- Wrapping Full Race Headers?
- welded wastegate flapper on stock turbo
- Stock Radiator!!!
- Lower Radiator Hose Pressing On Linkage???
- **help please**
- aem oil pressure gauge help
- Oil residues in the coolant reservoir tank
- il residues in the coolant reservoir tank
- need recomendations
- Problem (warning somewhat lengthy)
- a/c clutch clicking/ticking
- I wanted to show you guys something I've been working on.
- What o2 housing to choose???
- next step?!
- Help, will any 4g63 flywheel bolt work with Evo?
- Throttle Body Coolant Leak?
- GT35R boost creep
- 60k service
- BR double pumper or Full Blown for 700hp
- Turbo problem?
- Twin disc going out?
- OEM Replacement Plug Wires & Boots Won't Snap Down
- anyone removed the harmonic balancer
- Bov?
- Megan Racing vs. BR Magnaflow dB ??
- GSC S2 cams or Kelford 280 cams for FP red
- Quartermaster twin, please some info...
- Upgrading turbo
- Need Help....Hard to Start and Idle Issues....
- Built Block...What motor oil?
- Royal Purple 75W90
- At what stage is it best to buy injectors?
- How much for evo ix stock exhaust FULL
- Questions about oil pan
- apples to apples
- Think I need a Clutch...
- What HKS turbo is most like the GT35?
- i need the length of your...
- Cold engine full throttle?
- replacing cams need some suggestions
- Need Some Helppp!!
- To much pressure ? Loose connections ?
- IC sprayer problem
- anybody has idle problem?
- Boost leak causes knocks?
- how many people replace they clutch at there house?
- Greddy RZ BOV
- Anybody know whos Evo this is??
- p0138 code
- Where can i buy a "rally" style E-brake?
- M2's on Stock 8 Turbo
- car leaning out??
- Ignition setups
- oil return line being a pita
- Buschur RACE FMIC and AMS UICP?
- how to plumb boost control 101
- wear and tear?
- Tranny problem-- how screwed am I?
- Cracked/holes in tranny housing
- EvoPowerMods o2 dump vs QTP o2 dump
- 3 evo in Russia (help)
- Stock rubber intake BR air filter kit?
- Dual pumper questions
- 6 Gear Lockout
- Wastegate to atmosphere ?? need some help
- Are all 5 speeds the same?
- fuel system for 800hpevo
- Funny metallic click noise
- test pipe questions
- help with mods
- Ignition options?
- is my turbo f***D ??
- Attn engine builders
- Emission questions
- Precision 6162 on stock exhaust manifold
- Took my Evo in to dealer to get checked for whining noise
- self fit drop in's rods/pistons
- downshifting during clutch break in?
- antilock light
- Evo 9 rear o2 sensor
- Timing issues help please...look inside
- Exedy twin Specs
- hks 280 cams
- Evo9 Clutch pill
- From HTA35R to Full Race Borg Warner Setup
- About to buy an 02 housing...need help
- Can the stock clutch handle 400whp+?
- Clutch line help.
- Evo8 sounds like Subaru, Help!
- competition clutch?
- Quieting Down A Buschur Exhaust
- Rebuilding the Tranny....what's needed to be done?
- Boost issues (power not smooth)
- Cams or Evo 9 turbo for an Evo 8 with bolt ons
- Fidanza 4.3 ceramic clutch experiance?
- rod specs
- AVID motor mounts, anyone run them?
- Boost
- belt squeak?
- Apexi induction box owners....
- cracked transfer case HELP
- GReddy Competition Ti-C TBE?
- Kinugawa 20G
- NEW to the evo seen
- Not the normal missfiring problem.
- looking into final drive change
- MAF honeycomb starting to crumble? :unamused:
- BBK or DBB?
- OEM LICP coupler question!!
- need some input for 500whp+ results
- Having some tranny issues, chime in if you have an idea.
- Excedy Twin problem possibly, moves car at idle in nuetral!
- HELP! More Problems.
- any reds on 2.3 strokers?
- T3 Twin scroll turbo?
- Clutch Pedal Travel ? ? ?
- Cylinder wall thickness
- Headwork
- EVO 9 TURBO OR EVO 9- 20G for 20 PSI+380-400HP / crank ?
- Is there a 2.5" T3 GT 4 Bolt To 2.5" V-Band Adapter Turbo Downpipe
- Fic injectors?
- wastegate wont open??
- looking for a picture of evo8 timing belt
- witch intercooler is better, AMS or Buschur
- Reverse Sensor Location?
- Glowing Manifold
- Is it common for Cylinder #4 to run leaner???
- Tranny making noise in idle and cannot put the stick into gears!
- Really Bad News:(
- T-Case Death Whining?
- Kelford Cams are amazing
- Service Engine Soon (SES) Light - Codes Saved?
- who makes a uptop turbo kit (see pic)
- 4g63 head swaps?
- E85 questions
- Blown engine at 81k. Looking for Advice
- An EvoM shop??
- Advantages Hi-FLo Cat vs No cat
- Exhaust flange on turbo question (changing it out)
- Greddy PRofec B spec-II
- Evo 4 engine swap
- Tial wastegate question (AMS 50 trim kit)
- Car Died.....
- pwr radiator and 02 dump
- PLEASE HELP ME! After install serious boost spikes(AEM TRU BOOST)please read thanks
- 272 cam question
- How do u shift when ur daily driving ur evo?
- digital boost gauge sensor problem
- Replacement Exhaust Mani's
- MoTeC ACD controller
- what caused this to blow out???
- I knew I shouldnt do that 2nd to 3rd gear pull!!
- too much oil?
- exhaust manifold options
- Funny clutch thing
- What is that crap on my positive battery terminal?
- How do my plugs look
- wtb 10.5 hotside
- attn: ACT HDSS owners
- Synchronic Blow-Off Valve
- Evo 8 compressor modded vs evo 9 standard one, difference at power ?
- Fuel - Double pumper Vs Single inline
- Turbo XS FMIC & Buschur UICP
- Where to get stock fuel injector pintle cap?
- Ported Cast Exhaust Manifold
- Help with Lean Condition
- Throttle pedal feel.
- Gearbox Issues
- Intercooler decisions decisions
- Normal operating temperature on Evo 8's?
- PCV and Breather Blowby in oil catch cans
- ARP headstuds WTF??
- BEST Torque Damper / Front Motor Mount Set-up
- AN Fittings on Valve cover??
- Airbox lid question
- bolt type
- Tomei Solid Pivots???
- Upper IC pipe and BOV help???
- evo ix wheels
- HELP asap....
- HELP problem with my evo
- how is to run low 10s
- sheps
- How to blow 5k
- t-case filling?
- act hd vs xt
- ATI Superdamper
- Where can I send in my stock ix turbo for a discount on an FP Red?
- coolant issue
- Any suggestions? FP Red & mods
- hallman mbc vs. forge mbc
- TBE gaskets
- Evo VIII cat life
- Oil for built transmission,T/C and LSD rear diff.
- hks ssqv bov
- WTF is happening
- Car is lean now?
- WOT Tick!?
- external wastegate on stock turbo
- evo 7 compression
- How bad of a sign is this?
- another boost leak question
- Magnaflow Catback wit some brand downpipe
- ACL Bearings Question
- is there an evo(4-9) engine build video like this one anywhere?
- boost issue please help!
- Idle with Cams
- Ams 50 trim (Turbo whine?)
- Need rods....
- Back from Iraq. Need help with fluid change.
- Did the dealer just called me a NOOB!
- Low voltage after battery removal.
- I don't think my EVO likes the cold...
- Can anyone help me with Evo modification voiding warranty?
- Cam lope going away??
- ACT clutch or tranny causing lock out????
- down pipe
- Just to make sure... (AMS 50 trim coolant lines)
- Evo ignition problems
- My AMS aluminum pan showed up today! *PICS*
- Turbo Coupling
- whining noise when in gear?
- Im Depressed :(
- Buschurs Filter Kit
- Little advice for a manni
- stock turbo redhot
- LICP keeps falling off
- boost controller
- Evo 9 Block Evo 8 Head
- Help.. How can I mount the slim fan?
- FP Red Airflow Logs Wanted
- Help needed fast thanks!!!
- HELP: Stock turbo clamp
- as soon as my car hits boost it cuts out and stutters HELP PLEASE
- Q T P external o2 dump housing
- Precision Turbo 6262 daily driver???
- Weird Pop/Choke.....Pls help
- Is it possible to tune evo 8 on 2 wheel drive dyno
- Is the Evo IX Stock Turbo Capable of 9's??? Look Inside..
- weird noise from cabin
- GrimmSpeed
- Need help please???
- Anyone Running, INJEN HARD PIPES
- opinions on best rods.
- stock turbo w/ External wastegate
- BR race core intercooler installations pics?
- At full boost, car stutters, then takes off...
- L Support Bar for the Buschurs Filter Kit?
- ACT HDSD impressions
- Should I be worried?
