- Help needed fast thanks!!!
- HELP: Stock turbo clamp
- as soon as my car hits boost it cuts out and stutters HELP PLEASE
- Q T P external o2 dump housing
- Precision Turbo 6262 daily driver???
- Weird Pop/Choke.....Pls help
- Is it possible to tune evo 8 on 2 wheel drive dyno
- Is the Evo IX Stock Turbo Capable of 9's??? Look Inside..
- weird noise from cabin
- GrimmSpeed
- Need help please???
- Anyone Running, INJEN HARD PIPES
- opinions on best rods.
- stock turbo w/ External wastegate
- BR race core intercooler installations pics?
- At full boost, car stutters, then takes off...
- L Support Bar for the Buschurs Filter Kit?
- ACT HDSD impressions
- Should I be worried?
- oil leaking out of the valve cover!
- Happy Bday to Me, Happy Bday to Me!!
- Buschur Racing doing a start to finish EVO8 build, need input.
- Help! Advice needed!!
- Quick exhuast install questions
- evo9
- what spark plugs?
- EXEDY multiplate IMPORTANT QUESTION
- Fitment question
- rattling at idle and coasting in gear
- project evo 10 turbo in evo 1
- Fitment Question on Evo 8
- what coolant
- Battery in trunk
- Thinking about future upgrades, need help and advice
- FP3065 - Evolution 3
- Gift from the gods :P
- HELP!!! crank wont line up to TDC!!!
- Most-Wanted's Evo IX RS.. 468whp / 492tq.. STOCK TURBO!!!
- HTA35r 5 bolt .82 housing?
- kelford 272 vs FP4r
- 6 Speed Repair/Shop Manual
- Bc 280s Cams! Need Answer.
- should i get a new diverter valve?
- Engine Flush
- ACD PUMP Question
- Question about 2.3l twinscroll gt40r
- Problem with Buschur UICP w/1g bov clearing intake
- Looking for a quieter exhaust
- stock 8 motor whats the max power?
- FIC 1150 Injectors Install Questions
- noise coming from engine
- alright so clutch line weirdness
- Dealer screwed up my clutch?
- WTF happened...
- t case question
- What would ya'll do to the car??? (next mod)
- BOV/BPV Sound
- Help! Car getting stuck at 3k Rpms when stopped?
- ble lifters
- QuarterMaster Twin Disc 7.25" V-Drive Clutch / Flywheel (DSM)
- Shearer Fabrication Stock Turbo Manifold TESTED!!! +21hp
- Perrin drop in?
- FP RED updates: For those who have run it for a bit
- Ever have the (D) stub shaft stick to the axle?
- Wierd coolant temp issue...
- Restrictor pill location
- Motor Mount VS Torque Stiffy Damper
- MAF delete?
- Anyone have an evo 9 ecu I can borrow near Queens NY?
- Strange issue with cooling fan.
- Anyone else love it when this happens?
- Twin Turbo Evo?
- Weird rattling noise.... Any ideas?
- rpms drop at idle? need help
- Lower arm brace and engine vibration
- burning rubber smell coming from engine bay
- Fuel Rail and FPR help
- filter size
- TurboTrix Racing Fully Built Motor= 2.3 Stroker-Full-Race-FP HTA86-AMS VSR etc...
- My injector pulsewidth too high?
- GT3076R Problem?
- Where to go next!?!?
- AVC-R strange RPM readings
- tubular manifold measurements ?
- where to Buy IAC
- Help want to get a tune soon
- 6-Speed Sequential Shifter
- When do our trannys go boom!?
- ACT Clutch Q's
- whats stock?
- Evo8 3rd and 4th in Evo9
- Forge UNOS MBC
- Mystery Drip?
- Battery Problem, please help!
- o2 bolts???
- Major Idle prob..help!
- Pretty ETS Parts and some other nice stuff!
- O2 Housing suggest? FP Green
- Need help! Asap!
- MBC problem, help!
- best place to get FP red?
- porting ?
- Heatshield
- EVO 9 MR metal BOV or APS hibrid BOV?
- Difference between FP Evo Red n "CBRD full BBK" turbo.
- please help me find a silencer for a fujitsubo exhaust
- A/F ratio after Perrin Intake install
- Can you make an EVO RWD?
- Stock air box vs Vibrant cone air filter
- gt850r build
- Question on Megan TBE test pipe.
- EVO 9 plug wires
- 9k+ rev limit questions?
- Stutter at boost
- Cold Day Random Misfire
- Cam Gear adjustment
- Need help diagnosing a problem!!!
- fuel injectors
- Ticking sound during acceleration
- Help me choose what turbo would be best....
- Best Road Race Engine 2.3 or 2.4?
- o2 bung on midpipe ok to use for wideband?
- Twin BOV intercooler test fitting
- help with dead cylinder
- Flywheel specs?
- !!right clutch for the right setup!!
- which intercooler piping?
- Engine Swap
- BBK Full/E85 vs FP_GREEN/C16.. FACTS!
- Those with Greddy Intercoolers...
- Marks on injectors????
- Car is running slooowww
- Belt!!!!
- Looking for 2.75 Test Pipe
- need help just installed injen icp kit now care sputters
- Help From Vivid
- Better deal: Brand New flywheel or resurface the one i have?
- Project Hush (Quietest 3" Exhaust)
- whats need for a transfer case rebuild?
- Dejon Leak Stop Kit - Impressions?
- Exterior or Power !?!
- Air bypass Vacuum to Wastegate Acuator, Help! (pics)
- I think my Exedy Twin Disc needs a rebuild
- Need help ASAP, installing my intercooler right now
- Sand-like particles in Engine Oil?
- Spark plugs for evo 9 ?
- Starting issue
- return line on AMS FPR kit
- Need Help Guys Real Badly!!!
- start up
- what hard intake pipe?
- Walbro Fuel Pump Question
- Help me ID this turbo
- Cloudy Whiteish Smoke, Burning smell??
- Converting clutch: Pull to Push style ?'s
- Exhaust Idea/Question - Noob Content
- Engine Compression
- weird clutch, help!
- Be careful when cleaning the throttle body
- Where to buy exhaust gaskets?
- Advice for 300whp daily driver?
- Just a small write up on the ricer
- Evo 9 max HP with Stock Engine/Internals
- Average price for clutch install
- Pistons & Rods for 2.0 Setup?
- Question for daily driven HTA35r's
- wastegate?
- Need some turbo opinions please.
- Okada true COP setup???
- bov question.
- evo 4-8 compressor housing modifications ?
- Can this setup make 400whp!
- Help:Forge wastegate problem
- Engine vibration
- backwards recirc valve????
- cel
- What to do with coolant
- oil cooler elimination
- shep transfer case ,, which stage
- 9 turbo install???
- radiator issues
- Clutch question need help right quick
- SoundPerformance Quick Spool Valve???
- exedy torque settings
- swap to non-acd transfer case ?
- question on oil filter
- Analyze these pistons!
- Aftermarket cast manifold for stock turbo?
- Knocking - Pre Ignition issue
- Max Output on Stock Rods and Pistons
- Knock?
- New Alternator
- FIC Bluemax fuel injector?
- pleeez bare with me here...
- Compression test cold and warm egine: differences
- boost
- need help.... :(
- Is it normal or should I worry?
- Anybody currently runing the GREDDY t67 25g kit???
- Need Help locating where the 2 thrust bearings go.
- Broken!!! I think
- Injen bov popping out Fixed Finally!!!!!
- starter rebuild kit
- Fuel pump voltage
- Spec super twin
- Car will not idle/stay running
- White smoke only on start up?
- My evo 9 keeps juking from second to fifth? any suggestions on what to do?
- anyone bought turbos from nolimtmotors??
- Different Types of Manifolds
- Flapping sound
- boost gauge problems?
- *Question on how to preserve stock clutch*
- ETS Intercooler question
- newbie injector install question (pic included)
- car wont start
- Evo won't idle. Any suggestions?
- Kelford 272 on stock springs/retainers.
- tial bov on evos
- do you think there is a chance?
- Need timing belt tensioner tool, IL
- machine shop around rockford Il
- BF 272s
- Axles level 2 and level 5 from DSS
- Godspeed intercooler?
- Evo Idles down and dies>Need advice
- problem holding boost
- Gauging Interest: Evo VIII / IX Turbo Kit Around $1900
- Cam Gear recommendations
- Help!!! Coolant running low after motor build
- Clutch, Tranny issues mayb???
- Slave cylinder not bleeding
- Supertech or Cosworth?
- Just replaced my clutch!
- fuel pressure regulator question
- OEM clutch questions?
- Stock BOV fluttering at low boost?
- Ned help asap, Banjo bolts from block to turbo
- Pulling the Engine
- car isnt starting just cranking helppppp
- Idle relearn procedure
- Walbro Filter
- custom couplings?
- Defi BF EGT Issue...
- 5th Gear questions???
- Precision 6262 on a BR Cast Exhaust Manifold???
- COMP 280 or HKS 264
- Smart Opinions Please
- Diff choice help!!!
- Puck clutch break in, the real answer?
