View Full Version : Evo Engine / Turbo / Drivetrain
  1. advice needed for boost controller?
  2. Freeze Plug pop out!!!!! Its still runs fine after put back. What could this be?
  3. best clutch for 6-speed?
  4. P0303 code and car runs like poopoo
  5. 4G63 Internals
  6. evo gone wrong
  7. Car won't start in winter
  8. BR ported intake/65mm throttle body pictures
  9. help plz
  10. lookin to put out hp numbers
  11. Pulse Sparkplugs
  12. gizzmo boost controller
  13. quick BISS question??
  14. Need new clutch, debating PRICE v. NECESSITY
  15. Update and Thanks from Indy Evo
  16. Whining sound when driving
  17. Which Clutch?!?!
  18. OBX intercooler
  19. what setup do you recommend, n°1 or n°2
  20. help air is comming out of valve cover when i do boost leak test
  21. Advantage of WG Dump (Vent to Atmosphere)?
  22. Trickle Charger for Bushcur Mini-Battery?
  23. How to make an evo 8 block work in an evo 9 with a mivec head
  24. what should i do with a blown transfer case?
  25. Misfire with CDI COP system..
  26. JMFab o2 Dump
  27. advice if i should buy an intercooler now..
  28. exhaust leak from my hotside help!!!!
  29. Which of the three BOVs is best JDM VIII, IX, or X
  30. Coupler???
  31. IX Drivetrain w/ Tre Rear Diff vs. X's S-AWC
  32. Ported TB?
  33. IX Drivetrain w/ Tre Rear Diff vs. S-AWC
  34. Anyone ever blown a brand new turbo?
  35. Gasket Questions....
  36. how to replace prop seal
  37. Carbonetic twin questions??
  38. Some photos of my 2.3L build
  39. Will it take the punishment??
  40. Compression ratio opinion need your input
  41. evo 8 dipstick blowing out
  42. loud pop in 5th at 4.5k or 5k rpm
  43. Help! (MR 6th gear wont engage)
  44. Help with TO bearing popping out
  45. Question about 5 and 6 Speed Transmissions
  46. Timing belt skipped tooth fix...
  47. Question about HP capabilities / Power Goal
  48. Throttle hanging up between full throttle shifts
  49. Need Help!!!!! P0170!!
  50. 05 evo mr wont start
  51. Help w/ Cam Angle Senor Orientation
  52. Your opinion on this OBD-II / ABS / SRS airbag code scanner please..
  53. Headgasket? :(
  54. Valve Cover Oil Leak
  55. Do Evo IX have intercooler sprayers?
  56. Burning smell Help.
  57. 2.0 long rod
  58. Exhaust Smell
  59. aluminum rods
  60. Idle Concern
  61. 4 channel C.O.P. on a standalone ECU
  62. What Turbo Manifold/Kit does this look like?
  63. Larger hotside for Stock, Green, Red???
  64. Please help me diagnose my problems.
  65. Stroker or not?? Whats best on an evo 9
  66. ABS light on...
  67. anyone got IAT logs for perrin (or any non stock) intake
  68. Should I make my own Intermediate pipe?
  69. What is a safe boost # on stock 4g63?
  70. Motor Mount?
  71. Which camshafts?
  72. FP turbo setup for stock manifold and downpipe
  73. 1200CC injectors, Dual-Fuel pumps, 93-octane - Stock ECU
  74. Are these the correct NGK Spark Plugs for Evo 8 ?
  75. What causes High RPM lockout on ACT clutches?
  76. Spark Plugs for HTA35R!!!
  77. Help with wb02 !!!
  78. Recommended Oil Weights for Evo 8
  79. Exedy clutch bolts?
  80. Help with fuel door release
  81. Slowboy racing engine?
  82. all around turbo.
  83. Exedy bolt Help!
  84. WORKS Pistons
  85. Upgrading Evo 9 trans to Evo 8 4th and 5th gearing
  86. Issue with blown tubo * i need your help*
  87. Clutch
  88. Car Wont Start any suggestions
  89. Atp Gt35r
  90. Exedy Triple Cerametallic Questions
  91. Will a standard OBD-II scan tool pull ABS codes?
  92. cams installation
  93. Exedy twin disc clutch noise.
  94. peakboost mani.. which rad hose? need ASAP!!!
  95. ams compatibl with greddy
  96. Shepherd Transmission Options
  97. Upgrade path, hows it lookin?
  98. Please Help, Power steering little wire.
  99. 2006 EVO IX ACD/Transfer case fluids?
  100. 2.2L & 2.3L Strokers Passing Emissions
  101. Are Brian Crowers Really that good?
  102. Pump Gas Records...
  103. car hesitates/backfires under acceleration
  104. GT-A transmission oil change
  105. Redline Heavy ShockProof Gear Oil or Amsoil SEVERE GEAR SVG?
  106. Drivetrain question
  107. Who has heard of CXRacing FMIC's?
  108. Clocking the turbo WTF?
  109. Evo + Honda = boosty goodness
  110. Is 30psi on stock turbo 2 much???
  111. Straight Pipe Exhaust!
  112. Shifting problems..
  113. problem after clutch install HELP
  114. My Tranny Is Leaking
  115. Destroyed 1st to 2nd shift fork
  116. noise when turbo starts to spool
  117. Is it OK to use Amsoil SVG on EVO 8 TC and Diff?
  118. evo VIII intake fit on IX??
  119. No easy way to say this but I put a rod through my block
  120. idle problem with evo
  121. White smoke issued
  122. SES P0031 issue
  123. What should my spark plug gap be?
  124. 4.11 final drive
  125. When/why do I need a fuel pressure regulator?
  126. Carrillo pro-H beam rods
  127. Exedy MM022HD installed
  128. Exeddy mm022HBL clutch
  129. t-case post
  130. Upper I/C piping
  131. rear diff oil change= huge mess/picts :mad:
  132. Stroker with higher final drive, explain please
  133. Stock MR drain plug.
  134. Biggest Cams...?
  135. "Easiest" way to make 500whp...
  136. High Mileage Meth Cars
  137. clutch delay valve?
  138. FPRed on 91 Octane
  139. Fp Red
  140. Car Idles then dies
  141. What Is my best option in my Situation.
  142. how much hp with 9 turbo making with no meth
  143. Buschur Shifter Bushings VS AMS Underhood Shifter Bushings?
  144. Buschur Racing Mass Air pipe & Filter!?! The Good and the Bad?!?
  145. OBD-II scanner
  146. Longitudinal Engine/Gearbox
  147. Chromoly Flywheel
  148. Throttle Body Bypass-Mod
  149. AEM EMS and my starter
  150. Need advice on ignition
  151. SBC (South Bend Clutch) Anyone using one?
  152. valve train noise issue/or not?
  153. removed aircon, broke power steering-newbe plz help
  154. My car is shooting flames
  155. 1st Mod...What would you do?
  156. Is my valvetrain screwed?
  157. anybody heard of this turbo??
  158. Help!! No 1st & 2nd gear in my 5 month old Evo 9!
  159. tranny fluid change
  160. 50 trim dyno results question
  161. question about meth. inject
  162. How much boost can you run on FP RED
  163. O2 sensor - SOS
  164. Need an education: Swapping 05 ACD Tcase internals into 03-04 non acd Tcase
  165. Can a diff controller be rebuilt
  166. Help! Broken bolt!
  167. Hks T51r
  168. Good news for LBM evo 9 owners.
  169. Time Attack Engine
  170. Full Race manifold question
  171. Help! Timing belt came loose while driving!
  172. NEED HELP (Very Specific) !!!
  173. 2006 new eco ix oem tranny-do u still feel the notch?
  174. FP Green or FP Red?!?!
  175. 450 whp street monster!!
  176. Removing sand from inside of MIVEC valve cover???
  177. Modifying Intake to work with HKS 280
  178. acd transfer on non acd evo
  179. clutch install
  180. Exhaust Manifold ?'s
  181. fuel press question..
  182. Strange Problem
  183. whats the diff betwee rs lsd and aftermarket lsd
  184. I keep adding fuel and my car still runs lean. Ideas?
  185. Anyone know where to get Spring clamps locally?
  186. Radaitor Removal
  187. Boost Consistancy - Greddy Profec B-Spec II
  188. Engine not Starting, Help required!
  189. Competition Clutch Stg 2 for Evo IX MR opinions
  190. Full Blown's old EVO
  191. problem shifting 2-3, 4-5
  192. Help: Boost issues after clutch install
  193. Can head flow numbers be????
  194. Fp Hta Dsm88?
  195. Drop In's
  196. best exhaust system for the ix
  197. Cold Start W/ Cams
  198. How many cam seals do I need?
  199. electrical problem?
  200. FP Red w/ Stock Wastegate
  201. Intercooler kit for evo IX
  202. video request: kelfords
  203. ENGINE VIBRATES when clutch engages???
  204. EVO IX repair manual
  205. Jdm exhausts
  206. Best clutch for the AMS 850R turbo kit
  207. aftermarket crank pully worth it?
  208. My car seems to be stuck in warm up mode!!!!
  209. Oil leak or Busted CV Joint
  210. What would you do? 10.5 vs 50trim turbo
  211. Clutch Rattle. Need help!
  212. Comp Cams holding me back?
  213. Plugs on oil filter housing
  214. Evo 9 Turbo TME 20G Reviews!!!
  215. t case and or trans question
  216. Notchy 3rd gear on low rpm slow shifting but not on high power shifting
  217. Brief whine in first gear... what could it be?
  218. 2 fuel tanks; 1 for pump, 1 for race gas
  219. Oil Return lines
  220. Correct specs for the GSC S1 Evo 8 Cams?
  221. wb 02 installation tips?
  222. Transmission Fluids - 5-Speed - The BEST, and a Mix
  223. Hole in intake manifold?
  224. FPRed or BBK or Meth
  225. Building a motor: How would you go about this!?!
  226. Evo VIII Factory/Dealership replaced transfer case poll
  227. Evo IX Factory/Dealership replaced trasfer case poll
  228. Factory/Dealership replaced Transfer Case poll
  229. part throttle/high boost
  230. 03 Evo8 Driveshaft bearings bad, replace whole driveshaft?
  231. 2.1l strocker
  232. Boost Creep Help
  233. walbro fuel pump mods?
  234. Spark Plug Recommendation??
  235. Solution for the Trasfer Case issue...
  236. EVO 7 HRA 16G 9.8 turbo good for 400flywheel hp ?
  237. Stroke now, Stroke later
  238. 14MM Hex on mivec Intake cam (2)
  239. starter electrical problem
  240. hallman pro question
  241. Where's the best place to buy a new genesis battery?
  242. Wanting to take to the next step
  243. What Turbo Timer Do I Have?
  244. vacuum at idle
  245. coolant leak, need help ID source.. pics inside.
  246. To heat treat or not!!!!!!!!!
  247. strong vibration sound
  248. help!! routing of belt
  249. Evo9 Head Gasket
  250. Stroking to 2.3L, what mods are needed?
