View Full Version : Evo Engine / Turbo / Drivetrain
  1. evo engine with cam compression ?
  2. Exedy Stage 1 or No-name
  3. Clutch Advice for 450+hp
  4. HKS Header cracked
  5. Uego wideband gauge problem
  6. buschur 65mm throttle body /ported intake manifold
  7. 2.3L guys - highway milage
  8. Borg Warner turbo...
  9. pic request evo ix block
  10. Buschur Racing's HTA37R vs The new PTE FS635
  11. problems after coil on plug install
  12. no idea what to do
  13. Crankwalk clutch issues - Can't shift
  14. Anybody running the new "Skunk 68mm TB" yet?
  15. Stock WG Pressure??
  16. cosworth piston to valve clearance ?
  17. Any stock BOV's good to 30+ psi?
  18. Budget 2.3L Stroker Questions
  19. Light flywheel question
  20. Random grind, need advice.
  21. Need some Advide plz!
  22. Between the engine and the tranny...
  23. Inside a Weapon-R engine damper [video]
  24. could these four codes be related?
  25. warning signs
  26. Give me some help on a 4g63 motor swap into a 97 Mirage
  27. What hose is this?
  28. Kelford 272 or Cosworth M2
  29. Can't close this boost leak
  30. Aftermarket Oil Cooler
  31. Boost problem
  32. Muse Licp Versus Stock Licp-Pics
  33. Blowin coil packs..
  34. water injection
  35. hillclimb turbo
  36. jun stroker
  37. weapon-R intake manifold
  38. Cosworth head
  39. exhaust : w/silencer HP difference ??
  40. EPM o2 Dump installed on Casper's IX (vid)
  41. Powerband for the Kelford 272
  42. Nisei vs Muse
  43. Bogging down at full throttle?
  44. custom manifold coating
  45. boost cut
  46. Did my homework now I need some opinions - TURBO QUESTION
  47. honest opinion?
  48. water temp problem
  49. Buschur Racing double pumpers.
  50. GM3 vs MBC vs EBC
  51. what do u think is wrong?
  52. Slight clunk noise
  53. skunk2 valve springs
  54. intake heatshield?
  55. What brand exhaust is this??
  56. Spark Tech introduces Pro upgrade for Dynatek cdi's
  57. What sould i tell the mechanice
  58. Agency T3/T4 Turbo kit on an AMS DP
  59. Any ideas????
  60. Injen CAI/Full IC Piping Question
  61. Now what
  62. The Best Stock Turbo Manifold????
  63. Muse Motorsports ICP kit and mini batt
  64. stock intake vs ets intake
  65. Greddy Competition Ti-C Turboback Exhaust
  66. Idle and partial throttle hesitation
  67. AMS Header Blackness!!!
  68. motor carnage photos
  69. Im thinking of changing my setup
  70. ix wanting to stall on 1st gear and reverse
  71. Oil feed line from head?? Fitting for turbo kit
  72. I need help asap!!!!
  73. random cylinder misfire
  74. Oil gauge sending unit relocate
  75. ETS Radiator Pipe Constant Leak
  76. headstuds
  77. How to fix p0420 code
  78. question on acd
  79. how to tell if i have a walbro pump installed
  80. Forge RS Bov
  81. Buschur head vs AMS head
  82. anyone know?
  83. Comp 280 cams w/Meth kit
  84. To the pros: Which of these 3 Mods creates the most lag?
  85. New gasket or rethread the block?
  86. what the best option 3" or 2.75"
  87. 2 Slight problems. Input appreciated.
  88. Questions about coating the turbo, exhaust mani, etc...
  89. What could it be?
  90. no O2 sensor! Can i still clear my CEL?
  91. When will AMS new Intake Manifold be released?
  92. Experience with Works Stage 2 clutch?
  93. stock o2 housing specs
  94. What parts do I need to put back the OEM IX BOV?
  95. 5spd vs 6spd
  96. another front motor mount question.
  97. Engine knock @ 4500rpm
  98. 4G63 engine
  99. Need thread size for EGT probe.
  100. 4G64 Long Rod 2.2L Build
  101. TRE or Sheps?
  102. Tap In Two Lines To One Vacuum Hose?
  103. TRE Transmissions.
  104. evo8 radiator fan
  105. FP Red Install 56k Beware!
  106. Taking a while to turn over..
  107. Best aftermarket Turbo Set-up
  108. Who knows the durometer for most motor mounts?
  109. AMS GT950R aka Billet 67/65 is OUT! 830WHP Capable T3 Framed Turbo!!
  110. Clutches
  111. Blown front or center differential???
  112. My 2.3 Build!
  113. Titek O2 housing V2 and ebay housing
  114. GT TURBINE HOUSING FOR 35r
  115. how to check timing on Power FC!?
  116. Question for tranny rebuilders.. bearing solders
  117. Cobb Exhaust & Test Pipe.
  118. J-Pipe Nipple damage?
  119. P300 CEL on evo IX
  120. Where can I get a Fuel pump filter?
  121. HKS Adjustable Cams
  122. help with evo ix
  123. manifold plasma thermal coating ?
  124. 2.3l vs built 2.0l pros and cons?
  125. the most QUIET muffler...
  126. 4" exhaust on 35rs?
  127. Grinding Third Gear....still?
  128. evo moto clutch install
  129. Tomei procam (290 duration) recently released
  130. Kenne Bell boost-a-pump
  131. aps twin bov instructions
  132. Dyno numbers comming again from AMS...
  133. Skunk2 68 MM TB
  134. clutch question
  135. Anyone know where I can get a downpipe bolt at
  136. ACD Delete / Removal ?
  137. FP Red on stock internals
  138. Finally after months of wait Tomei 280's Evo IX
  139. hks camgear torque settings
  140. ATP mitsu to t3 adapter- anyone using them?
  141. FP Wastegate Problem!
  142. Turbo RPM! Good Tech Question
  143. How much power on a single Walbro 255??
  144. buying an evo ix
  145. Vacuum leak.
  146. Need help for cam choice
  147. Cam Damage! - PICS
  148. Compression Results, Good or Bad???
  149. Porting Differences in PWER?
  150. major exhaust question
  151. Stumbling evo
  152. My Dyno Numbers!
  153. 4:52 or 4:11 gears for 2.3L ????
  154. Another one bite's the dust 850R again.
  155. is this the right coolant?
  156. which clutch to get?
  157. Compression test low across the board
  158. terrible cutout in stock evo...
  159. Clutch/Tranny Problems
  160. drive train fluid
  161. Stock J-Pipe Coupler Size ?
  162. Can anyone awnser this for me?
  163. Exhaust swap
  164. does it work 2.4 lancer block for the EVO
  165. New Problem. trans issue. help
  166. Forge WG Actuator
  167. First time clutch job.
  168. start up not quick/smooth like it used to be
  169. LSD and AYC
  170. New stroker, can I start the car with my old tune?
  171. clutch gone again
  172. radiator hose touches manifold
  173. Anodizing is the best way to go in FMIC
  174. maf adaptor looks funny
  175. boost spike then fuel cut followed by oh s***
  176. Identify this filter
  177. supporting mods for fp green
  178. Modified Evo 9 turbo with a TD06SL2R and a MHI 20G???
  179. Evo 8 Turbo Questions
  180. Slight mis fire at idle and at WOT
  181. maf size
  182. Quick HKS SSQV Recirc question
  183. Fan not working..
  184. Any1 Used Lucas Oil products on their Evo?
  185. Clutch Position Sensor code thrown
  186. Comp Cams 280+ and stock valve springs
  187. Switching from pump gas to meth tune
  188. can't find a RNR manifold
  189. New Creader and P0300
  190. Just Opened My Engine . Need Some Input ( large Pics )
  191. Agency Power exhaust owners needed
  192. porting
  193. Boost Gauge. FPR or BOV
  194. what rods and pistons to go with??
  195. turbo compressor porting
  196. overboostin..help
  197. UR testpipe installed CEL! Need advice!
  198. Injectors Question????
  199. Boost Creep!!!! help
  200. slipping clutch and pedal adjustment
  201. Serpentine Accessory Belt, is it the same on Evo VIII and IX?
  202. Exhaust Question
  203. 2.3 .63 T3 Open Scroll to 1.06 Twin Scroll swap.
  204. Gates Racing Timing belts
  205. Shaft play on new FP Red???
  206. Q about my way to more power
  207. clutch question
  208. 4G64 Pistons
  209. 50 trim record hp and track times
  210. bad bov?
  211. Which Megan Downpipe?
  212. Crank angle sensor
  213. what to watch out for when buy an evo 8?
  214. Need help with 6th gear issue on IX MR
  215. which is better?
  216. help loud noise
  217. stock with build motor or trans?
  218. 95k Stud Install, HG too?
  219. where to get a tranny rebuild kit?
  220. cam spec sheet
  221. Wheel Bearings
  222. 2.3L and Green?
  223. notchy grabby clutch
  224. New starter new battery,,,Still click click
  225. which intercooler will fit??
  226. Going in for a retune soon, got couple questions
  227. Clutch noise while shifting
  228. fuel pump setup
  229. 02 housing??
  230. Car bogs when its not given enough time to warm up even in the warm temps
  231. A little help
  232. SUPER hard to shift when car is cold??
  233. I just replaced my broken Oil Feed Banjo Bolt and got this???
  234. QTP + Stock Exhaust Idle Problem
  235. EVO IX STOCK BOV fluttering
  236. How much boost can I run???
  237. UPDATE on my 9 Progress?
  238. what exhaust is this... ??
  239. what size thread chaser for the headbolts?
  240. cams question?
  241. Oreilly Auto Oem Axles
  242. Trasfer case question
  243. Help!!!
  244. Need Advise on Timing Belt Change
  245. Forced Performance WGA! Help Needed
  246. Mobil1 15W50... stock engine...discuss
  247. Perrin EBC Solenoid install
  248. Plugs for VIII with FP Red on E85?
  249. Where to get internal transmission parts?
  250. Car sounds like a subaru :'(
