- Should I change oil or wait a week?
- Are these stock VIII injectors?
- oil temp gauge went crazy
- oil cooler cleaning?
- Clunking noise help!!!
- ACT MB7-HDG6 (6 puck) questions pics inside
- 1200cc and one walboro on E75 and FP Red?
- Which cams for gt3037s
- impact fuel cut-off switch?
- fp red or fp green better for this setup?
- Oil cooler kit choices?
- Need some opinions on this clutch!!
- Wastgate Question
- Replacing nuts & bolts in the Engine Bay
- turbo/mani. and turbo/02 bolt sizes
- signs of bad fuel pump?
- Timing Belt noise
- Bolt-ON Turbo for 420HP
- Warmup Time
- Upgrade Path\Mod List for an FP Red on 93 Pump Gas and Meth Injection
- anyone running fpred with stock cams?
- PCV Valve?
- Oil Stick pulls out
- are these blocks the same??
- where can i get a evo 9 j-pipe???
- Oil pan heater?
- stock evo boost and fuel cut?
- how do u drive after a tranny rebuild?
- Manley Turbo Tuff's vs. Crower's
- fuel cut? misfiring?
- HTA37r vs PTE 72MM
- how much is to much shaft play
- Transfer Case housing material?
- Quieting my AMS exhaust
- Towing an Evo8 do' and dont's
- clutch question
- What AMP fuse for inline fuse of trunk mounted battery?
- HP estimate and What will stock 9 Block hold safely
- evo 8 t-case in evo 9 GSR?
- Engine Ticking
- Dumb question about front frame/radiator support.
- Test drove a 04 EVO today and notice the tranny kicking the gear into neutral.
- Double Muffler, or HFC, Which is smartest for CA?
- GT3037S HTA, Is it possible?
- Weird Clutch Problem???
- any big HP evo Ix's using HKS M series m40il heat range 8 plugs?
- 02 housing help!!!
- Aftermarket throttle body with IAC?
- **Buschur Racing Short Shifter**
- Which Head Gasket should I get? Cosworth for the 9 or 8
- Clutch problems still.... =[.. please help
- Any experiance with this clutch? ACT 6 puck?
- Car help!
- best ground in trunk.. help
- Clutch Replacement!
- shifter cables
- rebuilding evo9
- Whine and grind
- HELP PLZZ!!! evo in need of help
- Bad Bish (II) on the Cover of Japanese Bonzai Magazine !
- Finished my IX install
- how many variations of gt35 are there?
- Best Wideband....?
- Identify my Evo IX's exhaust
- how much boost can it handle
- Divided Downpipe (O2 Housing) Gasket
- Timing belt tensioner pulley bad?
- info changin my clutch and what tools are need
- Question about Exedy Triple disk.
- GT35r, 19-22psi, 340whp - Breakup, AEM EMS - Looking for ideas?
- Need help!!!!! 0 psi
- Wierd Drivetrain Sound
- maf translator question
- Stock Clutch Limit
- Installing Cam gear, front engine, and trans mounts, what order?
- Needed upgrades for a 400 WHP EVO?
- Porting
- evo x turbo on VIII???
- recommend me an intake pipe!
- Fuel injectors from mild to wild
- HP limits of stock coilpack/plug wires on Evo IX
- Check out this Head Gasket that I got in the mail, ugly !!!!!!!!!!!!!!!!
- Questions about install: FP Red, JMF o2 Dump, Ported/Coated Manifold
- What IX Spark Plug? 1 Step Colder?
- Radiator different Evo 8 and 9?
- Boost Clamps sizes??
- Amsoil Help
- HFS-5, Maximum methanol to fuel ratio?
- RE: Upgrade to IX today!!
- AEM UEGO Wideband Install
- Air Filter Shootout Test - Results!
- Just got P0171 code
- Magnecore 8.5mm wires not fit IX?
- Turbo IX question!
- RNR 35r ball bearing on stock block
- About to buy used greddy ti, need some help though
- gearing
- Driving untuned with fuelling mods and COP?
- need to find 5v/12v
- Header Wrap......any recommendations?
- 3" or 3.5"
- comp 280 question
- CEL thrown
- Boost Gauge suggestions
- Looking for the correct size.
- turbo IX upgrade tomorrow!
- Spark plug recommendation..
- Injen upper ic to bov
- AEM wideband giving weird readings..help
- AEM UEGO Vs Innovate Wideband
- is this still good?
- any carbonshaft users ?
- A few MIVEC tuning questions
- Lock the center diff
- People who run without an oil cooler, please chime in.
- Exedy HD or SD
- Stock engine, +400whp on pump, which turbo?
- thinking about an fp green,or cbrd full..
- Cryo treating questions for rotating assembly
- Possible MAF issue?
- A/C compressor probs
- hey please help boost problem i think!
- popping sound?
- Issue please assist
- I think my clutch might be starting to slip :(
- Need Help Guys Real Badly
- quick question
- sequential transmissions
- exedy twin not releasing
- evo 9 compressor housing
- Running 35r on stock maf
- Shell Helix Ultra
- evo 9 20g
- boost problem
- help p0234 wont go away
- So i think my two step was changed by previous owner
- Odyssey PC680 is a total POS (3rd one down)
- EVO 9/JDM MR BOV Inlet Size
- valve train noise
- Evo 8 Turbo with 20G Turbine
- Partial throttle hesitation.bucking/bad idle
- tomie 280 vs bf272
- Another HKS DLI issue!!!
- Check engine light faulty egr valve help me diagnose the problem.
- need help chosing parts. evo 9 only get one cam gear?
- Megan Manifold Anti-lag Port Bolts
- BR MBC Diagram?
- FP red setup help
- oil leaking from turbo pleaseeeee help!!!
- oil leak in turbo pleaseeee help!!!!!
- Intercooler Help
- Best cat placement in exhaust?
- question about tial bov
- Wideband position???
- what turbo should i get???
- Annoying RPM Drop
- ix mivec cam gear
- Wilson TB any opinions?
- ACD Removal
- How Much AWHP With These Mods I Got
- oil change to 15/50 and bearing failure
- Camshaft Install Question
- Car wants to stall in 1st gear and reverse. Need help!
- lean idle
- Opinions please on IC bottle
- another header
- It's a foking DSM afterall!
- power steering fluid
- my gas pedal sticks help
- AMS oil question
- e85 vs 110
- Question about intercooler size
- How does ur engine oil look after 2k miles?
- Oil Cooler hose question
- bbk, red, green test drive orlando area??
- fuel injector size
- Waste Gate Actuator Findings
- Only making 11psi. Possible solenoid problem?
- Coolant hose heat sheild question.
- Upgrading to IX turbo this weekend
- exedy twin disk studder
- HKS 2.3kit + GT3240
- Exedy Stg1... Who's got one, what do you think?
- idle problem
- BSP AutoX IX build
- Random Starting Problems
- should i tune ?
- IV Coils and Wires on an VIII?.....
- Boost Leak Test w/ Upgraded Wastegate
- Can a 8 wastegate actuator be used on a 9?
- CEL light trouble........
- intake question
- Rod and Piston weights
- Gizzmo Boost Controller Gain Settings???
- Tick from the Head/Injector Area
- intake question
- need help with timing setup on 2.4L evo setup
- Cherry Bomb Vortext Muffler
- Let's see your Oil Catch can installs
- Boost Leak Test - Help
- Possible Misfire?
- Planning a big build in chicago
- Walbro Install Help
- defog/defrost question
- Oil consumption ?
- exedy single plate
- lemmy's 4g63 build so far..
- fp red vs fp green on pump results
- Free Mods
- Twin Tial BOV's?
- Excedy triple disks?
- evo 8 tubular k member.. whos making one
- Evo III Water Pump Problem
- What does the E85 sticker look like at the pump?
- Intake Manifold Removal
- V band clamp Torquing?
- cometic head gasket size question?? PLEASE
- bogging
- Fuel pressure problem.
- gears
- Ebay Grounding kit
- brake pedal revs engine
- Car shaking and vibrating..wtf is wrong
- What turbo for my VIII ?
- Tubular Header ?
- Ported 9 turbo untuned... Is it safe???
- Engine viration?? Need advise
- wierd noise at idle (maybe cam gears)
- Radiators
- Do Evo's have issues with crank walk ?
- Pyrometer Install... Placement ?
- COP with stock ECU, DSM Ignitor and 300m Coils
- Air Filter
- engine problem
- New AMS TBE w HFC Setup
- When do you hit full boost? evo9
- o2 Housing Affect Exhaust Tone?
- 100oct vs 110oct vs e-85
- Reliable Horsepower Numbers
- cant decide which clutch to get
- Christmas came a little early
- Vacuum readings?
- front o2 sensor replacement
- Question of Curiosity
- APS Twin Vent Adjustments
- Help me mod my car for trackdays (road courses)
- Stock Evo IX turbo PERFECT shape
- Car won't accelerate
- Clutch pedal effort
