- Best 02 housing?
- Need opinion on water temp or oil temp
- HTA 86R vs PT6262 turbo
- problem with acd/heat/everything
- EVO 9 Transfer Case? (Possible Problem)
- I need help bad
- UICP that fits the ARC intake?
- (clunk clunk
- Okay, whats my problem?? CLUTCH/BOV
- mooohoohahaha
- Noob question! Catch Can
- 2.3L+TS3076r
- removing transfer case HELP!
- getting fp red have some questions
- New turbo, have some questions
- perrin's new filter?
- Oil feed line question
- Warning - All Those Who Use An Aeromotive FP Regulator
- Turbo oil supply line help please
- ... crap, i need a new tranny and t-case... best prices around?
- O2 Sensor Driveability...
- How much to repair a bent valve?
- 2 questions....
- P0335 & P0340 How do i fix this??
- Radiator fan
- Odd Noise
- Are the evo 9 stock headstuds safe to 30 psi used with an fp red?
- Manifold Fitment
- Need a new clutch
- HTA 42R?? Or something?
- Cracked valve cover
- Who is using Kelford 272 on stock springs?
- GT30R with injection?
- rebuild my clutch master cylinder?
- Can someone tell me whats wrong with my car?!? ACD Issues
- EBC removal
- GReddy Competition Ti-C Exhaust
- Oil Pump???
- Timing Belt goes streaking
- t66 turbo
- Launching
- Tial bov flange question.
- Can't decide on my next power upgrade
- Anyone ever rebuilt a Mitsu turbo?
- Stock Rods w/arp hardware?
- Precision Injector Users Using E85 Beware
- Smoke coming off vent after O2 and Exh Mani installed
- Our 900HP Capable T3 Turbo Kit is Out!!!
- BBK from Green
- Precision Turbo 67mm Billet Madness!!!! PICS inside..
- 4G63 or 4G64
- Amsoil
- Oil catch can
- mishimoto intercooler
- HTA86 Twinscroll
- belts
- NGK gap question
- anyone used this turbo before?
- Intake mani cleaner
- Throttle Hang?
- hey guys quick question
- FP Green and 2.3L
- PPI Intake manifold
- top mount vs equal length vs cast manifolds
- Can the OEM coolant be mixed with Dexco Red coolant?
- What's next for the Evo? Help please?
- tranny ques
- Is my transmission currently on life support?
- T-case Failure?? Please help!!
- OK I'm finally fed up..
- Shaking/Vibration During Launch
- CamShafts
- o2 Fowler or Relay??
- For those with Megan O2 Housing
- Burning Oil Smell After Turning Car Off
- Boost Drifting Bad
- Need your help
- will these injectors work?
- PCV Valve
- Can boost be upped from the stock solenoid or do I need a boost controller
- Any tuners here that can figure this out?
- Need help to find out what is causing this noise
- best sparkplugs for e85?
- having problem similar to boost cut.. but my fuel goes rich?!?!
- Experiencing boost creep with Buschur MBC
- Dynojet
- Fuel level sender ohm question
- mivec
- The "Bite" has a new toy to play with 6765 AKA 950R!!!
- what gasket is this?
- Throttle Body Leaking
- Anyone else have the Greddy Full Ti Exhaust?
- help needed . which cams to choose
- Retune after Fuel Pump Install
- Skunk2 68mm Throttle Body?
- What is this/what do these go to?
- trying to find hotside specs on fp red
- Whistling noise when driving, with vid/sound clip
- Fuel tank issue
- Help me get the right Bov/ UICP (dilema)
- where can I get a axel seal?
- fp red vs Gt30
- evo engine with cam compression ?
- Exedy Stage 1 or No-name
- Clutch Advice for 450+hp
- HKS Header cracked
- Uego wideband gauge problem
- buschur 65mm throttle body /ported intake manifold
- 2.3L guys - highway milage
- Borg Warner turbo...
- pic request evo ix block
- Buschur Racing's HTA37R vs The new PTE FS635
- problems after coil on plug install
- no idea what to do
- Crankwalk clutch issues - Can't shift
- Anybody running the new "Skunk 68mm TB" yet?
- Stock WG Pressure??
- cosworth piston to valve clearance ?
- Any stock BOV's good to 30+ psi?
- Budget 2.3L Stroker Questions
- Light flywheel question
- Random grind, need advice.
- Need some Advide plz!
- Between the engine and the tranny...
- Inside a Weapon-R engine damper [video]
- could these four codes be related?
- warning signs
- Give me some help on a 4g63 motor swap into a 97 Mirage
- What hose is this?
- Kelford 272 or Cosworth M2
- Can't close this boost leak
- Aftermarket Oil Cooler
- Boost problem
- Muse Licp Versus Stock Licp-Pics
- Blowin coil packs..
- water injection
- hillclimb turbo
- jun stroker
- weapon-R intake manifold
- Cosworth head
- exhaust : w/silencer HP difference ??
- EPM o2 Dump installed on Casper's IX (vid)
- Powerband for the Kelford 272
- Nisei vs Muse
- Bogging down at full throttle?
- custom manifold coating
- boost cut
- Did my homework now I need some opinions - TURBO QUESTION
- honest opinion?
- water temp problem
- Buschur Racing double pumpers.
- GM3 vs MBC vs EBC
- what do u think is wrong?
- Slight clunk noise
- skunk2 valve springs
- intake heatshield?
- What brand exhaust is this??
- Spark Tech introduces Pro upgrade for Dynatek cdi's
- What sould i tell the mechanice
- Agency T3/T4 Turbo kit on an AMS DP
- Any ideas????
- Injen CAI/Full IC Piping Question
- Now what
- The Best Stock Turbo Manifold????
- Muse Motorsports ICP kit and mini batt
- stock intake vs ets intake
- Greddy Competition Ti-C Turboback Exhaust
- Idle and partial throttle hesitation
- AMS Header Blackness!!!
- motor carnage photos
- Im thinking of changing my setup
- ix wanting to stall on 1st gear and reverse
- Oil feed line from head?? Fitting for turbo kit
- I need help asap!!!!
- random cylinder misfire
- Oil gauge sending unit relocate
- ETS Radiator Pipe Constant Leak
- headstuds
- How to fix p0420 code
- question on acd
- how to tell if i have a walbro pump installed
- Forge RS Bov
- Buschur head vs AMS head
- anyone know?
- Comp 280 cams w/Meth kit
- To the pros: Which of these 3 Mods creates the most lag?
- New gasket or rethread the block?
- what the best option 3" or 2.75"
- 2 Slight problems. Input appreciated.
- Questions about coating the turbo, exhaust mani, etc...
- What could it be?
- no O2 sensor! Can i still clear my CEL?
- When will AMS new Intake Manifold be released?
- Experience with Works Stage 2 clutch?
- stock o2 housing specs
- What parts do I need to put back the OEM IX BOV?
- 5spd vs 6spd
- another front motor mount question.
- Engine knock @ 4500rpm
- 4G63 engine
- Need thread size for EGT probe.
- 4G64 Long Rod 2.2L Build
- TRE or Sheps?
- Tap In Two Lines To One Vacuum Hose?
- TRE Transmissions.
- evo8 radiator fan
- FP Red Install 56k Beware!
- Taking a while to turn over..
- Best aftermarket Turbo Set-up
- Who knows the durometer for most motor mounts?
- AMS GT950R aka Billet 67/65 is OUT! 830WHP Capable T3 Framed Turbo!!
- Clutches
- Blown front or center differential???
- My 2.3 Build!
- Titek O2 housing V2 and ebay housing
- GT TURBINE HOUSING FOR 35r
- how to check timing on Power FC!?
- Question for tranny rebuilders.. bearing solders
- Cobb Exhaust & Test Pipe.
- J-Pipe Nipple damage?
- P300 CEL on evo IX
- Where can I get a Fuel pump filter?
- HKS Adjustable Cams
- help with evo ix
- manifold plasma thermal coating ?
- 2.3l vs built 2.0l pros and cons?
- the most QUIET muffler...
- 4" exhaust on 35rs?
- Grinding Third Gear....still?
- evo moto clutch install
- Tomei procam (290 duration) recently released
- Kenne Bell boost-a-pump
- aps twin bov instructions
- Dyno numbers comming again from AMS...
- Skunk2 68 MM TB
- clutch question
- Anyone know where I can get a downpipe bolt at
- ACD Delete / Removal ?
- FP Red on stock internals
- Finally after months of wait Tomei 280's Evo IX
- hks camgear torque settings
- ATP mitsu to t3 adapter- anyone using them?
- FP Wastegate Problem!
- Turbo RPM! Good Tech Question
- How much power on a single Walbro 255??
- buying an evo ix
- Vacuum leak.
- Need help for cam choice
- Cam Damage! - PICS
- Compression Results, Good or Bad???
