spark plugs and coolant suggestion for 9 MR
- Battery Is Shot. Are Mini Battery Kits Reliable & Recommended? What Brand Is The Best
- Gt3528r
- help. super frustrated. dont know what to do
- buschur race or perrin?
- Squeezing more PWR out of my HKS 272/280 setup!
- Ebay LICP installed Pictures?
- For those doughting the fp3065 Dyno here...
- My build 03 Ly Evo w/pics.
- circuit racing Fp V's Garrett
- Evo Engine / Turbo / Drivetrain - New organization?
- Taking out shortblock
- Evo IX Mivec Valve question
- Made The Plunge! Exedy Twin HD Clutch Kit!
- My FP Red Numbers.. yes another thread
- what different between koyo and mishimoto
- which clutch - fidanza or rps?
- ams mustache bar delete
- How to get stock boost!
- What's the difference? (RMR vs. RRE Stealth)
- Evo 8 engine tick / oil light, please help!!!
- Where did my EVO 8's coolant go? Bottle always near empty???
- FP Red Waiting List:
- Exoticspeed products
- Opinions please!!!
- wastgate conversion
- Big Turbo Guys how much timing are you running.
- Help Please!
- best bov/dp/test pipe/cat back for evo8
- Need new clutch
- clutch slipping
- shifting problem?
- High Octane fuel guys! How often do you change your O2 Sensor?Mine gave up aftr 15gal
- tranny fluid change
- Shifter bushing question
- Exedy Twin Pull vs. Push
- Evo 8 16g Bolt up to 1st Gen Eclipse?
- t3 t67 "big kahuna" by garrett?? pros/cons
- Best 3" downpipe for my 7
- What oil pressure is everyone reading?
- Thanks Buschur Racing!
- evo 7 oil cooler
- quarter master
- Checking "service engine soon" light.
- Tial Vs Garrett exhaust housings
- Oil on manifold...WTF? (Part 2)
- Info on turbo upgrade people running "4088R" Chim in plz ;)
- timing belt/water pump 8 and 9
- CBRD BBK Turbo... video... etc..
- Help Please
- '06 Evo MR & Quartermaster...
- AMS Resonated Test Pipe
- Need help with my tranny
- Lowest price on a FP-Red?
- Injen intake users
- Exedy Twin HD Specs? Under rated?
- Forced Performance Turbo Reliability
- fp green reliability
- Whiteline Rearbumpsteer kit and alignment
- Help Melted Spark Plugs
- Coolant leak evo 8
- triple disk + daily driver = FAIL!!!
- Please help ID this bov
- Turbo XS 3" Downpipe
- NGK Plug BR9ES vs BRP7ES
- Aftermarket Downpipe question with stock cat
- Very cheap exhaust setup
- Magnus ???? Pistons and rods ..
- 02 Housing and Downpipe mating questions?
- Buschur double pumper
- Best LICP & FMIC Setup
- Exedy Twin Clutch Disengagement
- Tranny woes
- What should I do next?
- e85 dayly driving?
- Boost problems
- EVo 8 Wastegate Actuator vs Evo 9 Wastegate Actuator
- Can anyone tell me why my clutch gets stuck halfway engaged?
- Help identify intake part
- Video Request: Idle with FP4Rs?
- Is this a real fp green?
- FP Red+?? Intake
- 1000cc, gt35r, e85
- Balance shaft Removal
- replacing synchros evo viii
- Just drilled and installed o2 foolers!
- high rpm problems
- HKS stopper type head gasket
- JUN Baffled Oil Pan & Oil Pan Baffle Plate
- Clutch for an auto x/ road race car/ street car
- 8 to 9 turbo swap. Did i do wrong?
- buschur injector question
- WILL THIS WORK FOR MY CAR? Evo 9 TME turbo on a evo 8......
- What is 1.8 bar converted to psi???
- AMS Downpipe rubbing on subframe?
- Probably going to install GSC S1 cams myself, limp to the dyno?
- Fuel Cut?
- JM FAB Drag Manifold
- need some help with mods
- Stock Limitations and GT35R
- question on cams
- power enterprise intake?
- Injen Intake w/ intercooler piping
- Pics of completed longblock
- GSC 264's
- MTX Neutral question
- Quick Q on mechanical O2 fix
- Whirling sound in low 1st gear/Reverse
- Anyone ever have issues with resurfaced flywheel?
- Haas this ever happened to anyone before?
- I cant keep my boost safe, any suggestions? (forge WGA installed)
- A/C compressor
- Question about stock IX MR clutch
- TILTON twin cerametallic users i need you info & experience here.
- DSM and EVO PTE injectors the same?
- Cam instalation question
- A safe psi of boost w/out a tune?
- Can you guys recommend me some mods
- More FP Red Numbers
- epm dump noise
- Clutch question
- Question on ATP stealth turbo kit
- FP Green to Red conversion
- Interested in 2.1 destroked from Slowboy
- helper over under spring removal!! (tilton clutch)
- Engine REV in between shifts ???
- TBody VIII & IX Question...
- HTA35R and E85?
- Pt 6262 63a/r or 82a/r?
- FMIC and Meth
- exhasut manifold nut..
- Clutch overkill?
- Something always has to go wrong..
- Oil cooler delete
- A/F jacked after altitude change
- Bad Clutch?
