View Full Version : Evo Engine / Turbo / Drivetrain
  1. Perrin EBC Solenoid install
  2. Plugs for VIII with FP Red on E85?
  3. Where to get internal transmission parts?
  4. Car sounds like a subaru :'(
  5. Revolver Cams...Yea or Nea?
  6. downpipe wrap
  7. Tomei vrs evo-9-20g
  8. Break in period for new head..
  9. MISHIMOTO intercooler ??
  10. New car... first problem.. :(
  11. Headgasket?
  12. Turbo XS dual stage boost controller reasembly...
  13. Buschur Mivec stage 3 head
  14. 2009 is going to be good...Thanks to AMS!!
  15. Evo 9 MR BOV vs Tomei BOV
  16. Instaling new Circlip
  17. Alternativ fuel pump to walbro 255lph
  18. What turbo for street ?
  19. intake mnifold senser on top what is it???
  20. 850R or better
  21. Clutch question...
  22. OK, so my evo9 is all messed up...
  23. SES light with o2 fouler and o2 simulator in.
  24. Buy the kelfords already!
  25. Evo8/9 water pump compatibility?
  26. Question on intercooler flow?
  27. MAF Sensor
  28. transfer case warranty or TSB?
  29. Vaccum leak ?
  30. engine check light
  31. Injector 100%! Power Fc!
  32. HEAD GASKET 86mm
  33. Maxing out the 9 turbo on 91 & Meth
  34. How is the drivability and idle of the Kelford 272 on an Evo 8?
  35. grinds gear(s) after clutch install???
  36. Transfer case concern...
  37. No DV or BOV
  38. 5th Gear problem
  39. car wants to stall? need help
  40. anyone ever heard of water jacket failure on gt3076
  41. "help" car wants to die?
  42. Stage 4 6-Puck Competition Clutch: Any Reviews?
  43. Stock air fuel ratio's
  44. Anti-Lock Light?
  45. bye bye to my cosworth
  46. Turbo and TB coolant hose size
  47. Cosworth M2 VS Kelfords 272/272
  48. What would I need...
  49. ? for people who changed the cam side motor mount
  50. Small prbolem with EVO rod.
  51. Transmission Nochy till Warmed Up
  52. Result of stock retainers with upgraded valve springs. (Pics)
  53. Coil over plug ignition are they worth it?
  54. Death Wine----this time not the front!!
  55. Picture of titanium wheels vs inconel ?
  56. just did a compression test,questionable results?
  57. aftermarket 2.75 inch downpipe with o2 bung already installed?
  58. Help me ID this manifold & DP
  59. AEM Wideband Sensor... Where to buy?
  60. Best spark plugs for evo 8
  61. Billet Vs. Cast Compressor Wheel 60-1
  62. Cam Position Sensor & Crank Position Sensor Codes Simultaneously?....
  63. Spun Rod Bearing
  64. tranny help/
  65. what intercooler to get...
  66. Fuel gauge inaccurate?
  67. any way to identify these items?
  68. Positives and Negatives of a 4.11 Final Drive Ratio???
  69. Noise under the hood.
  70. Need some help!!
  71. doing a 2.0 build
  72. twinscroll/singlescroll TURBO SHOOTOUT -- full-race / VE engineering / vivids dyno
  73. Evo owners with SSAUTOCHROME FMIC please Chime in on this thread
  74. Walbro 255 Fuel Pump Install Help
  75. Help she wont start!
  76. Help Identifying cosworth cams
  77. Tial bov rattles on idle (rattle noise)
  78. Oil on turbo outlet. Seals about to sh!t?
  79. Has anybody here used the WOT box
  80. Chunk of metal on transmission drain plug???
  81. Inspection question
  82. Short Shifter Goodies?
  83. Changed Downpipe will it affect my tune?
  84. Can I use a starter from a 2003 evo
  85. battery dead?
  86. Cobb exhaust rattle.
  87. Oil Cooler Upgrade
  88. Exhaust rattle/scraping
  89. Who is a smart Evo 8 tech??
  90. T-Case Leak
  91. timing after build motor
  92. engine dyno...
  93. High octane Fuel?
  94. Damaged engine?
  95. Oil leak from return fitting, anyone?
  96. TIAL exaust housing vs T3 twin scroll
  97. WTF is this possible?
  98. HTA86 question
  99. My car stops Idiling
  100. Screamer pipe = More fuel???
  101. Average hp tq numbers for people in Salt Lake???
  102. XtdŽ stage 3 clutch ?
  103. BF 272 idle clip
  104. Leaking valve seals, question regarding.
  105. Help: misfiring under boost
  106. Cheap Oil Changes
  107. yet another help thread
  108. To Buy OR Not To Buy
  109. Help
  110. 9 turbo or e85
  111. Spark tec or HKS Twin Power DLi2 Ignition Amplifier
  112. electronic boost controller?
  113. Need Help Please
  114. Megan Manifold with Meth?
  115. Help Please
  116. Transfer Case probs I think. Help?
  117. hallman mbc?
  118. Heat not working properly
  119. Best Spark Plug
  120. oil catch can pic request...
  121. Dump Turbo?
  122. Evo DOHC-4G63T
  123. Need to know about a motor swap
  124. Swap spark plugs and car wont start anymore?
  125. Dump Turbo?
  126. HELP I drop a bolt!
  127. cosworth big valve head squish setting
  128. need ignition switch
  129. Weird problem after install
  130. does boost controller add power??
  131. PO830 code?
  132. mod question
  133. When Things don't go right
  134. Front motor mount bolt.. question on size
  135. Carbon build up on coilpack
  136. I know you see this title all the time. BUT I NEED HELP!
  137. Full Race Prostock Manifold Installed - Pics
  138. 0-30 or 10-30 AMS OIL??
  139. Just bought an AEM UEGO
  140. A Couple of Questions.....
  141. Got an exhaust question
  142. Aftermarket FMIC weight > Stock?
  143. Headlight intake
  144. Tomei Full Turbo Kit Install........
  145. problem with car idle
  146. Leakdown Test questions
  147. Visual diff. t6 vs t4 vs t3
  148. BOV/Turbo
  149. Poor response at WOT
  150. Damn boost issues...ugh...
  151. Fp Red Boost Creep PLEASE HELP!!!!!!
  152. Battery Maintenance
  153. Evo MR gauges
  154. FP RED Vs Greddy TD06-25G
  155. REQ! camshaft test?
  156. Do ya'll think my motor will last...?
  157. Best place to Buy Quartermaster Twin Rebuild kit???
  158. Manifold adaptor
  159. Video Of AMS CNC Head.. :)
  160. Which is the Intake Cam?
  161. evo 1 clutch pedal play
  162. Block guided for head?? how to take out
  163. Should I swap out my cams?
  164. So, what do I need to do to solve the HKS intake idle prob?
  165. Any one using the HTA86 aka FP HTA3586 w/.63 AR Hotside???
  166. What exhaust manifold to choose?
  167. Buschur 2.0 liter motor pics just arrived
  168. garret gt28rs?????
  169. power problem
  170. UICP, Aluminium or Stainless steel? With & w/o meth
  171. aftermarket cams with a stockish sounding idle for a evo 9?
  172. Motor Rebuild (Only Rings & Bearings)
  173. service engine
  174. Question regarding Greddy Ti-C Exhaust
  175. so I replaced my TB shaft seals...
  176. Fuel Rail and Fuel Pressure Regulator Question
  177. Acessory belt broke, please look
  178. transmission question ?
  179. Did I get the wrong ebay o2?
  180. what is this?
  181. 4g63 block
  182. idle problem??
  183. Ticking noise
  184. Tomei Arms Turbo installed!!!
  185. Okada or HKS
  186. Installation beehive of valve springs
  187. Just ordered Fp Red, quick question. Thanks.
  188. PROBLEMS!!!! Need help guys.
  189. How can I seal up the hole?
  190. Trouble getting into First Gear
  191. High Powered Cars Running the T3 .63 AR Hotside??? Please Post in here!!!
  192. Is it possible for me to get close to 400whp with the following
  193. anymore twin turbo developement?
  194. OEM Timing Belt Limits?
  195. Bearing for eagle rod. ( broken engine )
  196. New addition!!!
  197. Ebay O2 Housing help.
  198. not sure on which clutch to buy
  199. Turbo inputs
  200. Buschur Racing begins "Project White" a wicked street build.
  201. o2 Sensor?
  202. Gear Noise... Please help!
  203. Do-Luck ACD controller evo 7,8,9
  204. Problem with HiFlow Cat!?!?!
  205. Test Pipe Help...?
  206. Test Pipe..?
  207. Short shifter for evo?
  208. Turbo doesnt kick in (cant go more than 40 MPH)
  209. Favorite Exhust Set-Up
  210. AEM Map sensor & stock intake manifold question
  211. Seperating the T-case????
  212. what to do
  213. Installing Cams do I need new Timing Belt and Tensioner
  214. ->Perfect weather, perfect shifting<-
  215. FP Valve Springs
  216. Syncro tranny fluid
  217. AMSOIL MTG Transmission Oil
  218. Valve Springs for M2's
  219. Cam Gear Questions
  220. Removing Cam Question
  221. PTE6765 on stock ecu??
  222. AMS 2.3? or Cossie 2.2 ?
  223. stm oil cooler
  224. Is my clutch going out?
  225. No Cats -- stinks worse than other cars??
  226. need help asap
  227. Head gasket?
  228. Porting
  229. re-adjusted clutch pedal.
  230. Whistling noise when car is driving!
  231. Car will not start....pulled codes and need your input
  232. Filter size affect power?
  233. Question on bov sound?
  234. Turbo Question
  235. EGR blockoff plate for the head?
  236. Extremely disappointed with EPM o2 dump
  237. Fuel Management Idea
  238. SBR SS Manifold?
  239. 1996 evo 4 blow off valve replacement
  240. Painting Headers ?
  241. Driver side axel popped out
  242. open dump for stock turbo
  243. T-bolt clamp help
  244. BOV VTA or Recirculate
  245. Exedy Twin Users with High HP Please Chime in!!!
  246. MHI Turbo and Blouch Turbo Same Thing?
  247. Stock Tranny Longevity ?
  248. Evo ECU Reset after Clutch Upgrade..
  249. Just Changed Clutch & Now Check Engine Light On
  250. oil pressure
