View Full Version : Evo Engine / Turbo / Drivetrain
  1. Closer 5th Gear
  2. need diagram of stock map sensor pigtail
  3. Turboxs exhaust vs AMS exhaust
  4. what power can a greddy vspec front mount hold
  5. Cant get o2 sensor out of o2 housing
  6. FP Red looses punch after 120 mph.
  7. ALS on gt series or Fp turbo's
  8. Newbie questions.....
  9. and an idle problem
  10. Need some help..
  11. New FP red vs Old FP red?
  12. Anyone had the A/C condenser fan fail?
  13. WOW you will never believe it
  14. what ever happened to top mount turbo kit
  15. Carrillo vs Manley
  16. Fp black dyno #rs
  17. Boost Surging/Slipping?
  18. Cat Question
  19. What to do? max stoxk turbo or upgrade?
  20. anyone use these?
  21. My EvoIX SE w/ FP Black and stock block
  22. Gasoline Leak - Odd
  23. Suggestions for air/fuel "gauge" setups needed..
  24. Cosworth M2 IX lobe centerline?
  25. What size vacuum line?
  26. Polished up one of the turbo manifolds....
  27. evo9 head onto evo 4-8, what is needed?
  28. Ebay O2 housings
  29. coils keep burning??? need help??
  30. A lag monster is spawned! (cam timing)
  31. clutch question
  32. Kasey at MAP's 2.4 Hybrid Build
  33. fuel pressure gauge adapter
  34. Anyone running the new PTE ceramic bearing 6262?
  35. 35R Long Rod 2.0 Build
  36. Injector Resistor Evo VIII 2003
  37. exedy twin disc slipping!!!
  38. Help guys i just want to know if a t28 flange will fit on a t25?????????
  39. Question: HKS DLI (Ignition Amplifier)
  40. intercooler question.
  41. clearances...what's acceptable?
  42. My FP Black
  43. Braided Lines? What to Change?
  44. PT6262 in ... FP Red out
  45. Ebay HKS 272's , not really
  46. Installing new Motor Mounts?
  47. Coolant Smell
  48. ACD leak, checking for more obvious places for leak before dropping transfer case
  49. Unofficial Quatermaster Twin disk review
  50. MR Turbo
  51. Stock Evo 8 exhaust diameter
  52. MR trans fluid in my hihg mile EVO 8
  53. IX OEM bonnet heat shield removal
  54. coated housing/exh manifold worth it?
  55. Synapse Piping
  56. Bov ?
  57. Best Fluids?
  58. Evo IX revv hang?? Anyone??
  59. Oil leak under transmission
  60. Busher's 3” downpipe fitment
  61. Car acting weird under boost!
  62. HKS 280 cams, whats wrote on them, and rust issue
  63. Cars banging around?!?!?!?!
  64. cluctch ret. spring
  65. car whines alot but runs good ideas?
  66. lets play y wont my car start...again!
  67. please help !!
  68. HELP -water pump
  69. compression test
  70. water pump?
  71. 2 ?'s. Is an 044 overkill for stock lines? Who makes tank to rail lines?
  72. Tial Recirc BOV
  73. Why does Fidanza hate MR's?
  74. Code: P0240 Catalyst System Efficiency Below Threshold
  75. One wheel on air and the other 3 don't move
  76. 6 speed output shaft
  77. 12psi at full boost? maybe problem with UTEC?
  78. comparison
  79. jun oil baffle/ slicer
  80. CBRD halfwidth rad, design input..
  81. valid test?
  82. Will Exhaust Silencer Reduce Power?
  83. Help!!! Boosting 1.8 Bars!
  84. Those of you who do their own porting,...
  85. siliconeintakes "non" catalytic converter
  86. MR (6spd) transmission drain plug magnet?
  87. BR, 2.4, high hp/high rpm build?
  88. Help!! Leaking oil!!
  89. Help: Ignition Coil Cooked itself...
  90. oil line and banjo bolt solution
  91. Another FP Black Thread
  92. Can P0420 error code be caused by air/fuel ratio gauge?
  93. HOW TO check for shaft play on turbo
  94. 2nd Gear clunk?? (yes, i searched)
  95. Sparktech COP? Big Turbo? Are you happy you did?
  96. hks twin disc
  97. idle problem
  98. black smoke after WOT
  99. My Epic Ebay TBE Install Thread.
  100. Stock Valve Question. Please Help.
  101. t-case gearing question...
  102. new built motor! smokin a little wen cold ???
  103. Stock internals - rev limit
  104. What size oil feed line should be used for a 35r?
  105. OEM crank vs Eagle crank?
  106. ses flashing at wot
  107. Tcase question!! HELP!
  108. casting imperfections?
  109. Diff Clunk
  110. 4g64 block with 4g63 trans
  111. Speed Sensor Leak: Removal?
  112. getting CCI Clutch, Can I reuse stock TOB?
  113. Boost leak bucking caused diff noise?
  114. 6-speed shifter vibration question
  115. HKS SSQV not working
  116. Mynes 3076
  117. Urgent Pully help needed!!
  118. help plz
  119. easy way to remove stuck doughnut gasket on dp?
  120. Normal for used set of cams?
  121. intake/clutch
  122. Is it my tune or o2 sensor?NEED HELP!!
  123. Lets play a game, whats wrong with my engine?
  124. pte 1000 cc install issue º
  125. Installed ETS Intercooler, UICP - some questions about hoses
  126. Idle Oil Pressure
  127. Boost leak test performed today.
  128. oil pump questions
  129. What is your highest injector duty cycle stock turbo and injector?
  130. exedy lightweight flywheel
  131. Not getting into gear!!!!
  132. Exhaust 2,5 with 2,75 ralliart or all 3 inch.
  133. yet another timing belt/tension problem, please help
  134. cel for o2s when they work fine?
  135. Aftermarket clutches wear faster?
  136. Maf Adapter and Cone Filter questions
  137. new LICP and O2 dump do i need a tune?
  138. Evo 8 shortblock in a 9? What's it take???
  139. Lets talk: Radiator Surge tanks!
  140. FP Green vs. FP RED vs 35R (non hta)
  141. Stud for top intercooler bracket snapped
  142. Megan Racing testpipe question
  143. P0171 and P2195 codes thrown while car idled for a while
  144. Does this sound like a blown headgAsket
  145. Having a P0335 issue
  146. Ecu code p0603 (help)
  147. Having a P0335 issue
  148. EVO 8 Stock Internals
  149. clutch and flywheel
  150. Cooling Fans stay on??
  151. Block surfacing needed?
  152. More wideband issues
  153. Oil pressure drop-when to act??
  154. Fp Red vs Fp Black Direct Swap #'s
  155. Stock Motor FP Red Thread
  156. Some Clutch issues?
  157. new in town
  158. After lower intercooler pipe install, problem starts.
  159. lost all spark! help
  160. Grommet Question
  161. Pulling timing - possible leak, knock?
  162. Help - What size bolt/thread for tensioner release (for changing cams)
  163. Spool
  164. Help me identify this fitting size for fuel rail
  165. Transmission leak
  166. Not just another clutch thread.... hopefully
  167. Help! Mod test-pipe for Buschur Slip-fit??
  168. crankwalk
  169. Oem vs. Stainless steel Oil return line
  170. shifting issues
  171. Can't stop boost creep on 6262 w/ AMS turbo kit
  172. Help!! My car hates boost!!!
  173. Boost gauge needle vibrating/shaking
  174. Help choosing cams! HKS 272 to ???
  175. titek o2 users, need some help!
  176. Need a picture of the clutch fork installed in the bell housing
  177. Sbr-t67
  178. help, this is tricky...
  179. Engine Noise (Video)
  180. Throw Out Bearing Question
  181. FMIC or Meth kit?
  182. im wondering what is the max boost u run in fifth gear with the fp red
  183. Whats the best solution to clean the sock filter in walbro?
  184. Misfiring Help
  185. About how much does it cost?
  186. Cam question
  187. Custom water to air IC build??
  188. R/TErnie 3in. 02 Dump Video
  189. 10:1 4G64 MIVEC Build Suggestions
  190. Please Read Timing Belt Came through cover
  191. FP red vs HTA3582 pics
  192. Stutter at 18 psi??!??
  193. Sounds like STI, lots of smoke, no coolant, failed gasket/cracked head?
  194. Do they make a block guard for EVO9?
  195. crank angle sensor quick help plz
  196. Boost gauge only reading 15psi, Possible boost leak?
  197. My Tomei Arms 7960 Setup
  198. Bullet proof bottom end?
  199. FP Red+SS LICP+Buscher Deluxe=bad fitment
  200. ACT clutch adjustment???
  201. Need help!!!
  202. AWESOME information and results, take a read.
  203. Valve Springs
  204. aftermarket intake manifold?
  205. Tomei Poncam in stock now!
  206. Megan 02 housing or Ported Stocker?
  207. BR presents the new FP BLACK HTA82!
  208. help with removing front subframe
  209. toque help needed
  210. creader for p0300
  211. Money to spend...
  212. Teaser pics...my 4G64 build
  213. Which Turbo Kit is this?!
  214. New pistons for E85 engines
  215. Question regarding E85 for long term use
  216. Drivetrain noise...again
  217. Whats my turbo worth?
  218. GL-4 in '05 LSD Trans?
  219. Wideband readings.....
  220. Timing
  221. Ebay ss Clutch line
  222. Is this a normal evo o2 sensor set up?
  223. MIVEC: Kelford or S2 cams to idle like stock?
  224. whats better Shep or buschur?
  225. Need a new alternator I think
  226. where to start first on my build.
  227. HELP! Boost leak?!?
  228. Transfer case bolts - size and pitch?
  229. Headstuds question...
  230. Mivec Cam advancing at random at idle
  231. Help: Clutch Pedal Vibrating Violently
  232. Will I be ok with stock plugs?
  233. Competition Clutch Stage 3 Gears Sticking at low RPM s
  234. SD Kit or Recirc?
  235. Exedy Twin SD - noisy & difficult 1st/Rev selection from stop
  236. thick oil in overflow tank(HELP)
  237. Jumping Accelerator
  238. Exedy Twin Metallic HD vs Exedy Triple Metallic
  239. aftermarket turbo
  240. Air Cleaner Bracket removal... help please
  241. Can't get into gear while stopped
  242. Forge DV Bucking
  243. exedy twin plate clutch judder
  244. Smoke from Hood
  245. Used Exedy/Cusco Twin Disc: What is it worth?
  246. Maxxed out stock turbo vs. Red or HTA Geen turbo
  247. White smoke from my muffler....please QUICK HELP!!
  248. acd reservoir relocation help
  249. waste gate dump question
  250. mod list..what do you guys think
